GET DIALED IN: Suspension Tips from the Pros!
MXEditor
As off road motorcycles have evolved into the amazing machines they are today, suspension technology hasn’t been left behind…but many riders still find the process of getting their bikes “dialed in” difficult at best, almost impossible at worst.
We spent time talking to the people that understand these complex systems, experts who’ve spent their whole careers working with suspensions, and we’ve convinced them to share with us some of their tips (and tricks) when it comes to setting up your bike for optimal suspension performance.
Most of these “tips and tricks” are easy to implement and most of these procedures you have probably already performed. But getting all of them to work in unison is the key to a well set up machine. And when it comes to riding off road bikes, “Suspension is the key to being fast and smooth.”
Suspension experts who offered advice for this ThumperTalk WIKI feature are C-Cycle, Factory Connection, FCR Suspension and RaceTech, and we want to thank them for their input.
1) What common mistakes do riders make when setting up their suspensions?
In talking with the four vendors above, they seem to all agree that not setting the sag to match the rider’s weight was the most common mistake made by off-road motorcycle pilots (we cover this later in this article).
Other common suspension mistakes that riders often make are:
Inaccurate compression and rebound damping adjustment(s)
Setting suspension to stock levels before custom adjustments are made
Incorrect spring/air rates for rider weight
Pinching forks legs at the axle
Insufficient grease in linkages
Drive chain too tight
Poor axle alignment
2) Can you describe the best (and simplest) way for riders to measure their sag?
Bob Luketic at FCR Suspension offered this explanation:
Take a measurement with the bike on a stand - typically the measurement is taken from the axle straight up to a solid mark on the fender.
Make sure these 2 points of reference are solid and that you measure from the exact same spots. You’ll need to write this number down.
Take the bike off of the stand, give it a few nice bounces to free up any stickiness in the linkage etc, and take the measurement from your 2 spots again, you will subtract this number from the 1st number and now you have your rider sag.
It’s always a good idea to do this with your gear on or allow for the extra weight of your gear if you’re in street clothes.
As a baseline if you are a 65 rider race sag should be 70-75mm's…an 85 rider--85-90mm's, and 125 and up 100-120mm's.
Most tuners we spoke to felt setting sag was so important, they have put instructional pages on their sites to fully explain the procedure:
RaceTech Sag Setting Page
Factory Connection Sag Setting Page
As a side note, a new product was released that can make measuring your sag on your own even easier, and it’s been reviewed by Team ThumperTalk. It’s called the Motool Slacker Digital Sag Scale…and Motool claims: ‘Rather than using an inaccurate mechanical sag scale, having to recruit a friend, or worrying if the measurements were taken correctly, the Slacker sag tool simplifies the process.’
3) Where should riders begin when tuning their new (stock) suspensions?
The tuner panel seemed to agree that the first thing to do is consult your owner’s manual and set the suspension to the stock settings. This includes setting spring rates and setting the sag as discussed above.
In this regard, Steve Ross at Factory Connection noted that “initial clicker settings are usually centered in the middle of the adjustment range to allow maximum adjustment in order to tune softer or stiffer”.
The RaceTech Staff added this advice: “The general rule of thumb is to start with proper spring rates. Without proper springs for your weight, the balance of the bike will be off and you won’t be able to get the sag numbers where you need them. The other thing to not be overlooked is the quality and freshness of the suspension fluids. Not all are created equal and fluid that needs changed will cause a loss of damping.”
4) What is the simplest, cheapest upgrade riders can do to their suspensions?
The experts agreed that having the correct spring rates are the best and cheapest upgrade you can perform, followed by fresh, clean fluids in suspension components and (again) setting your sag correctly.
5) What is the most common upgrade requested by customers?
Fork rebuilds with re-valving are the most popular upgrades all these tuners perform, and replacement springs are also in high demand. RaceTech Gold Valves were also mentioned by more than one vendor.
6) Can you offer any specific tips for motocross riders?
