FIVE DIRT BIKE BELIEFS: FACT OR FICTION?
MXEditor
Even though our sport isn’t that “old” compared to some others, it has its own share of beliefs, some rooted in truth and some not so much.
In this feature we’ll be looking at different things riders and racers say about off-road motorcycling and try to determine whether they are true or false…or maybe somewhere in-between!
We sat with a few of our staff and asked them to name a few of the pervasive and persistent beliefs that they felt were indicative of the theme stated above, so lets look at each of them and see what we find out.
(Editor’s note: In researching this article, many that were interviewed gave very long technical explanations to our questions. We normally edit these answers for the sake of length and clarity, but in this case we let the responders give longer, technical answers. Part of this is due to reader demand so let us know if this “works” for you, the reader, thanks!)
#1 HAULING YOUR BIKE WITH FORKS COMPRESSED BLOWS YOUR SEALS
We’ve all seen different and sometime creative ways of transporting off road motorcycles but the ubiquitous tie-down strap arrangement has to be most common. This involves attaching tie-downs to the handlebars and cinching the forks down until they don’t move…there’s no science to how far to pull the forks down and everyone seems to do it a bit differently so right away you have differences in technique and implementation.
But is this a good way to blow fork seals? Is this phenomenon fact or myth?
Obviously anytime fork seals are under compression they are being stressed, let’s agree on that. But are they stressed enough to help blow the forks seals?
We spoke with James Burry of Risk Racing who had this to say:
“Your forks and fork seals are designed to take big hits, and therefore a lot of pressure when that happens.  Of course that is for short period of time, which they are good at.  The issue occurs over time, and is compounded when people over tighten their tie-downs.  A new fork seal is soft and will “stretch and flex” with the added pressure, as there are designed to do, but as they age they lose their flexibility and their ability to hold the pressure over long periods of time.  Eventually they will leak.  It is best to just leave them at rest or reduced pressure during transit if possible.”
OK, so keeping them stressed all the time can be an issue…how about using a fork brace that sits between the front tire and underside of the fender?
He continued: “The fork brace can help protect your fork seals because it prevents the fork from being over compressed and therefore limits the overall pressure.  When the fork brace is squeezed between the fork and the tire, the tire becomes the “flexible” member of the group rather than the suspension.  The real benefit to the brace is to prevent the bike from compressing during transit.  If you use tie-downs, and are nice to your suspension by not over compressing, then you stand the chance for your suspension to compress further during transit when the vehicle hits a “g-out” style bump.  This can compress the suspension more causing the tie-downs to lose tension and possible become disconnected from the bike or vehicle…end result is a bike flopping down the highway.  So, the fork brace is easier on fork seals because it allows the user to tightly secure their bike without over-compressing the front suspension, and also prevents the suspension from compressing any further during transit.
OK so fork braces are a good accessory to use with tie-down(s) to prevent additional stress on the form seals, except when hitting a large bump which can loosen the whole arrangement. What about the newer stationary systems that attach to the floor of the carrying vehicle and to the footpegs or frame of the bike?
Burry continued: “The Lock-N-Load system responds to all concerns when transporting a bike.  It reduces pressure on the fork seals, limits the travel of the bikes suspension (and) eliminates the potential for a tie down to break. Of course the trade off is the (expense compared to) a cheap pair of straps.”
On this same subject, we had a look at two other factors that may play a role in raising or lowering pressure during transport and we came up with two items to explore:
Atmospheric Pressure - In theory, air pressure in your fork tubes stays static if all environmental factors remain identical, but that doesn't happen in the real world. One factor would be the altitude at which you transport the vehicle, because as you increase your height geographically, atmospheric pressure decreases. For example, atmospheric pressure is approx. 14.7 PSI at sea level, but drops drops to about 10 PSI at 10,000 feet...
So that means atmospheric pressure increases with decreasing height! So the pressure in your fork tube can rise or fall depending upon your location, but not dramatically at no more than a 5 PSI swing for 10,000 feet. So tie down solutions that exhibit static pressure in the fork tubes can have that value actually increase, causing even more stress on the seals.
