IT'S NOT TOO LATE! Read more... ×
Octane Ratings: higher = better performance, right?
grayracer513
A lot of confusion, mystery, and myth surround the simple question of what grade of fuel to use, what octane ratings mean, what detonation is, and the value of racing fuels. Part of the reason for that is the marketing that oil companies have done for over 70 years, in which they have promoted high octane fuels as an easy avenue to increase performance, when in fact, this is a very much backwards perspective on the matter. It is engines originally built for higher performance that need it.
Let’s see if we can clear up some of the misinformation! Click on to page two where we'll start with "Detonation: what is it?"
Gasoline engines are designed to burn gasoline. They are not designed to “explode” or detonate it. There’s a huge difference. During normal operation, air and fuel is introduced into the combustion chamber, compressed so as to improve the force of expansion as it burns, then near top dead center, it is ignited by the ignition system. What is supposed to happen is that the fuel immediately adjacent to the spark plug is ignited, and as it burns it ignites the fuel surrounding it and so on outward from there very much like a wave of flame. It’s like making a circle of match heads on top of a table and dropping a lit match in the middle (or anywhere else in the circle). The flame will spread rapidly, but never instantly.
Detonation is different. Detonation is the simultaneous ignition of all of the unburned fuel in the cylinder at the time it occurs, all at once. Normal ignition is a heavy, sudden push that continues over 90 or more degrees of crank rotation; detonation is like hitting the piston with a hammer instead of pushing it, and often has the effect you would expect from doing that kind of thing.
Up next: Why and how does detonation happen?
Detonation occurs when the heat and pressure in the cylinder rise to the point where the gasoline is ignited by just that, and not by contact with a flame. Once that level of heat is reached, it affects all of the fuel that remains to be burned equally and at the same time, rather than progressively, as a flame traveling from droplet to droplet of the fuel mist, and all of it ignites in the same instant, creating insanely high spikes of pressure that can and do cause horrendous damage.
In practice, the causes are one or more of excessive heat in the combustion chamber that allows temperatures to rise too high during compression, timing that is too far advanced, allowing the flame to build too much pressure before it can effectively turn the crank, hot spots in carbon deposits that ignite the fuel early, or simply a fuel the does not have sufficient resistance to being ignited by heat and pressure alone. That is, a fuel with an insufficient octane number.
Most of the time, what happens is that ignition takes place normally, and the flame front begins to spread over the combustion chamber as intended. But, as the flame spreads, heat and pressures in the chamber rise until they reach the point where the fuel can no longer tolerate them, the remaining fuel from the previous intake cycle detonates, often resulting in an audible “ping”. It can produce a sound reminiscent of having filled the top end with marbles or something, and can be quite destructive if it happens early enough in the power stroke. The correction, assuming that the engine is timed and jetted appropriately is to increase the resistance of the gasoline to being ignited by sources other than open flame. That means, a fuel with a high enough octane number.
That’s the form detonation usually takes, and at that level, in which only a part of the whole fuel charge is detonated instead of burned, it isn’t nearly as harmful as it can get. In the extreme, where the gasoline is pre-ignited, that is, ignited earlier than intended by an overheated engine, glowing carbon, etc., a larger percentage, or even all of the fuel may be detonated at once, and the results can be catastrophic.
Up next: What are the factors that influence normal combustion?
Compression, ignition advance, and the fuel’s tolerance of them. Compression is simple to understand. Compression creates heat, and more compression creates more heat. Possibly too much more.
Ignition timing is a little more complicated, but still pretty easy to understand. In a piston engine, there is a mechanical “sweet zone” in the rotation of the crankshaft that goes from just after top dead center (TDC) to around 90 degrees after top dead center (ATDC). In this zone pressure on top of the piston does the most efficient job of turning the crank. It’s also important here to note that throughout this zone of rotation, the combustion chamber volume is constantly expanding. Gasoline of any kind or blend burns at nearly the same rate under pressure regardless of the situation.
Now, picture the piston having just past TDC and starting down the bore. If you light the fuel now, it will take a certain amount of time for it to develop a significant amount of pressure to really do anything about pushing the piston down. While it’s trying to build pressure, the piston is moving away from it at the same time, and little is gained. So the timing is set to ignite the fuel in advance of TDC. This allows the burning fuel to build up a meaningful amount of “push” by the time the piston starts down, and ideally burning most of it within the “sweet zone”. Since the engine will speed up, but the fuel burn won’t, the faster the engine spins, the more advance it needs as it picks up speed.
