Everything You Need To Know About Installing a New Chain on Your Dirt Bike
Rob@ProX
Periodically inspecting and replacing the chain on your motorcycle or ATV is part of regular maintenance. Here, we go over steps and key tips for replacing your worn out chain with a new one.
The necessity to periodically replace the chain on off-road machines comes as a byproduct of operating in harsh environments containing dirt, mud, sand, etc. On road machines aren’t exempt from this maintenance task either, however, their replacement intervals are longer. Replacing your machine’s chain isn’t a tough job if you’re well equipped and prepared to take on the task.
Replacing your machine's chain is part of normal maintenance and should not be neglected.
To start, it is essential to have a copy of your machine’s factory service manual. Within the service manual, you’ll find specific instructions and torque specifications that may be required to complete the job. For example, if either of the sprockets requires replacement, it is imperative the nuts and bolts that secure them are torqued to the outlined specifications.
Before purchasing a new chain, you’ll want to confirm that the sprockets are in good condition. Pairing a new chain to worn sprockets will accelerate the rate of chain wear and be counterproductive. You’ll also want to inspect components that come in contact with the chain such as chain slides and rollers. Replacing these components at the same time as the chain is advantageous.
1744599409_prox_installing_chain(26).jpg.20f8af2a806f969296b838f496c0f909.jpg 1552378650_prox_installing_chain(28).jpg.a1792bf2951947aa90123f8c22992b4a.jpg
Inspect your sprockets before beginning the new chain install process. Notice how the grooves in the worn sprocket are asymmetrical in comparison to the new sprocket.
Inspections
Sprocket condition can be checked visually by looking at the sprocket teeth. Sprocket teeth take on a hook shape when they become worn, and in severe cases, shorten and round off when service has been severely neglected.
If funds allow, it’s always best practice to replace both sprockets when replacing your chain. This will allow for the most life possible out of your drive system.
Don't let a worn sprocket ruin your new chain. Replace them when you replace your chain.
The condition of the chain can be assessed by putting the bike on a center stand. Rotate the rear wheel and visually inspect the chain’s condition. As you rotate, feel the chain for tight spots or links that are stuck together. Attempt to pull the chain away from the rearmost part of the rear sprocket. If the chain can be pulled off the rear sprocket by a half sprocket tooth or more, it is time for a replacement. Similarly, if the chain moves significantly side to side when pushed and pulled on the sprocket, wear has occurred.
Check your chain's wear level by attempting to pull it away from the back of the rear sprocket. If it's half a tooth or more, it's time for a replacement.
Check any chain slides to ensure they have ample life left. Rotate chain rollers to ensure they spin freely.
798376040_prox_installing_chain(4).jpg.4e7df4b877ae2785b750d3e618738a7e.jpg IMG_8045.jpg.90a49e35485bf25aef416cd46bea4e72.jpg
Check your chain rollers and sliders as well. These are normal wear items, and they should be replaced when they show signs of excessive wear.
ProX also offer OEM replacement chain rollers in addition to chains and sprockets.
Chain Sizing and Options
Off and on-road chains used for powersports applications come in various sizes based on chain pitch and length. Before purchasing a new chain, you’ll need to confirm the appropriate pitch and size for your machine.
Chain pitch defines the distance between the chain pins. Common pitch options are shown in the table below along with their corresponding dimensions.
There are a couple of ways to determine the type of chain your machine utilizes. First, your factory service manual should contain this information. This is usually found in the rear wheel specification table. Second, most chain manufacturers denote the chain’s pitch on the side of the chain. You can obtain the chain’s length simply by counting the number of chain links it has.
Many chain manufacturers will indicate the pitch on the links of the chain itself.
Once you’ve determined the chain pitch and length you need, you’re ready to order. When it comes to ordering, you’ll need to decide on the type of master link connection you want and whether the chain is a standard chain or a sealed chain.
The most common chains in dirt bike and ATV applications are 420 (for minis) and 520. ProX offers both sizes of chains. ProX 520MX chains are available in both standard and X-ring, in standard and gold finishes. The gold finish is the result of a rust-resistant coating. ProX chains are made in Japan from high-quality Japanese steel. These chains come with master link style connections, which is the most common in modern off-road applications.
520 is the most common size for modern off-road motorcycles, and 420 is a common size for minis.