Air Temperature - It doesn't immediately come to mind when thinking about suspension components except at the pro level, air temperature can also contribute to stress on fork seals when under load as in transporting.
Temperature affects air pressure by causing the air to either become more or less dense, which expands or lowers its pressure. Warm air is less dense than cold air, and as air becomes less dense, its pressure increases.
Standard rule of thumb for evaluating pressure to air temperature ratio is tire pressure will increase by 1 PSI for every 10 degrees of ambient temperature increase, and this is true in reverse as well. So it's not a huge figure but between it is a contributor to elevated (unexpected) fork pressure.
The pressure in your fork tubes can increase as the temperature rises, and this again can cause additional pressure in the fork tubes causing even more stress on the seals.
Conclusion: Pressure on fork seals can be high and for long periods of time when transporting a motorcycle using the tie-down method, potentially leading to premature failure, and using a fork brace or stationary transport mechanism can diminish or eliminate this pressure extending the service life of your fork seals.
#2 HANDGUARDS CAN BREAK YOUR ARM
Riders and racers we spoke to had strong opinions about this statement but lack of real world examples hampered their arguments.
First of all let’s define what we mean by handguards…this would be a wrap around metal or plastic “bar” that stretches from the end of the handlebar around the rider’s hands and attaches to the front of the handlebars, creating a loop.
This “loop” of metal is the culprit at hand so to speak, in theory and in practice it can create a situation in which your arm can go through the loop and then be at the mercy of anything else that happens. You may leverage your arm and snap it…maybe get your arm caught in there as the bike drags you into an injurious situation - the possibilities are endless when you think about it.
But does it happen often? Is this phenomenon fact or myth?
Since we didn’t actually know any riders who this has happened to, we searched the Internet for some clues. Many of the responses came from threads just like these:
https://www.thumpertalk.com/forums/topic/556585-handguards-causing-broken-arms/
https://www.thumpertalk.com/forums/topic/645172-handguards-and-broken-wristsis-this-an-urban-myth/
The theme of these threads seems to be “it can happen…but usually doesn’t” and most riders/racers have never seen these happen…and if they have, it may have been due to other factors such as mounting the guard too high or so loose it wrapped around and “bit” the rider.
Conclusion: The myth of handguards being the culprit in broken arms and/or wrist injuries just doesn’t hold water. We’ve spoken to countless racers who’ve admitted they’ve never seen this happen. We aren’t saying it doesn’t ever happen but the notion that these components are so dangerous because of it just isn’t true, and most racers agree that the benefit of the guards far outweighs the risk of injury by not running them.
#3 GOTTA HEAT-CYCLE THE ENGINE TO SEAT THE PISTON
We just received a big bore 2-stroke engine back from our builder and we asked him…”how do we break in this engine, and is there a certain way you like to do it?” and as with almost everyone we’ve spoken to, he has his own way to “break in” the engine. But with today’s tight tolerances, computer machining techniques and improved quality control is this really necessary? How different are the requirements for a 2-stroke vs. a 4-stroke?
We figured asking some engine builders would be the best way to find out as they deal with this question all the time.
One of the best responses we got was from Tom Zont of TZR Racing and his extensive insight and experience dictated that we publish his comment in entirety.
Tom Zont: “The need to methodically heat cycle a new engine has changed over the years. With better materials being used, higher precision in the manufacturing of the parts themselves, and with most engines being liquid cooled, lengthy and methodical break in procedures are generally not as necessary on today's engines as they once were. This is particularly true with the newest 4 strokes.”
