Guide to Cylinder Prep for Your Top-End Rebuild
Kevin from Wiseco
Freshening up the top end in your dirt bike or ATV is a critical part of preventative maintenance. However, it’s not as simple as purchasing a new piston kit and dropping it in. Properly preparing your cylinder is equally as important as installing a quality piston. Cylinder prep recommendations are always included with the piston when ordering from Wiseco. Depending on your application, it will either say “deglaze / hone” or “bore & hone” or “bore / replate.” We’ll take a look at exactly what these different terms mean and how to perform these steps.
Deglaze your Cylinder
A common question is “Do I need to deglaze my cylinder?” The answer is: yes, unless it’s time for a replate or resleeve. If you’re engine has any time on it, the glazing process has begun. The term ‘glazed’ in this context refers to the motion of the piston ring(s) flattening out and polishing the surface of the cylinder wall during normal operation. The more time on the engine, the more glazed the cylinder is going to be. However, depending on how much time is on your engine and what type of cylinder you have, you may need to replate or resleeve, which we’ll discuss next.
5a986c1fc5cb7_Photo3.jpg.99239e5cab789421a414dd7ba96714ed.jpgNotice the shiny surface of the cylinder wall. This cylinder has become glazed over time.
Plated vs. Sleeved Cylinders
If your Powersports engine was made in the last 2 decades or so, chances are it is plated with a Nikasil (Nickel Silicone Carbide), chrome, or electrofusion plating. Nikasil has been the latest and most commonly used cylinder coating due to its wear resistance qualities, but they do still wear out. We recommend checking your manual for normal top end rebuild times, but generally if your engine has long hours, the overall condition of your cylinder will need to be closely reviewed. This will include not only the bore size and plating condition, but also the cylinder roundness and taper in reference to OEM service specifications. There are a number of good companies that offer replating services, just do your research and choose a trusted company. Your cylinder should come back with fresh plating, honed, and ready to go after a quick cleaning.
5a986c3f43bff_Photo4.JPG.f34b36beb26a7a3c6f00dc1be87c9a0d.JPGThis cylinder has been replated and prepped for the rebuild. The cylinder wall surface is no longer reflective and glazed-looking.
Other forms of cylinders that aren’t plated commonly have iron or steel/alloy sleeves. If your cylinder does have a sleeve, you should be able to see the seam between the sleeve and the actual cylinder. If you’re still not sure, check to see if a magnet sticks to the cylinder wall. If it sticks, it’s a sleeve, and if it doesn’t, it’s plated.
Much like replating a cylinder after normal top end rebuild time, your sleeved cylinder should have a new sleeve installed. The same cylinder shops that do replating should do resleeving as well, and it will come back honed and ready to go back together.
In short, if your engine has enough time on it to need a full top end rebuild, we recommend replating or resleeving your cylinder. Technically you can have your previously plated cylinder sleeved, but we recommend sticking with how it came from the OEM. If it is just freshening up with low hours on the engine, you should be able to just deglaze / hone.
What is Honing and Why do I Need It?
When your engine was made brand new in the factory, the cylinder was honed. Honing is a process of conditioning the surface of the cylinder wall to help with lubrication of the piston ring(s) during operation. Honing creates fine cross hatch imperfections on the surface of the cylinder bore. You can think of these imperfections as peaks and valleys in the surface of the metal. These are essential because it helps the cylinder wall retain oil to assist with piston ring lubrication. Theoretically, the idea is for there to be a very thin layer of oil between the edge of the piston rings and cylinder wall. If there was no oil to lubricate the constant contact with the cylinder wall, there would be too much friction and both the rings and cylinder would wear out quickly.
The term ‘deglazing’ simply refers to re-honing your cylinder to put those peaks and valleys back in your cylinder wall.
5a986c676fc51_Photo5.JPG.b402f15eecebbfa619d4bc1f8fc79402.JPGThis crosshatch pattern on the wall of the cylinder is the goal of the honing.
