Engine Oil Additives: Are they safe for my engine?
MotoTribology
The short answer is no, unless there is a very good reason for it.
The long answer includes explanations as to why the answer is usually no and can be read below.
Aftermarket or over-the-counter (OTC) oil additives come in a few general variations:
  • Performance Additives
  • Viscosity Modifiers
  • Cleaners
  • Inhibitors
  • Magic & Sci-Fi
There can certainly be other types, but a vast majority of OTC additives fall into one of these categories.
Performance additives generally include anti-wear, extreme pressure, and friction modifying additives. They often have some root in traditional oil formulations; meaning they are commonly used in existing oil formulations and advertised as "performance boosters". For the most part, as OTC additives, they are unpredictable at best, the marketing claims for their performance is rarely supported by any credible evidence, and they usually don't live up to the expectations.
A big problem is: more rarely equals better for these additives, and simply adding them does not increase the advertised performance reliably. Many of these types of additives experience diminishing returns with regard to performance and their proportion of the lubricant formula. Other groups of them actually experience decreased performance with increased concentrations. So adding them to oils that already have additives providing this performance results in neither additive groups doing the job right.
Another problem with these additives is their ability to disrupt the surface activity the additives of the original lubricant were designed to do. So by adding one of these chemicals, it is likely to diminish the original performance of the lubricant and substitute it with a potentially less effective replacement.
There are undoubtedly many anecdotes of these types of additives doing good, but that is more than likely due to either luck or a placebo effect. Every oil formula is different and adding these random amount of random additives is unpredictable at best without knowing the original oil formulation and exactly what you are adding at what quantity. No additive I have ever come across would work in every formula at the exact same concentration.
Viscosity modifiers are typically either high viscosity oil or a polymeric fluid. They are usually un-additized and therefore dilute the original lubricant's additive concentration. This is bad for similar reasons stated above regarding changing the additive concentrations. By changing the formula concentrations, you may be changing performance aspects that were balanced in the original formula to an unbalanced concentration. These additives can be useful in a few circumstances though. They can be temporary fixes to compression issues and leaks, but even in fixing those problems, you may introduce unintended consequences such as engine efficiency and oil supply through the pump. If it is the only way to get the bike somewhere for maintenance, it might be the best option, but still not good for normal use.
Polymer fluids in motorcycles add an increased risk. The increase in viscosity is usually very temporary because these polymers are not often shear stable. So once they shear, you have no increase in viscosity and a diluted bulk of oil. So it is a lose-lose in that situation.
Cleaners come in two main varieties: detergent/dispersant additives and flushing compounds.
Detergents and dispersants are similar to the performance additives in the sense that they are very surface active and can disrupt the surface active additives of the original oil to its detriment. Detergents, dispersants, anti-wear, and friction modifiers are carefully balanced in oil formulas and increasing the detergent concentration can prevent those other additives from interacting with the metal surfaces where they normally would. Generally speaking, unless you have an engine in absolutely terrible shape, with regard to sludge and carbon deposits, a good oil already has more than enough of these additives in it to do the job.
Flushing compounds are usually some sort of high solvency fluid meant to dissolve sludge and carbon deposits in dirty engines. These can be useful in very dirty and neglected engines as long as care is taken not to overdo it. If an engine has a high level of sludge and deposits, it is possible to release too much all at once and cause unintended harm by blocking oil flow or forcing that bulk of contaminants into areas it can do harm. So an engine flush can be useful, but care should be taken when doing so.
Inhibitors usually take the form of antioxidants. These are safer than some other additive types because they aren't generally surface active chemicals. They do still dilute the overall additive concentration somewhat and can possibly throw off the balance of a formula to produce worse overall performance though. There is less risk in using these types, but still, your typical oil should have more than enough antioxidant additives in it to begin with and there is rarely a need for more to be added.
One final thing I'll cover here is the "magic" and "sci-fi" group of additives. These are the types that usually make some pretty unbelievable claims. They are usually unbelievable for a reason; because they are nonsense. The claims by the "manufacturers" (usually marketers, not chemical manufacturers) are very lofty, always unproven and supported by anecdotes, and typically backed up by lots of buzz words and little substance in any true technical sense.