“On any new motor, 2-stroke or 4, parts like pistons, rings, valves and cylinder walls will indeed ‘wear in’ as the engine is run. The piston rings (contact) against the cylinder wall is an area that has a measurable effect on overall output being as good as that engine can be. There are some differences between 2 and 4-strokes in what is critical during the initial ‘break-in’ however. “
“On modern 4 strokes, there is no need to "seat the piston" thru methodical heat cycling. With electro-fusion/Nikasil cylinders, ultra precision cast and forged pistons, and the relatively uniform temperatures achieved with liquid cooling in a cylinder with no ports, damaging a 4 strokes piston is extremely hard to do as long as the engine has oil in it of course. With so much quality oil being splashed and pumped to lubricate the cylinder walls and piston skirt, there is really no need to ‘seat’ or ‘wear-in’ a 4-stroke piston when new. The rings themselves will indeed ‘wear in’ to the cylinder walls over time, creating a better ring seal at the 1 hour mark than when they were brand new. This will happen regardless of how many times you warm up the motor and let it cool (heat-cycle). We have and can put a brand new 4-stroke motor (bike) on a dyno, and as long as we simply warm it up to full operating temperature, we can run it wide open to measure its power output and not damage the piston or rings. The power will go up slightly but measurably, as the parts like the rings wear-in, and the engine becomes a more efficient air pump.“
“On a modern 2 stroke however, there is some merit into ‘heat cycling’ a new piston. Because of the elaborate casting of the ports throughout a 2-stroke cylinder, the temperature of the cylinder itself is not as uniform as in a 4-stroke. Temperature variations mean that the cylinder will not expand as uniformly as the engine temperature changes. This can lead to parts of the cylinder that do not expand as much as others. (Aluminum expands dramatically as its heated) You also do not have as much oil available to cushion moving parts as in a 4-stroke. Three to four ounces of oil per gallon of gasoline is not much when you think about how long that one gallon will run your engine for. With less oil to stay between the moving parts, the chances of parts rubbing together without adequate lubrication to prevent seizure or heavy wear are increased.”
“We want the piston to be very close fitting in the cylinder bore. That way it cannot tip or rock back and forth, so the rings will stay tangent to the cylinder walls and create a good seal. That new, exceptionally tight fitting piston is at risk for seizure against the cylinder walls if it expands too much or too quickly, in comparison with the cylinder that it is in. This is where the heat cycling can be a benefit. By methodically warming the piston up to incrementally hotter temperatures, we would gently, GRADUALLY scuff away material where the piston is running out of room to expand. The key here is the very gradual ‘scuffing’ away of material, ONLY in places where it has run out of clearance. Running a new 2-stroke engine for short periods, each time slightly longer, getting it slightly hotter than the last time, can indeed "seat the piston" gradually enough so as to prevent a full on seizure the first time the engine reaches maximum temperature under the most severe operating conditions.”
“The term ‘seating in’ is more appropriate to the pistons rings themselves, and I prefer the term "wearing in" when referring to the piston. ‘Wearing in’ the piston essentially means that you will allow the new piston to very gradually rub away areas on its skirts that become too tight in the cylinder bore because of un-even expansion, both of the piston itself, or the walls of the cylinder. Heat cycling is a cautious way of letting this process happen in a manner that is gradual enough so as not to have what we call a piston seizure. By engine builder’s standards and terminology, a piston seizure is not always a piston that becomes completely stuck, melted or wedged in the cylinder. A heavily ‘scuffed’ piston skirt on an engine that never quit running can still be considered ‘seized’ by many, to varying degrees anyways.”
“Many factors involved can influence how critical it is to ‘heat cycle’ a new 2 stroke engine to ‘wear in’ the new piston, and too many to list here. But as a general rule, it would never hurt anything by heat cycling a 2-stroke a few times before running it at full race pace. Don't confuse ‘heat cycling’ (to break in or wear in new parts) with a standard "warming up". Every modern 2 or 4-stroke should ALWAYS  be warmed up gradually, as close to full operating temperature as possible, before going wide open down a holeshot straightaway. Letting all internal moving parts expand to their normal operating size somewhat gradually, will reduce wear on parts that are expanding at different rates. Not just in new engines, but for their entire lifespan.”
Conclusion: The belief that “heat cycling” your engine before full operation is important, even more so for a 2-stroke versus 4-stroke. It’s not detrimental to your new engine and can result in an engine that will run longer and realize its full performance potential.
#4 OFF-ROAD BIKES REQUIRE THE HIGHEST OCTANE FUEL AVAILABLE
Most of us love our motorcycles and want to give them the best fuel available…but what does “best” really mean when it comes to off-road motorcycles. With bikes like Honda’s CRF250R coming stock with over 13:1 compression, this is becoming more important.
