HOW TO: Keep Your Cables In Fine Working Order
FiftySeven
Required Tools: Cable lube, cable lubing tool, 8mm T-handle or socket, 10mm box-end wrench.
CLUTCH CABLES
STEP 1: Start by spinning the quick adjuster on the clutch perch inward to increase the amount of cable free-play. By doing this you will reduce the overall tension of the cable, making the process of pulling the cable out of the clutch perch a snap.
STEP 2: Now that the cable has plenty of free-play (slack), align the slot in the adjuster with the slot in the perch so that the cable will be able to slide through the clutch perch. With one hand, grab the cable and pull it in the direction away from the perch. With your other hand, pull the clutch lever back to the bar and release it quickly, snapping it out. A couple snaps of the clutch lever may be necessary to pop the cable free. After sliding the cable through the lined up slots and out of the perch, the ball at the end of the cable should easily pull out of the clutch lever.
STEP 3: Install your cable-lubing tool onto the end of the cable between the cable housing and the cable ball. Your cable-lubing tool will have a larger diameter hole on one end, which is designed to butt up against the cable housing. Now that the lubing tool is in place, stick the cable lube spray nozzle into the hole on the lubing tool and spray lube until you see it run out of the cable housing at the opposite end of the cable near the clutch cover.
STEP 4: Now that your clutch cable is nicely lubed, the final step is to put the assembly back together. Start by pushing the ball back into the lever. Next, be sure that the slots on the quick adjuster and the perch are still lined up, and slide the cable back through the perch. To easily get the cable housing back into its home on the clutch perch, follow the same procedure that you used to pop it out. Again, this is done by pulling the cable in the direction away from the perch and snapping the clutch lever until it pops into place. Finally, turn out your quick adjuster to take out the free-play until it feels right for you.
THROTTLE CABLES
A push-pull style four-stroke throttle is used in this example. The same principles will apply when lubing the throttle cable of a two-stroke, but only one cable will be present, making the process even easier.
STEP 1: Start by using a 10mm box-end wrench to loosen the adjuster screw located on the outer side of the throttle housing.
STEP 2: On a four-stroke, be sure to pay close attention during this step to how the two cables are routed through the housings and attached to the throttle tube.
Remove the two 8mm bolts that hold the two halves of the throttle housing together. Pull the housing halves apart to expose the cables, again paying close attention to their routing. Next, pull the cable balls out of the throttle tube. It’s usually best to leave the throttle tube and housing on the bar during this step as you may not have enough free-play in your cables to slide it off the end of the bar. Forcing it off could cause binding and/or damage to the cables.
STEP 3: Now that the cables are disconnected from the throttle tube, pull out the throttle guide (present only on a four-stroke), and remove each cable from their housing. Now that your cables are completely removed from the throttle housing, follow the same steps as found in “STEP 3” of the clutch cable procedure for the lubing of each cable. Note: Before spraying the lube it is best to remove the cables from the carburettor to prevent the excess lube from settling on the diaphram.
STEP 4: The final step is to reassemble the throttle mechanism. Lay the first cable over the throttle guide and slide the guide into the housing. The guide should slide with little effort and will butt up against the throttle housing. Repeat this process with the second cable by laying the cable over the cable guide first, and then slide the guide into the second half of the housing. Now that the two sides of the housing are pressed back together, the cables must be rerouted and fastened to the throttle tube. The cable on the right side of the throttle housing (closest to the brake reservoir) will wrap around the side of the throttle tube. The cable on the left side will wrap around the opposite side of the housing. Secure the housing halves back together with your 8mm, but leave them somewhat loose. Push the throttle tube until it bottoms out into the bar end and then back it out just a fraction of an inch so that the tube does not bind up against the end of the bar. Once you find the proper placement of the tube, securely tighten the 8mm bolts. Finally, adjust the free-play, if necessary, out of the throttle cable with your 10mm box end on the throttle cable adjusting bolts to your liking.
User Feedback
Recommended Comments
There are no comments to display.
Join the conversation
Guest
Add a comment...
  Only 75 emoji are allowed.
Loading...
  • Similar Content
    • By NoFiddyPilot
      The Phoenix 118 handlebar will take you and your dirt bike anywhere your heart desires. Whether you are carving through the trees, racing moto’s at your local track, or enjoying trails with your family, we have the setup to make your day of riding even more fun.
      CLAMP AREA (1-1/8”)
      The oversized clamp area is 1-1/8”(28.6mm) to allow for a tapered design that creates strength while eliminating the crossbar clamp to allow added flexibility. What that means is your arms take a little less punishment and your day of riding goes on a little longer.
      WIDTH (800mm)
      Laser-etched cut-lines on the ends of the bars help for those that are dodging tight trees and need to shave off metal. Or maybe you simply feel the 800mm (31.5”) width feels too wide. Measure twice, cut once, install grips, go ride.
