Auto or Manual: Which Rekluse Clutch is Right For You?
Spider Tech
Different machines, types of riding, and skill levels may benefit from different clutch setups. So how do you decide which clutch is right for you? Here, we break down each of Rekluse's clutch offerings to help you make an informed decision.
While riding a motorcycle may seem elementary to an experienced individual, it’s not the act of riding that’s so impressive as how a motorcycle works. Very few people take to the time to think about all of the minute steps required for a bike to even start, let alone be ridden. Of course, there’s the piston pumping up and down, fuel igniting in the combustion chamber, and the crankshaft turning energy into rotary motion. One of the most overlooked components of an engine is the clutch system. In fact, it’s generally considered an afterthought; that is, until it stops functioning properly.
Never overlook the importance of a properly functioning clutch.
Motorcycle enthusiasts may view the engine’s clutch as a small piece of a large puzzle, unnecessary to worry about until new clutch plates are required. However, the clutch can actually be a huge performance advantage. Rekluse, an Idaho-based company that has been making their own line of clutch systems for 17 years, knows this all too well. Their first centrifugal automatic clutch (known as the Z-Start), put them on the map. Top off-road racers across various disciplines have raced, and won, with the Rekluse auto clutch. As an aftermarket company, reaching the pinnacle of the sport can’t be accomplished by offering an inferior product. Every component is tested to its maximum capabilities before ever being used in a race situation.
Today's Rekluse clutches are the result of 17 years of development, engineering, and testing. This is an ever-evolving process that fuels Rekluse's continued development.
Rekluse offers six different options across the auto and manual clutch categories for dirt bikes. Although known for their automatic clutch systems, Rekluse makes state-of-the-art manual clutch packages. Which one is right for you? Auto or manual? RadiusCX or EXP 3.0? Core Manual TorqDrive or Core Manual? Read on to find out.
Understand Your Options
Think about your preferences, expertise, and shortcomings as a rider. Are you a beginning motocross racer, focused on mastering throttle control and maintaining corner speed? Perhaps you’re an avid trail seeker, searching for unconquered terrain in the most hostile environments. Whatever the case, it’s important to understand that your bike’s clutch can either help or hinder your goals as a rider. Understand that you have options.
1303800570_COREMANUALTORQ-DRIVECLUTCHKX450F19.thumb.jpg.ef920196ce219348fa9a528f1e28775d.jpg CoreEXP_YZ85.jpg.9c9e4b505d869d58f6b9486d06ef69f1.jpg 398454557_TORQDIRVECLUTCHPACKRMS-2801009.thumb.jpg.67fe2ec4a884339a208354c9cb1586f2.jpg
Different riders will benefit from different clutch setups. Read on to understand which of the various options will be most beneficial for you.
Conventional clutch systems can be easily abused, leading to premature wear and eventual failure. Constantly pulling in and releasing a clutch lever causes fatigue. Automatic clutches can help solve those problems. Is there a drawback to using an auto clutch? Some may find the technology foreign, requiring practice in order to achieve comfort. Wrap your head around the idea of coming to a stop with the bike in gear and your hand off the clutch. Fortunately, Rekluse covers the spectrum of clutch configurations.
Rekluse Technology
Through extensive research and development, Rekluse created three technological advancements that are shared among various clutch systems in their line. These components are a telling sign of Rekluse’s commitment to achieving clutch mastery.
EXP
The Houdini of clutch tech, Rekluse’s EXP disk is responsible for engaging and disengaging the clutch based on centrifugal force. When the motorcycle reaches a certain rpm, the EXP wedges slide out to expand the disk and engage the clutch. All of this is happening from engine idle to about 3,000 rpm. The point at which the clutch engages can be fine-tuned with different wedges and springs for a customized feel.
478018180_RADIUSXCLUTCH(DDS)RMS-6313083(EXP).thumb.jpg.1f04dec842782168ead3a37708f8d685.jpg
The EXP disk is the key to auto clutch performance. This is the piece that automatically expands and contracts based on RPM to engage and disengage the clutch.