The tuner panel noted that a balanced bike is what riders should be striving for when addressing motocross suspensions. Let’s hear what they had to say about motocross riders suspension tuning.
C-Cycle: “Motocross requires good balance front to rear. Each machine brand has specific tuning for handling attributes.”
Factory Connection: “Motocross riders need to find the right balance between plushness for the braking and accelerating bumps, but still having enough bottoming resistance for jump faces and harsh landings. It’s OK for the suspension to bottom a couple of times a lap as long as it’s not too harsh. In-fact bottoming is good as it’s an indication that all the available travel is being utilized.”
FCR: “Stay up on your suspension maintenance. We see so many riders that are riding on suspension that’s so worn out that it’s really dangerous…an oil change and service goes a long way and can catch anything that may be getting ready to fail. Some bigger companies will tell you to service it every 20 hrs…when we see a suspension that’s been beat on for 20 hrs it (usually) needs a complete overhaul and it can be costly. We recommend an oil change and check up every 10hrs, it's super cost effective and really is the best way to stay safe and to keep that machine on the ground!”
RaceTech: “For motocross we focus on a fork setup that is firm enough to not dive and deal with braking bumps and chop. We need good bottoming resistance for jump landings all while providing a plush feel in the hands that tracks up nicely. The shock setup for motocross requires a plush initial setup for traction and we want to keep the tire tracking the ground in acceleration chop. While still being plush initially, we need a shock that’s firm enough to hold itself up in ruts and provide bottoming resistance for sharp edges and jump landings. We aim for our setups to leave the shop with valving settings that land the clickers in the middle of their ranges to allow for plenty of adjustment and tuning. Gold Valves also help make the clickers more effective.”
7) Can you offer any specific tips for desert riders?
Addressing your motorcycle’s high speeds and the obstacle-filled terrain encountered in the desert was important to the panel and here’s what they said about desert riders suspension tuning.
C-Cycle: “Desert racers (require) stiffer suspension settings.”
Factory Connection: “Desert racers face an incredibly varied terrain; the key is to set up for 80% of the riding and always being mindful of any high speed or river wash/sand sections. Desert racers normally need to be a little stiffer set up than you’re typical off-road rider.”
FCR: “Tips for desert riders, especially desert riders, is to really, really get a qualified shop to help get the suspension set up for that type of riding. The speeds are so different than say…an enduro rider back east... (so) take some time and really, really set that stuff up good!”
RaceTech: “For desert riders we focus on a fork setup that will hold up in high speed rolling whoops, while keeping a plush feel in the rider’s hands. We also re-valve steering stabilizers which is extremely important for desert. This helps keep the rider from fatiguing by not having to work so hard to keep the front end straight and avoid headshake. The Gold Valves for steering stabilizers help create more effective adjusters and improve the adjustment range. For the shock, we look for a plush initial setup for small rocks and chatter while still firm enough to not blow through or bottom in rollers.”
8) Can you offer any specific tips for enduro riders?
Enduro riders are always looking for some additional “plushness” when hopping logs and jumping rocks and roots all day. The tuner panel agreed and offered this advice.
C-Cycle: “Enduro (bikes require) softer suspension settings.”
Factory Connection: “Depending on the extent of rocks and roots, G-outs, elevations changes and jumps, usually a softer and plusher setting is desired. Rebound control is always important with off-road riders and is often overlooked. A lighter rebound adjustment is typically preferred to maintain a responsive fork and shock to react to the rock and root terrain.”
FCR: “Tips for enduro riders would be to keep your suspension clean. Typically the enduro guys that (FCR) helps out - they are always in the slop and it can really wreak havoc on the components, especially the fork seals and shock linkage and swingarm pivots. You’d be amazed at how (much) dirt, sand, and water can find their way into the seals and bearings…and if your linkage and swingarm aren't working smoothly there’s no way your shock will work to its potential.”
RaceTech: “For enduro, (RaceTech) looks for a setup that focuses on a more plush setup front and rear. We look to provide great traction for technical sections and to absorb rocks, logs, and roots. This is a much plusher setup at low speeds.”