But if the fuel is ignited too early, the pressure and heat may reach critical levels before the combustion chamber volume has begun to enlarge adequately, and the portion of the fuel that lies in front of the advancing flame may then detonate.
Octane is the fuel’s detonation resistance.
And that’s all it is. Gasoline is a blend of several hydrocarbon solvents, among them toluene, benzene, heptane, and octane, plus a number of less active ingredients designed to do things other than add to the fuel’s energy levels. The number “100 octane” is based on the detonation resistance of 100% iso-octane. When a fuel is labeled “95 octane”, it resists detonation under pressure as well as a blend of gas consisting simply of 5% n-heptane and 95% iso-octane.
Octane number indicates ONLY this resistance to detonation. High octane gas does not burn hotter, colder, easier, harder, cleaner, dirtier, or with any more or less power because of the octane number. Differences such as any of these other fuel characteristics that actually do occur are the result of the overall fuel blend used for that particular gasoline, and it is both possible and common to find major differences in these qualities in different gasolines that all have the same octane rating. Race gas is a perfect example of this, as we will see later.
Up next: Why can I use 91 octane when my manual says I need at least 95?
There are three different rating systems used to find the octane number of a fuel. The oldest is the Research Method. This method uses a special test engine with a variable compression ratio to compare the relative detonation resistance of fuels with equivalent heptane/octane mixes.
A newer method called the Motor Octane method also uses a test engine, but runs at 900 RPM instead of 600 as in the Research Method, and uses higher temperatures and variable timing to compare fuels. It is considered a more accurate gauge of how gasoline will perform in modern engines than is the Research Method, but it’s rarely used in any kind of advertising because the rating numbers tend to run from about 8 to 12 points lower than the ratings arrived at with the Research engine. A fuel rated 100 Research Octane Number (RON) will only post up a best of 90-92 Motor Octane Number (MON), in spite of the fact that they have very close to the same real detonation resistance regardless of the test method. But oil companies are much more likely to promote their products by quoting RON than MON, if you let them, because it comports with all those marketing myths they’ve been selling all these years. This is where the third rating method comes in.
In an effort to reduce consumer confusion and promote some level of consistency, the US Government requires that the average octane number achieved by both methods be posted on gas pumps and be called the “Anti-Knock Index”. You see it as “R+M/2” on the pump. So when your manual says you need 95 octane, and your bike is from Europe or Japan, you’re being quoted Research Octane Number. The equivalent Motor Octane number would be about 86, and the average would be 90-91, so that’s what you would look for at the gas pump.
Up Next: So, do I need race fuel?
If you can buy pump gasoline that meets the minimum octane requirements of your engine, you don’t need race gas or octane boosters to raise the octane number any higher. Your engine will run detonation-free on any gas that rises to that level, and paying any money out to run the octane rating up any higher than that is just a pure waste.
There are, or may be, several other reasons to improve on the pump gas you find in your particular area. A lot of what goes into commercial automotive pump gas is there to do things other than create power, and those ingredients may be partially or completely inert as far as their contribution to the amount of power the engine can produce from it (referred to as “energy content”). Ethanol fuels are a good example. By itself, ethanol has an RON of 108, but its MON is only 88. E85 fuel is 104 RON, and only 85 MON. Furthermore, to get the same power as non ethanol gasoline, you have to burn 15-25% more of it.
Oxygenating agents are added to pump fuels to aid in the more complete burning of fuel for the purpose of reducing emissions. Oxygenates are added to race fuels as accelerants, and there is often a fairly big difference in the chemicals chosen for that job. Ethanol is an oxygenate, but it produces much less energy per volume in and of itself than most gasoline components, so it reduces the energy content. MTBE (methyl tertiary butyl ether) is an oxygenate that produces more energy when burned than ethanol, and releases more oxygen in the process, so it’s more often used in race fuels.
You can generally gain power through using race gas, but rather than a gift that keeps on giving, it’s a modification that you have to keep on paying for for as long as you want to use it, and it often requires rejetting to make the switch, so you kind of have to stay with it. The extra power IS NOT a result of the usually higher octane number, but comes from the specific blend of hydrocarbon compounds used in the formula. A number of octane increasing components such as xylene and toluene also increase the energy content since they actively contribute to the combustion event, as opposed to tetraethyl lead, with is essentially inert as a fuel component.
