Rekluse Auto Clutch: Everything You Need to Know
Spider Tech
Whether it's in the woods or on the motocross track, one of the critical components that have a significant effect on rideability and traction is your engine’s clutch. The clutch is responsible for transmitting power from the crankshaft to the final drive of your machine. Traditionally, powersports machines are offered with manual transmissions and use wet, dry, or slipper clutches.
At Rekluse, we specialize in high-performance clutch solutions that are easily installable into engines traditionally utilizing wet clutches. Auto clutches have inherent advantages over the other clutch types mentioned. Before considering an auto clutch, it’s important to understand all the essential details of what an auto clutch is, how it works, and the numerous benefits that street and dirt riders can expect. Different auto clutch options are available depending on the type of riding and budget, so it’s important to understand which one is right for you.
RadiusCX Auto Clutch - Cable Actuated Configuration
Auto clutches have inherent advantages, but it's important to understand all the critical details to know what's right for you. (RadiusCX cable actuated model configuration shown)
What is an auto clutch?
An auto clutch is a type of clutch that automatically engages and disengages the   based on engine RPM, and ultimately, the power being transmitted to the final drive. The ability to engage and disengage the clutch via rider input through actuation of the clutch lever is retained; however, rider modulation of the clutch isn't necessary in many situations.
An auto clutch allows easy starting and stopping without using the clutch lever, and virtually eliminates engine stalling. Unless you have mastered clutchless shifting, the clutch lever is still used when shifting gears.
Star Racing Yamaha and Rekluse Clutches
Star Racing Yamaha has utilized Rekluse auto (RadiusCX) and manual (Core Manual TorqDrive) clutches throughout the 2019 and 2020 MX season.
Justin Barcia Yamaha YZ450F Rekluse Clutch Motocross
Justin Barcia and the Monster Energy / Yamaha Factory Racing Team utilized the RadiusCX auto clutch for select rounds of the 2020 Lucas Oil Pro Motocross Championship.
654103075_RekluseClutchLeverStillFunctionalwithAutoClutch.thumb.jpg.c566767677136d400bfa3a93079c4b73.jpg
Rekluse auto clutches automatically engage and disengage the clutch based on engine RPM. The option for rider modulation of the clutch via the lever is retained, but unnecessary, except for during shifting.
An auto clutch should not be confused with an automatic transmission. Shifting gears is still an essential aspect of riding an auto clutch-equipped machine. An auto clutch is also different than a slipper clutch. When aboard a slipper clutch equipped machine and the throttle is chopped, the clutch disengages. When riding an auto clutch-equipped machine and the throttle is chopped, power transmission to the final drive is maintained, effectively maintaining engine braking.
Destry Abbott Racing With Rekluse Auto and Manual Clutch
A unique characteristic of Rekluse auto clutches is their ability to retain engine braking when the throttle is chopped.
How does an auto clutch work and what is an EXP disk?
Centrifugal force is the governing force that allows an auto clutch to work. Centrifugal force is the resulting force that acts on an object rotating around a centerline. The heavier the rotating object or, the faster the object is spinning, the more inertia it will have, and the more force it will exert.
An auto clutch features a special clutch disk that is designed to utilize the principle of centrifugal force. The Rekluse clutch disk that gives an auto clutch it’s automatic properties is called an EXP disk. The EXP disk essentially acts as a friction disk that responds to engine speed.
Rekluse EXP Auto Clutch Disk
The Rekluse EXP disk is the key ingredient to Rekluse's auto clutch formula. It's a friction disk built to respond to the centrifugal force of the spinning engine.
The EXP disk is comprised of wedges that are positioned circumferentially around the clutch disk. The wedges are tuned and designed to respond to increases and decreases in engine speed. As engine speed increases, centrifugal force increases, and the wedges in the EXP disk exert an outward force on the two halves of the EXP disk, causing them to expand and the clutch to engage. As engine speed decreases, centrifugal force decreases, and the force exerted by the wedges decreases in the EXP disk, resulting in contraction of the two halves, which causes the clutch to disengage.
Rekluse EXP Auto Clutch Technology Graphic
To ensure the clutch is disengaged at idle, the clutch is set up so that a small gap of about 0.030” exists between the clutch pack and pressure plate. Off idle, as the throttle is applied and engine RPM increases, the EXP disk expands outwards, overcomes the installed gap, and engages the clutch. Since the auto clutch automatically engages at engine speeds higher than idle, the functionality of the clutch lever and traditional clutch deactivation/actuation methods can be retained without any modification. Finally, because an auto clutch works exactly like a standard clutch above idle, features associated with traditional clutch operation such as engine braking are also retained.
Rekluse RadiusCX Ring Adjuster GraphicRekluse Adjustable Slave Cylinder Auto Clutch Graphic
Rekluse Clutch Cable Perch Adjuster Auto Clutch GraphicRekluse Core EXP Auto Clutch Center Adjuster Graphic
Depending on your application and the auto clutch package you have, Rekluse has proprietary designs for adjusting installed gap, which is a critical step in optimum auto clutch performance.
Advantages of an auto clutch
If you’re considering switching to an auto clutch, here’s a few of the advantages and how they’re possible:
No Stalling - Since the auto clutch engages and disengages as a function of engine speed and at idle the clutch is set up to be disengaged, stalling is not possible.
Tunable - Rekluse EXP disks are tunable. The EXP disk can be tuned to engage at various engine speeds, and how quickly or “hard” the clutch engages can also be manipulated.