Master Link Connection
Clip Type - Clip type connections are widespread nowadays and are notable for their ease of installation. Clip type master links are not quite as strong as rivet type. However, they can be installed with no special tools.
Rivet Type - Rivet type master links require a special rivet tool to install but offer a more permanent connection.
A clip type master link.
Chain Seals
The difference between a standard chain and a sealed chain is that the former does not use any type of seal to retain chain lubricant. Sealed chains, often referred to as O-ring chains, utilize O-rings or similar variants to retain lubricant which helps reduce wear and prolong chain life.
There are different styles of O-ring chains available, such as ProX’s X-ring chains. ProX’s X-ring chains are a sealed O-ring chain but have less O-ring surface area touching the link surfaces to reduce the drag in comparison to a normal O-ring chain. The advantage is in the design of the O-rings themselves.
CLICK HERE for a full explanation of the differences between standard and O-ring chains to help you decide which one type is right for you.
Tools
To replace a chain that utilizes a clip type master link, you’ll need the following:
  • Pliers for pressing on the chain plate or master link plate pressing tool. Pliers will also be used to install the master link clip.
  • Flat blade screwdriver for removing the master link clip.
  • Grinder, punch, and hammer, or chain breaker tool to adjust chain length.
To replace a chain that utilizes a rivet type master link, you’ll need the following:
  • Chain rivet tool for installing the master link.
  • Grinder, punch, and hammer, or chain breaker tool to adjust chain length and to remove the old chain.
Ensure you have the proper tools before beginning your chain replacement job.
Chain Removal
On chains utilizing a clip type master link, chain removal is as simple as prying off the master link clip and removing the master link. Through use, the master link plate usually wears enough so that it can easily be slid off the link. If the master link plate is tight, the master link should be driven out by using a punch and hammer or chain break tool.
196353322_prox_installing_chain(9).jpg.4fd82b8b390bf7bfd9c1d4ff6d06fbf9.jpg 523411771_prox_installing_chain(11).jpg.28dc33ee4b94b91cde527c879fa391c7.jpg
For clip style chains, one easy way to remove the master link clip is to use a pair of pliers to push the clip off by using the chain pin for leverage.
Chains utilizing rivet master links will require pin grinding so that one of the links can be removed. Grind the rivets that retain one of the links flat, then use a punch and hammer or chain break tool to push the chain link out.
Chain Installation
If necessary, resize the chain to your machine by removing the appropriate number of chain links. Remember to count the chain links of the old chain to establish the length of the new chain. Don’t lay them side by side and try to set the length because the chain stretch that occurred in the old chain will lead to an incorrect chain length of the new chain.
Chains almost always need to be sized (have links removed). Your manual should specify the required number of links, but sizing it up on the bike will give you a good idea if your rear axle will be in the recommended position.
Chain links can be removed by carefully grinding the rivet flat to the chain side plate, then driving the pin out with a punch and hammer. Alternatively, a chain break tool can be used.
Sizing the chain can be done by grinding and punching, but the easiest way to remove links is to use a tool made specifically for the job.
Loosen the rear axle nut and slacken the chain adjusters. The new chain will necessitate this since it has not worn or stretched.
Position the two chain ends on the rear sprocket. Next, install the master link whether clip or rivet type. Be sure to include the o-rings when installing sealed chains.
Clip Type Master Link Install
Once the master link has been installed, install another pair of o-rings (on sealed chains) followed by the master link plate. The master link plate will need to be pressed onto the master link. Use a pair of pliers to squeeze the plate onto the master link. Press the plate on far enough so that the grooves that retain the master link clip become exposed. A pair of small c-clamps can sometimes be helpful when installing the plate, or a master link plate installation tool can be utilized.
1146730853_prox_installing_chain(36).jpg.ea7d0dca30b46be9f2e9aa5f50db0b33.jpg 695643366_prox_installing_chain(37).jpg.d91773eb411be3ab1edb7322b43a74a1.jpg 2100589540_prox_installing_chain(38).jpg.25b78c93801fc5c5778638e3304667a7.jpg
Place your master link through the wheel side of the chain so the clip will face out. Next, press the master link plate on the outside of the link. Using a pair of pliers to press the plate past the grooves on the chain pins should  be sufficient.