As far as vaporization rates, burn rates, etc., etc., differently configured engines require fuels with different attributes. Factors are carbs vs. fuel injection, long vs. short intake tracts, high vs. low RPM operation, and steady state vs. non-steady state operation (like boats and airplanes vs. dirt bikes). Race fuels come in such diverse varieties for this reason.
Incidentally, octane boosters are mostly snake oil. There are a few good ones that are available from automotive speed shops, but most of the ones you see on the shelf at the auto parts store are useless. They say they raise octane by one or two or three points, but that’s a change of 0.1 to 0.3, not 1 to 3 octane. Injector cleaner might actually be more effective.
Next: So, will more octane benefit me?
An excess of octane number beyond what your engine needs is completely harmless and has no downside except for the damage it does to your wallet. If it’s simply a question of octane, as long as you don’t ping on ordinary pump premium, you don’t need any more octane to prevent detonation, and preventing detonation is the only thing high octane is good for.
Have a question or comment? Post it below! You'll be helping to expand the depth & value of this topic and at the end of the day, that's my goal! :thumbsup:
Edited by grayracer513
  • Like 8
User Feedback
Recommended Comments
Thank you so much for this post. Makes me sick when my friend and I drove 2 hours round trip to buy race fuel for him at $9 something a gallon....
Share this comment
i did some engine work and use a stage 1 cam and hi-com piston in my XR650 and I had pinking issues after the work was done. I switched to a higher octane fuel and that cured the problem.
Question - under these conditions, will the higher Octane help the motor run cooler?
Share this comment
Great post, thank you.
You did however forget to mention how good race gas exhaust smells, particularly when mixed with two-stroke oil.....
Share this comment
here in Canada at least, 91 or premium gas has no ethanol in it which screws up carbs and seals if it sits for too long. i always use non ethanol as it won't gum up carbs and eat o-rings and seals.
Share this comment
Let me point something out.
"Detonation occurs when the heat and pressure in the cylinder rise to the point where the gasoline is ignited by just that, and not by contact with a flame". - Did you mean spark?
as a flame traveling from molecule to molecule" - that is far from how physics works.
Skimming through your article I've found similar fallacies, which make me skeptic about the accuracy of what's to follow.
Share this comment
To the extreme lover of self... Dan Oliveria..
Allow me to point something out that escaped you...
Initially the combustion is started by a spark... After that you have a traveling flame front..
So... Follow me here... Focus...
The spark event is not what would be causing the heat and pressure rise... It would be combustion... And also, the flame front would be giving off radiant energy... Traveling much faster than the flame front... And adding heat to the periferal portions of the air fuel charge... Making them more volatile prior to the arrival of the flame front..
So no... It isn't the spark doing all that Mr Racer was explaining... It's combustion... Which is usually associated with flame...
Class dismissed..
Continue with your self love...
Share this comment
How about for tuning your EFI system? Is there enough of a variance of degrees relative to TDC that might warrant a higher octane fuel? (Given that you're not pinging at a factory setting)?
Share this comment
I had an old timer who ran dragsters tell me how to make an octane booster from Xylene and few other components.  never knew why he sued it but now i do.  and even to this date i still use that recipe for higher compression motors.  thanks for making it make better sense.
Share this comment
@mixxer correct! Continue with the self-love, lol. Kidding.
@singletrkstar Yes. If you can adjust timing advance with a tune, it can require more octane from the fuel. If your motorcycle is like my WR250R without a knock sensor, I have no idea how you'll make a safe tune. Knock sensors actually detect such slight issues that you'd never hear it. This is why a professional tune is so important.
@XR650Kid Of course with a high compression engine you'd need a boost in your octane rating. Predetonation will increase combustion temperatures, but you're talking about an engine that's now a higher compression hotter engine that was originally a lower compression, cooler engine. As a whole, your engine will still be hotter now with the newly needed higher octane as compared to before your engine mod. That's how I'd look at it.
Share this comment
Thanks for the awesome article!
I may be beating a dead horse but it seems like everyone has a different opinion for avgas in bikes. "Factors are carbs vs. fuel injection, long vs. short intake tracts, high vs. low RPM operation, and steady state vs. non-steady state operation (like boats and airplanes vs. dirt bikes). Race fuels come in such diverse varieties for this reason."