Austin Paden, Rekluse Product Manager/Race Development, elaborates, “There was a lot of thought that went into the ramp angles during the development process, and how the wedges would ramp out while rotating. Small changes to the wedges made a big difference in how the auto clutch performed. Our goal was to make something lightweight, easy to adjust, and functional.”
This graphics illustrates the simple, but innovative, process of the EXP disk and how it achieves auto clutch functionality.
EXP technology is utilized on the RadiusCX, RadiusX and Core EXP 3.0 automatic clutch systems.
Read more about how EXP works and find clutch systems with EXP here.
TorqDrive
Exactly what the name implies, TorqDrive is based on the principle that using more friction plates in a clutch pack creates increased torque capacity. Rekluse accomplished this by decreasing the thickness of their plates in order to use more plates in the same confines, while developing their own friction material for increased durability.
Check out how TorqDrive increases torque capacity.
Paden states, “The idea was to increase torque capacity to the system. Ultimately, the goal was to allow for more tuning options, lighter feel at the lever, and lessen clutch operating temperatures. The world of Supercross and motocross is based around a standard functioning manual clutch. The market in that segment is very competitive. We learned that other companies were using standard-based friction plates. Yet race teams were still having issues with breaking friction plates and experiencing clutch fade, which was caused by expansion. Our goal was to find a fiber compound that was durable, even when the operating temperature became extremely hot, yet be thin enough to fit more fiber plates into that same working area.”
"Our goal was to find a fiber compound that was durable, even when the operating temperature became extremely hot, yet be thin enough to fit more fiber plates into that same working area." - Austin Paden, Product Manager
The friction plates are made out of steel, which bucks the trend of using aluminum. When subjected to extreme heat, aluminum expands roughly twice as much as steel. Expansion leads to clutch fade. Rekluse essentially solved an age-old clutch malady through metallurgy.
Additionally, the steel-based friction plates have unusually shaped friction material totally unlike a traditional square or rectangle-shape. Paden explains, “We came up with our own fiber material and design, which is based around oil flow. That material is on a steel core, which maintains its integrity, even when the engine gets really hot. As a result, you don’t get clutch fade or constantly have to adjust the clutch cable in the middle of your moto. The Rekluse TorqDrive system contains 12 friction plates in most Japanese-manufactured bikes, versus seven or eight in a OEM/stock configuration.” Additionally, the TorqDrive pack comes with steel lining clutch basket sleeves to eliminate wear and notching to the clutch basket tangs. Rekluse left no stone unturned.
Rekluse developed a more durable clutch fiber compound while simultaneously improving the pad design for better cooling. The fiber material sits on a steel core, creating a complete package that drastically reduces clutch fade.
TorqDrive technology can be found in the RadiusCX and RadiusX auto clutches, as well as the Core Manual TorqDrive and TorqDrive Clutch Pack manual editions.
Read more about how TorqDrive works and find TorqDrive-equipped clutch systems here.
Core
Heat is the mortal enemy of an engine’s clutch. Rekluse confronted that problem head-on by developing their own hub, pressure plate and clutch cover. Made out of billet aluminum and designed around optimizing oil flow to lower clutch operating temperatures, Core is literally cool.
Paden states, “We made the parts lighter in order to create less rotating mass. In comparison to the competition, what’s noticeable about our hubs and pressure plates are that they have very open profiles. The bottom and top of the hub have features that basically act as a dam for the oil. Oil that makes its way into the center hub is directed through the clutch plates. More flow reduces heat. The pressure plate is also open, and any oil that comes from the front side of the clutch system makes its way to the center clutch.”
Rekluse Core billet inner hubs and pressure plates are designed to promote better oil flow and less rotating mass.
A close inspection of an OEM/stock hub will likely reveal oil holes and features that are located in the profile where the drive plates would ride. With this design, the holes are potentially blocked, preventing oil from reaching the clutch plates. Rekluse found a solution. Paden explains, “The Rekluse-designed hub has the oil holes and features on the ribs themselves. There are features in the drive plates, which act like pockets, so the oil is able to flow to the clutch plates without restriction.”