Next, install the master link clip. The master link clip is directional and should be oriented so that the closed end of the clip leads the direction of rotation. By orienting the clip this way, should the clip hit an object during operation, it will not become dislodged from the master link. To install the master link clip, position it in its mating grooves on the master link. Use pliers to seat the clip fully in its grooves.
1316849781_prox_installing_chain(39).jpg.a0e4d54c4c4558344b75ee380a42da5e.jpg 1883916002_prox_installing_chain(41).jpg.144565d98e0b64f5a26ec0a0afdda9d9.jpg
Now, install the master link clip. The closed end of the clip should lead the direction of forward rotation of the wheel. Use a pair of pliers with leverage against the pin to fully snap the clip in place. Be sure it is fully seated.
Rivet Type Master Link Install
To install a rivet type master link, you will need a master link rivet tool. It’s recommend to follow the instructions provided with the tool to perform the rivet operation. The chain manufacturer will also provide specifications which govern the appropriate amount of flare to add when deforming the rivets.
Setting Chain Slack
Once the master link has been installed the chain tension should be adjusted so that the machine has the appropriate amount of chain slack. Your machine’s service manual will outline how to measure the chain slack and define the slack range. Most manufacturers recommend measuring chain slack with the bike on a center stand. Slack is then measured by pulling up on the chain near the center of the swingarm and measuring its displacement. Most dirt bikes require 30 - 60mm (1.18 - 2.36 inches) of chain slack. Carefully manipulate the chain adjusters so that they tension the chain evenly and align with the same reference points from side to side. Once chain slack is correctly set, torque the rear axle nut to the specification outlined in your service manual.
163775942_prox_installing_chain(45).jpg.d493973694c45be38884bc290edab064.jpg 1024975068_prox_installing_chain(44).jpg.328b1ec30bf5d8711d589e824556c30a.jpg
Once installed, adjust your chain slack to the recommended spec using the axle block adjusters. Secure the lock nut when finished, then torque the rear axle nut to spec.
Post Installation Tips
Most chains are pre-stretched to reduce the amount of initial chain stretch that occurs once the chain is put in use, however, it is never a bad idea to keep an eye on the chain slack after the first few rides.
New chains come pre-lubricated from the factory. However, you should always ensure your chain stays lubricated throughout its life. Lubing your chain before or after every ride, especially muddy or rainy ones, should become habitual.
Find ProX chain and other components for your bike HERE!
  • Like 3
  • Helpful 3
User Feedback
Recommended Comments
I put the master link in from the outside with the clip on the inside.  When and if it fails then the master doesnt take damage the cases as it works its way out.
  • Like 7
Share this comment
"Most chains are pre-stretched to reduce the amount of initial chain stretch that occurs once the chain is put in use"
Chains don't stretch.
  • Sad 1
Share this comment
 I do the same. Also less likely to have a failure of the clip b/c it is facing away from impacts from rocks or a bent chain guide.
Edited by BigDaddy22
  • Like 2
Share this comment
That's a great tip .
Share this comment
Thank you, I've been preaching that for years.  The pins wear, thereby lengthening the chain.  You know it is really, really worn when you can tie the chain in a knot. 🤣
Share this comment
We understand the material in the chain doesn't physically stretch, it's just the term the industry uses for the relationship between the pins/links. When we say pre-stretched, we mean the chains are put under an initial stress load much like they would experience on a dirt bike for the first time. This helps all the components settle in and seat to operating location so you see less need to adjust the chain quickly after the first couple rides.
  • Like 3
Share this comment
Just a pet peeve of mine, I'm very OCD.:D
Share this comment
Noticed my year old chain needed to be slack adjusted , when I took up slack I counted six ( 6 ) broken links in my 525 budget aftermarket Amazon BUDGET chain . I replaced it with a DID , Drz 400 s
Share this comment
Am I the only one that cleans the excess grease off a new chain with chain cleaner?
The important parts that need lube are behind the rings, therefore all the excess grease on the outside just flings up and makes a mess.
  • Helpful 1
Share this comment
How many of you safety wire your master link clip?  If so, is there a favorite tool for accomplishing that?  If not, why not?  Thank you.
Share this comment
Join the conversation
Guest
Add a comment...
  Only 75 emoji are allowed.
Loading...