How to Hone your Cylinder
The most common tools you’ll find for honing small engine applications are rigid or brush hones and ball hones. Hones can be ordered by size according to your cylinder bore, just cross reference your bore size with the information from the company you order your hone from.  The hone company should also have recommendations on grit and material type based on what type of rings you have.
After disassembling your top end, inspect your cylinder wall and ports for damage. If you had a piston seizure or something break, chances are the cylinder was damaged. Depending on how extensive the damage is, sometimes cylinder shops can repair them. If you see any questionable damage or deep scuffs, we recommend sending your cylinder to a trusted shop for their best recommendation.
If your cylinder is in normal condition with no damage, and you’re just changing rings between top ends, honing should be the only thing required. If the glazing is minimal and you can still see a fair amount of cross hatch marks, you should be able to get away with using a rigid or brush hone to just restore those cross hatch marks. You should only have to hone for about 10 – 15 seconds at a time until you can see consistent cross hatch marks.
5a986c7c00360_Photo6.thumb.jpg.2a564bb87d55dc488fdb1164f12cc3b7.jpgA soft hone brush like this is one of the tools that may be used to prepare the interior surface of the cylinder.
The ball hone will be a little bit more abrasive, which is why we don’t recommend using a ball hone on plated cylinders unless they are specified to be safe. If you do need to use a ball hone for heavier glazing on your sleeved cylinder, attach it to your drill and lubricate it with a light coat of motor oil. Make sure the cylinder is secured and stationary, and the ball hone is spinning before entering the cylinder. Hone the cylinder back and forth for about 10 – 15 seconds, then switch to the opposite spinning direction and repeat. Check the cylinder for the desired cross hatch marks, and repeat if necessary.
After honing is complete, be sure to clean the cylinder thoroughly until there is no residual material.
When reassembling your top end, always be sure to double check your piston to wall clearance.
Do I Need to Bore my Cylinder?
If the instructions for your new piston say “bore & hone” or “bore / replate,” it’s because you ordered a piston that is larger than the stock bore size. Instructions to bore and hone your cylinder means your cylinder did not come plated from the OEM, and only requires to be machined out to the correct size for your piston. However, if it is a sleeved cylinder, consider having it resleeved depending on the time on the engine. Instructions to bore and replate your cylinder means your cylinder came plated from the OEM, so the only work required is to have the cylinder machined to the correct size for your piston, and then replated / honed.
5a986c920e569_Photo7.JPG.7b4377a3038963af63dd5a4dc581bd3c.JPGWe recommend having your local trusted cylinder shop do your boring and replating work.
In any case, we recommend having the cylinder bored by a professional machinist with the proper equipment. Cylinder shops that replate and resleeve usually have the capability to bore as well.
Don’t Forget to Chamfer and Clean Up
After any boring or honing work on a cylinder, it’s important to chamfer all ports and the bottom of the cylinder. Chamfering is smoothing out any sharp edge to leave a symmetrical sloping edge. Creating sloped edges on the bottom of the cylinder allows for easier piston and ring installation. You also want to make sure that the edges of the ports in the cylinder have a nice slope as well so the piston rings don’t get caught on any edges during engine operation.
If your cylinder has an exhaust bridge, be sure it is relieved .002” - .004” to allow for expansion.
5a986ca709a1f_Photo8.JPG.a675707bc4013e95dfa520f8173f3ab3.JPGExhaust bridge relief is important in certain 2-stroke applications. Read more about exhaust bridge relief here.
Lastly, be sure to properly clean any parts that have been worked on. Cylinders that have been bored and/or honed will have residual honing grit. This must be removed by washing with warm soapy water until an oil dampened cloth does not show any grit after wiping the surface of the cylinder wall. Once clean, apply a thin coat of oil on the cylinder wall before proceeding with your rebuild.
