How to get a non running bike running again
thejunkman
So you have a bike that is not running. Maybe it is a bike that you have had for years and it has just been sitting or it is a bike your looking at for sale but the owner states "ran when parked" meaning, it doesn't run now. As a matter of fact the latter is how you can generally get a great deal on a bike and with this article and video you can take advantage of that non running bikes low price.
Typically the reason a bike was running and now isn't is usually fairly simple. Most problems can be traced to the fuel system, probably causes is fuel was left in the system creating a varnish like substance when the lighter elements of the fuel flashed off. This leaves the small passageways clogged or plugged resulting in inconsistent or no fuel flow. There also could be minor ignition issues but usually that is rare, more on that later. Lets get back to basics.
Click on the Getting a non running bike running video to see an in depth video of the procedure outlined below:
Step 1
Evaluate the bike, is it missing crucial parts for it to run? If not start the dis-assembly for cleaning and inspection this includes the fuel tank itself. If it is missing parts, locate or source the missing parts before going further as this will minimize delays further in the process.
Step 2
Fully disassemble the carburetor and fuel shut off. These are the most common places that the problems will originate as well as where most of the debris preventing proper fuel flow and metering will be found.
Step 3
Clean, clean, clean, and more cleaning. Carburetor dip is a good idea for the carb body and other related parts. Just remember to remove any rubber or fiber parts as carburetor dip may "eat" or dissolve them.
Step 4
While your carburetor parts are soaking check out the ignition components. Replace the spark plug, it is cheap, and will rule out a potentially faulty plug of unknown condition, refer to a service manual for specific testing if you have a "no spark" condition. Most "no spark" conditions can be traced to a kill switch wire grounding out at the handlebar or somewhere along the harness.
Step 5
Reassemble the carburetor returning all the settings like the float height, jetting specs, and air/fuel screw (depending on which it has) to the factory specs found in the manual. Re-install the tank and fuel shut off. Attach the fuel lines use clamps when necessary. Fill the tank with a little bit of fuel open the tap and check for leaks and/or a flooding carburetor.
Step 6
If the previous steps were done properly attempt to start the bike. Be sure your in neutral and have your hand on the throttle and kill switch for safety so you can shut down the bike should something happen.
User Feedback
Recommended Comments
There are no comments to display.
  • Similar Content
    • By Chipewa
      Hey guys,
      I have a 1969 (approximately) Honda Z50. It was given to me after my uncle died. He would ride it around the dirt lake road between our families houses with a beer in one hand and a cigarette hanging out of the side of his mouth laughing the entire way. If you've ever seen or owned a Z50, they are a little ridiculous. All I wanted when I was younger was to ride his mini bike but I never got the opportunity. After he died, it sat in his garage for a number of years until i eventually came to own it.
      Unfortunately after sitting for so long, it is not starting at the moment. In addition he was not much of a mechanic so it needs some serious TLC. I thought it would be a great honor to restore it in his name and put it back on those lake roads.
      I need help guys. I can figure my way out around a bike but I am a little curious where to start with this old hunk. I would be happy to get it running again but I am also looking at possibly engine swapping this little guy (80cc or 125cc) if possible. And I know what you're thinking, "waste of time.. or this idiot has too much time on your hands"......agreed but I think you can agree that would be pretty badass. And for the short amount of time this thing gets used it would be a fun little project for nights at the lake.
      If you have any advice on where exactly to start or if the engine swap is possible please let me know. Not looking to hear from any of you automatic 'nay-sayers,' have a little imagination and appeal to your younger 12 year old self.
      Thanks,
      Chip
    • By Paul Olesen
      I thought this week it would be a good idea to share with you an example of what can happen when dirt gets passed an engine's air filter. This will be a short post, but a picture is worth a thousand words. In my next post I’ll go into detail on how to properly care for your air filter to help ensure that this never happens to you.
