Installing grips
Bryan Bosch
I'm sure there are a million different method for installing grips, but this has worked well for me.
Tools & Supplies Needed
- new grips
- Razor knife
- Some sort of solvent (paint thinner, acetone, lacquer thinner)
- Grip glue
- wire cutters
- Wire tie pliers
- Grip wire
- Hair dryer
Removing the Old Grips
Snip the grip wire with your wire cutters and cut the grips off with your razor knife. On the throttle side, be careful not to slice your plastic throttle tube.
Prepping the Bars/Throttle Tube
If your bars/throttle are not clean, the glue will have nothing to adhere to. Use your razor knife to carefully remove any chunks of old glue and finally wipe both sides clean with solvent, letting the solvent evaporate before moving on to the next step.
Installing the Grips
Make sure you have the correct grip for the correct side of the bars. The throttle side has a bit larger inside diameter.
Many of the top grips are well, grippy. This means that sliding them on the bar/throttle tube with glue can be a nightmare. There is nothing worse than getting the grip 2/3rds of the way on and it won't budge any more! To avoid this, plug in the hair dryer and warm up each side of the bar, installing one side at a time. With the bar ends heated, apply grip glue to the bar and inside the grip. Because the bar/throttle tube is warm, the glue will become more fluid, allowing the grip to easily slide into place. I like to give the grip a full rotation on the bars before orienting it, so that I know the glue is distributed throughout the entire surface of the inner grip. In terms of how much glue to use, you only need enough for a very thin layer. More glue is not necessarily better.
Let the glue tack up for a few minutes and now you're ready to install your grip wire. Most grips have grooves already molded into them for this purpose, typically three wires per grip. You can tie the wires using a pair of vice grips, but specific grip wire pliers are the simplest to use and yield the best results. Snip off the excess wire and make sure that the ends of the wire are resessed into the grip and groove as not to irritate your hands.
Using this method, I've never end up with grips that begin to spin on the bars, something that can be a real issue if you use hand guards (open grip ends) and you ride hard in wet/muddy conditions.
Also, it's debatable if this method applies to the throttle side. I personally use glue & wire on the throttle tube, but many don't. It very well might be overkill, but on the other side of the coin, I never have grip slipping issues. What method that is best is up to you. :thumbsup:
User Feedback
Recommended Comments
Can anyone post pictures? I've never heard of the wire on grips before. I think I'm going to get heated grips to put in with my new grips. Is there anything different when doing that?
Share this comment
I use petrol i think i seen it one time on here. The petrol softens the rubber and when it sets it never moves. no messy glue
Share this comment
  • Similar Content
    • By Bryan Bosch
      FLO MOTORSPORTS 3.0 Foot PEGS
      Rounded Edges Loctite on Cleats Extra Wide platform. KTM Footpeg Size is 57mm Wide and 86mm long. Stainless steel Flat teeth Removable Teeth (Cleats) with 5mm Hex Self Cleaning Mud Grooves. Foot pegs are possibly the most over looked parts on a bike but one of the most important parts. No matter how much power your bike makes, it means nothing if there is no control of the bike . You probably haven't given much consideration to you're footpegs before, but pretty much all professional AMA  supercross , motorcross  and off-road riders ride go with aftermarket footpegs for a wider platform, more grip and overall control of the bike .
      Our Pro series Flo Motorsports Foot pegs will offer all of the above . The foot pegs you are about to purchase are the same pegs used by Factory Supercross teams like Traders Racing (Yamaha) , BPR Home Depot ( Yamaha)  and JMC Husquvarna.   Our pegs are constructed from highly durable 7075 T6 alloy making them much more durable then some standard cheap 6061 T6 that many competitors use on the market.
    • By ThumperTalk
      Each footpeg is cast from 17-4 stainless steel, given a solution-annealing treatment, and age-hardened for superior strength
      Width (57mm) and length (90mm); slightly convex platform for better boot positioning and grip when leaning forward or back
      Dual-plane teeth provide traction without the stuck feeling
      Available with 1/2 rear offset to allow more space
      Use your OEM springs, unless otherwise noted in application chart
      Made in the U.S.A.
    • By ThumperTalk
      Built-in ergonomics; adjustable grip, height and setup
      Electromagnetic-polished patented system
      Allow both standard and lowboy setup with reversible collar insert with each peg; collars may also be purchased separately to take footpegs from one make to another for an exact fit
      Superwide (58mm) for comfort and traction control
      8mm Fast Kamber Mounting System (FKMS) allows camber angle adjustment for more control to keep a rider on the bike
      Available in three versions: F3, F5 and F6
      F3 footpegs feature SS setscrew teeth; easily adjustable and replaceable
      F5 footpegs feature SS press-pin teeth that are semi-replaceable (can be replaced up to three times); no adjustment necessary; just bolt up and ride
      F6 footpegs have the same great features as the F3 and F5 but have an improved cleat design to provide sure grip footing in any terrain
      Each system comes with reversible collars, springs, an 8mm FKMS system and teeth (F3 footpegs come with two different height setscrews, and F5 footpegs come with press-pin teeth installed)
    • By ThumperTalk
    • By ThumperTalk
      Wider than stock for sure-footed comfort
      Cast from stainless steel not welded
      Serrated for positive footing, but points are rounded for safety
