Preparing your bike for storage. A way that works.
Erik Marquez
Riders all over have reasons to store a bike, winter or going away to school for a year, extended work trip and many other reasons.
The good news is the process to store it is the same no matter the reason.
Good storage prep is the key to a bike that can be brought back online not just quickly, but at little to no cost, no repairs required.
How great would it be to come home after a year, spend just a few min in the garage to get your bike ready to ride?
I will discuss 6 key areas. Understanding there is no one best way for all so this article is just A Way.
A way that has proven to work countless times on bikes stored over winter, or several years be me personally, and hundreds of others I've made these suggestions to.
If you have a way that works for you and results in fast startup, no repairs needed post storage perhaps this article is not for you. If you have never stored a bike or have and would like to read some ideas that might help you avoid some issue you had last time, read on.
As always, this article is not a comprehensive step by step procedure. It does assume the reader has a basic understanding of using tools, working on a motorcycle, safety and precautions when doing both. If your not comfortable removing your spark plug, don't know how to get your motor to TDC, then please don't. Hire a qualified mechanic or even better,  bribe a qualified friend to come over and walk you through it.
  1. Exterior Preparation
  2. Fuel System
  3. Electrical System
  4. Engine & Cooling System
  5. Storage Location
  6. Bringing the bike back to life
So let's get into it.
Start by cleaning the entire bike with a mild detergent and water. Avoid spraying bearings, seals, electrical connectors and components directly so to not force water into them. If you use a pressure wash, be VERY careful of this.
If possible, start and ride the bike to evaporate any water trapped in the motor and drag your brakes to dry them as much as possible. Use compressed air if you have it, or even a shop vac set to vent. Clean your chain with a plastic bristled brush and chain cleaner. Spray your clean chain with a petroleum based chain lube, and wipe off the excess with a shop rag. If you have an o-ring chain, make sure to use o-ring safe lube. While you’re still in lube mode, take your WD-40 and spray down the foot peg pivots, kick start pivot, folding shifter pivot and lever pivots. If it can rust, give it a shot or corrosion preventive. Take the time to get a good overall inspection of brake pads, suspension linkage, chain and sprockets for wear... Great time to get those things ordered so they are waiting when it's time to ride again.  If your motorcycle is equipped with grease zerk fittings, go ahead and give them a few squirts of quality grease and wipe off the excess that inevitably oozes out. Lastly, air up the tires to spec.
Fuel System
There are different methods of preparing fuel systems for storage. Steel tanks, plastic tanks, carbs, or FI, long term (more than 4 months) short term, or indefinite (or unknown) storage times all give some options. As I started this article, I'll lay out A way, a way that has proven to me and many others to work well in a variety of situations. If your bike has a steel fuel tank, you have two choices both are concerned with keeping tank rust a bay. If you will be putting the bike back in service in 4 or so months or less, Treat the
fuel with a known quality fuel storage chemical.. I have had great luck with Stabil 360.
Its claim to off gas corrosion preventive protecting tank areas above fuel line has shown to work well in a 90 bike training fleet I manage, these bikes sit for weeks to months unused. Making them very representative of the average rider’s stored bike.
Fill the tank to the brim, leaving as little air space as possible. Filling the tank completely will greatly help it from rusting, which is a major issue in some areas. Plastic fuel tanks are more forgiving, but even so I prefer to drain them completely. Another fuel option is, filling with race gas, something like Sunoco SS 100  or VP C10, C12, ect . Race gas has no ethanol and overall has shown to be very Stabil for long term storage. Once the fuel has been stabilized, start the motorcycle and let the fuel circulate throughout the entire system.
If storage will be very long term or length unknown and you have a steel tank... consider draining and fogging the tank with fogging oil. Fogging oil will be available at some auto parts stores and most boat/marine shops. And of course is available online easily.
A fogging oil I have found readily available, reasonably priced and works well is  image.png.b81fbccdc43f13b83364e65cf09e56d5.png
Lastly, heat....if your living or storing your bike in extreme high temps, Texas summers in a shad, or no AC garage... highly recommend draining the entire fuel system no matter carbureted  or FI, steel or plastic tank. The fuel will evaporate in the high temps leaving behind a residue you don't want to deal with.