9) What modifications does your firm perform for riders in search of suspension improvements?
C-Cycle: “C-Cycle provides education, rebuild and custom tuning. We also provide chassis, bearings, wheel building, lowering and ergonomics services.”
Factory Connection: “Factory Connection changes springs and performs custom valving on forks and shocks based on rider needs. Models are different and every rider is different. Because of this, Factory Connection has an expert team of technical staff ready to take your calls and talk through your needs making recommendations on set up, springs and valving. We personalize each suspension component to each rider’s needs and preferences. Factory Connection is a suspension only shop, with company owned, company operated locations across the USA offering a wide range of suspension parts and services including: Re-valve and Rebuild services. Factory Connection Springs, Factory Connection Oil, Factory Connection Specialty parts and OEM wear parts.”
FCR: “The most common upgrade that is requested here would be two things, the proper springs and fork rebuilds.”
RaceTech: “Race Tech specializes in personalized suspension setups that provide a plush feel with drastically improved bottoming resistance. For most off-road and motocross bikes, that means RT Hi-Performance Springs and Gold Valves along with a personalized valving setup.”
“We offer a full line of suspension products, parts, and tools. Pretty much everything you could ever need to work on and setup suspension; Paul even wrote the Motorcycle Suspension Bible and hosts Technical Edge Suspension Seminars where he has taught most of our competitors how to tune suspension. G3-S Custom Shocks, Gold Valve Fork Emulators, Rebound Valves, G2-R Cartridge Kits, and of course seals, bushings, and fluids are also very popular items.”
“Every setup that leaves our door is 100% guaranteed to exceed your highest expectations and Race Tech products are made right here in the USA. We strive to provide a fantastic product, but also to provide the best support in the industry to make sure the riders who choose Race Tech love their setup. Many ThumperTalk members have my personal cell number available to them 24/7, 365 days a year if they ever have any setup questions and I offer that to anyone that chooses Race Tech.”
In conclusion, there is no “magic bullet” when it comes to suspension setup. All parts on your machine must work in unison to provide the best performance. Riders need to “go back to stock” and establish a baseline for suspension tuning and write these settings down so you can keep track of your progress and remember that there are experts like the ones mentioned here that can help you set up your machine for the optimal responsiveness in virtually every type of terrain.
Article Resources and Contact Information:
C-Cycle Suspension Services - East Hampton, Connecticut: 860-267-1710
Factory Connection - National and International Locations: 800-221-7560 (USA)
FCR Suspension - Palestine, Ohio: 330-426-4600
RaceTech Suspension - Corona, California: 951-279-6655
Photo Credit: RaceTech Suspension
User Feedback
Recommended Comments
Please elaborate for on this:
"As a baseline if you are a 65 rider race sag should be 70-75mm's…an 85 rider--85-90mm's, and 125 and up 100-120mm's."
What determines your rider number?
Share this comment
Probably referring at engine displacement.
For example 85 cc dirtbike has less fork/shock travel then a 125cc or bigger bike.
Share this comment
So much talk about spring rates being one of the first things to do along with setting your sag, but no one ever mentions that with stiffer springs for heavier riders, you need to get the rebound under control, or else you have a dangerous, harsh ride. A heavier spring will want to rebound much harder and will kick you all over the place. What's worse is that once you figure that out and you crank in the rebound clickers, that will eventually affect the compression since it is a two way valve, so you need to go way out on the compression and you have funny feeling suspension. For heavier riders using heavier springs, spend the extra and get a revalve!
Share this comment
What is the purpose of the measurement in the 4th picture down in the attachments section?
Share this comment
This is showing taking a measurement for setting/checking fork preload.
You can find it in the Fork GV Twin Chamber Install step by step guide.
We (Race Tech) offer many of these step by step guides in our "How To:" section on racetech.com.
Thank you sir. I have used your site many times over the years. Changes to preload are done above the spring perch with the aluminum spacers right?