Anyone (Grayracer) care to comment and help me put it to rest or have the ability to argue better?  LOL
Share this comment
Higher octane fuel burns more slowly. If you run higher octane fuel than required, you should advance your ignition timing to compensate. In older engines manufacturers warned against using the higher octane rating than required, because the  mixture could still be burning when it passes your open exhaust valve. In the older engines, this could lead to a burnt valve.
Share this comment
Excellent reading, I am now well informed ,thank you
why did you disrespect the lady on the street, 3 men are dead this year in my city riding dirt bikes on city streets and a lot more got busted up, what are you like 10 years old because that's how you ride pal
Share this comment
I appreciate the writer's attempt to educate others, but I would also agree that some of his statements are somewhat off.  Detonation is actually more correctly termed knock. There are two major phenomena – abnormal combustion processes – that can cause engine damage if left unchecked.  As an expert in internal combustion, J.B. Heywood, described starting at page 450 in his book, Internal Combustion Engines Fundamentals: “ Knock is the name given to the noise which is transmitted through the engine structure when essentially spontaneous combustion of a portion of the end-gas – the fuel, air, residual gas, mixture ahead of the propagating flame – occurs. When this abnormal combustion process takes place, there is an extremely rapid release of much of the chemical energy in the end-gas, causing very high local pressures and the propagation of pressure waves of substantial amplitude across the combustion chamber.”
The other major one is surface ignition, often called pre-ignition – when the air-fuel mixture ignites before the spark event.  Both knock and pre-ignition are different types of abnormal combustion and most of the time - neither are called detonation in the automotive engineering world.
In simpler terms, knock happens when the spark ignites the mixture, the flame front travels out, and a pocket of air fuel mixture elsewhere in the cylinder ignites - and that flame front and pressure waves collide with the flame front and pressure waves started by the spark.  It's incorrect to say that ALL the fuel in the cylinder ignites spontaneously. The end-gas - the unburnt gas before the end of the flame front - is what is spontaneously combusting. That causes the knock or ping noise.
Using high octane fuel is a waste of money unless you can advance the spark timing or raise your compression ratio enough to take advantage of the high octane fuel's resistance to knock.  No power comes from the higher octane fuel alone. The increased cylinder pressure due to the advanced timing or higher compression ratio are the main factors in the increase in torque (which most people feel in the seat of their pants and call power).
I highly recommend reading Heywood's book. It is required reading for automotive engineering students.
Share this comment
FINALLY!  Great write up!  Running a racing fuel company for decades, I fought this argument all the time.  If you don't need octane, quit paying for it!!  Burn rate is a whole different can of worms.  Thanks for this!!
Share this comment
In the mid-west, most premium gas has no ethanol in it.  If I am doing an extended trail ride, I will fill up with the lowest priced non-ethanol in order to extend my fuel range by a few miles.  I have an 88 Honda NX650 that has a small gas tank compared to a KLR, like about half the size.  Also, I read that ethanol burns hotter, and I have an air cooled engine.
Share this comment
Most 10 year olds have more respect - and if they ride dirt, can ride a wheelie other than in a straight line without crashing.  This kid is a moron.  I expect mommie and daddy paid for the bike and the medical care.  They will probably pay the bail and/or funeral costs too.
Article is spot-on.  Quibbling over terminology is silly.  BTW, pre-ignition by itself means nothing - it leads severe knock/ping/detonation but knock also occurs from other causes.  As explained in the article.
Finally, small changes in injection timing are unlikely to have any effect on knock, unlike ignition timing where 1 or 2 degrees can make a significant difference.
Share this comment
I found the best reasons for using race fuel are consistency and quality; those two items are important when your tuning is approaching critical mass of the engine's performance limitations...whatever that means :-)
Also consider a few other things.  Pump gas is designed to work with everything from your lawnmower to your friend's ZR1 Corvette. Some pumps dispense all thier grades of fuel from one nozzles/hose. Pump gas has an additive package that changes with the seasons and location of the fuel.  Pump gas is very price competitive, which means the manufacturer and refiners are always looking for ways the make it cheaper.  Some fuel vendors are very specific about where thier fuel comes from, while others buy thier fuel at "fuel auctions".  Some of these fuels have been rejected by other vendors because of...? For most of us this doesn't mean that much but for others; it does. Just food for thought.
