Bearing press for $3.50
nscmj3
No way I'm gonna pay $89.99 for a stupid piece of all thread and washers to press bearings into the swingarm. Here's a cheaper way that worked just as good:
Buy a 12" piece of 3/8" all thread, some 1 1/2 washers, 2 nuts, and the appropriate size socket (19mm for a honda xr400.)
I put a mark on the socket for the appropriate depth to press the bearing. (5.5mm in this case.) Make sure the socket is lined up, and start cranking on each nut! Here you can see the bearing next to the socket going in:
That's all there is to it! i pressed all 4 swingarm bearings in about 45 minutes. No freezing, heating, or even greasing/lubing! And the best part is...I can spend my $90 on something else!!
User Feedback
Recommended Comments
There are no comments to display.
  • Similar Content
    • By racerbri
      This is a simple bolt up shock made for a DRZ-125.  Great shape.  $400 plus shipping.
      Still Available:  BBR anodized upper triple clamp and stock parts
      Need stock parts? I parted a whole bike and have most things except the motor, frame and plastics. I have:
      Stock wheels front and rear (19"/16")
      Complete front end - forks, triples, brake mastercyclinder, brake line, caliper, wheel and rotor.
      Stock gas tank (black)
      Spare brake shoes
      Tell me what you need and we can work on a price.
    • By NeilT
      I'm new to your community and I have a question that I'm sure has been asked and answered many times before but navigating this site can be a bit confusing at times. My question is this; is there enough adjustment in the suspension of my 2017 XR650L for my 200 lbs. for southern CA off road and street riding? I would say I'm an aggressive, intermediate rider. If so what adjustments should I make? If not what mods should I do and what size fork and rear springs should I be looking at? Any local companies here in LA? Thanks
    • By Ktm520sxrider
      The oem bushings were tight and hard to take off. I took them off to replace them with new pivot works bushings so I carefully expanded the bushing and got it on easy without stretching it at all and now the bushing is not even as tight. Do these need to be tight on there? I put it on the only way it could go and it seems like the gap in the bushing got bigger.