Always be sure to cover all your bases when freshening up the top end in your machine. Giving the required attention to all areas will help you be sure you’re getting the smoothest performance and most reliability out of your engine.
  • Like 15
  • Helpful 1
User Feedback
Recommended Comments
I don't necessarily agree.  I've rebuilt plenty of two strokes by cleaning piston residue (aluminum) off the cylinder with lye, and putting in a new piston and rings if the cylinder is in spec.  After running lean it or dry seize.  There's more potential to screw it up with a bad hone job than running what you have.  Plus it inevitably makes the hole bigger.  If static compression is in spec after doing so, you're good.
Edited by squared
  • Like 3
Share this comment
If you're just trying to knock the glaze out of the cylinder with a brush or ball hone, changing the size of a Nickle carbide bore is next to impossible. If you try to ball hone a two stroke with a hone that's too big, well, that's another matter.
  • Like 3
Share this comment
On 3/4/2018 at 10:09 PM, gumball37 said:
Hi, i should mention that for the optimun bore/hone job... "clearance wise"
Your machinest will need to take measurements from your new piston.
Absolutely. We provide finished size of all our pistons, which should be given to the machinist so the cylinder can be finished at the correct size allowing proper clearance.
Share this comment
Thank you for the comment. This is why we don't recommend using a ball hone unless absolutely necessary, in which case it still must be made sure that the grit and material of the ball hone is safe for the finish of the cylinder. A brush hone can reduce the glazing in common cases. Piston-to-wall clearance should always be checked as well before final assembly.
On 3/2/2018 at 2:44 PM, UG_ALLSTAR said:
Good read and an excellent resource.
Thank you!
Share this comment
You failed to mention how brittle plating is and why it is very risky to run a ball hone in a two stroke cylinder. When the balls clear the ports they will gain some speed and smack the plating upon clearing the port. Which runs a very high risk of chipping the plating around the ports....
Maybe should have listed some alternatives to deglazing other then a hone such a WD40 and a scotchbrite pad.
Share this comment
Our main recommendation in the article for deglazing is a brush hone, which is much less dangerous than a ball hone. Ball hones should only be used when absolutely necessary, and they must be used with caution, as you noted. Personally, I think if someone needs  a ball hone because the glazing is that bad, it'd be safer to have a professional shop refinish it. Scotchbrite and WD40 is definitely another option, it's just tougher to regulate degree of the cross hatch.
Share this comment
The deglaze recommendation has been around for quite some time, I've been rebuilding engines since the early 70s and first heard it then.  I'd wager a guess that it's been around since before ww2 when metals, manufacturing and machining were not what they are today.
I'm not a metallurgist, but I do hold a doctorate in engineering, and I don't think it's required in a lot of instances.  This needs to undergo a controlled test to demonstrate the efficacy of the process and identify the relevant factors.  Lubricants have also changed significantly, and a glazed cylinder, like chrome may present less friction..again, it needs to be tested.
Share this comment
On 3/16/2018 at 2:04 PM, wazzabie said:
Is a hone like this ok to use?
As long as you're good enough with your motor to keep the stones completely within the bore. The second one of those stones reach up past the bore's depth or height, it'll kick over like shown in the picture, then smack back down within the bore. Not ideal. So the question is, are YOU good enough to use one like that?
Share this comment
No. That is a brake cylinder hone, not a brush hone.
Share this comment
Recently (10 hours)  put in new piston and rings, I didn’t do any prep to cylinder. After reading your article I feel like I should have some work done to the cylinder and possibly get another set of piston and rings (even though this set is close to being brand new.
Curious as to what an expert like yourself would recommend!
Thanks!!
Share this comment
Thanks!!
From the photos, the cylinder does look like it has a good amount of glazing, so I would recommend at least getting a soft hone brush or even a scotchbrite pad in there to deglaze and get some of your hone pattern back. The cylinder wall won't hold much oil in the condition it's in now. You may be able to reuse the same piston as long it looks good after inspection, but I would re-ring it so they break in with the redone cylinder. Make sure you clean the cylinder thoroughly with soap and warm water after deglazing! You should be able to wipe a white rag over the surface after cleaning and not see any black residue.