Higher octane doesn't give your bike more power, it burns slower to avoid detonation in higher compression engines. Detonation is a very destructive force in an engine and should be avoided at all costs. You can find more in-depth reading on octane HERE.
What does the manufacturer of your bike recommend? This is extremely important because all engines are different. You must base your decision on what grade gasoline to use by knowing the minimum grade recommended by the manufacturer. If they don’t recommend high octane gas for your bike, then you're just throwing away money by using it…there is no real benefit…except if you detect pinging or knocking when using lower octane gas, that would require you raise the octane rating to compensate.
Conclusion:  The answer here is a lot more evident than some of the other items we’ve covered in this article. Always use the fuel with at least the octane rating specified in your owner’s manual. Using a higher grade is of little detriment in most cases except to your wallet…but using a lower grade that could encourage detonation can do a lot of damage and why risk that for the sake of a few pennies per gallon?
#5 BANGIN' OFF THE REV LIMITER IS BAD FOR THE ENGINE
If you’ve been to the local MX track in the last few years or watched Arenacross/Supercross on television, you’ll hear riders and racers revving their 4-stroke bikes right up to the limits…until the rev limiter kicks in and interrupts the ignition circuit, lowering the revs and then allowing the circuit to re-energize and do it all over again, causing that familiar 4-stroke “panic rev” sound that used to associated mostly with trying to lift the front of your bike before impending doom.
Justin Barcia comes to mind…
Now many riders just do it for a variety of reasons that we won’t get into here…what we want to know is whether it’s bad for the engine? It sure sounds like it would be…but we see racers run their bikes like this constantly during a racing event without seeming to cause damage…is it because of the rev limiter?
We’d just assume that this is a bad way to run your engine, bouncing off the rev limiter when not needed, but many newer riders use this technique and report that it actually helps them concentrate and stay focused, almost blurring out their opponents and the outside world with this wall of noise.
So we reached out to some a few professionals who have a better insight into the specifics of how and why this technique can affect your engine.
First up was Brent Kirk from Fastheads, who crafts amazing motocross cylinder heads and valve train components for all motorcycle brands. They offer world class precision seat machining, modifications, porting repairs, and general head servicing, so we figured Brent would be one good guy to ask about this.
Brent Kirk: “Rev limiters keep the RPM’s within the limits engineers have designed the engine to operate. On 4-strokes the valve train is the most crucial factor in setting limits for RPM (because) valve springs are limited to how high of RPM they can efficiently be operated. At a certain point they can't keep up with the speed of the valve and cam and this is due partly to harmonics. As a shock wave flows up and down the length of the spring and can actually deaden it ability extend and when the cam can not control the valve due to the spring, all kinds of devastating problems can occur. Valve float is when the valve is moving so fast that it slings itself of the end of the cam lobe and if it doesn't meet up with the back side of the cam before it closes, the valve will slam the seat and bounce. During this uncontrolled time valve shims can fall out, valves can break along with lifters, retainers, keepers and springs. The best engineered coil springs won't perform much over 14,000 RPM.”
Kirk continued: “On a stock 4-stroke race motor engineers limit the RPM’s so the valve spring keeps the valve train under control and within its operating range…this done by retarding the timing when the crank reaches and per determined RPM. We normally only see engine failures when the valve train is tampered with or not maintained.”
Next up we spoke with Derek Harris of Harris Performance Engineering, who specializes in building custom racing 2 and 4-stroke engines in his state of the art performance shop located in Marion, Texas.
Harris: “With the involvement of the factory teams into amateur racing at an aggressive level, (Justin) Barcia was signed to a large salary with endless bikes, equipment with a full-time mechanic.  He would rotate practice motors once every 2 weeks or so, or more frequently if it broke. Matt Biscgelia was on the same program, and while Matt doesn't ride like Justin - it was at least once a month he would have pieces thrown out of his cases....Kids saw Barcia and the video coverage at the same time and the rest is history.”
“So a production motorcycle IS built to run on the limiter all day, however, not many people follow OEM service manual suggestions. Example; Honda suggests cranks every 15 hours with full engine inspection/tear down on their 250F. Parts are stressed proportionally to RPM.  The more RPM, the more stress. So if you spend time on the limiter - the bike will wear out more quickly. What's most sad is all the engines with exception of the new KTM 250F's do not make good power at the limiter.  It's faster to shift before then.”
