Grips, Grips, Grips, and more Grips!
Brian Wilson
Here is a collection of suggestions and tips by TT members for installing Grips.
There are a few opinions on putting on new grips, but this seems to be the overall best method.
Materials You Need
- New Pair of Grips
- Grip Glue
- Dish Soap
- Water
- Paper Towels
- Sharp Razor or Sharp Scissors
Step 1: Removing Your Current Grips
1.1: Using Scissors
I think scissors is the best tool to use for this, but they have to be sharp. First grab a pair of scissors and cut into/around the end of the grip that is furthest away from the handlebars. Then slide one of the Scissors' blades under the grip and cut (this is why you need sharp ones). Depending on the type of grips you have it's obviously going to be easier to cut the side without the waffles on it. After your finished hacking away at the old grips toss then aside, and continue onto the next step.
1.2: Using A Razor
Take your razor and slide it down the grip at the "top" of it and the "bottom" of it. Depending on how much glue was used to put it on (if any) you might need to slice it a few more times. After taking the grips off, toss them aside and continue onto the next step.
Step 2: Cleaning
In order to install your new grips, you need to first clean the area where the grips go. It's important to try to remove all the excess glue (if used) off of each side. You can use a rag and water to take it off since the glue used was probably elastic type of material which is very easy to take off.
Step 3: Putting on your new grips
3.1: Preparing The Grips
Now that your grip surface area's are clean and ready to go, it's time to install your new dirt bike grips. First take both grips and go to a sink. Put both grips aside and put soap all around your middle finger, (since it's the longest of them all, right?) and then smear the soap around it with your other hand. Then dry off the hand that doesn't have the soap on your middle finger (so you don't get soap on the outside of the grip when you grab it, and put your middle finger inside one of the grips making sure you have soap all around the sides of the grip. Put that grip down so that the entrance of it is in the air and do the same thing to the other grip. When your finished with the other grip put it down next to the other one so that the entrance of the grip is in the air. Now clean off your hands so that theres no soap on them and look at both grips. One hole is smaller than the other, why? The grip with the larger hole goes on the side where your throttle tube is (the right side) and the grip with the smaller hole goes on the left side. Make sure you remember that. Now grab your two grips and go back to your dirt bike.
3.2: Installing Your New Grips
First slide your left grip on, and slide it back off, then do the same to the other one. You just did that to make sure your putting the grip on the right end, and to lube the bar. Now, grab your grip glue and make streaks of glue going from where the top of the grip would be, to the end of the bars. Make about 6 streaks. Now grab your grip and side it all the way on. Do it slowly and try to pull the sides of the grip so that the grip doesn't just push all the glue up, but it actually goes on top of the glue. Once it's on grab some paper towels and get rid of the excess glue that is at the top. Now do the same exact thing for the other grip, and let them sit there for at least 8 hours untouched, so that the glue can dry and so the grip gets secured in place.
Frequently Asked Questions
Question: I put my grips on but after my first ride they twisted around. Why?
Answer: You either didn't put enough grip glue on or you didn't allow the grips at least 8 hours to completely dry. If you can try taking off the grips without cutting them and redo everything, or try to straighten them out, roll them back a little and putting glue where it's rolled back then rolling the grips back over the glue.
Question: I don't have any grip glue, what do I do?
Answer: You can try using some other type of strong glue. Some people actually use hair spray, and they say it works but I've never tested it.
Question: Is there anything else I should look for?
Answer: Yes, if there is friction when you twist your throttle remove the grip and install a new one.
This is an excellent tip for whenever you've putting on new grips at the track and don't have any glue.
Take 4 zip ties and put them inside your grip with the rigid side facing the grip and slick side facing the handlebar. You want one on the top, bottom, left and right all around the inside of the grip.
Then you slide your grip on, once its on simply take a pair of pliers and pull the zip ties out...make sure you have a good bite on the tie and pull slowly so you don't break it off in there.
Your grip will be on there really tight to say the least, you don't need to safety wire them, but I do anyway to make me feel better.