Typical claims are:
  • large increases in power and efficiency
  • rebuilding of metal surfaces from the inside out
  • fixing leaks with no effect on any other property of the oil
  • "nano" (This prefix above all other things makes me cringe and look closer at marketing claims. Yes I will admit I am prejudiced against "nano" materials in lubricants, but I will also be the first to admit it when I see one that is proven to actually work as advertised.)
Typical results are:
  • nothing
  • harm
  • benefits claimed with zero evidence
  • lighter wallet and again, nothing
For a motorcycle with a wet clutch, one thing to especially look out for with any additives is whether it will affect the clutch. Some additives are right up front with it and say not to use it with a wet clutch, but others are less obvious.
So in summary, yes there are a few circumstances where benefit can be had from using an OTC additive. In most cases though, there's not much to gain and they either result in a performance decrease or no change at all.
  • Like 6
User Feedback
Recommended Comments
I figure if you're running the right oil for the application in the first place, the oil has all the recommended additives in it already. The only additive I've ever used is basically a surfactant.
Share this comment
  • Similar Content
    • By Hayden Pratt
      I've had my bike since June and have rode it probably 16 hours. Have done oil , oil filter / air, tires, springs all that jazz so far. Probably will need a rekluse or a clutch cover soon and some graphics..
      Besides the point. - I just changed my oil before my last ride and I came home with some seepage between my clutch cover and on the other side. I dont know if I over filled (used one full bottle of Ti-Lube 20W40 (.956L) - Honda recommends 1 - 1.25 liters. So I dont think I overfilled.
      Is it time for new gaskets or seals? Help me troubleshoot please. Thanks
    • By Drzjosh125
      I had a disastrous oil change today. I only drained out one of my drain bolts (the one on the back right side of the engine) at first. After draining that one bolt, I put 1 and 1/4 quarts of oil in the bike. And then, "OH CRAP!" I realized I had only drained that reservoir.... I thought maybe if I drained one bolt it would also drain most of the other? But I wasn't taking any chances so I drained out both bolts this time and started over. I then put 1 and 1/4 quarts back in and finished up. I checked the oil level window, and it looks like the oil goes over the window? This bike has no dipstick which sucks. I took the bike for a 10 minute ride and stopped and held it upright and it still looked like it was over the window. Where is the level supposed to be? Is it supposed to be over the window? I don't think I put too much, if I did please let me know. I ALSO CHANGED THE OIL FILTER. Thanks!
    • By frontline510
      I recently acquired a 1990 KDX200. The bike runs reasonably well for it's age. The first ride over 30 min the gearbox oil started overflowing into the airbox (overflow hose is routed to airbox). The oil that overflowed and the oil in the gearbox are an odd shade of dark forest green. The oil appeared to be overfilled slightly which explains the overflow. What I don't understand is the weird dark blueish greenish gray color of the oil.  I believe the PO used motul 10w40 ester gearbox oil because he gave me a half used gallon. I use Motul 710 2t oil which is blue, and run green coolant in the radiator. I drained the gearbox oil and there was a nice little clump of dark gray metalic paste on the magnetic drain plug, which should explain the gray hue. What I do not understand is the greenish blue hue. Anyone know what in the heck is going on with this old horse?
      The pic shows a sample of my drained oil. When held up to the light it turns more of a green color. Oil still feels slick as can be.
    • By Drewboroce
      Can’t find   Ignition / sprocket side cover gasket I’ve looked and looked but can’t find one that looks like this I’ll post a pic it’s ripped tho that’s why I need a new one
    • By crfjunky1320
      Hey guys, just curious as i recently bought an older crf450 and I am doing my first valve replacement myself and as I pulled off the valve cover there was a large pool of oil around the springs. Spark plug is dry. Is oil in the valve cover normal? Trying to find any extra parts I might need to replace while I have the top end torn apart.
      Thanks!