“In summary - the more you rev your bike consistently - the shorter it will live. “
Conclusion: The belief that “hitting the rev limiter all the time can ruin your engine” has some basis in truth. Yes, rev limiters are set to kick in before potential damage to the engine occurs, but only in a perfect engine. Any weakness in engine components is magnified and there is a much higher potential for failure of these components at high RPM’s.
:prof: What do you think of this article? Where did we hit? Miss? Have something to add or correct? Share your thoughts in the comments section below.
  • Like 28
User Feedback
Recommended Comments
I've been riding since the early 70s and I've never heard the first one.  I've heard plenty of times that it will sack your springs, that is a common misconception, but in all my years I have never heard the myth that it would blow fork seals.
As for bark busters, you must not get out much.  There are a number of tales of broken wrists and arms on a long thread on this website, I personally know a couple people it has happened to.  You are plain wrong in outright dismissing this as a myth, it doesn't happen very often, but it CAN and WILL happen.  If nothing else just look at the physics of what is going on and Murphy's Law, someone is going to get their arm caught in there even if you never met any one it has happened to.  You conclusion is invalid even without any anecdotal evidence on your part.
Edited by cjjeepercreeper
Share this comment
As for bark busters, you must not get out much.  There are a number of tales of broken wrists and arms on a long thread on this website, I personally know a couple people it has happened to. You are plain wrong in outright dismissing this as a myth, it doesn't happen very often, but it CAN and WILL happen.  Y If nothing else just look at the physics of what is going on and Murphy's Law, someone is going to get there arm caught in there even if you never met any one it has happened to.  You conclusion is invalid even without any anecdotal evidence on your part.
Pretty sure it says just that: ;)
Quote
  • Like 4
Share this comment
Yeah, I just get all wound up about this subject.  I won't run them and no one I know will either, I've had a broken wrist and it sucks.  My "flag" type handguards have saved my fingers several times, they fold around my hand.  I recently broke one and need a new pair, but they do work.
Share this comment
One other comment.  Concerning octane, good advice.  But, no matter what you are using keep your ears open for the sound of pinging.  Not all gasolines are created equal, what is labeled 92 octane at one gas station may equate to what is labeled 89 at another.  You never know.  I try to stick with one brand if at all possible, we have 2 CRF450Rs and a big bore higher compression XR250R, all need premium fuel.  The other 2 bikes will run on about anything, a stock XR400R and a stock TTR230.
Share this comment
Most of my fingers thank me for running them. The scars on the guards are all the proof I need. And, I have had my front brake lever pushed when a pair of non wrap around "handguards" flexed rearward. Almost crashed on that one. They're Ok for light brush or roost, but little more.
  • Like 2
Share this comment
3 minutes ago, Bryan Bosch said:
Most of my fingers thank me for running them. The scars on the guards are all the proof I need. And, I have had my front brake lever pushed when a pair of non wrap around "handguards" flexed rearward. Almost crashed on that one. Ok for light brush or roost, but little more.
I may someday run them if I ride in an area with trees that are closer together.  But even in the mountains its not really that tight like it is in forests in some other parts of the country.  But, I do admit, they do prevent broken levers, or even this :crazy: :
Share this comment
I'm looking down at the scars on my arm, and I wish that the bark buster thing wasn't true, however it's something always in the back of my mind because I was one of the rare few. I will say however, that I believe the bark buster design was completely at fault, and not the bark buster itself. It appears that the type of bark buster I used then is largely no longer in production.
The kind I had used before are very similar to what you'd find today, however they were 100% plastic -- as in there was no aluminum running through the center. The lack of rigidity would deflect bumps and branches, but in a high speed impact, they would simply fold in on themselves, and that's exactly what happened when I broke my arm. The bark buster "cup" folded in on my hand and spun around 180 degrees, snapping both my radius and ulna, requiring multiple surgeries on both.
