Complete Guide To Installing FCR MX on a XR600
jtf1307tie
Now for the fancy part. Our engineering group just bought a 3D printer so I made my own custom perfect fit adapter. It is solid plastic. I can't say for sure how well it is going to hold up but initial test are promising. Gasoline/ carb cleaner seem to have no affect on the plastic. It is winter here so I haven't got any real world field testing done. There are several differenet types of plastics that can be printed so I might want to try a few different prototypes. Anyone who wants the file, pm me and I will send it to you. If you know someone who has a 3D printer have them make you the part. We have the "Makerbot 2" it took 6-1/2 hours of printing time to make it solid.
p1466480046-4.jpg p1466480676-2.jpg p1466481088-4.jpg p1466481220-4.jpg p1466481802-4.jpg p1466481908-4.jpg p1466482170-4.jpg p1466468912-4.jpg p1466468964-4.jpg p1466469402-5.jpg p1466475800-5.jpg
You will need to file off the lip of the carb in order to install the printed adapter. I used RTV sealant to glue it on. It's a snug fit, even without the RTV it's hard to get off the carb.
I used DOT-COM's Jetting suggestions and it runs great. Thanks for all your hard work buddy!
158 main
45 pilot
NCVT needle 3rd clip from the top
leak jet is still stock - I think it is something like #65
Here is the total parts list and pricing.
2007 CRF250 FCR MX --- $130 Shipped - Ebay
2007 CRF250 Tusk throttle cables $14 -- Rockymountainatv FYI --- 4" longer than stock XR650L cables but will fit the XR650L housing. The longer cables fit much better. No binding or Stretching when turning.
Hot Start Button OEM parts 2007 RMZ450----Rockymountainatv 13410-35G10 STARTER VALVE | MODEL K5 $18.88
XR650L intake boot -- $23 shipped --- Ebay
Jets Prox brand from -- Rockymountainatv -- $15
NCVT Needle OEM parts 2004 YZ450F --- Rockymountainatv TA-14916-VT-00 NEEDLE (#NCVT) | $9.37
Custom printed part Freebie!!!!
Total Cost $210 give or take a little
If you have any question let me know. I will do my best to answer them. Enjoy the new found power.
*UPDATE* 5-1-14
A few members who have done this upgrade have reported that the gas tank was interfering with the top of the carburetor. Due to possible variations when buying a used carburetor or if you are using the stock tank or an aftermarket tank, this may be the case. It is very easy to remold or push in the area on the tank that is the problem. Firstly remove the tank from the bike and drain all the gas, leave the cap off and let it air out for a few days. Mark the area that needs clearance. This next step is very important, only use a heat gun to heat the plastic tank, this is the only safe way to gradually bring the plastic up to temp until it is soft enough to deform with some applied force (palm of your hand). Do this slowly moving the heat gun in small circles to gradually bring the area up to temp. I used a heavy pair of leather work gloves to push on the area I needed to deform. Once you get it to deform hold it there for a few minutes until it cools and sets. Put your tank back on and check the clearance repeat as needed.
If you need more clearance and don't want to deform the tank additionally, you can cut a piece of 1/2" thick rubber and glue it to the rear rubber tank / frame bumper. This will raise the rear of the tank just enough to get the clearance you need.
I am also still making the adapters for members who request them. If you want send me a PM and I will get back to you asap.
  • Like 2
User Feedback
Recommended Comments
Hey jtf,
Are you still around, can I get hold of your printer program Please? I`m undergoing this conversion for my own XR.
Cheers,
Dirt/rider/Alan.
Share this comment
  • Similar Content
    • By Yahya Omarjee
      So I need to change (or just top up for now)  my transmission oil and there's no motorcycle shops near me.
      I've read a lot of threads about ATF the F, but it looks like none of the spares shop stock it. Can I use AFT DX ii instead of type F until I find type F
      The owners manual recommends 4 stroke 10W-30 , if I can't use the ATF DX II, can I use normal car 10W-30.
      Please help, want to ride tomorrow
    • By BTbrigade
      Hi y'all,
      Just picked up a '96 XR600R and I'm excited to read some literature. I've done a lot of searching in this forum, and I've seen multiple posts claiming the manuals are posted in the FAQ. I haven't had any luck finding the FAQ section (which is typically pinned, right?). Can anyone point me in the right direction?
    • By Bryan Bosch
      2019 American Motorcyclist Association-sanctioned Grand National Cross Country Series season gets underway Feb. 23
      Electric mountain bike classes added, youth racing program expands
      PICKERINGTON, OH – February 20, 2019 – (Motor Sports Newswire) –  The 2019 season of the AMSOIL Grand National Cross Country Series, an AMA National Championship, kicks off Feb. 23-24 with the Big Buck GNCC in Union, S.C.
      For 2019, the series’ added classes for electric-assisted mountain bikes, which will have a stand-alone event at Loretta Lynn’s Ranch in Hurricane Mills, Tenn., on July 27, and will be at eight of the series’ 12 other rounds.
      The GNCC also reduced the number of adult competition classes and increased the number of rounds in its Micro (50cc) program for racers ages 4 to 8.
      GNCC series promoter Racer Productions will donate 40 tickets for each of the series’ 13 events to the Veterans Ticket Foundation, which will make them available to active duty and retired service men and women and their families at no cost.
      Series events will be broadcast live on RacerTV.com and rebroadcast on NBC Sports. Live coverage of the Big Buck GNCC begins at 1 p.m. ET Feb. 23.
      For information about the GNCC series, including its rules and class structure, visit gnccracing.com.
      2019 AMA GNCC Series Schedule
      Feb. 23-24: Big Buck Farm, Union, S.C.
      March 9-10: Hogwaller, Palatka, Fla.
      March 16-17: Aonia Pass MX, Washington, Ga.
      March 30-31: Steele Creek Campground, Morgantown, N.C.
      April 13-14: Moree’s Sportsman’s Preserve, Society Hill, S.C.
      May 4-5: X Factor Whitetails, Peru, Ind.
      May 18-19: Sunday Creek Raceway, Millfield, Ohio
      June 1-2: Seneca Highland, Alpine, N.Y.
      June 22-23: Snowshoe Mountain Resort, Snowshoe, W. Va.
      July 27: Loretta Lynn’s Ranch, Hurricane Mills, Tenn. (eMTB only)
      Sept. 14-15: Johnson Family Farm, Harpursville, N.Y.
      Sept. 28-29: Matthews Farm, Mount Morris, Pa.
      Oct. 12-13: TBA
      Oct. 26-27: Ironman Raceway, Crawfordsville, Ind.
      About the American Motorcyclist Association
      Founded in 1924, the AMA is a not-for-profit member-based association whose mission is to promote the motorcycle lifestyle and protect the future of motorcycling. As the world’s largest motorcycling rights and event sanctioning organization, the AMA advocates for riders’ interests at all levels of government and sanctions thousands of competition and recreational events every year. The AMA also provides money-saving discounts on products and services for its members. Through the AMA Motorcycle Hall of Fame in Pickerington, Ohio, the AMA honors the heroes and heritage of motorcycling. For more information, visit www.americanmotorcyclist.com.
      Not a member? Join the AMA today.
      Source: American Motorcyclist Association
