Radiator Coolant Basic Maintenance
Bryan II
There are tons of threads on ThumperTalk about oil changes, but far fewer on radiator fluid. Because of this, I thought that this would be a good topic to cover.
At a minimum, radiator fluid should be changed once per year. If you race, at least twice a year. When you do this, it's a good idea to flush the system with white vinegar and distilled water (50/50 ratio).
After you've drained the old coolant, fill it up with the vinegar/water solution, run your engine until warm. Drop the solution and fill with clean water to flush the system. Drain the water and fill to the correct level with your favorite coolant. Do not overfill.
The acid in the vinegar does a good job of cleaning out the old coolant and contaminants but will not harm engine seals.
In terms of coolant, there are lots of choices and you can't go wrong using what your manual recommends. Most coolants are ethylene glycol based, so make sure to dispose of it where your pets (and young kids) aren't exposed to it. Because it's sweet smelling and tasting to them, they'll drink it and if they ingest enough, dead puppy or kitty.
I personally use Engine Ice. It's propylene glycol based, making it much less toxic to humans, animals plants, etc... and it's premixed with distilled water, ready to run with freeze protection down to -26 and a boiling point of +256.
If you live where winters are cold and you choose not use a premixed coolant/antifreeze, be sure to check the mixture with a hydrometer. You can get them for cheap at just about any auto parts store. You simply suck up some fluid, count how many balls float and cross reference the number of the freeze protection chart.
Also, the specific gravity of ethylene glycol and propylene glycol are not the same, so make sure that you use the correct hydrometer. For example, Engine Ice claims freeze protection to -26, but an ethylene glycol specific hydrometer will read only to +20. Not a problem per se in this example (you'd still be well protected), but the other way around could be trouble. I've found that some hydrometers just don't specifically say what coolant they are for. However, most are for the more traditional ethylene glycol.
Hopefully this is of value to some and I've always had excellent results following these practices. May winter come late and that you log lots of happy, trouble-free miles.
Edited by Bryan II
User Feedback
Recommended Comments
I ersnally think 1 time a year is overkill, let be a little environmentallly responsible, same as in oil changes!
But that said. let your conscious be ur guide!
Share this comment
I use Evens waterless coolant and find it great....I have a Husaberg fe390 and a KX250f bothe bikes have Rekluse Z-Start pro clutches. Never had an issue with the Waterless coolant.
Share this comment
On adding water to the vinigor and the water flush. There are debates on the effects of the cl2 in water (chlorine). I make chlorine for the past 23 years and can tell you that chlorine is some bad stuff. It can eat carbon steal and stainless steal like there nothing to it. Even at the right temp start a chlorine and metal and not stop till one of the other burns up. But there is very little in tap water, is it enough to do harm? With the anti corrosion in anti freeze I would guess if you ever see corrosion in a radiator it is from tap water. I usually drain my stock fluid at some point flush with di water and refill with engine ice and have had radiators over 5 years old and the flues right below the cap look like new. Anyway just research tap water in radiators and you decide for yourself. We had large chill water systems that we only used mill water (well water) plus anti freeze and did not use di water because the engineers says that di water does not react and cool the metal surfaces right but every time we open that system it is caked with rust.
Share this comment
Guest WesternMDMtnMan
Posted
Changing once a year is very much overkill especially on some of the newer coolants.  Most of the newer ones are rated for at least 2 year intervals with normal use.
Share this comment
Great article. Also a good idea, is to change out the factory fill after your first few hours on a new bike. They always have metal contamination.
Share this comment
Join the conversation
Guest
Add a comment...
  Only 75 emoji are allowed.
Loading...
  • Similar Content
    • By scarymoose69
      So as ive been digging more into my 1985 CR250, ive discovered the "magnesium water pump case" problem. My waterpump housing has been repaired with JB weld and doesnt look bad at all fortunately. looks like the case had only moderate corrosion to begin with too.
      Im worried about the radiators being clogged with magnesium junk, but ive only ridden air cooled bikes previously and have no clue if my radiators are good or not.
      Ive ridden the bike a couple times this summer, on pretty warm (75-80 degrees) days. I ride trails only with it as of now, and im in the pipe 25% of the time. Sessions have been for 2-3 hrs with maybe a 5min break here and there. No obvious issues, no overflow. Running green peak 50/50 premix.
      How do i check if my radiators are clogged so i dont burn out the motor?? If theres no obvious issue should i even check??
      I also heard only to use evans waterless too. Will 50/50 premix still cause corrosion?
    • By Jake Hoskins
      I know the title doesn't really explain it much, but here's the basics. I have a carbureted 2018 TE250, and I have been wanted to make my motor alot more lively. I made a thread asking people how I could acheive this, and most of the replies I got told me to swap out the head and cdi to those of a SX/TC motor. After doing a lot of research, I decided that I wanted to make my engine as close as I can to a TC250 motor. By looking at a ton of owner and shop manuals I have found that the primary differences are: head, cdi, jetting, flywheel weight, and gearing. I have already decided to do the head and cdi (ordered and going to be installed before the next trip). The gearing I am thinking about going from 13 to 12 teeth on the front sprocket, event though I know this won't get me anything like the SX gearing, at least I can link the powerband a bit better. The only other mods I have done are a lectron HV carb, vforce reeds, fmf turbinecore silencer. So my question is what can I do to make my motor as close to the SX motor as possible?
    • By Burke Moore
      So I was looking at the stock parts diagram for my ‘05 yz85 and I noticed that one one side of the crank there is a little indention and there is a little piece the fits into the indention. I looked the old crank from me engine and it had the hole with the little piece in it but then I looked at my new pro x crank the hole is there but there is no piece to fit into it. Is this an issue? Top picture is old crank and bottom picture is new crank.
    • By dragonov756
      DESCRIPTION
      Fastheads Xtreme Cylinder Head Service is one of our many service option packages for the Honda CRFs. In this service package, we replace the intake seats with our Beryllium copper intake seat and run Del West’s CrN titanium intake race valve on those seats for an extreme wear protection. We also replace the exhaust guides with a Bronze Manganese guide for a better wear and run either an OEM Honda steel exhaust valve, or a Kibblewhite stainless steel exhaust valve. Our machinist then blends the seats in and cuts all four seats to the perfect concentricity with our Rottler SG7 valve and guide machine. We then replace all springs with Honda OEM upgraded springs, and replace all guide seals with Viton MX guide seals. After we assemble the cylinder head with the parts listed above, we vacuum test the cylinder head for correct seal. Once all that is finished we top off the service package with one of our Fastheads heat resistant cylinder head decals for authenticity.
      Crf450l
    • By Pbuhler
      Hey guys wondering if anyone has seen this problem before.  2002 yz250f. Bike runs perfect other than when I go over any rough areas the bike will almost stall out for a second, especially at lower rpm.  If I hold the throttle wide open in a lower gear it wont do it.  I have set the float height and tried several different settings but it doesn't get any better or worse.  Have also tried adjusting the mixture scew on the bottom of the carb both directions about 1/4 turn and that doesn't help either.  Any suggestions would be appreciated.   Thanks