Share this comment
  • Similar Content
    • By Alby Swadling
      Hi just looking for some advise as i just bought a tm 300 2 stroke 2004 and unfortunately its overheated and damaged the piston and head so i was just wondering as im new to 2 strokes what kind of damage ive done and what else to check for and you’ll see the damage in the photos. For some reason the air filter has come off which i thought it would make it run a bit lean plus i did the fuel ratio at 40-1 rather than 33-1 so yeah my fault but im looking to repair the bike and to get it back running again.
    • By Austin McQuiller
      So I acquired a 1994 DS 80 that had been sitting in a shed for a few years after sitting up against a garage for a few years. I decided to tear it apart and found a bunch of Ice inside one of the covers. I then decided to rip the thing completely apart figured either it’s gonna be a lot of pieces I can’t put back together or a lot of pieces I can figure out. (I’m an automotive mechanic and didn’t figure a dirt bike could make me look to stupid)
      Upon getting it completely ripped down it seems as if the lower end has been rebuild very shortly before it was abandoned, and the top end was completely shot. I found a 2002 JR 80 online that had a fresh top end rebuild on it just before the guys son tried to replace the kickstarter gear without splitting the casing. Enough said I got it split apart and the tension spring for the kick starter was wrapped around the gears.
      Going back together what is the best way to make sure all off the gears are completely lines up or what do I need to watch for? Also the shift pins in the shift cylinder (not sure what the thing is actually called) there is one pin different from the others and I’m not sure the location it needs to be in.
    • By Samuel Theriault
      Hello!
      This weekend I opened up my 2004 yz125 and was pretty surprised by the condition of the parts. I ran it for a whole season and before that was PO's time on top which supposedly isn't more than 2-3 hours but never can be sure about that.
      I was thinking of doing a top end job on it but after seeing what it looks like I am tempted to run it another season. This is my first time opening up a bike hence why I am asking for advice. I will attach a bunch of photos of the cylinder, head, and piston. I was pleased by the very small amount of carbon build up on the piston crown and the extremely small amount of up down play in the rod. In fact I can't feel any play in the rod but only a tiny amount in the piston itself. None of the vertical lines in the jug catches my finger nails.
      I have quite a few questions that I will label with numbers to make answering easier.
      1. Do you think this can run for another season?
      2. Should I atleast change the ring?
      3. What is the ring gap size supposed to be? (manual doesn't talk about it, unless I missed it)
      4. The manual talks about aligning the ring gap with a small pin in the ring grove. Is this relevant since the ring will just rotate away anyway?
      5. One of the circlips open end is near the piston pin slot but I can't rotate it away from it, is this okay? (both clips seem stuck)
      6. Is the nikasil still good on the cylinder? (especially above the exhaust port it seems worn off)
      7. kinda off topic, how do I unplug this connector? (image below)
      8. Just as an extra, what should I look for in general when opening up a two stroke like this?
      Thanks alot in advance! I can get more pictures if any of you want to.
    • By Mahali 27
      My friend recently gave me his pit bike cause he no longer had the time to fix it up. The bike needs a new gasket on the right side of the engine, or a sealer to hold compression (I’m not sure what it’s called) and a piece to connect the fuel line to the motor (also not sure what that’s called) he has bought multiple gaskets but none of them seem to fit, we’re not sure what make it is but it’s a 125cc. I’m new to dirt bikes and don’t really know much but I’m trying to fix it up. If anyone can tell me what kind of bike it is or any tips that would be very much appreciated.
    • By Kevin from Wiseco
      The piston is one of many wear items in your powersports machine. It may last longer than tires or a chain, but it should still be treated as normal maintenance when the time comes. Here, we go through key tips to help you know when it's time for a refresh.
