Product Spotlight: Alpinestars Tech 7 Boots
Chris Cooksey
These days expensive protective equipment saturate the market, but Alpinestars has a motocross boot that offers high dollar protection with high end quality at the average man’s price.  I have worn the Sidi Crossfire 2, Garne SG-10, SG-12, and Alpinestars Tech 10 boots.  While these top-line boots all share impressive features my favorite is the Alpinestars Tech 7, with the low retail price of $349.  Once Western Power Sports became a distributor for Alpinestars I immediately tested the Tech 10 against the Tech 7 boots.
My initial thought was I would prefer the highest priced boot, the Tech 10.  While this boot is amazing, I felt like I could literally jump off the roof and have no ankle injuries (not recommended), I struggled with the lack of flexibility.  I am 6’4” and have suffered many foot and ankle injuries throughout the years, the most recent was a ruptured Achilles’ tendon.  I tend to look for boots that offer support and protection, yet allow me the freedom to ride comfortably and the Tech 7 meets this criteria.  If I was riding AMA Supercross I would opt for the Tech 10, but for me and my Vet B riding level the Tech 7 is heaven on my feet!
Look for both the Tech 7 and Tech 10 boots available in the TT store.   https://www.thumpertalk.com/shop/cart.php?m=search_results&c=&catID=4443&v=&id=&venID=&attrList=&manuf=1602&priceFilter=&sortBy=PriceHiLo&search=Tech+7&sort=5&asc=desc&page=2
KEY FEATURES
• New dual compound sole is seamlessly integrated into the base structure for superior durability and features high performing rubber grip patterning and enhanced feel. The sole and footpeg insert are replaceable.
• The anatomically profiled shin plate features a dual closure system with an internal microfiber flap attached with Velcro® for a precise fit closure while the rugged and durable shin plate attached securely with a precision adjustable buckle.
• Wide entry aperture for convenience and allows broad ranging calf fit adjustment and support.
• Innovative buckle closure system includes high-impact aluminium bridge closures, with memory settings and a quick release/locking system with self-aligning design for easy, precise closure and improved riding performance. All buckles are replaceable.
• Redesigned instep and Achilles accordion flex zones construction for superior comfort, control and support.
• Extended microfiber gaiter helps prevent excessive water and dirt entry.
• Internal lining includes anti-slip microfiber suede on the heel to help keep foot in position.
  • Like 3
User Feedback
Recommended Comments
I much prefer the Tech 7 over the 10. Inner booty is a no go for me.
I have tried every high end boot on the market and the Fox Instinct is my go to. I have a new set of SG12's sitting on the shelf still with tags.
Boots are such a personal thing.
  • Like 2
Share this comment
Ive owned a few prs of tech 7s and tech 3s. Always end up back to them because the price was what I could afford at the time. While they work well when new and broken in , they dont last long.
issues...
1- the design has no ankle "pivot" so all "support" is a function of the material properties wich are breaking down from the moment you start using them. In a short time they go from quite good to same support as a cheap boot.
2- evey pair Ive had has colapsed arch supports and the sole on the kick start side is toast. Really no reasion for an arch to cave like this when a small amount of steel or composit in this area would stop such a problem.
3- the lowest buckle will hit on shift lever if you are a very farward rider. this rather larger "bump" around lowest buckle can easily down shift the bike or slip it into mid shift.
4- The buckles tend to get hard to use over time. Plastic used in the buckle reciever is a bit soft and can be easily deformed. As well they constantly need a bit of silicone lube or the friction properties will resist the buckle from snapping into place.
She looks good but The design needs some refinment. Boots may be a "personal thing" BUT I have found this personality to grow old quick ;)
Edited by lowmass
Share this comment
I have a set of Tech 7's that I've owned since '09.  They fit well and they've held up amazingly well.  Stiff at first, and even now they aren't easy to walk in, but here's the thing: I haven't even slightly injured either foot or ankle since I bought them, in spite of the countless times I've bounced my toe off a rock or had the bike fall on my foot.  Not once.  And isn't that why you wear boots?