 Electrical System
If your bike has a battery, steps to keep it viable are needed. To keep it fully charged which extends battery life overall, but especially in storage a battery tender is suggested. A brand I like a lot for its effectiveness is Battery Tender. And the Battery Tender
JR is a perfect fit for storage needs. 713331561_batterytenderJR.jpg.d72e88edc4fba40165f47cd405ed0bbf.jpg
A bonus is it comes with a  pigtail you can attach to the battery, so you have a "permanent" SAE plug available for hooking up your tender now, or later to keep the battery charged, or even hook up a battery charger should the need arise later.
Battery life has lot to do with the climate it’s stored in. If your bike is stored in an unheated area, remove the battery from the bike and store it in a heated a space. Basements, storeroom or a even a closet will work. The more stable and moderate the temp the better.  Keeping the battery from freezing along with a Battery Tender or like product will keep the battery at its best.
Another thing I feel is important as regular servicing but helpful in storage prep is cleaning and protecting your electrical connections. Yes it's time consuming, but so is diagnosing electrical gremlins next year because a little water snuck in during that creek crossing or from the pressure washer. If cleaning and protecting connections is a regular part of your bike maintenance you can likely skip this step. If not, take the time now to disconnect, inspect each connector, and spray with a cleaner and corrosion protector like
A google search will find it widely available...If not this, then another product labeled to clean and protect electrical connectors
Engine oil & Cooling System
A fresh oil change should be done before you store your bike. Do this after the wash and dry, best bet is do it as a last thing after running the motor to warm.
Dirty engine oil contains corrosive acids and other contaminants that you do not want to leave in the engine during storage. If you are in a coastal region or area with high humidity fogging oil should be applied through the spark plug hole. Clean well around the spark plug and dispose of it. With the spark plug out, shoot a few sprays down the spark hole and turn the motor over a few times leaving it at TDC. Once the fogging oil has been applied, install a fresh spark plug.
Next is your cooling system Make sure that the coolant is up to spec. Fresh coolant is a good idea, if it’s been awhile. With any motorcycle fluid, when in doubt change it. Brake and clutch fluid are hydroscopic, meaning they absorb water. You do not want that "wet" fluid in your clutch or brake system at all, but for sure not in storage. There are moisture meters available cheaply to test your fluids, they are specific to type, so DOT 3, DOT4, DOT5.1 .  If you don't want to buy and use one, just change the fluid before storage and make sure reservoirs are topped off. If there is any doubt replace that fluid.
Storage Location
Great so your bike is all prepped for storage, one last decision. Location, Location, Location.....If you have a choice, put it in the same room conditions you would but your grandmother (your favorite grandmother). The less you expose the motorcycle to extreme temperature fluctuations and humidity the better. Once the location has been chosen, put the motorcycle up on a stand. Using a stand keeps the weight off the tires and suspension. If a stand is not option, using a piece of wood to park the motorcycle on will keep the tires from sitting in dirt, cold concrete, or damaging the tile or carpet in the spare bedroom rotting (what don't blame me if your significant other does not allow you to park your bikes in the house, mine does..LOL). Once the motorcycle is in its home for storage, throw an old blanket or tarp over it. This will keep the dust to a minimum. If you are in a coastal region, skip on the cover. This may trap moisture under the cover, contributing to corrosion. Same if your bike will be stored in a windy location, a flapping tap and cause a fair bit of wear. Better to leave it to get dusty and wash it later than have paint or plastic worn on.
Of course protecting the bike from UV light is another consideration, the tarp does this, or in a shaded spot (there is that spare room in the house again). I have seen riders remove plastic and painted parts storing them inside because the bike itself had to sit on the back porch in the sun, wind and dust.  The more you do in advance, the less you will have to do later.
When the time has come to get your bike back on the track, trail or street sights all the work you did when you stored it bike will make start up simple and fast.. More importantly no repairs or services will be needed costing riding time and money.