The zip ties help the grip go on easy, there is no messy glue and no drying time. :D
Alright if any of you were ever like me you know that it is a hassle to get a grip on sometimes. It always seems as if the grip was too small for the bars... well there has been many attempts at trying to get grips on and many don't work. For instance oiling the inside of the grip so it will slip on, that works to get it on, but then the grip can slip and slide after further use upon it. This trick has worked best for me and I'm sure it will work great for you... Alright find an old windex bottle or any type of spray bottle that isn't used anymore. rinse the prior chemical out thoroughly, now put in a couple squirts of dish washing soap and pour in some water. Now shake it until completely mixed. Spray the inside of the grip thoroughly with the soapy water. Now quickly slide the grip on to the bars or the throttle tube. The benefit of this trick is that it has the slipperiness of oil, but unlike oil the soap and water will dry and evaporate as where the oil wont... most of the time grip glue is not required, it is really your preference... :D
A really simple way to install grips is to use an air compressor with a blow gun nozzle. Simply blow air into the grip as you push it on. The grip will inflate slightly and just float right on. No soap or any other lube. Quick and simple. Also works great to remove grips.
Lay a towel or 2 down around your bike or quad to where nothing can spill on it, take off the old grips by cutting, air gun, oil, etc. Fill the new grip with gasoline (any octane will work but not sure about diesel) and just shove the grip on fast and in a hurry find the place you want the grip to stay and 30 seconds later you wont be able to move them.the gasoline will dissolve out of the grip and never be noticed. I used this trick with Scott grips and it worked great. Hope this tip helps with other brands! :D
With clean bar ends, grab a hi-power hair dryer and heat up the end of the bar you need to apply the grip to. At the same time, heat the grip to make it pliable. Once both are toasty, slather on some grip glue on the bar end, then inside the grip. The heat allows the grip to stretch over the bar end easily and the glue won't get tacky when it's hot. It also allows you to give the grip a twist to distribute the glue, again without the glue getting tacky. I've used this method serveral times now and it's the best I've tried.
Best method I've found to apply grips and eliminate grip twist.
Wrap a double layer of friction tape (black cloth tape available at most auto parts stores) around clean left bar end and throttle tube.
Spray friction tape and inside of grips one at a time with brake cleaner (don't get it onto plastics) and slide grips into proper place and rotation. Clean-up with towel and brake cleaner. Allow to dry overnight.
Works very well for larger hands as this does increase the diameter of the grip slightly, and mine have never twisted.
Instead of grip glue or superglue, use spray paint. I really cant remember where I saw this a long time ago (maybe Dirt Rider) but you can reuse the grips, if you really have to by taking an air hose and compressed air and blowing the grips off.
User Feedback
Recommended Comments
I used to build golf clubs and have installed golf grips so many times I can't possibly count them. Here is the way golf grips are installed , and it works just as well for motorcycle grips.
Use 2 sided tape, like golf club grip tape, available at any golf shop. Apply the tape to the bar. Then use something like alcohol, or golf club grip solvent, that will completely evaporate (if using alcohol, be careful to not do so around heat, open flame, or sparks). Put a small amount of alcohol/solvent in the grip, hold your hand over the open end of the grip and give it a shake, coating the entire inside surface of the grip. Now quickly pour the solvent out of the grip and onto the tape on the bar. Quickly slide the grip onto the bar and adjust it as need be, you will have several seconds to adjust the grip before the solvent starts to evaporate. Then let sit for a few minutes until you can't rotate the grip with your hand. That's it!
Share this comment
Slapping on new grips? Unbox grips, take a utility knife to the old ones and slice and dice em off your handle bars. Clean off any glue any way you see fit, you know the drill. Buy some Honda grip glue, follow the instructions, glue the grips on, and let them dry completely as per the directions. Task complete....
Share this comment
I was lazy one day and used some gasoline on a rag to get some gas on the inside of the grip, slipped right on.  When dry it is not going anywhere.  my new method
Share this comment
Join the conversation
Guest
Add a comment...
  Only 75 emoji are allowed.
Loading...
  • Similar Content
    • By sledhead999
      With 7 mm wider stepping surface than standard.
      Material:
      Aluminum
    • By sledhead999
      Only mountable with Magura brake systems!
      Material:
      Aluminum
    • By sledhead999
      made from aluminum fits Magura clutch reservoirs
    • By armourbl
      Below is a how to article I've put together that demonstrates how to service the 2008 Honda Progressive Steering Damper.