      The series of photos below shows a sad case where dirt has found its way into the engine and wreaked havoc. The photos are all from the KX250F I bought on the cheap with the sole intention of rebuilding the engine and documenting the process for my book, The Four Stroke Dirt Bike Engine Building Handbook. Honestly, I couldn’t have bought a better bike for the project, nearly everything on the bike was worn out or screwed up from the previous owner.
      Here is how the air filter and airbox looked prior to disassembly.
      Here is the back side of the air filter. The filter was completely dry. There was no grease on the sealing face of the filter or the airbox flange. In this particular case, dirt could have got into the engine through the filter or between the filter and sealing flange. The amount of dried mud in the airbox and on the bike also makes me suspicious that muddy water got into the engine instead of just dirt. I honestly can’t say for certain.
      The airbox itself was also extremely dirty.
      Once the engine was disassembled I carefully examined the piston assembly and cylinder bore. At first, I could not get any of the rings to move freely. Only after I had pounded a pick between the ring ends of the compression ring was I able to get the compression ring off. As I removed the compression ring, a load of sand came with it.
      This photo of the compression ring doesn’t do the situation justice. Some of the dirt was actually removed from the ring as I handled it.
      Here is a close up of the compression ring. Note all the grit!
      The oil rings didn’t fair any better, were just as stuck, and had a lot of dirt on them.
      Here you can see dirt inside the ring grooves and at the edges.
      Here is dirt I rubbed off the oil rings.
      Miraculously (and fortunately for me) whether the engine sucked in dirty air or water, it happened quickly and stuck the rings to the piston so they could no longer seal correctly, and the engine subsequently lost compression and power in a hurry. This speculation is based on the fact that the cylinder bore showed no signs of excessive wear or damage and it measured well within the service limits. This is an outcome I never though possible and is hard to believe.
      I hope you enjoyed this brief write up on the damage that can result from ingesting dirt, whether from abnormal circumstances such as dropping a running engine into a mud hole or simply neglecting to take care of the air filter when running the engine in dusty conditions. In my next post I’ll show you how to care for and install your filters so these problems don’t happen to you! Questions or comments are always welcome and I enjoy hearing from you all!
      -Paul
      https://www.diymotofix.com/
      If you like my blog, click the "Follow this blog" button in the upper right. You must be registered to do this.
    • By Bigbenny54
      Hi everyone,
              So I recently purchased a 2001 YZ250 with no Engine. I am looking to make it in to a single track enduro bike. I am right now looking for some what of a complete engine and have come across one recently pulled motor out of a 2011 yz250. To my knowledge the only thing different about the motors from pretty much 99-Present is the swing arm pivot. I guess they changed sizes in 02. I was wondering if anyone knew if it is possible to interchange that 2011 engine into an 2001 frame?
      Thanks!
    • By Mastermason434
      Color Touchscreen GPS/GLONASS Handheld with Preloaded TOPO Maps
      > 2.6-inch color capacitive touchscreen
      > 3-axis tilt-compensated compass and barometric altimeter
      > GPS and GLONASS satellites for faster positioning
      > 250,000 preloaded geocaches from Geocaching.com
      > Preloaded TOPO U.S. 100K maps with extra internal memory to hold more maps
      eTrex Touch 35t is a compact, rugged and reliable GPS/GLONASS handheld with color touchscreen, preloaded TOPO 100K maps, dual GPS and GLONASS satellites positioning, 250,000 preloaded geocaches and wireless connectivity (ANT+®, VIRB® and smart notifications). With a 3-axis tilt-compensated electronic compass and barometric altimeter, you’re ready to navigate anywhere.
      More @ https://buy.garmin.com/en-US/US/into-sports/handheld/etrex-touch-35t/prod529595.html#gallery-dialog
    • By ThumperTalk
      Xtreme White bulbs give a cool white light output so the driver has better color perception on depth perception and better contrast than conventional halogen lamps