Had I had an aluminum backed bark buster, this simply wouldn't have happened. Back in 1999, bark busters weren't exactly standard equipment and necessity as they are now unless you were a "hardcore kid", and I cannot recall the last time I've seen a set that were 100% plastic without some sort of aluminum running through them. I have a feeling I know why.
Share this comment
malignity, fair enough and for me the rotating 180º is something I hadn't considered. Without the guards, what would the likely damage have been? Smashed fingers etc? Were the ones your talking about like the ones on my Husky?
Share this comment
1.    If you have fork bleeders, just bleed the air after compressing them and you have no need to worry.
3.    The 2-stroke advice may have merit.  In a 4-stroke?  Get it nice and warmed up before riding it hard (I like to let it idle for a few, then go putt for a few, which also gives some time to make sure everything sounds/feels/runs right after putting it back together) then ride it like you stole it for maximum power via optimum ring seal.  It says you can do this above, but neglects to tell you that you should.
4.    It's probably also good to point out that if you have relatively easy access to Ethanol-free fuel, use it.
Share this comment
This exactly, I am a mechanical engineer and can tell you that the fork seals thing is BS, the only thing you are doing by compressing the forks is causing previously damaged seals to leak. In this application the seals are pretty much entirely damaged by debris and fork tube nicks, not the 20 PSI that got built up when the bike is tied down.
Same deal with bark busters, people get broken by them all the time, I have hurt wrists twice running them due to big impacts jamming my arms through them.
Its not hard to find people who hurt themselves with them in real life, just most aren't going to argue about it on the internet where everyone and their brother is driving in to trees all day and being saved by the all powerful bark busters.
Share this comment
On the road legally since 1968. Hauled in pickups and on trailers. Never had a strap come loose, never had one come off - nada. Compress forks an inch or two and good to go. Attach tiedowns so in case of a big bump they can't unhook. Bikes from Kawa 90 to Geezer Glide HD's. Hitting a bump - in your truck or on a trailer - which has suspension of its own - is as damaging as hitting a bump riding the bike !!! Horse Hockey
Share this comment
How good do your rate for fork suspension?  I find that the likelihood of a hand coming off the grips and going forward is greatly dependent on the quality of the fork damping.  Same with headshake. If the bike chassis or suspension setup is such that it brings on headshake easily, then it makes wrap-around guards more risky.
Share this comment
Once was from pegging a loose babyhead in whoops then landing swapped out, the other was from the front wheel catching in a rut in a motocross track and slamming the bars sideways. These were on two different bikes.
Share this comment
Good article, things to think about. Lots of opinions. The rev limiter thing was pretty funny. Uh yeah that is going to be an issue at some point. Waaaaaaah nah nah nah nha nah nah nah nah nah. Lot of guys in SX doing that, especially the 250s from what I heard sitting 6 rows up from the track in Seattle. Of course if you've got a spare motor or two in the truck...
Share this comment
Good article! You definitely got some differing opinions here in the comments, but you stirred it up anyway. Re barkbusters. I've run them in Baja for a long time, and also have them on my singletrack bike. I have a habit of hanging on way past the point of no return, and I had a barkbuster get spun around on my throttle wrist one time, and break some bones. But I've also have gotten out of shape in the woods and smacked a tree more than once, and was very thankful for them!
  • Like 2
Share this comment
After "karate chopping" his wrap around handguards a couple of times during minor get-offs, MXJunky has since discontinued using them in favor of the plastic, non-wrapping handguard type.
Share this comment
Handgaurds
Though I think the injuries reflected on this post are probably a minority, I do think the problems some have had is concenring enough for me to reconsider my use of the plastic wrap arounds. I've always thought having them was a no brainer. Now my brain knows better. This discussion is very enlightening.
Edited by MotoXImage
Add context
Share this comment
We all like to think we ride our offroad bikes twice a week and run 2 tanks of gas through them every time we ride but the truth is our bikes tend to sit for weeks or months.  Here in Arizona that is really bad.  Our pump gas contains ethanol that makes a mess of carburetors, petcocks, and gas tanks.  The ethanol pulls moisture out of the air and causes the aluminum to corrode and the gas tank to rust or the plastic to swell and crack.  Ducati had a recall on gas tanks swelling due to the amount of ethanol in our gas.  I cleaned the carb on my KTM EXC so many times that I wore out the jets.  I run 100 octane Torco race fuel, it's not priced too bad but it saves on cleaning carbs and replacing expensive parts.  So yes not all offroad bikes need high octane fuel to run right but it will save time, money, and parts if you live in a state that has ethanol in the gas.