      A friend of mine was brave enough to take his apart and feel out the process. I've taken and tried to perfect it along with instructions and photos.
      Let me start by saying this damper is built just like a rear shock. In the picture below the item marked number 1 acts like the nitrogen bladder on a shock, only instead of a rubber bladder there is a piston and spring. The item marked number 2 is the shaft and has the seal head and valve piston and shims. Item number 3 is the adjust knob -- which we will not remove during the service of the damper.
      Start by removing the damper and clean it really good. This will prevent any dirt from contaminating the work area and internals of the damper.
      Next, place the damper in a bench vise with the bottom facing up. Then remove the two circlips. I don't recommend using anything but circlip pliers for this job. The area is tight on space and you don't want to risk weakening the clips or scratching an surfaces. NOTE: When you slip the circlip off of the shaft, do it as close to the eyelet and bearing as possible. You don't want to scratch the shaft surface where the seals ride.
      Next we need to remove the plastic cap on the spring side of the damper. The cap has two flat sides. Use a pair of needle nose vise grips set with just barely enough gripping force as to not damage the plastic cap. Then very slowly pull the cap out giving care to the rubber o-ring wrapped around the cap. You can actuate the shaft of the valve piston to help push the cap out as well.
      Someone else made the discovery that the hole in the center of the plastic cap is threaded. You can thread the correct size bolt into the hole and use this to pull the cap out instead of pliers.
      Under the cap will be the spring. Remove the spring.
      Under the spring will be the piston, which looks a lot like an engine piston. It has a recessed hole that is threaded. Find a spare bolt with the same thread pattern and thread it in a few turns. Then lift out the piston slowly, giving care to the rubber o-ring wrapped around the piston.
      Here is what the piston looks like after you have removed it.
      Now slowly pull out the shaft along with the seal head and valve piston. You can wiggle this back and forth a bit in the process. Just be careful for the rubber o-ring again.
      Here are the parts you should have laid out now.
      An amazing discovery here is there isn't much oil in this damper from the factory, and the quality of it doesn't seem to be very good either. In the syringe (is that how you spell that) below you can see there is about 14 cc or ml of oil in the damper. I have 28 hours on my bike and look at the oil. When I'm done with the rebuild, I'm guessing there is about 20 cc or more oil in the damper.
      A friend picked this up for me at the dollar store. It was in the kitchen area with the pots and pans and other kitchen tools. Marinate Injector. It really makes doing this job easy because you can control how much oil you pour in to the cavities.
      Ok, now make sure everything is clean. Spray some brake cleaner inside the damper cavities and blow it out with compressed air. Then place the damper body back in the bench vise and fill the spring side cavity slowly with the oil of your choice until it is filled to the top with no more oil transfer into the valve piston cavity.
      I'm using Maxima Performance 5W Fork Oil. Just for reference you could use whatever weight you want. The thicker, the heavier the action will be on the damper. My friend is actually testing out Rotella in his at the moment, but has no ride time with it. It is much stiffer than stock with the Rotella, but I wouldn't say extreme. With the 5W Fork Oil, mine is now noticable at the stiffest setting on the adjuster.
      Next we will insert the spring piston back into the damper body. The goal during this process is to have no air trapped below the spring piston. Very very slowly insert the piston at an angle that allows any air under to float to the top before the o-ring begins to seal. Only insert the piston a short distance. We don't want it to drop too far. Then remove the bolt.
      Now, air can be compressed, but oil cannot. So, insert a shop rag and soak up any oil on top of the piston. The area above the piston where the spring is located is the only place we want air in the system. Without air here, the damper will hydraulic and you will get no performance from the damper.
      Now insert the spring and push it in until the top of the spring is about flush with the top of the cavity.
      Now place the cap on top of the spring. I found that pressing it in can be kind of tough with big fingers, so I used a phillips head screw driver along with my free hand to tempt it into place. Do you best to only push it in far enough to be able to install the circlip. We want to keep as much oil as we can under the spring piston without any pressure on the spring.
      After you install the circlip, the oil level will look something like this without over flowing the top. At this point, there isn't any force on the plastic cap or circlip. It will pop fully into position during the last steps of the installation.
      Slide the seal head as far as possible from the valve piston. You do this so that when you insert it into the oil, you can raise and lower the valve piston to bleed out any trapped air in the valve piston and shims.