Share this comment
I've been wearing high end "pivoting ankle" style boots for many years. Last year I had to find a good, non pivot style boot, so I could get away from wear ankle braces under my boots. The pivot style boots I'd grown to love allowed too much movement for my old, weak ankles, so I had to start wearing braces under them to limit some of the mobility. But, this was becoming an uncomfortable and even sometimes painful way to go. I didn't want to give up the fit and fill of the higher end boots, but most of those are pivot style boots now. The Tech 10 looked like he way to go, but they had booties that I didn't want to mess with and a very large price tag. And being that I've never liked Alpinestars boots, so I was very skeptical of trying them, but there was little else in the way of a non-pivoting / non-bootie boot to choose from. I pulled the trigger on a pair of Tech 7's and hoped for the best.
I'll have to say when I put them on the first time I was very impressed. They felt like no other Alpinestars I'd ever tried on before and as comfortable as any >$500.00 boots I've owned. My ankles felt very secure in the boots right off and I could still walk in them. But, would I be able to ride in them? Would all that security going to come at the cost of feel and control?
On the first ride day with them I was sold. Shifting and braking was still easy with good feel, yet my ankles weren't hurting. I could even get up on the balls of my feet more without ankle strain. I had just found the perfect boot for me and the coolest part was they WEREN'T the most expensive boots on the market! They are actually a reasonable priced boots with true high end fit and feel. And I can almost have two pair of these for the price of their higher end siblings.
I've been wearing these boots for over a year now and I'd have to say I still feel pretty much the same as I did about them when they were new. My only gripe about these, and any Alpinestars boots for that matter, are the buckle system. Although better than in the past, I'm still not a fan of their buckle systems. These are passible, but I think there are much better buckle systems out there.
Yet, even with that, I'll have to say my next pair of boots look to be Alpinestars Tech 7's, because I'm sure I can't find a better boot for the price.
Share this comment
issues...
I have to answer some of your points as they are not accurate.
1.  The boot has a pivot, see attached pic along with Achilles' tendon lock out stop.
2.  The boot has a shell that cannot collapse, if you had this issue it might have been on a previous version.  Do you have a picture?
3.  If the buckle is hitting your shifter, you need a longer shifter or have your feet in the wrong position (ask Gary Semics, you might be doing something wrong).
4.  The buckles are now high impact aluminum and by far the easiest most consistent buckle system available.
Thanks!
Share this comment
Dang, should just use this as my spotlight...  Thanks!
Share this comment
Yes, very much. I ordered in a pair some years back, tried them on and they went right back in the box. Exchanged them for a pair of SIDI Crossfire TA's.
Part of the reason I commented that I never cared for Alpinestar boots.
Share this comment
Thanks!
Chris is correct, ALL my tech 7s were the previous versions.
If they have overcome the issues then amen, its been a long time commin ;)
Share this comment
I'm finally ready to replace the Tech 10's I've had since 2001. I've had some of the same issues with the buckles mentioned above, but didn't feel it necessary to replace them until I'd had the boots 12-13 years or so. I'd say I got my money's worth out of that pair, but the 10s are quite a bit more expensive now than they were back then, and I don't need nor can I afford the fanciest top-of-the-line model these days. I have however become quite accustomed to the interior 'booty', and boots I've tried on that don't have one feel very strange to me. Because I have really small feet, it is especially important for me to choose the boot with the most up/down ankle flexibility for shifting/braking. I actually ordered a pair of Tech 7s from BikeBandit, only to get a notice shortly thereafter telling me that the model had been discontinued & was permanently out of stock. I'm assuming this was because of the size & color combination I selected, but y'all think I should just get the Tech 7s & assume I'll get used to the booty-free interior once they're broken in?
Share this comment
  • Similar Content
    • By Havingfun
      No peick thread?  got his jaw busted up bad, sucks.  There's no good videos?