BJ
Share this comment
Most likely your bikes running a little cooler due to the changed flamefront. I'd rather go in that direction than the other way. So in the end, not only are your fuel parts cleaner, your bike actually has added engine life because it has less contaminents cooking into the combusting chamber. Less likely to stick rings, reduced friction etc. As a dual sport rider I'm more vulnerable to spotty gas pump fuel. Add that to the EPA's stingy fuel curve which makes todays bikes run very lean. Which leads me to ask this. Which gas stations have the best premium gas?
Share this comment
Bark busters, are the greatest thing since sliced bread. I spent many years riding enduros in Ky, Tenn, Indiana and busted every knuckle on both hands. When bark busters came along, never again did I bust one! You guys running them flimsy plastic sows ears are fools, or ride in the west where there are no trees closer together than 5'. If your breaking wrists, then you better go back and learn how to ride. Never had an aluminum bark buster ever rotate on my bars. Wrist injuries would be a good topic. All the top GNCC racers seem to have wrist injuries. (Why) I'm guessing it's because they don't tape their wrists.
Share this comment
old stories die hard, they mostly finally die with the guys that dreamed them up.
1    compressed forks on the way to a riding area are not harmful to the seals,  prolonged compression like leaving it all winter will shorten the life of the fork springs.  15 year old forks seal are likely to fail under any pressure and your springs are already sacked.
2.   you hang around the rev limiter and you will pay...............for sure.   You do not have a perfect motor, don't go there.  Hang around the beginers in 250 class,  lots of rev limiter  tears.
3.  heat cycle the two stroke is correct,  bigger the piston the more critical.  No one makes big bore two stroke cycles, maybe an occasional 300-400 250 kitted.  check the really big bore snowmobile engine builders and they will supply you with their heat cycle break in procedure.  125 or 250 mx bike.........no big deal.
4 bark busters..................no accounting for odd ball accidents.  Serious accounting for racing tight tree woods riding, you want to win, you protect your hands...............they don't heal.
we must of finally put the rest the " more oil in the gas the more the hp " .........tough old stories.
Share this comment
Bark Busters have saved me far more than they've ever hurt me.  I don't race and I don't jump, but the trails I ride have tight gaps that I have to shoot through and I wouldn't even think of doing so without a good buster mounted up.  Just had this conversation over the weekend with other riders.  My bars are cut down to 27.75in, effectively making them into minibike bars.  Trees and dumptruck-sized boulders so close that it ups the "pucker factor" when going through them at speed.  Went riding in a new area this weekend and took my boys' stock 250x and my 300EXC.  Setup is everything and immediately noticeable when I rode the 2 bikes back to back, especially through the boulders.  Both had busters, but my cut bars felt so much more comfortable in the tight conditions.  If they didn't already have them mounted, I would've been crawling through the tight spots in Granny-low!
I run the highest octane I can get (which isn't very high in rural Montana).  Our 1-pump town only sells 85 octane, so I try to fill up on the road to our riding area an hour away.  Like previously mentioned, you'll hear it when it happens.  Back off the throttle or downshift to lighten the load.
Share this comment
Fuel/Ethanol/Octane; To help with carb corrosion after the last ride turn off fuel and run the carb dry, otherwise the fuel and ethanol evaporates and leaves the H2O that's responsible for the corrosion.
Pump octane = R+M, "R"easearch number is the result of testing a small engine near idle, and not a number associated with race fuel but a good fudge number for some big oils to use to bring up the "octane" of a fuel that uses a low "M"otor number component that you will find associated with race fuels and is what makes power. And "Octane" isn't what the formula really is, it's the AKI or anti knock index. So R+M/2=Octane, if you want to really know how much M component in the fuel see how far you go on a tank of the A EM PEE EM stuff and for a few cents more P/Gal try one of the more $ brands and go many miles more, honest! and keep combustion chamber cleaner.