Taking it a step further, Rekluse created their own clutch cover that allows for roughly 50cc more oil capacity. More oil equals decreased operating temperature.
Rekluse_inner_hub.png.a4b43c3f277dfe6b636fe1628ca6dd52.png  10295980_RMS-396CLUTCHCOVER(FRONTLEFT).thumb.jpg.500d172629ed3ccb02bd02dc35d3a803.jpg
Rekluse billet hubs have oil flow features directly on the ribs, adding another measure to clutch plate oiling. Also, Rekluse billet clutch covers allow for additional oil capacity to keep things cooler.
Core technology is utilized in RadiusCX and Core EXP 3.0 auto clutches, as well as Core Manual TorqDrive and Core Manual clutches.
Read more about Core technology and find Core-equipped clutch systems here.
Automatic: What are your Options?
Rekluse offers three automatic clutch options – RadiusCXRadiusX, and Core EXP 3.0.
RadiusCX is the Taj Mahal of automatic clutch systems, featuring a plethora of Rekluse’s latest technologies. It contains the best features, as far as cooling and auto clutch performance. If you are a clutch abuser, the RadiusCX is for you. Like the other auto clutch options, the rider can use the clutch lever for manual operation. Given that it’s full of benefits, this is also the most expensive auto clutch in Rekluse’s line ($1,019).
The RadiusCX is the ultimate clutch package for riders desiring the auto clutch. It includes the Core billet components, TorqDrive technology, the EXP 3.0 disk, and the billet slave cylinder for DDS models (shown here).
Find RadiusCX for your ride here.
RadiusX is the little brother to the RadiusCX. Featuring EXP and TorqDrive technology, the system comes with the EXP disk and clutch pack, as well as the clutch basket sleeves. It does not come equipped with the Core billet components, and as such, is priced at $629.
The RadiusX features EXP and TorqDrive to deliver a great auto clutch experience, it just does not include the Core billet components to keep the price point lower.
Find RadiusX for your ride here.
Core EXP 3.0 ($919) utilizes the EXP centrifugal disk, meaning that you can come to a complete stop in gear with clutch out and not stall the bike. The package also includes the Core billet parts. OEM/stock clutch plates are required with the Core EXP 3.0.
The Core EXP 3.0 includes the EXP disk and all the Core billet components, but utilizes stock clutch plates.
Find Core EXP 3.0 for your ride here.
Manual: What Are Your Options?
Rekluse also offers three manual clutch options – Core Manual TorqDriveCore Manual, and TorqDrive Clutch Pack.
Core Manual TorqDrive ($949) was designed for serious racers, used at the Supercross level on down to the amateur ranks. It has the most adjustments as far as tunability, and outstanding durability. The kit comes with Core and TorqDrive technology.
Find Core Manual TorqDrive for your machine here.
394862038_COREMANUALTORQ-DRIVECLUTCHRMS-71001002(FEATURE).thumb.jpg.44ece656fb50f8cef775305c37e5c2b9.jpg
The Core Manual TorqDrive kit inludes Core billet components and TorqDrive technology. The power delivery improvement and added durability is nothing short of impressive.
Core Manual is essentially a billet replacement for the stock hub and pressure plate. Some riders may prefer the feel of riding with OEM/stock friction plates. If that statement explains you, then the Core Manual is your best option. It is priced at $519.
Find Core Manual for your machine here.
2139210423_COREMANUALCLUTCHRMS-7081(1).thumb.jpg.3d0cbaddda76a3c0df355f4333328cf1.jpg
If you want the durability and cooling characteristics of the Core billet components but prefer the feeling of stock clutch plates, the Core Manual is your clutch.
The TorqDrive Clutch Pack takes the clutch pack used in the Core Manual TorqDrive and puts it into a stock hub and pressure plate. It’s very affordable, and a good alternative for racers on a tight budget. At $349, it doesn’t break the bank.
