Complete Guide to Installing Motorcycle Piston Rings
Billy@JEPistons
With years of performance piston experience, JE knows ring operation is just as important as piston quality. Follow along with our complete guide to installing rings on your motorcycle piston(s).
The correct installation of the piston rings is an essential aspect of rebuilding any four-stroke engine. This task is perceived by many to be simple. However, there are vital aspects of ring installation that should not be overlooked. Improper installation of the piston rings can result in limited engine life, reduced power, and high oil consumption. In this article, we’ll walk step-by-step through the ring installation process so that the next time you’re rebuilding your engine, you know exactly what to do and what to watch out for.
JE now has pistons available for many late model applications. Find the performance you've been looking for.
For starters, never attempt ring installation without the appropriate documentation available for reference. At JE Pistons, comprehensive instructions are included with most new piston kits. This ensures the engine builder has the necessary information available to do the job successfully. The machine’s factory service manual should also be on hand throughout the build so that things like torque specs, service limits, and procedures can be referenced.
It's important to read and understand any assembly and installation instructions that come with your pistons.
These instructions are for representational purposes only and not valid for all JE pistons.
Process Overview
Before diving into installation details, a quick recap of the process will be helpful to understand what’s to come. Shown below is an outline of the major steps you’ll go through.
  • Measure ring end gap
  • Clean all rings
  • Mark piston where the end gaps should align
  • Install oil rings
  • Install 2nd compression ring
  • Install primary compression ring
  • Verify groove clearance
Not sure which piston ring set you need to order? Check out our guide here.
In addition to understanding the steps you'll be performing, laying out all the components needed helps stay organized and prepared.
Time for a new piston kit? Find one here!
Step-by-step Process
Measure Ring End Gap
Before installing the rings onto the piston, it is imperative that the ring end gaps are checked and verified against the specs provided with the installation instructions or factory service manual, whichever is applicable. If more than one compression ring is used, confirm any design differences between the two by referencing the installation instructions. Chamfers on the inside edge of the ring or different markings at the ring ends are common identifiers used to denote ring differences. Need clarification on all the markings used on JE rings and pistons? Click here.
To check the ring end gap, simply install the appropriate ring into the cylinder bore and position it near the top of the bore. Use the depth rod end of a caliper to ensure the ring is square to the bore. Next, use feeler gauges to measure the ring’s end gap. Carefully insert various thickness feeler gauges between the ring ends until the gauge just begins to drag between the ring ends. Note the thickness of the gauge and compare it to the end gap specifications provided. This process can be repeated for any additional compression rings used.
The majority of JE's motorcycle rings are pre-gapped, but it's always good practice to check ring end gap for all compression rings prior to installing on the piston.
At JE Pistons, the ring end gaps are preset at the factory to fall within spec when installed in healthy cylinders used for normal applications. The end gap of the first compression ring should always be less than that of the second compression ring. If the end gap specs are outside of range, first double check your measurements and verify the cylinder bore is the correct diameter. Assuming no issues are found with the measurements or cylinder bore and the end gap measured is too tight, the rings can be carefully filed. To do so, use a small file and file one end of the ring. Be sure to maintain parallelism to the other ring end as you remove material. Remove small amounts of material and check the end gap periodically so that you don’t remove too much material.
If ring end gap does need to be adjusted, evenly file one end of the ring only in small increments and continue to check until it's at the desired spec.
Clean
All piston rings should be cleaned before being assembled onto the piston. Before cleaning, confirm the ring ends are free of burrs. Any burrs present can carefully be dressed by gently breaking the edge with a small file. Next, use your preferred parts cleaner to wipe down the rings and piston.
Make sure your rings are clean and free of any debris or burrs.
Mark the Piston
Review the instructions provided with your piston kit, or the guidelines provided in your owners manual if no alternate instructions are provided, and note the specified positions of the ring end gaps. Use a marker to mark the edge of the piston crown with the intended ring end positions for the oil control and compression rings. Doing so will help ensure no orientation mistakes are made upon ring installation.