  • Similar Content
    • By Blake K
      I have a 2004 honda crf450r with probably over 500 hours on it but im not sure since it has no meter. I Bought it when I was 16 back in 2013 which means I've had it for around 7 years. It was pretty well taken care of and had the motor top and bottom rebuilt probably 15 hours before I got it. I have been riding it every weekend possible ever since I got it. I ride 95% trail with a very tiny bit of road just to get to another trail. I don't ride hard all the time, but I would say 70% of the time I would consider hard riding, wide open throttle, lots of shifting, racing other bikes. I have hit the rev limiter like maybe 2 times ever since I've had it.
      Oil changed probably every 3 rides or so. There's a strange soft ticking coming from the bike rope end and my guess is valves since I have never checked them once. It seems to be running very strong still, never has burned oil, and starts cold every time around the 3rd kick. Starts hot on the first kick.
      My question is when do I rebuild this thing? Should I be worried even if I can fix the slight tick in the top? It doesn't show any signs of breaking down on me but I feel like I'm on a grenade. I dont want to get it inspected by anyone and if it comes to it I'll be rebuilding on my own.
    • By ThumperTalk
      No Toil Industries has partnered up with ThumperTalk to bring you giveaways on their unique dirt bike & atv maintenance & care products!😍 Up for grabs is 5 product bundles, each worth over $200.00 💰 consisting of:
      (1) No Toil pre-oiled air filter
      (1) No Toil extreme conditions air filter
      (1) No Toil Super-Flo kit*
      (2) No Toil air filter maintenance kits
      (1) No Toil air box cleaner
      (1) No Toil bike wash kit
      (1) No Toil chain lube
      No Toil is the ONLY completely biodegradable & non-toxic air filter treatment. 🌎 Its tacky plant-based filter oil locks in dirt and is only released with No Toil's proprietary filter cleaner powder. It cannot be washed away with water or harsh solvents. #ditchthesolvent
      To enter for your chance to win, login using the giveaway widget below. It can take a few seconds to load, but if for some reason it doesn't, tap HERE.  Also, you are NOT required to have a Facebook account to enter, only a valid email address.
      Login with your email OR Facebook to be automatically entered, then check out the optional bonus entry options that increase your chances of winning!
      Enter the No Toil Industries Product Bundle Giveaways!
      No Toil's air filter maintenance system is easy-to-use, biodegradable & non-toxic.
      Ready-to-ride, pre-loaded with No Toil air filter oil.
      Ride extreme conditions? The No Toil Extreme air filter is up to task.
      No Toils' Super-Flo air filter kit is ideal for 4T riders looking for max HP & throttle response.
      Everything you need to get your airbox and exhaust squeaky clean.
      No Toil loves air filter maintenance, but believes your chain is important too!
      Hey, that's it. The giveaway entry widget is up there ☝️
    • By Jason P.
      Hello fellow 2020 KLX300R owners, I hope you're having a good day. I am planning on purchasing a 2020 KLX300R of my own but before I do, I need to know about maintenance intervals. I know that the less powerful KLX230R is pretty much "bulletproof" in terms of reliability if you keep up with engine oil changes, cleaning the air filter, and lubricating the chain. The 300R is much more different though since it has 4 valves instead of 2 on the 230R, liquid-cooling as opposed to air, and a DOHC compared to a SOHC. How does this affect maintanence and reliability? Is the regular oil change, filter clean, and chain lubrication enough? Thank you!
    • By TherealSisu
      I'm almost 17 and looking at getting my first dirt bike, not too powerful or expensive.
      Where I live there's only (at the moment) one CRF 150F for sale versus a lot of 150Rs. From what I have heard the 150F is way more reliable and cheaper to own.
      Is it actually a big difference or should I just get a 150R if I can't buy the 150F?
      also the bikes I've looked at are 2005-2006 around 1200-1400€.
    • By kjtroyan
      2008 crf450r- Attached is a picture of deep grooves in my crank case from running too wide of an o ring chain. This is after 4-6 hours of total engine riding time. The groove is probably 2-3mm deep.  I realize the mistake I made and I have switched to a Narrow DID x ring chain. My question is. How can I repair this to prevent further damage? I was thinking job weld and a piece of thin aluminum or steel sheet metal. Maybe a washer in welded to the case? How thick is the case in this area and should I be worried about it cracking in the future?
