Official Launch of the Highly Anticipated Leatt GPX 6.5 Carbon Helmet (Video)
Bryan Bosch
All of us at Leatt are excited to bring you an awesome video recapping our official Media Launch for our brand new GPX Helmet. Nothing but good times were had in the amazing conditions at LACR last week. Along with our GPX 6.5 Carbon Helmet, the media was able to test our new DBX 4.0 Windblock Gloves and GPX 4.5 Lite Gloves. Unsurprisingly we received top class feedback, Check out all the action!
For more info on the new Leatt GPX 6.5 Carbon Helmet, click
HERE.
User Feedback
Recommended Comments
where are you getting your numbers? This helmet only weighs a little over 1,100 grams, the Airoh aviator weighs just under 1,100. Do your homework before you post silly comments!
Share this comment
The Leatt web site says "from 1285g". I had a large in my house for 3 days and it weighed 1350g on my scale. So, it's a good bit more than 1000g.
I returned mine. The single "turbine" on the forehead left me with a very sore pressure point after 20 mins or so of wearing it. I wore it around the house for about 3 hours in total and it became painful each time. The concept is good but to have the turbine directly in contact with your head puts too much pressure on too small a spot.
The other more glaring problem was that the shell was not aligned to the inner liner well. When you put it on and put your goggles on, you could see that the mouth guard was rotated 1/4-1/2 inch to the right.
The fit was good. Large was right on the money for me since I wear a large in all other helmets I've had recently. The materials seemed excellent. The finish on the shell was excellent. It is a very small helmet shell. You could tell it was obviously smaller when you set it next to my other helmets.
I would have liked to have tried riding in it but the sore spot on my forehead and the poorly aligned shell made it a return item. If it was only the shell issue I would have gladly exchanged it but the pressure point made it a no go for me.
Share this comment
Yeah, these are designed for round/oval heads, which are the majority of humans out there.  But it sounds like, you have, as I do, are "long/oval" head shape.  This creates a forehead pressure point, and sometimes a little extra room on the sides.  I think the Bell Flex fits okay and a very few others.    But you need to contact the manufactures customer service to get them to tell you for which head shape their helmets are designed.  It does suck having a long/oval head when buying helmets.
Share this comment
  • Similar Content
    • By yz250f_spud
      Dual Axis knee and leg guards are comfortable, well ventilated protectors with two pivot points that allows them for more accurately bend with the human knee’s natural movements. They cover the knee, even when fully bent, as well as the lower thigh and most of the lower legs. Great levels of impact protection are proven by the CE impact safety standard they are certified to. They are also certified to CE’s abrasion resistance safety standard. Strap buckles are low profile with no edges to hang up on your riding pants. Straps are also backed by soft, comfortable, vented airprene material that resists slipping. Lighter weight, most comfortable and offers more freedom of movement than almost any other CE certified protection system.
    • By Bryan Bosch
      Quick Overview
      Leatt®’s top of the line chest protector. The Chest Protector PRO has been designed to integrate perfectly with all Leatt neck braces although it works equally well without a neck brace. Exclusive BraceOn™ elastic strap system attaches the protector to the Leatt® brace yet provides independent movement of body, brace and chest protector. Redesigned for 2013 using Leatt’s 3DF foam this protector is now the lightest outside worn chest protector (with shoulder and upper arm guards) to pass the two highest levels of CE, front and rear, impact protection.
      Product Description
      • The back of protector meets the highest impact CE approval, CE EN 1621-2, Level 2
      • Chest protector impact tested and CE certified to prEN 1621-3 level 2
      • Extremely high impact testing results achieved by use of Leatt’s new 3DF foam in front and back
      • Unbelievably light for all that protection at only 2.6 pounds (1150 grams)
      • Close fitting allows for over or under the jersey use
      • Made with High Density Poly Ethylene (HDPE) hard shell outer shield and washable biofoam
      • 7 front and rear venting slots help keep rider cool helps keep rider cool
      • Adjuster bolts allow for different length both front and back for personalized fit
      • Front and rear removable plates allow brace to fit close to body
      • Adjustable arm and chest straps for great fit
      • Removable shoulder and upper arm guards
      • Fits riders from 54 to 109kgs (120-240 pounds.)