Follow the ring end gap orientation instructions for your specific piston(s) and mark the piston so you know where each end gap should end up.
Oil Control Ring Installation
Modern oil control rings typically utilize a three-piece design and consist of two side rails and an expander ring. Three-piece oil rings can be challenging to install if the ring design and methodology are not understood. The expander ring is the waffle shaped ring and features a stepped edge on the top and bottom of the ring. The side rails are the two small, thin rings which complement the expander. When properly installed, the side rails sit on the top and bottom of the expander ring against its stepped edges. For this reason, the expander ring must be installed first.
The other feature of the expander ring worth paying attention to is its ends. Due to the expander’s accordion-like shape, it is possible for the ring ends to overlap in the ring groove. For proper installation, it is imperative that the expander’s ends butt and do not overlap.
The ends of the expander ring should be touching, but not overlapping.
To install the expander ring, lightly coat it with engine oil. The expander ring is non-directional, so it can be installed in any orientation. Carefully work the ring past the compression ring groove into the oil ring groove. Adjust the expander ring as necessary, so the ring ends are correctly positioned. Ensure the ring ends butt together and don’t overlap.
1473626747_Photo10.jpg.e50b132681d6cda1de1e9534a525a142.jpg 961553440_Photo11.jpg.03931e469f5f35941e179eacb6fd131a.jpg
Start by installing the expander ring after lightly coating with oil.
The side rails are also non-directional. Lightly lube the side rails then install them on the piston. Make sure the side rails sit correctly against the stepped edge of the expander ring and that their end gaps are positioned properly. Once the side rails have been installed, double-check the end gap positions of all three rings that comprise the oil control ring assembly.  Ensure the expander ring’s ends are not overlapped and ensure the assembly moves freely within the oil ring groove.
1268235293_Photo12.jpg.02fc2022c4f4579c982a160b92c04ec6.jpg 912111049_Photo13.jpg.b2f346b5a077a161282414668a84f7dd.jpg
Oil and install the oil expander rails below and above the expander. Be sure they are resting evenly and the end gaps are lined up with the appropriate markings.
Compression Ring Installation
If the piston utilizes two compression rings, the second compression ring should be installed first. Refer to the installation instructions to determine the proper orientation of the ring before installation. Typically, dots or letters will be marked near the ring end, which denotes the top of the ring. Internal edge features such as chamfers may also be used to identify the ring and its correct orientation. Lightly oil the ring and then carefully work it over the piston into its appropriate groove. Adjust the ring’s end gap position so that it aligns with the mark you made for it on the piston crown. Repeat this process for any remaining compression rings.
1224468335_Photo14.jpg.06acf3f840669cfd986d194eea892885.jpg 1738231766_Photo15.jpg.6f2047c6024975caf55633aaf1586aa3.jpg
Install the compression ring(s) in a similar fashion, lightly applying oil and carefully working the ring around the crown of the piston. Be careful not to twist or bend the ring out of shape as it could affect its ability to seal properly.
Confirm Groove Clearance
Once the compression rings have been installed, the ring-to-groove clearance should be checked. To do so, insert a feeler gauge between the ring and groove. The clearance can be identified by finding the feeler gauge that drags ever so slightly between the ring and groove. Note the groove clearance and compare it to the specification provided in the installation instructions or factory service manual.
One of the final measurements to take after the rings have been installed is compression ring to groove clearance. Use a feeler gauge for this and find the size that has slight drag. Compare this spec to what's outlined in your instructions or owner's manual.
At this point, ring installation onto the piston is complete, and subsequent steps can be taken to complete the engine build. While installing the piston rings onto the piston is a critical step in the build process, it can be performed by anyone when the proper steps are taken. The process simply requires the correct measurements are taken, cleanliness is ensured, and installation techniques are used.
In search of a quality, performance forged piston for your bike? Click here to see what's available for your machine.
  • Like 5
  • Helpful 1
User Feedback
Recommended Comments
If I'd had only seen this 6 weeks ago, ugh.
