Make it a bit easier to get that new tire on
Red Dog
I'm one who likes to have fresh tires on my bikes rather than run them til they're going bald. But with 3 bikes in the household, it seems I end up changing tires quite often. Am I fast at it? No, but I've learned that it pays to be smarter than the tire. As most of you already know when mounting a new tire, lubing up the bead certainly helps, but here in the desert it seems that the lube (generally soapy water or WD-40) dries before I'm finished. What I've found that works much better is the lube that electricians use for pulling wire through conduit. It's thick so it doesn't make a huge mess and stays where you want it, doesn't dry too fast, but it does dry, it's water soluble, is cheap, and can be found at the big box hardware stores as well as at the electrical supply outlets. Or maybe you have a friend who's an electrician that you can mooch some from.
What's your best tip on making tire installation easier? This is a wiki, so click the "edit" button in the upper right and help me expand this topic!
User Feedback
Recommended Comments
I use baby powder in the dez, how does that lub work for setting the bead. Rimlocks work great but still if too much gunt you can still spin a wheel on some bikes. Always looking to try something different especially if it makes it a little easier.
Share this comment
 This stuff works great! you can get by with the cheapo stuff at your 'Harry Homeowner' improvement store (but if you have a locally owned electrical supply in your town then support them - the stuff doesn't cost much). I use it on trials tires which are particularly tricky to get to seat because of the rim protector lip. Basically I smear a light coat of lube on the sidewall next to the bead (all over the rim protector lip) and then pump about 65 - 70 Lbs. into it. After a few minutes of this crazy over inflation the bead slips into place. Be sure to just use a light coat for this as you want it to eventually dry so when you let the air out to the regular pressure the bead won't pop back off.
Share this comment
I have a bucket of Ascot tie non diluted tire lube (like Murphys). You can use it straight like a jell or make soapy water with it.
Share this comment
  • Similar Content
    • By ThumperTalk
      An alternative from the originator of mini-bike training wheels
      Footpegs retain original factory location
      Swept back design positions the wheels more in line with the rider for improved handling and appearance
      Narrowed stance to help in avoiding obstructions while retaining stability
      Once installed, can be removed within minutes by removing retainer pins
    • By ThumperTalk
      Tire Application: Intermediate
      Tire Construction: Bias
      Tire Type: Offroad
      Rim Size: 19
      Tire Size: 120/80-19
      Position: Rear
      NOTE - SAFETY WARNING: For information on tire care, safety, maintenance, mounting, manufacturers warranty and other information consult tire manufacturers publication(s) and/or website(s) for complete tire information. The tires used for your application must have a load index and speed rating equal to or greater than the tires fitted as original equipment.
      High performance bias ply
      New Silica compound for improved wet and dry grip
      Dual tread compound on rear tire for longer life and better traction when cornering
      Larger crown radius for greater stability and extended tread life
      H speed rated
      Tubeless
      H speed rated
      Tubeless
      M403 front tire provides the rider with improved cornering control and feedback, even at full-lean angles
      M404 rear tire offers added traction and slide control, allowing better acceleration out of corners
      Performs well in a wide range of soils
      Prototype versions developed and tested by top AMA Supercross and Motocross racers and factory teams
    • By ThumperTalk
      Tire Type: Offroad
      Rim Size: 21
      Tire Size: 90/100-21
      Position: Front
      H speed rated
      Tubeless
    • By ThumperTalk
      Rim Size: 19
      Tire Size: 120/90-19
      Load Rating: 66
      Tire Type: Offroad
      Speed Rating: M
      Position: Rear
      Value-priced, offroad tire handles a wide variety of terrain conditions
      High durability construction for long wear and great traction
      All new compound for improved grip and durability
      Patterned after the popular D752 MX tire with a modified knob structure and resized knobs that also feature increased radius at the base
      Tube Type
      120/90-19
    • By ThumperTalk
      Position: Rear
      Load Rating: 64
      Rim Size: 18
      Tire Size: 4.00-18
      Tire Construction: Radial
      Tire Type: Trials
      Speed Rating: M
      New D803 was Geoff Aarons 2006 AMA Trails championship tire
      Rear tire is a radial that works great for offroad trail riding
      4.00-18