Find TorqDrive Clutch Pack for your machine here.
The TorqDrive clutch pack gives you the advantages of increased torque capacity without the added cost of billet components. The most affordable way to get all the holeshots.
What the Professionals Run
Rekluse’s list of sponsored riders reads like a who’s who in all of the major forms of two-wheeled off-road motorcycle racing series. In fact, Rekluse relies on some of the world’s best athletes for product development and durability.
Given that Rekluse produces a variety of clutch applications, it makes sense that their fleet of sponsored riders have their particular favorites. The 2018 Monster Energy Supercross Champion, Jason Anderson, along with the rest of the Rockstar Husqvarna factory team, prefers the Core Manual system, which they pair with OEM/stock fiber plates. Dean Wilson opts for the TorqDrive clutch pack, as it easily drops into a stock clutch system. The Star Racing Yamaha team has been using the full Core Manual TorqDrive kit for roughly five years. In that span, the 250 program has won championships with Cooper Webb and Aaron Plessinger.
288219382_Annotation2020-02-28142711.jpg.5e1a7db01c3498b836f338403c543572.jpg FERRANDIS_2019_STAR-YAMAHA_OCTOPI__RJS8694.jpg.081196a12652f6950189695e06612695.jpg
Rekluse products go through multiple stages of testing and development, from in-house prototypes to detailed refinements with elite race teams.
Dubbed “Mr. Versatility” by Racer X Illustrated, Ryan Sipes has competed in a bevy of different off-road disciplines over the past few years. From ISDE to GNCC, Sprint Enduro and event Flat Track, Ryan’s clutch of choice is the RadiusCX. Another GNCC racer, Ricky Russell, has used the RadiusCX system for the past year and a half. It makes sense, given that GNCC races are gruelingly long at three hours, where hand fatigue and engine stalling can be major issues.
Paden explains that Endurocross riders tend to bounce back and forth between auto and manual clutch options. “Auto clutches were incredibly popular for several years in Endurocross, and then racers started gravitating to manual clutches. Right now, we’re in this state where guys are going back to the auto systems. It’s one of those scenarios where if one guy who is winning goes auto, the rest follow.” Given that a motorcycle clutch is a beneficial aftermarket modification, it is a change that is quickly picked up and copied by the competition.
Believe it or not, there are some riders who prefer to race Supercross with an automatic clutch. Paden explains, “I have done back-to-back testing with top privateers in Supercross, and most post faster lap times with an auto clutch. They couldn’t believe it. That’s because an auto clutch makes the bike's power feel smoother.” Smooth doesn’t feel fast to most riders, but the stopwatch doesn’t lie. Paden believes that more riders will start preferring automatic clutches in Supercross over time. It’s not a crazy theory, given that roll speed is an important part of clearing jumps and being successful in Supercross.
While an auto clutch may not 'feel' as fast to some Supercross riders, many of those that have tested it have posted faster lap times. Could we see a migration to auto clutches in Supercross?
If you’re still unsure of which Rekluse clutch to install in your motorcycle, give the clutch experts a call at 208-426-0659, or browse the Rekluse website at www.rekluse.com.
User Feedback
Recommended Comments
There are no comments to display.
  • Similar Content
    • By DevinBianc88
      Ok so I have no way to upload a video on here, I’m having an issue with my ktm exc 450 motor making a rattle noise. I tightened up the clutch basket nut since it was loose, but know I’m stumped. I domt know if this is normal or not. I just did the top end on it and it runs fine, I just don’t like this noise.
      UPDATE—- Crank nut and clutch basket nut for anyone who stumbles across a similar problem
    • By kdxyardsale
      This is the latest information, of course subject to change, for SX/MX 2020.