Share this comment
So "dialing in" means get the right springs, set sag, and have a healthy suspension. OK. Well the damping has a huge effect on the way the suspension behaves, I'm really surprised no one talked about how to tune damping. Everyone knows springs sag and fresh oil, good bushings, etc. so the "dialing in" of damping part is where we could really use the help. Just my 2 cnts
Share this comment
  • Similar Content
    • By Leo Vereen
      Only a few days left cant wait to get there and camp and do some grilling out. Will get there early friday hope its not to wet. There is a 40 to 50 percent chance of rain all week. Could be another mudder.
    • By Freemotion
      Specifications
      ENGINE
      BORE (MM)72
      COMPRESSION RATIO13.2:1
      COOLINGLIQUID
      DISPLACEMENT IN CC293.2
      DISPLACEMENT IN CI17.9
      ENGINE TYPESINGLE-CYLINDER
      STARTERELECTRIC / KICK
      STROKE72
      VALVE CONFIGURATIONREED VALVE
      TRANSMISSION
      NUMER OF SPEEDS6
      TRANSMISSION TYPEMANUAL
      TIRES
      FRONT TIREDUNLOP® GEOMAX AT81 90/90 R21 54M
      REAR TIREDUNLOP® GEOMAX AT81 110/100 R18 64M
      BRAKES
      FRONT BRAKE DIAMETER260
      FRONT BRAKE TYPEHYDRAULIC DISC
      REAR BRAKE DIAMETER8.7
      REAR BRAKE TYPEHYDRAULIC DISC
      SUSPENSION & STEERING
      AIR ADJUSTABLENO
      FRONT SUSPENSION BRAND NAMEWP
      FRONT SUSPENSION TYPEINVERTED FORK
      REAR ADJUSTABLE REBOUND DAMPINGYES
      REAR ADJUSTABLE SHOCK / SPRING PRE-LOADYES
      REAR SUSPENSION BRAND NAMEWP
      REAR SUSPENSION TYPETWIN SIDED SWING ARM
      SEAT HEIGHT (IN)37.8
      OTHER
      FUEL CAPACITY (GAL)2.6
      MANUFACTURER COUNTRYAUSTRIA
      MANUFACTURER TYPEENDURO
      DRY WEIGHT (LBS)221.6
      WHEELBASE (IN)58.4
    • By Enduro Girl Rider
      Hello everyone!
      Looking for help with AMA rules and off road racing rules. 2018 was my first year racing.  I'm not familiar with rules of moving up.
      I  competed in Sprint Enduro series in womens C class. I raced 7 of 8 rounds. 2 days of racing in each round. I didn't had much of competition,  I computed  against only 4 riders and they were almost twice my age. I won 4 of 7 rounds and with that I won championship. By rules of sprint enduro riders who win championship and 2nd and 3rd place finishers who won at least 2 events overall have to move up in next class.  If I choose to race in this series again I have to move up to A/B class there are no B class for women. And I would be racing against women who have been racing for years and much faster than me.
       For women who got 2nd place and won 2 overalls organizer made an exception because of her age, kept her in women C for 2019.  And making me move up, And I feel that I'm not B rider yet.   For 2019 I want to try GNCC Or even local series.  In womens C in GNCC series I think I will place in a mind pack.
       I was looking at AMA rules of advancement. My name is not listed in B class advancement list.  Because I raced in only 14 races and my RVP is 14 not 15.  By  AMA rules I should be advanced if I have 15 or higher.  I called AMA to check  They telling me that I earned advancement by the series so I should move up. But in the rules of AMA  It doesn't say  if you winning the series you should move up.
       So if I race in GNCC should I move up to A/B or compete in C class?
    • By MANIAC998
      Ballards was the premiere Yamaha team to ride for, and they won numerous Championship’s through the years. Here he gives his input on the new Yamaha WR450.