    • By Bryan Bosch
      The all new 2013 Leatt® Pro Lite is the lightest and most comfortable Leatt® yet! Leatt’s top of the line in neck braces, the chassis is made from 100% lightweight Aramid reinforced Carbon fiber. The ventilated chassis and padding plus the all new CoreFlex rear thoracic strut makes this brace a premium safety investment! Invented by motorcycle racer and trauma surgeon, Doctor Chris Leatt, and built around Leatt® Corporation’s patented Alternative Load Path Technology, this brace is CE certified as personal protection. Used and trusted by more world and national motorcycle, ATV, bicycle and snowmobile champions than all other neck braces combined. Leatt’s Pro Lite neck brace is a professional product for riders who take their riding and safety seriously.
      New, one piece, CoreFlex rear thoracic strut has independently flexing sides for improved comfort and fit New CoreFlex rear thoracic strut has built in fracture point designed to snap off in a severe crash New matte carbon finish New lower rear padding for improved helmet clearance New color coded rear thoracic strut angle wedges for easier angle adjustment New Rear thoracic strut can be set to -5°, 0°, 5°,10°and 15° for the perfect fit Lightweight aramid fiber reinforced carbon fiber matrix chassis. Ventilated chassis and padding on both front and rear. The greatest range of motion of any Leatt-Brace® Side mounted paramedical designed hinges that opens easy both left and right Open celled light weight removable & washable ventilated Velcro-free padding Engineered collarbone cutout to help keep your helmet and brace away from your most fragile bones Unique one piece rear thoracic strut designed to break away in severe impact scenarios Comes with optional harness system with quickrelease buckles On-board rear thoracic angle adjustment CE certified as personal protective Equipment 89/686/eec Replacement parts available Available in size small/medium or large/x-large
    • By Bryan Bosch
      Vented Off-Road glove with optimum protection. Our maxed out glove when it comes to bike feel and protection. Imagine the softest, slimmest glove palm ever and CE certified impact protection so well engineered that you can not feel it. Uniquely engineered vented off-road glove for maximum riding comfort with NanoGrip Aramid fiber reinforced palm and CE Certified impact protection at knuckles, fingers, thumb and upper hand.
      CE tested and certified as Personal Protective Equipment 89/686/EEC
      CE tested as impact protection:
      > Knuckle prEN 13594:2014
      3D molded self-locating Armourgel impact protection for:
      > Knuckles
      > Fingers & thumb
      > Upper hand
      NanoGrip palm:
      > Ultra-thin for maximum bike feel
      > Nano fiber technology 7.500 thinner than hair
      > Very stretchy and flexible
      > Premium dry and wet grip
      > Touch screen function
      > Aramid reinforced palm protection
      > Pre-curved snug fit seamless palm
      > Micro injected cuff restraint
      > Multi-ply Nylon thread stitching
    • By Bryan Bosch
      The Pro jacket is a fully waterproof, windproof jacket with a hidden neck cuff that stretches over a neck brace to help keep out the elements. Soft, pliable and durable the Cordura outer shell has fully taped seams and waterproof zippers to keep the water out on even the longest of rides. It also features removable CE certified shoulder and elbow protectors and has a rear pocket for optional CE back protector. 3M reflective material adds safety for road use.
      • Great for road, or off-road use
      • Waterproof zippers and zip out waterproof liner
      • Hidden neck cuff deploys to cover any Leatt® neck brace including STX
      • Neck cuff is windproof, waterproof and breathable to maintain rider comfort
      • Multiple front pockets
      • Window pocket on sleeve
      • Large bottom back pocket for liner
      • Spandex stretch in sleeves & body
      • Full, zippered, ventilation in front, back & sleeves
      • Can be worn with or without a neck brace
      • Removable and adjustable sleeves