And.... the valve slams closed AND BOUNCES? That's a resilient valve and seat but the embellishment to convey the point only makes one question the validity of the statement if one is not confident in their understanding the physics involved (as do the grammatical errors) otherwise a good assessment.
And the handguard deal, I guess you could say the sharp points on foot pegs can cause nasty cuts if your foot slips off.... if it's a concern grind the points off and don't put hand guards on your bike but good filler for an article I suppose.
Share this comment
I call bs on the blown fork seals....yes oil can get past the sealing lip, but what physical damage is done? They’re not “blown” as in torn or broken. A healthy seal will actually seal harder with pressure. Many times I’ve cleaned the sealing surface and continued using them. It is however very possible that old seals become hard and leaky requiring replacement.....this applies to any seal or gasket.
Share this comment
  • Similar Content
    • By Jkirkland
      TLDR: Valve lash is increasing considerably during break in, does this mean it's eating my cam/rockers or should I adjust and continue?
      Hey guys. I need some advice on my 96 XR600R break in that is maybe not going so well. I guess I'll start with a quick history of the bike...
      I swapped it over to a Kansas titled XR650L frame and registered just in time to leave for a week long trip to Colorado with some buddies.  We went down by Telluride/Ouray and rode a bunch of jeep trails.  It was blast and the XR ran great.  However it burned oil like CRAZY! I probably put 6 quarts of oil in it over that week, and my buddies said they could see it smoking like my 2 stroke.  I almost made it home too, about an hour away she gave up, would not run and made clunking sounds when I tried to kick it over - was not locked up though.  A buddy came and saved me.
      Upon tearing down the motor, I found that the top end all appeared to be fine.  I was surprised to find that what I thought was a stock motor had a 100mm JE 10.5:1 piston... Evidently it had been detonating on the highway while I had my music plugged in and could not hear it.  Damn.
      I sent the crank off to Ken O'Connor racing and ordered a Wossner 100mm 9.3:1 piston.  I am planning to take this bike to baja and need it to run on whatever kind of gas I can get, so I figured I'd go for the lower compression piston.  After rebuilding it I put it, I mounted it in the frame and got ready to break it in.
      Here's the details on my bike setup and break in:
      Maxima 15W-50 Break-In Oil - High Zinc.  Website says it is safe for wet clutches and motorcycle transmissions... Jetting: 155 main, 68 pilot, 2.5 turns out on fuel screw. Stock CDI; UNI air filter; Stock header with inlet welds ground & FMF powercore muffler Put 1 liter oil in frame, 1 liter oil in through one of the valve inspection covers.  Waited several minutes for the oil to all drain to the bottom end. Cycled kick starter over until I saw oil coming out of the external line at the head.  Bolted it up. Motor had sat for ~3 weeks between assembly and start up. Didn't add oil until day of start up. Upon starting it up initially, it was making a loud tapping sound. What the hell? It ran maybe 15 seconds like this; I shut it down and found the valves were set loose.  Could have SWORE I set the valve lash properly with the motor on the bench.  Oh well; reset lash and tried again.  Sounded much better after this, I ran it for maybe 5 minutes varying throttle from idle up to 1/4 throttle or so.
      I let the bike cool down for a couple hours and then did a similar exercise.  Rode it up and down the street a few times, seemed to be either running lean or missing? Didn't really seem right.  Didn't want to start after this and the lever kicked back real hard on my leg several times.  Brought it back in the shop; found that the valves were pretty loose again.  Intake went from .10mm to like .18 or something like that (.003" to .007").
      Lash should not increase during break in, right? Does this mean I am eating through my cam or rockers? Cam, rockers, valves, springs, etc. are all the same parts as before rebuild.  I did lap valves.  Is this a normal thing that I should not be concerned about?  I have done full rebuilds and top ends on other bikes and never experienced this.  I am planning to remove the valve cover and investigate later tonight.
      I will post updates later if nobody advises me otherwise before I tear it down in a couple hours.
      Thank you for reading and for advice.  Any knowledge/time is greatly appreciated.  Sorry for the long post.