FWIW: I run Shell 93 Premium (non-E) in my 300KTM.  In my XR250R I run whatever I bought for my lawnmower.   Personally, I don't want a bike that needs race fuel.
Share this comment
I recommend nuking the original article and replacing it with this one.
Share this comment
  • Similar Content
    • By ThumperTalk
      An aero-form reed valve that corrects the problems associated with existing reed valve designs Maintains flow velocity through the valve and re-directs the intake charge for even distribution to the intake ports Provides quicker, sharper throttle response and more horsepower. 1-piece aluminum casting; no manifolds to trim or plastic pieces to insert. Boyesen Pro Series RAD Reeds included.
    • By Erik Marquez
      Much has been written about the OEM Mikuni BSR36 carb, you can jet it, tune it, tweak it, but in the end, it’s still a CV carb, with limited potential. Used on on all S and SM model DRZ's. (plus late model E bikes in the US)
      If your reading this now, you have already decide the extra HP and better throttle response of a well jetted FCR39 MX carb was worth the price. That’s the hard part.. What follows, is much easier. Installing the FCR on to a DRZ originally equipped with the Mikuni BSR36 is not hard. Though some general knowledge of motorcycles and Carbs specifically is important, with the right attitude and understanding your install will be full of stop and go as you research, learn, and ask questions. Anyone with decent mechanical ability and basic tools can perform this install.
      The Thumper Talk Keihin FCR39 MX carb kitfits all DRZ's having a BSR36 carb, All S and SM models, and 2007 and later E model bikes.
      The kit includes:
      - 016-925 Keihin 39mm FCR MX Carb with choke (no TPS)
      - 021-216 FCR Adapter 2 3/8", carb to S airboot
      - 021-439 Adaptor O-Ring
      - 017-262 EMN Needle
      - 021-012 Airboot adapter bolts (2)
      - P/N 13111-29F00 OEM Suzuki E Intake Manifold
      - P/N 09402-58208 OEM Suzuki Clamp
      - P/N 13685-29F00 OEM Suzuki Vacuum Port Nipple
      Carb comes standard with the following:
      - 200 Main Air Jet
      - 160 Main Jet
      - 45 Pilot Jet
      - 100 Pliot Air Jet
      - EMR Needle
      Prepping the new Carb and bike for install
      Remove and discard the plastic throttle wheel guard, it will interfere with fitment relevant to the frame, and really is not needed.
      Move both upper motor mounts to the left side; this allows needed clearance for the throttle wheel
      The TPS connector will not be reused with the new FCR carb, you can follow the carb end up wiring to the connector and unplug it there. Use some dielectric silicone and tape to blank off the connector, you can cut the wires there, heat shrink or tape the ends, or simple stuff the carb end of the TPS and wiring harness up under the seat, zip tie it in place and leave it. Bottom line, it is not used for this install.
      If using a vacuum operated fuel petcock like the OEM one found on the DRZ S or SM, you will need to install a vacuum nipple in the manifold. Luckily there is a spot just for this and an OEM part to install. It is P/N 13685-29F00 OEM Suzuki Vacuum Port Nipple and included in the TT Kit
      Install the jetting required for your motor modification level and riding area. Provided are four common jetting setups. For many, that’s all they will need to do, for some, additional tuning will be required. Use what is here for a base, make a post as to what your bike is doing related to jetting you do not like, and let the experts help you through the tuning.
      be descriptive, and specific.
      Include your current motor and intake mods, jetting set up, altitude and temp where you ride. mods, jetting set up, altitude and temp where you ride.
      Basic Jetting
      sea level stock exhaust or "quite,96db,corked up etc aftermarket pipe", 3x3 -
      155 main jet
      200 main air jet
      EMN needle
      clip 3
      45 pilot jet
      2 turns fuel screw
      o-ring mod
      sea level,aftermarket pipe with open muffler-
      160 main jet
      200 main air jet
      EMN needle
      clip 3
      45 pilot jet
      2 turns fuel screw
      o-ring mod
      4000-600ft,stock exhaust or "quite,q,96db,corked up etc aftermarket pipe", 3x3 -
      145 main jet
      200 main air jet
      EMP needle
      clip 3
      45 pilot jet
      2 turns fuel screw
      o-ring mod
      4000-6000ft,aftermarket pipe with open muffler-
      150 main jet
      200 main air jet
      EMP needle
      clip 3
      45 pilot jet
      2 turns fuel screw
      o-ring mod
      In addition to the above or custom jetting, an extended adjustable fuel screw is highly recommended.
