How To Rebuild Control Cables
ronbuell
Last year I had some bad luck as I was working on my bike and found a broken throttle cable. Yamaha wanted like $40 for a new set, (and didn't have them in stock anyway) and I wanted to save the ride that day, sooooo, here goes. NOTE: I own a MIG welder, so this was easy.
I went to the hardware store and found some round steel rod of approximately the same size as the end that came off my cable. The I took a 4" angle grinder with cutoff wheel and cut a slot for the cable to slide into. Taking the MIG, I grounded the rod, and set the heat and feed down slightly from a thin metal setting. I tacked the end of the cable first, check the position and then hit it again in the slot. Then I smoothed off the weld with the cut off wheel and cut the rod off at the appropriate length to fit the throttle wheel on the carb. All I had to do then was adjust the slack to install the cable and I was done. That was last year and the cable is still working fine.
Since then, I've also been able to repair clutch cables in the same manner. AND... I've found a source for new inner cables:
http://www.jagwireusa.com/index.php/products/mountain/499
My local mountain bikes store carries these and for less than $5.00 I can get a new inner cable and simply weld on a new end once cut to length. It's a great way to save money in these tight times!!
Ride hard, reduce your cholesterol 30 points !!!
User Feedback
Recommended Comments
There are no comments to display.
Join the conversation
Guest
Add a comment...
  Only 75 emoji are allowed.
Loading...
  • Similar Content
    • By NoFiddyPilot
      The Phoenix 118 handlebar will take you and your dirt bike anywhere your heart desires. Whether you are carving through the trees, racing moto’s at your local track, or enjoying trails with your family, we have the setup to make your day of riding even more fun.
      CLAMP AREA (1-1/8”)
      The oversized clamp area is 1-1/8”(28.6mm) to allow for a tapered design that creates strength while eliminating the crossbar clamp to allow added flexibility. What that means is your arms take a little less punishment and your day of riding goes on a little longer.
      WIDTH (800mm)
      Laser-etched cut-lines on the ends of the bars help for those that are dodging tight trees and need to shave off metal. Or maybe you simply feel the 800mm (31.5”) width feels too wide. Measure twice, cut once, install grips, go ride.
      SWEEP (55mm/12°)
      Keeping your elbows up is critical to control your bike. All of our bars have a 55mm/12° sweep that helps put you in that proper position.
      HEIGHT
      Four different rises allow for an easier choice in finding the right bar for your motorcycle. It is not a hard and fast rule that your height means you need a particular rise. It’s a personal preference for those that want a shorter bar or one that is quite a bit taller. We are here to assist in finding the right bar height.
      options: 70mm - 80mm - 90mm - 100mm
    • By throttlebuff
      I came on to see if anyone is having handling issues.  I cannot seem to figure out what is going on but since I have owned this bike I have problems controlling the thing. it's been a couple of years.  I let a buddy ride it and when he handed it back he was shocked i was even riding it the way it is.  I recently bought a 150Xc for my son and it feels so stable compared to mine.  how is that possible?  I thought maybe it was the rubber handle bar mounts as I was getting almost a quarter inch of wiggle on the bars. I replaced them 2 times.  that didn't help. I have tried various PSI in the forks.  tire pressure is fine. right now i am at 135psi and 15 15 on the rebound and dampening.  i weigh 190. i  have forks at the second line at the top.  the bike seems to either ping off stuff or is jerky or something. I feel like I have no flow and am constantly trying to make corrections. it is tiresome.. this isn't like reacting to obstacles but a genuine problem i am having with controlling the bike on single track. Sometimes it's like I am turning to much too soon and have to bring it back and other times i am not turning enough.  i am 50 years old 190lbs and am seriously starting to think it is my &%$#@!ing body getting weak or something.  when it is not a turning issue and i am in a technical uphill obstacle situation however, my riding has greatly improved.  so, i don't think this is the case.  something is going on and it is driving me &%$#@!ing nuts, because i am developing a shitty ride style because of it..  I had a minor bend in the front rotor that i replaced because i thought maybe this was setting it off while braking but that didn't help me.  so, i am now either selling the &%$#@!er or thinking about sending forks off to get setup as the guy i bought it from had them done and although we are about the same size i don't know what was done to them.  Just seeing if anyone has had any problems or heard about other folks having issues.  i love the bikes power and have modded the starter so it fires up quick and would rather not deal with selling and buying.  The stability of my sons 150 is what made me think about getting rid of it as it has seems funky since i got it and I ain't the only one who thinks that it is awkward to control.  hope this finds everyone doing well and you are getting in a lot of seat time.
    • By mikenac
      Pro Pegs Titanium Footpegs
      The Choice of Champions including Brett Metcalfe, Justin Brayton, Malcolm Stewart, Blake Baggett, Justin Bogle and many more!
      Tig Welded Aerospace Ti-6AL-4V Titanium
      60 mm (2.4”) Wide Design
      Lightweight ( 350 gr/Set )
      30 Teeth for ultimate grip
      Precision Fabrication by Hand
      Reduces boot wear as your foot is no longer grinding away on the peg!
      Manufactured to the highest standards from aerospace grade titanium, using the latest manufacturing techniques to produce the strongest welds, eliminating stress and corrosion. Pro Pegs Titanium sets the standards with a bigger platform and greater surface area providing the rider with maximum GRIP!
      Pro Pegs Ti pegs weigh only 175 grams each. (5.9 oz). About half the weight of the stock steel pegs with almost twice as much support and grip!
    • By John Bond
      RFX Pro Series Flex+ Gear Levers have all the same great features as the Factory Edition but include a forged shaft instead of the billet machined part. This helps reduce cost and makes this an excellent affordable high grade lever replacement for everyday racers.
      Features a new style, color anodized, CNC machined anti-stick tip which resists dirt build up thanks to an enclosed spring design. Also included is a new style low profile tip bolt which stays tighter for longer.
      Features:
      New Anti-Stick folding gear tip New enclosed tip design New low profile gear tip bolt Forged shaft and tip for increased strength Knurled tip for improved gear shifts Stainless steel spring & Pivot to resist corrosion Laser etched RFX logo
    • By John Bond
      RFX Hardware Pro series CNC parts are designed, tested and manufactured for the serious competitor. Using our 30 years of racing and engineering experience we have blended quality designs, superior materials and precision manufacturing processes to create factory racing parts available to everyone.
      Pro series CNC parts are race tested by top UK and Worldwide race teams.
      Pro series CNC footrests, levers and controls are available for all modern motocross and enduro bikes.
      FEATURES
      CNC Aerospace grade billet aluminum construction Flexible pivoting tip to reduce impact damage Tight manufacturing tolerances for improved fit Quality hardware throughout the range Color anodized for that factory look Laser etched logo on all products Tested by top UK race teams