      The piston in an internal combustion engine is arguably one of the most important components found in the engine. When it comes to high-performance engines used in powersports applications, it is also a component that is regularly replaced and serviced. Knowing when your piston should be replaced and how it wears is key to maintaining a reliable engine. To help you make that decision, we laid out replacement intervals, piston wear, why it’s important to replace the piston, and piston replacement options.
      Piston replacement intervals are typically outlined in your machine’s factory service manual. Using dirt bikes as an example, many manufacturers outline a piston and ring replacement schedule of every six races or 15-30 hours for a four-stroke, depending on the machine. If you’re new to the sport or have never looked at your factory service manual, these service intervals may seem shockingly short. The service intervals are based on the service schedules required to maintain a high-level racer’s machine. Unfortunately, for the average rider, the outlined service intervals commonly end up being conservative.
      The recommended piston service intervals outlined in your manual may be shocking, but the actual required service time depends on many variables that differ by each rider.
      In reality, piston replacement intervals should be established based on how the individual owner rides and maintains their machine. It’s true that forged pistons exhibit greater strength and wear resistance, but the variables of rider and maintenance still apply. Engine displacement, engine make, air filter maintenance, environmental conditions, riding style, and the type of riding the machine is used for will all influence how long the engine should be operated before servicing it. Monitoring the engine’s health through periodic checks such as compression and leak down tests is the best way most riders can appropriately time major service tasks, such as piston and ring replacement. Due to the number of variables that affect engine wear, it is simply not possible to specify a replacement schedule that fits everyone’s needs other than a very conservative schedule.
      Realistically, there are too many variables to establish an official recommended piston replacement time. Sticking to the short time recommended in the manual can be overkill for some, but keeps things on the safe side. (We are not endorsing dry assembly with this photo, it was just mocked up for photo purposes.)
      Piston wear will typically occur in four key areas for both two and four-stroke engines, which include the piston skirt, wrist pin bore, ring grooves, and piston crown. The next time you disassemble your top end, keep an eye out for these wear points.
      Piston Skirt Wear
      Nowadays, on four-stroke engines, the piston skirt is very short and limited to the major and minor thrust faces of the piston. For reference, the thrust faces correspond with the intake and exhaust valve sides of the cylinder head. Two-stroke pistons use the same nomenclature, but feature much longer, more pronounced skirts.
      Piston skirts experience load on the major and minor thrust sides, resulting in wear in those areas.
      Piston skirt wear occurs because of the thrust loading that results from the inherent geometry of the crank mechanism as the engine fires. Peak combustion pressure occurs slightly after top dead center, which causes the piston to thrust into the cylinder wall.
      Skirt wear can be observed both visually and by measuring the skirt’s diameter and referencing it against the diameter outlined in your service manual. Skirt wear will appear as a polished area on the major and minor thrusting faces of the piston.
      Notice the polished-looking wear marks on the forged piston on the left, and the vertical wear marks on two-stroke cast piston on the right. These reflect wear after a substantial amount of run time. The grooves on the two-stroke piston are a potential sign of dust/dirt in the cylinder.
      Your pistons may feature one of a few different types of skirt coating. Wiseco pistons utilize different types of skirt coatings depending on the piston, including ArmorGlide and ArmorFit coatings. These coatings are screen printed on and are applied to remain on the skirt for the life of the piston. You will likely see some wear on the skirt coating after putting time on your piston(s), but if it is worn all the way through the coating, there’s a good chance there’s an underlying issue that needs investigation. Too little clearance, foreign material in the cylinder, and improper cylinder preparation could be causes of excessive skirt wear.
      This piston is equipped with ArmorGlide skirt coating. However, the wear patterns are indicative of the possibility of foreign material, such as dirt, making its way into the cylinder.
      On two-stroke engines, skirt wear can occasionally be heard audibly while the engine is running, which is commonly known as “piston slap”. A rhythmic metallic sound often accompanies a loose or worn piston when the engine idles. What can be heard is the piston rocking back and forth in its bore as it reciprocates.
