Quick Fix for Bleeding Fork Seals
revolucien
After practice at a muddy track one day, I found one of my fork seals bleeding. One of the old pro's showed me this trick.
Step 1
Grab yourself some generic tear-offs (film negatives will also work) and cut the end off one of them with some scissors.
Step 2
Remove the fork guard and place a flat screw driver between the edge of fork and the dust wiper and gently pry them apart sliding the dust wiper cover down.
Step 3
Take the tear-off and slide it against the fork tube, in between the fork tube and seal.
Step 4
After working it around the fork pull it out and you should see some small particles. Believe it or not those will cause your seals to leak badly. Repeat this several times and you should see less and less.
Step 5
After, don't forget to also clean the dust wiper before replacing it. Put the dust wiper back on and try bouncing on the forks a little and take a look, it should be cleared up.
This won't help if your seals are worn out but, it may save you a trip to bike shop and the cost of replacing seals.
There is also a tool called Seal Mate designed specifically for this purpose if you don't want to use tear-offs or film negatives.
In addition you may want to use a neoprene fork seal protector. These ‘seal covers’ filter out and help prevent particles from reaching the seals and therefore reduce the need for cleaning and also extend the life of the seal.
User Feedback
Recommended Comments
Great tip! like a DIY Seal mate, I also recommend fitting Neoprene seal Guards (not the Velcro wrap round ones) but proper one piece slide over ones, I fit Viper Neoprene Seal Savers just to save you clearing out the fork seals all the time!
Share this comment
  • Similar Content
    • By racerbri
      This is a simple bolt up shock made for a DRZ-125.  Great shape.  $400 plus shipping.
      Still Available:  BBR anodized upper triple clamp and stock parts
      Need stock parts? I parted a whole bike and have most things except the motor, frame and plastics. I have:
      Stock wheels front and rear (19"/16")
      Complete front end - forks, triples, brake mastercyclinder, brake line, caliper, wheel and rotor.
      Stock gas tank (black)
      Spare brake shoes
      Tell me what you need and we can work on a price.
    • By NeilT
      I'm new to your community and I have a question that I'm sure has been asked and answered many times before but navigating this site can be a bit confusing at times. My question is this; is there enough adjustment in the suspension of my 2017 XR650L for my 200 lbs. for southern CA off road and street riding? I would say I'm an aggressive, intermediate rider. If so what adjustments should I make? If not what mods should I do and what size fork and rear springs should I be looking at? Any local companies here in LA? Thanks
    • By Ktm520sxrider
      The oem bushings were tight and hard to take off. I took them off to replace them with new pivot works bushings so I carefully expanded the bushing and got it on easy without stretching it at all and now the bushing is not even as tight. Do these need to be tight on there? I put it on the only way it could go and it seems like the gap in the bushing got bigger.
    • By Powerban
      We build suspensions for riders at all levels of riding and racing, from the professional ranks to the mini rider looking to begin his or her quest to race at the highest level of competition.
      Each and every PR2 order is 100% custom built and valved to the customer's exact needs and for maximum performance.
      Selecting the proper valving and spring rates for your application is part of the custom fork/shock building process. When you place your order with PR2 Racing Technology, you will be asked to provide as much information about riding ability and your motorcycle as possible so that we can coordinate selecting the proper setup for your bike.
    • By WideningArc1
      PRODUCT DESCRIPTION
      The best possible suspension set-up for each track is most often what decides the winner. The PODIUM® RC3 gives riders unsurpassed suspension performance along with the ability to fine tune to the perfect setting quicker and easier than ever before. FOX's proprietary external adjustments allow riders to independently dial in the optimum amount of high- and low-speed compression, rebound, and bottom-out control, completely independent of each other.
      FEATURES/TECHNOLOGIES
      Adjustable Bottom-Out Control  (B.O.C.) to change the end of travel damping without affecting the first 3/4 of travel F.A.S.T. (Fast Adjust Spring Technology) preload device Dual compression adjuster with huge range of adjustment DLC coated shaft Exotic, proprietary coatings on shock body and reservoir to enhance durability and significantly reduce stiction High flow, Off-Road racing truck inspired damping piston ADJUSTMENTS
      - Bottom-Out Control (B.O.C.) - 24 clicks - Spring Preload with new F.A.S.T.  preload device - High Speed Compression - 24 clicks - Low Speed Compression - 24 clicks - Rebound - 24 clicks SPRING
      Coil APPLICATIONS
      Motocross Racing
