eddster500r
2009 DRZ400sm I bought this bike with a little less then 600 miles.  I have since put down more 60000 miles on the bike.  I thought I would share a little about my bike and the modes i have been able to do.
1. Gearing I Run a 16 tooth front sprocket and a 37 tooth rear.  And you can go all the way down to 35 tooth if you wanted to slightly modify the rear hub. I would advise against this.  My opinion, a with mildly modified DRZ(exhaust and 3x3 mod) I would not go with taller gearing than 16-39 or 15-37.
2. Rear Tire, You can run up to 160/60 R17,  My opinion 150/70 R17 is the best handling.
3. Rewiring Charging cable, by shortening and using a thicker gauge wire that is routed from the battery over to the starter relay and then back into the loom.  As well as bringing down the Fuse AMP down to 15amp.  15amp is enough to operate 100 watts of light.
4. 4mm Stroker, Can be installed using the stalk piston and 91 pump gas.  5mm stroker needs to modify the crank case and replace the piston.
User Feedback
Recommended Comments
  • Similar Content
    • By Jameydog
      - Triangular style flasher.
      - Terminals and nuts are included for installation.
      - Comes in pairs. Works on 12V AC/DC.
    • By Erin whitsett
      I have an 05 yfz 450 when i attempt to start it, it makes no click just the red temp light comes on and my neutral light is green. I have had my battery checked and it is in good condition also i have replaced the regulator rectifier. odd contributing piece of info my lights do not work either they did before i had this problem.  Please any advise would be greatly appreciated
    • By Stealthskier
      Hey guys, I have a 2014 crf250l and the current gearing is 13-40. I am dissapointed at how  slow the acceleration is,so am trying to buy a new rear sprocket. I am currently trying to decide between a 45 and 48 tooth. All help is appreciated.
      Thank you
    • By 4strokeOnly
      New, never used Sunstar 47T steel rear sprocket for 520 size chain.   Part number 3577.  Made in Japan.
      Stock size sprocket for the DRZ-400E with 112 link chain.
      These are the most affordable & cost effective sprockets I've ever used.  My bike was stolen so I'm liquidating my spare parts.  Your's for a bargain.
      $20 + shipping.
      From Sunstar website, fits:
      Suzuki DR-Z250 2001 - 2007
      Suzuki DR-Z400 2000 - 2003
      Suzuki DR-Z400E 2000 - 2007
      Suzuki DR-Z400S 2000 - 2018
      Suzuki DR-Z400SM 2005 - 2018
      Suzuki DR250 1990 - 1993
      Suzuki DR350 1990 - 1999
      Suzuki DR350SE 1996 - 1999
      Suzuki RM-Z250 2007 - 2018
      Suzuki RM-Z450 2005 - 2018
      Suzuki RM125 1980 - 2008
      Suzuki RM250 1981 - 2008
      Suzuki RMX250 1989 - 1998
      Suzuki RMX450Z 2010 - 2018
      Suzuki RS175 1980 - 1982
    • By DontMakeWaves
      I have a Honda SL125 engine and I'm trying to wire it up so that it can run without the battery. I found this guide http://waynescyclegarage.mysite.com/custom.html and I've followed it and done just what it says, but I'm not getting any spark. I used a voltage meter on the stator and there seems to be no issues with that. I also put one wire of the meter on the wire going into the coil and the other on the spark plug and when I use the kick starter it comes up with something on the voltage meter, but despite all that, I still get no spark. What could I be doing wrong?