    • By tj306mx
      Hi all, this is my first ThumperTalk post in awhile on here... So, Last night, I thought of how long some of these guys have been racing professionally and how deep was the field the year they all went pro was and I just wanted to make this list of rookie sensations of motocross/supercross that came up through the amateur ranks and what year they went pro rather it was on their own dime after Loretta Lynn's and other Amateur events or on a team contract basis. (**European riders not included on this list since they usually have turned pro a few seasons prior to coming over to race in the U.S.) (Maybe missing a few names)
      2000- Travis Pastrana (SX), Billy Payne (SX), Tyson Hadsell (SX), Mike Corder, Ivan Tedesco (MX)
      2001- Andrew Short, Michael Blose, Chase Reed, Troy Adams (all MX)
      2002- James Stewart (SX), Billy Laninovich (SX), Josh Hansen (MX), Ryan Mills (MX), Ryan Morais (SX), Justin Brayton (MX)
      2003- Broc Hepler, Brian Gray, Richie Owens, Bobby Kiniry, Shane Lusk  (all MX except Lusk)
      2004- Davi Millsaps, Mike Alessi, Josh Grant, Kyle Chisholm, Ryan Sipes, Tommy Hahn, Matt Goerke (all MX except Millsaps)
      2005- Ryan Villopoto, Jason "J-Law" Lawrence, Josh Litchle (RIP)  (all MX)
      2006- Ryan Dungey, Zach Osborne, Marty Davalos, Broc Tickle, Michael Lapaglia, Jimmy Albertson (all MX except Lapaglia and Davalos)
      2007- Trey Canard, Nico Izzi, Kyle Cunningham, Austin Stroupe, Wil Hahn, Matt Lemoine, Cody Gilmore (all MX except Lemoine and Cunningham)
      2008- Pj Larsen, Alex Martin, Blake Wharton, Hunter Hewitt, Sean Borkenhagen, Scott Champion (all MX)
      2009- Justin Barcia, Darryn Durham, Christian Craig, Jimmy Decotis, Cole Seely, Weston Peick, Blake Baggett, Les Smith, Taylor Futrell (all MX except Durham)
      2010- Dean Wilson, Eli Tomac, Ian Trettel, Dakota Tedder
      2011- Jason Anderson (SX), Kyle Peters (MX), Tyler Sjoberg (SX), Justin Bogle (MX), Gannon Audette (SX), Lance Vincent (SX), Shawn Rife (SX)
      2012- Zach Bell (MX), Jessy Nelson (MX), Jesse Wentland (MX), Jacob Hayes (MX), Dillan Epstein (MX), Gavin Faith (SX), Justin Starling (SX)
      2013- Joey Savatgy (SX), Adam Cianciarulo, Cooper Webb, Brady Kiesel, Matt Bisceglia, Shane McElrath, Mitchell Oldenburg (all MX except Savatgy)
      2014- Jace Owen, Chris Alldredge , Rj Hampshire, Luke Renzland (all MX except Owen)
      2015- Aaron Plessinger, Colt Nichols, Alex Frye (all SX except Frye)
      2016- Bradley Taft, Tristian Charbonneau (all MX)
      2017- Chase Sexton, Cameron McAdoo (both SX), Joey Crown, Sean Cantrell (MX)
      2018- Justin Cooper, Garrett Marchbanks, Enzo Lopes, Mitchell Falk (all MX)
      feel free to add more names you guys, if you see any missing info... and no I did not use any Racer X sites during the making of this except at the end for the new youngsters!!!
    • By MANIAC998
      Of those three, or any other new 450 SX racers, who’s going to do the best?
      My guess is Plessinger will have a great race or two, but ultimately won’t finish the season high in points. Savatgy impressed the Hell out of me at MEC! But I just don’t think he’ll hold together for the season either. Osbourne is the unknown. He’s older than most, so he should have maturity on his side, so I’ll stick with him for highest finishing rookie in the 450’s.
    • By Kev_XR
      First day of racing is over.
      Entry list.
      https://motocross.transworld.net/news/2018-paris-supercross-entry-list/