      Piston Crown
      Piston crown wear will occur as a result of aggressive or improper tuning, and on four-stroke engines, a damaged or mis-timed valvetrain. Engines operated with a lean mixture at full throttle will see abnormally high combustion temps, which can cause detonation. The results of detonation will be visible on the piston crown as a pitted or eroded surface.
      The pitting in the center is a pretty clear sign of detonation. In many cases, pitting and erosion will be much more evident the leaner the running conditions.
      Piston crown damage due to valvetrain contact will be visible as indentations or cracks near the valve pockets. Valvetrain contact can occur due to valve float caused by excessive RPM or mis-timed valves.
      Notice the half-circles in the valve reliefs. This is a clear sign of valve contact with the piston.
      Ring Groove Wear
      The piston rings move in and out of their grooves because of the ignition of the air/fuel mixture in the combustion chamber. Once the mixture is ignited, the cylinder pressure increases which energizes the compression ring and forces it against the cylinder wall, causing it to slide in its groove.
      On four-stroke engines, the compression ring will transition from seating on the bottom of the ring groove to the top ring groove at the end of the exhaust stroke due to forces of inertia acting on the ring.
      Ring movement during operation will eventually wear ring grooves beyond their designed size. Substantial run time can also leave carbon deposits in the ring grooves, affecting ring seal and performance.
      Ring and groove wear can occur due to the sliding and reciprocating motion of the rings and can be exasperated by carbon deposits that accumulate in the ring groove. Ring and groove wear can be qualified by thoroughly cleaning the ring and groove and then measuring each. Most service manuals outline specifications for ring width, groove width, and piston ring to ring groove clearance.
      Ring wear can be easily visually observed, but can be confirmed by taking axial height and radial width measurements and comparing them to the original spec.
      Wrist Pin Bore Wear
      Wrist pin bore wear occurs as a result of the loading of the wrist pin joint through inertia and combustion loading. The wrist pin bore will typically wear into an oblong shape. In some engines, wrist pin bore wear will be visible in the top and bottom of the bore. Usually, a portion of the bore will appear burnished or polished. Alternatively, the wrist pin bore can be measured from top to bottom and from side to side. Both measurements can be compared to one another to determine how much the bore has become out of round and to the diameters specified in the service manual.
      Wrist pin bores typically wear into a vertical, oval shape due to the pushing and pulling forces of engine operation. Visual inspection can show excessive wear, and a vertical and horizontal diameter measurement can tell you how out of round it is. If it's proving out of round, it's probably time for a replacement.
      The importance of replacing the piston at regular intervals in high-performance powersports engines cannot be overstated. If left unattended, the resulting cumulative wear of the piston will eventually result in a catastrophic and expensive engine failure. Typically, too much time on a piston can lead to gradual and finally complete failure of the skirt in both two and four-stroke engines.
      Between aftermarket suppliers and OEMs, replacement piston options are plentiful and can be overwhelming. The most common upgrade and consideration most riders are faced with is whether or not to move to a forged piston. Forged pistons can be a nice upgrade for many riders because they can offer additional strength and wear resistance over cast pistons.
      Forged pistons achieve greater strength than cast pistons by using different aluminum alloys and manufacturing processes. The forging process for pistons results in finished components that have a tighter molecular structure and grain flow optimized for strength. Comparatively, cast pistons are not cast under high pressures and have molecular structures that are not as tight or organized, which in severe cases, can lead to voids, inclusions, and air pockets.
      Forging pistons results in a better-aligned grain flow and higher tensile strength.
      Read more about how Wiseco forges pistons here.
      Wiseco has been forging pistons in the U.S. for decades and has spent countless hours on research and development to make their forged pistons the option that best combines performance and wear resistance. Still, there is a lifespan to a piston, and the above tips should be used to practice regular maintenance on your machine.