      Supercross resumes
      #11 - Salt Lake City, UT, May 31, 2020
      #12 - Salt Lake City, UT, Jun 03, 2020
      #13 - Salt Lake City, UT, Jun 07, 2020
      #14 - Salt Lake City, UT, Jun 10, 2020
      #15 - Salt Lake City, UT, Jun 14, 2020
      #16 - Salt Lake City, UT, Jun 17, 2020
      #17 - Salt Lake City, UT, Jun 21, 2020
      Motocross starts July 4 and ends Oct 3rd dates not officially
      announced but follows this order, only 11 rounds.
      Florida National WW Ranch Motocross Park Jacksonville, FL
      High Point National High Point Raceway Mt. Morris, PA
      Southwick National The Wick 338 Southwick, MA
      RedBud National RedBud MX Buchanan, MI
      Thunder Valley National Thunder Valley MX Park Lakewood, CO
      Spring Creek National Spring Creek MX Park Millville, MN
      Washougal National Washougal MX Park Washougal, WA
      Unadilla National Unadilla MX New Berlin, NY
      Budds Creek National Budds Creek Motocross Park    Mechanicsville, MD
      Ironman National Ironman Raceway Crawfordsville, IN
      Fox Raceway National Fox Raceway Pala, CA
      2020 Monster Energy Cup - Carson, CA, Oct 10, 2020
    • By Dj Robinson
      Just bought a 2000 KX 250 two-stroke for a great deal when looking for a project bike. When I put the bike in neutral which is a little hard to find, it jumps into first gear by itself and trys to takeoff no matter if I squeeze the clutch lever or not. When I first started the bike it basically did a burnout in my garage with no throttle applied   and the clutch lever pressed then it just stalls out eventually this happened for about five seconds. Attached are some pictures of my clutch disk and clutch basket from what I researched today the basket should not look this bad , but do you guys think? Is the clutch  the source of my problems or is it something internal and would I need to split the case.
    • By indy rider
      2020 MXGP CALENDAR GETS JUGGLED, COUNTRIES DROPPED & MORE CHANGES TO COME
      Everybody knew that there would be a new 2020 FIM World Motocross Championship schedule coming out—it is inevitable in the current climate and to be expected when trying to juggle different countries, their corona virus regulations and the complexities of international travel. Here is the latest Grand Prix schedule as of Tuesday, May 12, 2020.
      The calendar changes are as follows:
      (1) The MXGP of Russia, that was scheduled to take place on the July 5 will move to the August 2.
      (2) The MXGP of Latvia that was due to take place on the July 12 will now be happening on the August 9..
      (3) The Belgium GPs that was schedule to take place on one of two above dates will now move to October 25
      (4) The German GP, Czech Republic GP and Italian GP at Imola will be scheduled later.
      (5) The Italian GP at Maggiora, which was scheduled for the July 19 as well as the French GP have been canceled for 2020.
      (6) The Motocross des Nations remains on September 27 at Ernee , France, even though there are 11 Grands Prix races scheduled after its date.
      REVISED 2020 FIM MOTOCROSS WORLD CHAMPIONSHIP
      Mar. 1…Matterley, Great Britain (Held)
      Mar. 8…Valkenswaard, Holland (Held)
      July 19…Maggiora, Italy (canceled)
      Aug. 2…Russia, Orlyonok,
      Aug. 9…Kegums, Latvia
      Aug. 16…Uddevalla, Sweden
      Aug. 23…KymiRing, Finland
      Sept. 6.…Afyonkarahisar, Turkey
      Sept. 13…Shanghai, China
      Sept. 13…TBA
      Sept. 27…MXDN, Ernee, France
      Oct. 4…Trentino, Italy
      Oct. 11..Arroyomolinos, Spain
      Oct. 18…Agueda, Portgual
      Oct. 25…Lommel, Belgium
      Nov. 1…Jakarta, Indonesia
      Nov. 8…TBA, Indonesia
      Nov. 22…Neuquen, Argentina
      Nov. 29…TBA
      TBA…Loket, Czech Republic
      TBA…Teutschenthal, Germany
      TBA…Imola, Italy
    • By mxaniac
      A little Pro MX to watch.