      Merge Racing makes a very nice one. What I like most about it is the Injection molded knob.. stays cool when the engine is hot, for easy adjustments. And because of its T shape is easier to grab with gloved hands and make adjustments.
      If not the Fuel screw from Merge, then any of the aftermarket screws not made from aluminum. Be very careful on the removal and install of the new fuel screw.. you have a small spring, washer and rubber O-ring that sits on the screw inside the body. One or more of these part sometimes remains in the body, and comes out haphazardly on the end of the old fuel screw. Very easy to lose one or more parts.
      The Fuel needle clip position is counted from the top, flat end of the needle. The needle pictured is in clip 3 position.
      Install tips
      No need to buy new throttle cables, the stock S cables work fine.
      Attach the throttle cables with the curved one on the bottom
      Hoses are routed like this
      It’s really not too short. People say this all the time due to the physical measurement between old carb set up and FCRMX being different, the FCR setup is slightly shorter. The air boot is plenty long enough. The preferred technique is to put the carb in the boot first. Then pull it forward to the manifold.
    • By mebgardner
      This "plug and play" kit has been developed so that the very fine Golan Mini Filter, 10 micron, can be fitted in-line to the KTM 690 Enduro & SMC motors, between the fuel tank and the injector, but can be easily accessed for cleaning and servicing without having to remove the airbox.
      It consist of a custom-built length of high-pressure OEM fuel hose, and OEM quick-release couplings and a Golan Mini Filter.This can be easily attached by disconnecting the OEM dry break and fitting our filter kit in between, and only requires the removal of the airbox once for fitting this kit.
      We have found the 10 micron Golan Mini Filter, which can be unscrewed and the filter washed, virtually removes any problem with injectors blocking, which can be a pain on long trips.
      Will work with or without our EVO1 & EVO2 tanks fitted.
      Suits all KTM 690 Enduro & SMC
    • By mebgardner
      Made in the USA !
      CJD-FFNK-690 Kit shown in all three colors =  KTM LC4 690 Enduro/SMC 08′-17′ ( Product show in picture is current ).
      The separate diamond shaped billet aluminum cover plate is now ALL ONE PIECE for aesthetics giving that OEM appearance on the 690.
      The stock KTM LC4 690/KTM 990 SMT fuel fill suffers from a few problems. The stock key lock system is susceptible to breaking keys, it also has a reputation for allowing dirt and grime in which is a huge problem on EFI systems and lastly the flip up cap can be cumbersome for filling with fuel or getting to your luggage. Our answer is a billet fuel neck that attaches directly to your gas tank, using the stock o-ring for a nice fit. Venting is done at the same 90 degree angle as OEM which eliminates having to use a breather vent cap. If you have removed the SAS system you can cap the body vent and vent from the top with a breather listed below.
      The fuel fill is CNC machined from ONE piece using aircraft aluminum, not a 2 piece welded part like others, and hard anodized. Specially crafted to replace your OEM system. No modifications to your bike or tank are necessary – simply remove the original and bolt ours into place.  Includes an Acerbis Viton sealed plastic fuel cap, which can easily replaced if need be. All hardware and mounting instructions included. Lightest kit on the market.
      Also works on your KTM 990 SMT with this style filler system.
    • By Red_250X
      Just wanted to give you X fans some real world successful jetting settings. I just got back from a trip to Colorado and wanted to share these settings.
      Our camp was at 6100' and we rode up to 13,000'. Temperature was between 65 and 85 (absolutely PERFECT!).
      Modifications:
      Airbox opened about a third of CCC recommendations.
      Baffle removed, but spark arrester in place.
      Pilot jet changed from 40 to 42.
      Setup:
      -Needle in stock position
      -Main jet - 142
      -Air screw at stock position (I probably could have made some improvement, but I was having too much fun riding and I didn't experience any hesitation)
      The bike ran great and climbed some HUGE hills. Most of our riding was single track, switchbacks, very difficult and technical - a lot of 1st and 2nd gear.
      NOTE!! Apparently, the 250X is jetted lean in stock form. Opening the airbox and removing the baffle leans the carb even further. IF YOU DO THESE MODS, REJET YOUR CARB!!! Otherwise you could do serious damage to the motor. It will run significantly cooler when it is not lean. I live at about 600' and am running a 152 main jet.
