Eliminate the frustration of being a space case
Red Dog
I'm sure we all have had this happen more times than we care to admit. How many times have you loaded up to go riding only to find when you're gearing up that you forgot something? Even if you're not the one it happens to and your buddy forgets something like his gloves, boots, goggles, helmet or whatever it's a crappy way to mess up a otherwise good time.
The best way to avoid not having all your gear together and ready to go is get a large gear bag and use it. Get one that's big enough to hold all the gear you need to go riding and keep it packed and ready to go at all times. That way when you get the call to go moto, or just hit the trails, that parts done. You most likely don't wait to decide to go riding before you get your bike ready. Why do that with your gear? Gear bags that are big enough to hold everything don't have to be cost prohibitive to own. Sure there's some deluxe ones out there that cost over a hundred bucks, but to me that's more than I want to spend. If you look around, you'll see that a nice big bag can be had for less than $40.00. I got one on sale at a local dealer 4 years ago for $29.95 and it has been used a lot and still is holding up great. Seperate compartments for the boots is definately the way to go.
Every time I come back from riding I wash the gear that needs washing and repack the bag and set it next to my bike. If you do this and make it a habit you'll thank yourself many times over. Especially when your buddy forgets his gloves and you have yours. Who knows, maybe you'll have an extra pair stashed in there he can use cause you know he just tends to forget things.
User Feedback
Recommended Comments
I have a family that rides, so buying five or six different gear bags was not attractive. I went to Walmart and got two large plastic totes with snap on lids for less than $10 each. The kids throw  all their gear in one and my wife and I throw our gear in the other. Things get washed and put back in and then they get put back in the trailer with the bikes
Share this comment
Join the conversation
Guest
Add a comment...
  Only 75 emoji are allowed.
Loading...
  • Similar Content
    • By jaybellnv
      Moto Bling Kit for your KTM includes rear wheel chain adjusters, oil fill cap, front and rear brake reservoir cap, air tube caps, rim lock caps, and steering stem nut.
    • By Madsmokey12
      The STEALTH ULTRA HD Soundbar Series represents the world’s first universal high performance plug and play sound system for side by side’s, golf carts and just about any mobile application. The Patented design is built with a full extruded aluminum housing which looks similar to our Rogue 4 led light bars. All STEALTH models feature a full range speaker array plus additional titanium dome tweeters for dynamic output and performance. Now with an ALL-NEW RF Wireless Remote for full control from steering wheel cradle. IP67 Rated.
    • By Powerban
      Reflect-A-GOLD™ is an adhesive heat shield made from a metalized polyamide polymer laminated to a light weight glass fiber cloth with a high temperature pressure sensitive adhesive for use in extreme temperature swing environments. Our lightweight, adhesive thermal shielding is easily applied and removed. It's minimal clearance and ease of use makes Reflect-A-GOLD™ a highly effective material for firewalls, fuel cells, engine covers, under hoods, engine compartment, bulk heads, seat bottoms and anything or area that needs protection from heat.
      For firewalls, bulkheads, engine covers, floors, seat bottoms & more
      Handles continuous temps up to 850°F
      Resists UV degradation for long-term performance
      Adhesive protected by release liner rated up to 325°F
      0.0065" thick
      Easy to apply and remove
      Radiant Heat Resistance:
      850°F
      Adhesive Heat Resistance:
      325°F
    • By speedtoad
      I think honda let us down with the new CRF250L. We didn't need another Japanese softcore Dualsport option. Suspension looks good for street but not enough for serious off-road, and 320 lbs wet is way to much for a 250. This is basically a small trail bike just like the CRF230L.
      Looks like the motor is from the CBR250, tuned for better low end. Should last forever and at $4499 retail the price is low.
      I won't be trading it for my DRZ. I would consider the new NC700x for a commuting bike. I saw it at the motorcycle show. Its lockage 21 liter storage was a nice option.
    • By gots_a_sol
      I see there was a thread like this, but it hasn't had a new post in almost 2 years, so lets see if this one has better luck.
      I picked up my '03 WR on Friday
      Took it out for its first ride on Sunday along with my buddy with a yz400. The day went well and so far there isn't really anything obvious that needs to be changed.
      Today I flushed the old coolant for some engine ice.
      Also I adjusted the rear brake lever down and removed the odometer/cable also since it is broken. I'll pick up an hour meter before the next ride and the yz parts to eliminate the speedo drive.