      SWEEP (55mm/12°)
      Keeping your elbows up is critical to control your bike. All of our bars have a 55mm/12° sweep that helps put you in that proper position.
      HEIGHT
      Four different rises allow for an easier choice in finding the right bar for your motorcycle. It is not a hard and fast rule that your height means you need a particular rise. It’s a personal preference for those that want a shorter bar or one that is quite a bit taller. We are here to assist in finding the right bar height.
      options: 70mm - 80mm - 90mm - 100mm
    • By throttlebuff
      I came on to see if anyone is having handling issues.  I cannot seem to figure out what is going on but since I have owned this bike I have problems controlling the thing. it's been a couple of years.  I let a buddy ride it and when he handed it back he was shocked i was even riding it the way it is.  I recently bought a 150Xc for my son and it feels so stable compared to mine.  how is that possible?  I thought maybe it was the rubber handle bar mounts as I was getting almost a quarter inch of wiggle on the bars. I replaced them 2 times.  that didn't help. I have tried various PSI in the forks.  tire pressure is fine. right now i am at 135psi and 15 15 on the rebound and dampening.  i weigh 190. i  have forks at the second line at the top.  the bike seems to either ping off stuff or is jerky or something. I feel like I have no flow and am constantly trying to make corrections. it is tiresome.. this isn't like reacting to obstacles but a genuine problem i am having with controlling the bike on single track. Sometimes it's like I am turning to much too soon and have to bring it back and other times i am not turning enough.  i am 50 years old 190lbs and am seriously starting to think it is my &%$#@!ing body getting weak or something.  when it is not a turning issue and i am in a technical uphill obstacle situation however, my riding has greatly improved.  so, i don't think this is the case.  something is going on and it is driving me &%$#@!ing nuts, because i am developing a shitty ride style because of it..  I had a minor bend in the front rotor that i replaced because i thought maybe this was setting it off while braking but that didn't help me.  so, i am now either selling the &%$#@!er or thinking about sending forks off to get setup as the guy i bought it from had them done and although we are about the same size i don't know what was done to them.  Just seeing if anyone has had any problems or heard about other folks having issues.  i love the bikes power and have modded the starter so it fires up quick and would rather not deal with selling and buying.  The stability of my sons 150 is what made me think about getting rid of it as it has seems funky since i got it and I ain't the only one who thinks that it is awkward to control.  hope this finds everyone doing well and you are getting in a lot of seat time.
    • By mikenac
      Pro Pegs Titanium Footpegs
      The Choice of Champions including Brett Metcalfe, Justin Brayton, Malcolm Stewart, Blake Baggett, Justin Bogle and many more!
      Tig Welded Aerospace Ti-6AL-4V Titanium
      60 mm (2.4”) Wide Design
      Lightweight ( 350 gr/Set )
      30 Teeth for ultimate grip
      Precision Fabrication by Hand
      Reduces boot wear as your foot is no longer grinding away on the peg!
      Manufactured to the highest standards from aerospace grade titanium, using the latest manufacturing techniques to produce the strongest welds, eliminating stress and corrosion. Pro Pegs Titanium sets the standards with a bigger platform and greater surface area providing the rider with maximum GRIP!
      Pro Pegs Ti pegs weigh only 175 grams each. (5.9 oz). About half the weight of the stock steel pegs with almost twice as much support and grip!
    • By John Bond
      RFX Pro Series Flex+ Gear Levers have all the same great features as the Factory Edition but include a forged shaft instead of the billet machined part. This helps reduce cost and makes this an excellent affordable high grade lever replacement for everyday racers.
      Features a new style, color anodized, CNC machined anti-stick tip which resists dirt build up thanks to an enclosed spring design. Also included is a new style low profile tip bolt which stays tighter for longer.
      Features:
      New Anti-Stick folding gear tip New enclosed tip design New low profile gear tip bolt Forged shaft and tip for increased strength Knurled tip for improved gear shifts Stainless steel spring & Pivot to resist corrosion Laser etched RFX logo
    • By John Bond
      RFX Hardware Pro series CNC parts are designed, tested and manufactured for the serious competitor. Using our 30 years of racing and engineering experience we have blended quality designs, superior materials and precision manufacturing processes to create factory racing parts available to everyone.
      Pro series CNC parts are race tested by top UK and Worldwide race teams.
      Pro series CNC footrests, levers and controls are available for all modern motocross and enduro bikes.
      FEATURES
      CNC Aerospace grade billet aluminum construction Flexible pivoting tip to reduce impact damage Tight manufacturing tolerances for improved fit Quality hardware throughout the range Color anodized for that factory look Laser etched logo on all products Tested by top UK race teams