      (Sorry Mog)
    • By Erik Marquez
      This preventative Maintenance "fix" is applicable and recommended for ALL YEAR and model year DRZ 2000 -2013
      Why does my counter shaft (C/S) sprocket get loose? Is it the nut? Or something else? The “Loose” sprocket” situation in most cases really is not what it seems; the C/S nut is not coming loose. Though that can be a contributing factor. http://www.thumperta...=1&d=1277642132
      24 CIRCLIP
      18 WASHER
      15 GEAR, 3RD DRIVEN (NT:22)
      16 GEAR, 4TH DRIVEN (NT:24)
      21 WASHER, 1ST DRIVEN LH
      13 GEAR, 2ND DRIVEN (NT:26)
      14 BUSH, 2ND DRIVEN
      22 BEARING, DRIVE SHAFT, LH
      34 SPACER, ENGINE SPROCKET
      33 SPROCKET, ENGINE (NT:15)
      38 WASHER
      37 NUT, ENGINE SPROCKET
      These are the parts that are located or clamped togeather between Circlip #24 and the Countershaft sprocket nut #37 The theory, which in follow on years has been substantially proven though wide spread use of the “Loctite Fix” and follow on inspections. Is that wear of the C/S second gear bushing is what causes the “loose” C/S sprocket nut. Users find the C/S nut loose and then tighten the nut, against what is now a worn, mushroomed bushing, this causes bind in the counter shaft. A little may go unnoticed for many miles, a little more bind, and the bushing will seize to the gear, counter shaft or both. Causing hundreds of dollars in repair and possible a crash when the transmission sizes. It's believed the primary cause of second gear bushing wear, is the slight rotation of the sprocket on the counter shaft. There is not an interference fit between the sprocket splines and the counter shaft splines, which is what allows this movement.
      TT User Noble and Sargentrab, the original investigators of this issue initially thought the second gear bushing wear /deformation was caused by over tightening the nut...
      So we have identified the problem as, loose fit between the C/S sprocket splines and those of the countershaft. Again Noble noted
      This theory was originally derived from inspection of three DRZ transmissions, but has since proven true with many others, to include my own and many I have worked on over the years.
      The Fix, or.. How to:
      The fix: As the root cause issue is clearance between the C/S splines, and the sprocket the fix is focused on that. Using an Anaerobic threadlocker (AKA Loctite) that cures to thermoset plastic when it comes into contact with metal in the absence of air, used on the splines and C/S threads has been proven on hundreds, if not thousands of DRZ’s to stop the rocking motion of the sprocket and thus the wear of the second gear bushing solving the mystery of the “loosening C/S sprocket nut”
      The procedure: What brand or type Anaerobic threadlocker you use is dependent on what is available in your area. The established standard shown to work when done as advised is Loctite brand (Henkel corp) High Strength Thread locker PN 271 263 (NOTE: Henkel corp Updated their product line.. 263 is now the correct product number, replacing 271) .
      In the years since this procedure was established we have had two employees from Loctite visit the forums and speak on the use of Anaerobic threadlocker for this application. One company representative stated emphatically the use of a thread locker would not work, he implied we were idiots for trying and wasting our time. When it was pointed out that we had been using Loctite 271 for many months and it in fact did do what we needed. The company rep implied we were idiots and never came back.LOL
      The second company representative , had a much better attitude, was very helpful and stated, while he acknowledged our success in using the 271 product, a better option was available. Loctite retaining compound 680 or 638 was recommended.
      The problem is, that product was marketed for heavy equipment or  industrial use and not widely available. Some members have not been able to locate these products at any location industrial or not. Others have found 680 or 638 at Farm equipment suppliers (John Deer) or Fastener and bearing suppliers are great places to find Anaerobic threadlocker or retaining products used on heavy equipment or industrial machinery.
      Which brings us back to the tried and proven to work commonly available Loctite brand High strength threadlocker 263. This is the product recommended, many other like products will work I’m sure,, If 263 is not available to you,, Choose a like product from another manufacture.