When I installed the expander ring it overlapped. It made the rings stick. The instructions I had really were geared toward someone that had experience with this type of build. I'm from a 2 stroke background and so the expander ring was new to me.
I showed the overlapped expander to a buddy that used to build 2 stroke motors. He suggested cutting it, i did.
The install didn't have stuck rings anymore so I thought I was good to go. Instead, the oil rings weren't functioning properly so oil was dripping out my exhaust. So off comes the head and base gasket (over $120) and new rings were ordered along with a diamond cut hone.
Currently breakin's at over 400 miles. Changed the breakin oil at 100 and I'll run 400 miles of breakin oil  before I go back to synthetic.
BTW, I chose the hard breakin method and not the manufactures slow breakin. My 350 with almost 13,000 miles is  running great. Might even have more power than before the new top end and valves. Originally the shop I bought the bike at replaced the oil during the 100 mile checkup with synthetic. I've learned that using synthetic that early prevents the rings from fully seating in.
Probably best to wait at least 500 miles before you switch to synthetic.
I posted my failure so that others won't make the same mistake or a similar one.
This is a truly epic write up. Question though, in the Je piston kit I got the second compression rings had no markings whatsoever. It was just black. Is that possible?
  • Similar Content
    • By hayden Howard
      Okay... so I have replaced my top end before on my 04 yz250 just to make things clear. I changed it last year around july, and I rode it a crap ton during that summer on trails and in some open fields and some every now and then during the winter. 40:1 with P97 using amsoil dominator 2 stroke oil is what I used everytime. Well one day this year back in March I got on it and it it just wasn't right. Itd sputter before the powerband kicked it, i had a lot of spooge coming from under the pipe on the motor and going up hills seemed impossible because it wouldn't have any power because it was too busy sputtering. So I checked the reeds and they're good and I changed the air filter and it was good but it still wasn't right. Then I figured it was jetting. So I had the stock jetting that was in it that had been in there for 2 years and ran great, MJ 178, PJ50, need position 2nd from the top. So I experimented and got the jd jetting kit and it said to use a 175 jet  but it was too rich with that and would sputter top end so I have the jets at MJ 168, PJ 45, and red needle at the 1st position but is still choppy on the low end about 1/8 - 1/2 then it'll kick in good. So I have read that worn rings on the piston can cause for rich jetting and having jetted it pretty lean to run better and still not perfect I went ahead and bought new gaskets and a wiseco piston for it so see if it'll run better. But my question is, when I change it should I change all the jets and needle position back to stock? Or should I use the JD jetting chart and go by from what that says? Thank you guys so much. If you have any tips let me know please
    • By KadanV
      I went for a ride with my yz 125, it felt like it had low power and we thought we fouled a plug. Tried a new plug, didn’t fire and felt like there was low compression. Did a compression test, it read 35. Tore open the top end, big hole in the piston. I tried to drain the coolant, it didn’t drain out of the drain bolt. But once I pulled the top end, coolant was overfilling out of it. The crank and everything had coolant all over it. Drained the trans oil, coolant in it. I opened the water pump to check the seal assuming it was the reason for the coolant in the trans oil, it seemed in perfect condition. Although, the pump had a broken fin, and there was a weird brown look in the case of the pump, almost looked like rust.
      Here are the pictures I took
    • By KadanV
      Decided to take off the expansion chamber to check the piston out today. Did a rebuild 19.7 hours ago with a wiseco piston. How does this piston look? Is it almost time for a rebuild?
    • By Kas_shifflett
      So I just did a new top end and cam for my 08 crf150r, and I know when you break them in, run slow and low RPM for the first tank of gas, ( not meaning you can beat the crap out if it in the second fill up) what do you guys do when breaking in your 4 strokes, and how do you do heat cycles, I was thinking about riding woods for 30 mins slow, let the bike sit and cool down then ride for another 30 mins, how do y’all do it, first rebuild so I’m new here, thanks guys
    • By John Bond
      HI anyone knows if a 2010 or plus piston can be used in a '07 KX450F?
      I will put some images here, Thank you!
