Can't get those steering stem bearing races out? Here's how!
yz440e
I recently did my first set of steering stem bearings this last weekend. IT WAS HARD, especially to get the races out.
Here is a mock up of a cut away steering stem if you were looking at it fron the front of the bike:
I researched every old thread on TT and most said to do the brass punch way:
(you hammer at the punch on the lip of the race, all of the way around, til it gives way)
But after about 3-4hrs of trying this I was sick of the punch slipping off the race, I tried cutting the race off with a dremil but that just caused frustration and it was highly likely that i would score the inside of the head tube. The other way i found on here that would most likely work, but i did not get the oppertunity to try was running a ARC, MIG or TIG bead along the face of the old race and it will supposedly drop out when the weld cools because of the contraction when the weld cools down.
NONE OF THESE WORKED FOR ME! So i set out to develop my own method which i have not seen on TT yet:
You will need:
>Steel pipe (1-1.5ft in length) (needs to fit inside of your head tube with about an 1/8" play on either side, does not need to be exact at all)
>Metal punch, chisel or tapered piece of metal (i prefer a chisel)
>Hammer
>Penetrating fluid (optional, helps though)
THIS WILL ONLY WORK IF YOU HAVE AT LEAST A SMALL LIP!! DONT TRY UNLESS YOU CAN FEEL AT LEASET A TINY BIT OF A LIP!! 90% of bikes do have a lip.
Spray Penetrating Fluid around the part of the race that contacts the stem. Insert the pipe so that about the same amount is sticking out on either side of the end of the head tube. Move pipe over to one side of head tube. Jam chisel or tapered metal next to pipe and hammer in so it is VERY snug. Hammer oposite side of pipe and it should drive right out!! :applause: Heres a pic to demonstrate:
This took me less than 5 minutes to do both, just repeat the other way for the top race, a very easy process.
User Feedback
Recommended Comments
There are no comments to display.
  • Similar Content
    • By Bryan Bosch
      FLO MOTORSPORTS 3.0 Foot PEGS
      Rounded Edges Loctite on Cleats Extra Wide platform. KTM Footpeg Size is 57mm Wide and 86mm long. Stainless steel Flat teeth Removable Teeth (Cleats) with 5mm Hex Self Cleaning Mud Grooves. Foot pegs are possibly the most over looked parts on a bike but one of the most important parts. No matter how much power your bike makes, it means nothing if there is no control of the bike . You probably haven't given much consideration to you're footpegs before, but pretty much all professional AMA  supercross , motorcross  and off-road riders ride go with aftermarket footpegs for a wider platform, more grip and overall control of the bike .
      Our Pro series Flo Motorsports Foot pegs will offer all of the above . The foot pegs you are about to purchase are the same pegs used by Factory Supercross teams like Traders Racing (Yamaha) , BPR Home Depot ( Yamaha)  and JMC Husquvarna.   Our pegs are constructed from highly durable 7075 T6 alloy making them much more durable then some standard cheap 6061 T6 that many competitors use on the market.
    • By ThumperTalk
      Each footpeg is cast from 17-4 stainless steel, given a solution-annealing treatment, and age-hardened for superior strength
      Width (57mm) and length (90mm); slightly convex platform for better boot positioning and grip when leaning forward or back
      Dual-plane teeth provide traction without the stuck feeling
      Available with 1/2 rear offset to allow more space
      Use your OEM springs, unless otherwise noted in application chart
      Made in the U.S.A.
    • By ThumperTalk
      Built-in ergonomics; adjustable grip, height and setup
      Electromagnetic-polished patented system
      Allow both standard and lowboy setup with reversible collar insert with each peg; collars may also be purchased separately to take footpegs from one make to another for an exact fit
      Superwide (58mm) for comfort and traction control
      8mm Fast Kamber Mounting System (FKMS) allows camber angle adjustment for more control to keep a rider on the bike
      Available in three versions: F3, F5 and F6
      F3 footpegs feature SS setscrew teeth; easily adjustable and replaceable
      F5 footpegs feature SS press-pin teeth that are semi-replaceable (can be replaced up to three times); no adjustment necessary; just bolt up and ride
      F6 footpegs have the same great features as the F3 and F5 but have an improved cleat design to provide sure grip footing in any terrain
      Each system comes with reversible collars, springs, an 8mm FKMS system and teeth (F3 footpegs come with two different height setscrews, and F5 footpegs come with press-pin teeth installed)
    • By ThumperTalk
    • By ThumperTalk
      Extra Wide 57mm pegs soften monster landings
      Super light and strong
      Triple cleated design with cross brace