      Start with removing the counter shaft nut and sprocket, clean and degrease the threads and splines using brake or contact cleaner. Remove all scale and rust. (Note, on rare occasions the sprocket may be difficult to remove due to rust or corrosion. Or if this is a used bike, a previous owner may have already done the Loctite fix. And the sprocket will likely need a small two jaw puller to remove),
      Remove and clean the spacer, and check the O ring behind it and replace. If the spacer is deeply grooved or pitted / rusted. it will need to be replaced, and the seal as well.
      Apply 4 drops (More is not better, if you douse the splines and the loctite gets under the spacer and into the seal area, once it sets, the seal can be damaged) of 263 to the splines of the counter shaft, just outboard of where the sprocket will rest once installed. Distribute the drops around the shaft evenly.
      The threadlocker tends to wick into the spline gaps, so you really do not need to slather a lot on to get the job done. Install the spacer and o rings onto the C/S, and then the sprocket.
      Use a drop of 263 on the counter shaft threads and install the lock washer & C/S nut. Using the chain as a holding tool, tighten the C/S nut to 105 ftlb.
      Remove the chain and rotate the countershaft by hand, It should rotate without any binding. Some drag will be present and is expected. If it rotates freely, then you are good to go. Bend the locking washer over, let the thread locker cure for a minimum of 8 hours and go ride. There is a lot more to anaerobic thread sealant and thread lockers, Different types, primers that can be used to prep the surface and or speed cure time. Cure time based on temp, air in contact with the product, type of metal in contact… And that would make a great 20 page thread in the general forum… But the bottom line, no matter what the product data sheet says for Loctite brand High Strength thread locker 263. No matter what a company rep may say. It works in this application.
      Removing the sprocket after installing it using Loctite 263: Lastly, we come too, “How do I get this sprocket off, once I have installed it using Loctite 263 to help fix it in place?”
      Anaerobic thread sealant does become soft when heated. The problem with heating the counter shaft and sprocket is, there are o ring and a seal that reside right behind that sprocket which might be damaged by the heat. So go easy.
      Use heat on the nut to soften the thread lock, then remove the nut.
      Then;
      The simplest method I and others have found to remove the sprocket is to use a small two or three jaw gear puller. Commonly available from most any automotive tool supply house, or Sears for that matter. . Rent or buy the puller, it’s a good tool investment.
      Using the chain and rear brake as a holding tool, flatten the lock washer, and remove the C/S nut. If you use an impact gun to remove the nut, make sure the transmission is not in gear.
      Remove the chain, and place the puller jaws over the sprocket. Make sure the puller screw is centered in the counter shaft. Apply some pressure to the puller. If you use an air impact gun, the sprocket will come right off. If your using a ratchet or wrench, tighten the puller, then give the center screw a light rap with a dead blow hammer.. The sprocket will break free and can now be removed.
      New or updated information and products would always be welcome. So if you have something new, quote this thread and start a new one. Let’s discuss it and see what comes up. Thanks. Thanks for looking, Fix that loose sprocket and go ride. I’d like to thank Noble and Sargentrab for their original work in discovering what was causing this problem, and devising a solution that has been proven with the test of time.
      Parts required for the repair of a leaking counter shaft seal are:
      SEAL, DRIVE SHAFT OIL 09283-30053
      SPACER, ENGINE SPROCKET 27531-29F00
      O RING (D:2.5,ID:21) 09280-21008
      Often the screws holding the seal retainer are damaged if you attempt removal without first heating them to 250c to loosen any thread locking compound, and do not use an impact screwdriver. If danged and need be replaced,they are BOLT, RETAINER (6X14) 09126-06007
      However they can be replaced with common hardware, countersunk screw, grade 8.8 and above 6mm x 14mm
      Replacement nut and washer are:
      ENG SPROCKET WASHER 09167-22012
      ENGINE SPROCKET NUT 09140-18006
      If you just a complete parts kit, here's one from All Balls (also sold under the brands of MSR and Moose):
      https://www.thumpertalk.com/shop/All-Balls-Counter-Shaft-Seal-Kit-p4797952.html