If fuel was left in the bike, drain the carb float bowl to allow fresh gas from the tank in. Even though the fuel was stabilized, the small volume that is contained in the float bowl will deteriorate much quicker than the much larger volume in the tank. Double check all fluids.  Install the battery if it has one and you removed it. Check the air pressure in the tires. If the bike was not stored clean and protected from dust and such, give it a quick wash and you’re ready to fire it up.
If you did your job correctly, the motorcycle should come to life. Take an extra few minutes at warm to check for any fluid leaks or strange noises. First start up you may get a bit of non-normal smoke. Corrosion protector you sprayed on the bike during prep, fogging oil in the cylinder. It will burn off in just a few minutes.
I always like to do a very short oil change interval after the bike has been stored, just as an abundance of caution as well as it gets me a chance to inspect the oil and filters for issues.
There you go, A Way to prep and store a bike.. No doubt many readers will have their own way that has proven to work for them...if so great, if storage is new to you or you have had issues in the past after storage, consider the process or above.
The process in this article were used to store the bike in this forum post . As were many others over the years.
Edited by Erik Marquez
Reader suggestion
  • Like 4
User Feedback
Recommended Comments
...I would add "blow the dirt out of the spark plug hole, pull the plug and throw it away, squirt 4 or 5 squirts of oil into the cylinder, place a rag over the hole and hit the starter for a couple of revs, gap your new plug and install.  In the spring, besides not having any corrosion on the cylinder walls or valve seats, that oil will give you great compression and it will fire right up.  (yep it smokes for a very short while)...
Great instructions.
Share this comment
Great instructions.
Thank you for the feedback>Perhaps you missed it, but the write up does mention doing just what you suggested. OIl and spark plug
The article does not really touch on basic mechanic procedures like cleaning around the plug before removal, removing the negative battery lead first and such..It's assumed the reader knows these things. It does suggest plug replacement though and I like your point about cleaning around the plug such a common and well understood thing can easily be missed be the new DIY mechanic. We only know what we know.
Fogging oil is a specific type of oil used to protect cylinders. It is not only formulated precisely for that task, but the aerosol application ensures the fogging oil is distributed to all parts of the combustion chamber, piston to valves.
Maybe have another read of the article, perhaps there is something else you missed in it, or I did.
Thanks
Share this comment
For a single cylinder engine, after fogging, bump the cylinder to TDC. On a 2T the piston will cover the exhaust port. On a 4T, at the top of the compression stroke, the valves will be closed.
Edited by DaveCR
Share this comment
1 minute ago, DaveCR said:
After fogging, bump the cylinder to TDC. On a 2T the piston will cover the exhaust port. On a 4T, at the top of the compression stroke, the valves will be closed.
Thanks another one of these things I do automatically but did not put into words for others.
Thanks
Share this comment
  • Similar Content
    • By Bryan Bosch
      Mothers® Aluminum Wheel Cleaner is formulated to safely and easily clean uncoated polished aluminum and anodized wheels. Gentle, yet effective, Aluminum Wheel Cleaner also works great on painted, clearcoated, color coated, steel, modular, chrome, custom or factory coated wheels and hubcaps. You could say it's the All Wheel Cleaner!
      Mothers® Aluminum Wheel Cleaner provides fast and effective cleaning no matter what kind of wheels you have. Its unique spray on, hose off design safely penetrates, dissolves and suspends all types of brake dust, grease, dirt, and grime, making rinsing a snap. No need to scrub. Mothers® Aluminum Wheel Cleaner does the work for you!
      Simply spray Mothers® Aluminum Wheel Cleaner generously onto a cool wheel. Allow the foam to work for one to two minutes. Do not work in the sun and do not allow the cleaner to dry on your wheels. Hose off your wheels with a strong jet of water and dry them with a clean Microfiber Towel. That’s all it takes for sparkling clean, like-new wheels!
      Don't take any chances with your wheels! Mothers® Aluminum Wheel Cleaner works on everything from anodized aluminum to factory clear coated to chrome wheels and leaves them all shining like new.
