How to repair stripped carb float bowl threads
yzdude250f
Ever backed out a stuck screw on you carb and brought the threads out with the screw or crossed threaded the fine threads on your costly carb and think its trashed well think again, here is a simple fix to get you going again within under an hour.
I'm about to show you how to stripped threads on a flat fcr carb and these procedures follow (should be similar on other models)
first you need to go to a local auto-parts store or hardware store and get a helicoil kit for the stock bolt size m4 x 0.7 (standard on fcr 37 flat side carb) others models may be different) mine was purchased at koi auto parts for around $30.00 but we got my dads discount actual price is closer to $55.00 the helicoil kit comes with 12 helicoils and the proper tap tool, you also have to purchase a 11/64 drill bit to oversize the the hole and drill out the remaining threads so you can inserts the helicoil.
Get a clean work space.
Now gather your tools.
Assuming your float bowl is already off due to the stripped threads in the hole if not remove now.
Gather your Helicoil kit or similar kit (Helicoil brand part #5546-4)
11/64 drill bit drill and some fresh screws to put in the new inserts anti seize torque wrench i used a 1/4 inch pound wrench
and lastly some lube for the threads when you drill them.
Step One
inspect the carb (Im pointing to my stripped hole below)
now clean out the the loose thread debris with a fine pick or something similar. now get your drill and insert the drill bit and start drilling out the damaged threads (i replaced all mine to be safe but the bad one was really the one by the fuel inlet this is a tricky one because you cant drill all the way through like the others so you have to measure the depth and set the depth with a bit stop so you dont go too far and go into the fuel inlet cavity. * TIP (securing in a vice makes this whole process easier)
(showing the bit stop)
Step Two
get out your tap and make the new threads for the Helicoils to thread into.
once you do this get the Helicoil insert tool and thread them in to the hole you tapped thread them a 1/4 to 1/2 below the edge of the surface. (except the back ones that are used to line up the bowl go ahead and insert these into they are flush enough for the bowl to flushly seal the surface) lastly you can break the tang on the Helicoils but its not needed if you chose not too.
(showing the tapping)
Lastly take your carb and blow through and clean with compressed air to get any metal shavings and insert your new screws into the bowl just as you did before and reassemble but this time use some anti seize so this does not happen again.Now torque them down properly i used a 1/4 inch pound wrench.
User Feedback
Recommended Comments
There are no comments to display.
  • Similar Content
    • By Paul Olesen
      I thought this week it would be a good idea to share with you an example of what can happen when dirt gets passed an engine's air filter. This will be a short post, but a picture is worth a thousand words. In my next post I’ll go into detail on how to properly care for your air filter to help ensure that this never happens to you.
      The series of photos below shows a sad case where dirt has found its way into the engine and wreaked havoc. The photos are all from the KX250F I bought on the cheap with the sole intention of rebuilding the engine and documenting the process for my book, The Four Stroke Dirt Bike Engine Building Handbook. Honestly, I couldn’t have bought a better bike for the project, nearly everything on the bike was worn out or screwed up from the previous owner.
      Here is how the air filter and airbox looked prior to disassembly.
      Here is the back side of the air filter. The filter was completely dry. There was no grease on the sealing face of the filter or the airbox flange. In this particular case, dirt could have got into the engine through the filter or between the filter and sealing flange. The amount of dried mud in the airbox and on the bike also makes me suspicious that muddy water got into the engine instead of just dirt. I honestly can’t say for certain.
      The airbox itself was also extremely dirty.
      Once the engine was disassembled I carefully examined the piston assembly and cylinder bore. At first, I could not get any of the rings to move freely. Only after I had pounded a pick between the ring ends of the compression ring was I able to get the compression ring off. As I removed the compression ring, a load of sand came with it.
      This photo of the compression ring doesn’t do the situation justice. Some of the dirt was actually removed from the ring as I handled it.
      Here is a close up of the compression ring. Note all the grit!
      The oil rings didn’t fair any better, were just as stuck, and had a lot of dirt on them.
      Here you can see dirt inside the ring grooves and at the edges.
      Here is dirt I rubbed off the oil rings.
      Miraculously (and fortunately for me) whether the engine sucked in dirty air or water, it happened quickly and stuck the rings to the piston so they could no longer seal correctly, and the engine subsequently lost compression and power in a hurry. This speculation is based on the fact that the cylinder bore showed no signs of excessive wear or damage and it measured well within the service limits. This is an outcome I never though possible and is hard to believe.
      I hope you enjoyed this brief write up on the damage that can result from ingesting dirt, whether from abnormal circumstances such as dropping a running engine into a mud hole or simply neglecting to take care of the air filter when running the engine in dusty conditions. In my next post I’ll show you how to care for and install your filters so these problems don’t happen to you! Questions or comments are always welcome and I enjoy hearing from you all!
      -Paul
      https://www.diymotofix.com/
      If you like my blog, click the "Follow this blog" button in the upper right. You must be registered to do this.