      Raise and lower the valve piston in the damper body deep enough that the seal head doesn't touch the oil and only high enough that the o-ring on the valve piston maintains a seal on the damper body. If you accidently raise it higher than the seal, it is OK as long as you don't raise it higher than the oil level. Do this until you see no more air bubbles coming to the surface.
      Keep the oil level at the top of the damper body during the bleed process. Top it off again after you see no more air bubbles.
      Now raise the valve piston as high as you can without breaking o-ring seal on the body. Then, with the oil level still topped off, lower the seal head very slowly so that about half of it is still exposed. You should see the trapped air from under the seal head bleed out through the oil.
      Press the seal head with your fingers as far as you can into the damper body. It will not go in far enough at first to get the circlip in. This is OK. While pushing down on the seal head, actuate the shaft down and up. Repeating the process several times. You should see more air and some oil bleed past the seal head in the process until you eventually have the seal head almost recessed enough to install the circlip.
      Again, the goal is to get all of the air out of the system, except for where the spring is located.
      When you think you are close to getting enough space to install the circlip, place it on top of the seal head. Remember to slip the circlip over the shaft as close to the eyelet and bearing as possible. You don't want to scratch the shaft surface where the seals ride.
      Connect you circlip pliers to the circlip with one hand. Then use a shop towel under the thumb of your other hand and push on the seal head and circlip until it snaps into place.
      Now remove the damper from the bench vise and check that the shaft freely travels through the entire range of movement. You also want to listen for any trapped air. If you hear air or the travel is restricted, you need to start the rebuild process over.
      I hope you find this how to article useful. I'm not expert, so I'm willing to hear from anyone who has perfected the process better than I've outlined above. The goal is to make this a doable project for anyone.
      This rebuild can be completed in about 15 minutes from start to finish with the right tools.
      ben
    • By BK723
      A Footpeg with a Proven Purpose.
      Better peg traction & much improved comfort while not changing the characteristic of how the peg feels.
      The Impact Moto Peg, Patent # US 6390488, accomplishes this by isolating the cleat from touching metal to metal, resulting in the rider experiencing less vibration and abuse transferred to the foot. With the Impact Moto Peg your foot will stay planted, while your feet, ankles and knees will feel better. This adds up to a better day on the bike.
      How does it perform?
      Proofed out in the notoriously choppy, teeth chattering, West Rim in Southern Utah, a trail that is initially so harsh with slick rock ripples many find an alternate route to the “good stuff.”   This was the perfect proving ground for the Impact Moto Peg, as often riders feet vibrate or bounce off of the pegs from the continual chatter. With the Impact Moto Peg the harshness of the rocks was squelched, the riders feet stayed on the pegs, and brutality of the notorious chop tamed. Further the slick rock drops provided the perfect opportunity to test the how the Impact Moto Peg performed on massive impacts. Our test riders repeatedly launched big rocks to flat landings, noticing none of the sharp pain or sting shooting through their feet to their lower back as they would with any other peg.
      What is the Impact Moto Peg made out of?
      Both the cleat and the base are made out of 7075 T6 aluminum, providing the best structural integrity and wear resistance. The cleat is 77mm long by 58mm wide to provide additional support for your foot. 13 5mm Inserts are positioned for optimal traction and wear resistance. The base is shot peened and anodized, while the cleat is hard anodized for wear resistance. The cleat is isolated from touching metal to metal through our base elastomer on the bottom, and cup elastomers on top. 10.9 bolts secure the cleat to the base, making the Impact Moto Peg not only the best performing, but the strongest aluminum peg on the market.
      Features
      Absorbs vibration and abuse.
      The elastomer absorbs vibration allowing your feet to remain better planted on the pegs. High-frequency abuse like spikes, jolts, and bumps are also dramatically reduced through the cushion of the elastomer.
      Exceptional traction
      A combination of our tooth profile coupled with minimized vibration, and larger platform (77mm x 58mm,) literally grabs hold of the bottom of your boot.
      Hard Anodized 7075 T6 Aluminum
      Provides exceptional construction, strength and wear resistance.
      Orange, Red, or Blue to suit you.
      All Impact Moto Pegs have a black body with either orange, red or blue elastomers of your choice to suit your personal touch.