    • By Paul Olesen
      I thought this week it would be a good idea to share with you an example of what can happen when dirt gets passed an engine's air filter. This will be a short post, but a picture is worth a thousand words. In my next post I’ll go into detail on how to properly care for your air filter to help ensure that this never happens to you.
      The series of photos below shows a sad case where dirt has found its way into the engine and wreaked havoc. The photos are all from the KX250F I bought on the cheap with the sole intention of rebuilding the engine and documenting the process for my book, The Four Stroke Dirt Bike Engine Building Handbook. Honestly, I couldn’t have bought a better bike for the project, nearly everything on the bike was worn out or screwed up from the previous owner.
      Here is how the air filter and airbox looked prior to disassembly.
      Here is the back side of the air filter. The filter was completely dry. There was no grease on the sealing face of the filter or the airbox flange. In this particular case, dirt could have got into the engine through the filter or between the filter and sealing flange. The amount of dried mud in the airbox and on the bike also makes me suspicious that muddy water got into the engine instead of just dirt. I honestly can’t say for certain.
      The airbox itself was also extremely dirty.
      Once the engine was disassembled I carefully examined the piston assembly and cylinder bore. At first, I could not get any of the rings to move freely. Only after I had pounded a pick between the ring ends of the compression ring was I able to get the compression ring off. As I removed the compression ring, a load of sand came with it.
      This photo of the compression ring doesn’t do the situation justice. Some of the dirt was actually removed from the ring as I handled it.
      Here is a close up of the compression ring. Note all the grit!
      The oil rings didn’t fair any better, were just as stuck, and had a lot of dirt on them.
      Here you can see dirt inside the ring grooves and at the edges.
      Here is dirt I rubbed off the oil rings.
      Miraculously (and fortunately for me) whether the engine sucked in dirty air or water, it happened quickly and stuck the rings to the piston so they could no longer seal correctly, and the engine subsequently lost compression and power in a hurry. This speculation is based on the fact that the cylinder bore showed no signs of excessive wear or damage and it measured well within the service limits. This is an outcome I never though possible and is hard to believe.
      I hope you enjoyed this brief write up on the damage that can result from ingesting dirt, whether from abnormal circumstances such as dropping a running engine into a mud hole or simply neglecting to take care of the air filter when running the engine in dusty conditions. In my next post I’ll show you how to care for and install your filters so these problems don’t happen to you! Questions or comments are always welcome and I enjoy hearing from you all!
      -Paul
      https://www.diymotofix.com/
      If you like my blog, click the "Follow this blog" button in the upper right. You must be registered to do this.
    • By ThumperTalk
      Keep your foam filter in like-new condition
      BIO Liquid Power filter oil was developed and produced by Texaco exclusively for Twin Air; exceeds the strictest standards on biodegradability by 16%; starts thin for deep, even penetration and dries to an even-coating, high-tack shield that traps dirt, dust and grit
      BIO Dirt Remover cleans Liquid Bio Power oil by using granular detergents instead of solvents; water-soluble cleaner can go right down the drain without clogging the drain or harming the environment; will not harden or damage filter foam
      Recommended for all foam filters
      Kit contains one BIO Dirt Remover and one liter liquid BIO Power Filter oil
      BIO Dirt Remover in 1 liter bottle, BIO Liquid Power filter oil in 1 liter can or 500ml spray can
    • By ThumperTalk
      Fresh, clean scented silicone detailer restores the factory shine
      Excellent for use as a polish, undercoat protectant and light lubricant
      Repels water and dries completely
    • By SlickProducts
      Slick Suds 32oz. Super Concentrate mixes with water to make a total of 16 Gallons of ready-to-use wash. Slick Suds is a specially formulated biodegradable wash and wax designed with the highest quality ingredients to clean and remove road dirt, bugs and grime without harming waxed or gelcoat finishes. Slick Suds can be used as a traditional wash or waterless application to safely clean and polish painted surfaces, windows, chrome and other areas of your vehicle leaving a protective wax coating.
