Poor mans plastic restoration
Red Dog
Many years ago I had a riding buddy who showed me his trick to making his old KDX look like it had new plastic (at least from a few feet away anyhow). Since that time I have used Plastic Renew to restore my plastics when I've laid my bike down and scratched it up. If used properly, Plastic Renew does a really good job. But it costs around $17.00 a bottle and requires a fair amount of time and a bit of work if you want good results. If your plastics are not too scratched up and they just look dull and old, for less than half that much money you should give this a go.
What you do is get a bottle of Mop & Glo (the stuff that you use for vinyl or linoleum floors). First clean the plastic really good using a non oily type of cleaner. Don't use Plexus or SC-1 as they have silicone in them. Then take a paper towel or whatever and apply a light coat of the Mop & Glo. Be sure to use slow smooth strokes when applying to avoid bubbles. It should begin to dry in a few minutes. After a little bit, apply another coat or two. Depending on how bad the finish was will determine how many coats you need to put on.
Anyhow, it should look much better and you'll be happy to have your bike shine again. I've tried this on my old chest protector too and it worked beautifully. I don't know if it will give the desired results on transparent plastic (the see through stuff) but on solid colors it works great. You can also go right over graphics too as it helps shine them up as well.
If for some reason you feel like you made a big mistake, don't panic. Just use a little bit of ammonia and water to strip it off and you're back to where you started. Now you can step back and admire your handy work. Good luck.
User Feedback
Recommended Comments
There are no comments to display.
  • Similar Content
    • By Crunch406
      I searched and couldn't find a similar thread. Modding season is upon us.I cleaned and oiled my air filter, changed my 13 tooth cs to a 14, cleaned and lubed the chain, changed the oil and filter, and installed my Battery Tender. It was a good day. Tomorrow, I ride.
    • By Powerban
      Seat covers use gripper material on the sides and top and have madgrip ribs. The gripper top and madgrip ribs combination allows the rider maximum grip for control and confidence required at the top level.
      The madgrip ribs use a unique material which is robust and harder wearing than all the other ribs on the market today.
      Madgrip ribs allows the rider maximum grip from sliding back under acceleration which give the rider control and confidence and allows the rider to easily move forward and re positing when required.
      The gripper material is hard wearing and durable, for extra protection CFX TCT protection can be added to the knee area to reduce wear or add extra grip.
    • By Tigger800xc
      GENERAL INFORMATION
      These super little plastic fuel cans are extremely sturdy. they are made in Germany, and include a strap retaining slots as part of the moulding which is a genius design feature. Please note that these fuel cans are not sold with straps, but we do offer these separately (see this link for details).
      Available in a few different sizes and colours, this is the 1.5 litre natural (clear/white/cream colour) version.
      At 50 MPG this will get you 16.5 miles, and at 30 MPG it will get you 10 miles. Usually this is plenty to get you out of trouble, and if you're not sure, why not get two!
      Dimensions:
      The body of the can is:
      235mm high
      125mm wide
      65mm deep
      Including the cap it is 275mm high.
      The inside diameter of the filler neck is 29mm.
      It weighs just 300g
    • By Adrenolin
      DESCRIPTION
      This container stores and transports fuels such as white gas and kerosene. A child resistant cap is included, and the standard connecting threads accept the pump from MSR™ liquid fuel stoves.
      Made of ultralight, extruded, seamless aluminum. Available in 325ml (295 max capacity), 650ml (590 max), and 975ml (880 max).
      TECH SPECS
      Weight: 114g (650 ml)
      Ideal for: Camping
      Made in: USA
    • By Jr9racing
      DESCRIPTION
      Each cage is built and fabricated with the highest quality American steel tubing. Besides powdercoating, we do everything in house. This includes cutting, bending, welding, notching and machining.
      FEATURES
      Fully mig/tig and inspected American made seamless high-strength steel tubing Grade 8 hardware Delrin sliders Lowest profile in the market and most solidly built.