Rekluse EXP Auto Clutch Disk Tunable Wedges Springs Graphic
Dead-on power delivery - An auto clutch simulates perfect clutch modulation which results in better traction.
Reduces physical and mental fatigue - Since the utilization of an auto clutch yields fewer situations where the rider needs to engage the clutch, physical fatigue is reduced. Mental fatigue is also reduced since riders no longer need to focus as much on clutch operation.
Clutch lever is still operational - If circumstances arise where manual clutch operation is advantageous, this can easily be accomplished.
Engine braking is unchanged - Because an auto clutch operates just like a standard clutch above idle speed engine braking is not affected or altered.
Rekluse RadiusCX DDS Auto Clutch for KTM Husqvarna
(RadiusCX DDS for KTM / Husqvarna hydraulic actuated model configuration shown)
Who benefits from using an auto clutch?
Rekluse auto clutches are designed for numerous applications and offer riders inherent advantages in each of them. There are application-specific advantages that riders can benefit from as well:
Motocross
- Automatic modulation of the clutch allows riders to ride a taller gear through corners.
- The rear brake can be applied fully without fear of stalling.
- Ease of operation allows the rider to focus more on their line.
Woods
- Automatic modulation of the clutch allows for better traction in slippery conditions.
- Navigation of technical terrain is easier.
- Ease of operation allows the rider to focus on their line.
Ryan Sipes Erzberg Rekluse Clutch
"In the slicker, rockier, rooty-er stuff, I trust RadiusCX [auto clutch] more than my finger." -Ryan Sipes (Photo: Future7Media)
Trail
- Steep and technical hills can be navigated without worrying about feathering the clutch to keep the RPMs up and the bike running.
Zach Bell Kawasaki KX450 Rekluse RadiusCX Auto Clutch
Zach Bell and the Precision Concepts team races WORCS and other West Coast GPs aboard their RadiusCX equipped KX450s.
Rekluse RadiusCX Auto Clutch Kawasaki KX450
Rekluse RadiusCX Auto Clutch for the Kawasaki KX450
Adventure Bikes
The RadiusX auto clutch covers a wide range of Adventure Bike applications:
Rekluse KTM Adventure Bike Clutch
Photo: Gnarly Routes
Yamaha YXZ1000
 The Rekluse EXP 3.0 auto clutch for the Yamaha YXZ1000 allows you to operate the manual transmission with ease, with smoother clutch engagement which comes in handy when maneuvering at low speeds in technical terrain.
Yamaha YXZ1000 Rekluse Clutch
 Photo Credit: UTV Action, Cain Smead
Auto clutch durability
Similar to OEM applications, auto clutch durability depends on the end user and how aggressively they operate their machine. That said, Rekluse auto clutches are designed to last at least as long as OEM clutch applications. Since the clutch is mechanically engaged at the same RPM every time, clutch wear is consistent which helps prolong clutch life. Auto clutch durability also depends on ensuring the clutch is within spec and adjusted correctly. Auto clutch riders need to perform a simple and quick check called “free play gain,” which is a comparative measurement taken at the clutch lever periodically.
Why are auto clutches innovative?
Rekluse auto clutches are innovative because there are no other clutch solutions on the market that offer significant rider advantages while at the same time retain conventional clutch functionality and ease of use. Innovation doesn’t stop at functionality, the number of installation options and the ease at which an auto clutch can be installed are also worthy attributes, not to mention the fact that no modifications are required to install any of Rekluse’s auto clutches.
Rekluse EXP Auto Clutch Disk in Engine KTM / Husqvarna DDS
All Rekluse auto clutch systems are drop-in, no additional modifications are required.
Auto clutch options
 To help you understand how each clutch option differs, the highlights of each clutch are identified below, and a comparison table is presented that also shows key differences. Whether you’re a top-level racer, avid adventure rider, or dedicated trail enthusiast, there is an auto clutch option for you.
RadiusCX: $1,049 - $1,179 (Dirt Bike and ATV)
- Premier, top of the line auto clutch.
- Features all the latest technology offered: EXP, Core, and TorqDrive
- Increased friction disk count transfers more power to the rear wheel while eliminating clutch fade.
- Provides optimal lever feel.
- Yields highest level of durability.
- Increased oil circulation through the clutch.
RadiusCX
RadiusX: $649 - $749 (Dirt Bike, ATV, ADV, Street)
- Excellent mix of performance and cost – uses OEM hub and pressure plate.
- Includes TorqDrive and EXP technologies
Rekluse RadiusX Auto Clutch
Core EXP 3.0: $949 - $1,079 (Dirt Bike, ATV, YXZ1000)
- Core EXP 3.0 uses OEM friction disks, meaning power transfer will be equivalent to stock engine performance.
- Includes EXP and Core technologies.
Rekluse Core EXP 3.0 Auto Clutch
Understanding how Rekluse auto clutches work is proof they are an advantageous option over various applications. View Rekluse clutch options for your machine here on the website, or use the dealer locater to find your closest Rekluse dealer. If you have any questions at all regarding which clutch is right for you, installation, or adjustment, Rekluse experts are happy to help and can be contacted at 208-426-0659 or by email at customerservice@rekluse.com.
What the pros are saying:
Rekluse and Star Racing Yamaha – Clutch Technology for Champions
Dylan Ferrandis on Rekluse RadiusCX Auto Clutch
Precision Concepts Kawasaki Team Manager Robby Bell on Rekluse
Still not sure which clutch is right for you? Check out our complete guide here to help you decide!
  • Helpful 1
User Feedback
Recommended Comments
A buddy of mine ordered a Beta 500 with an Auto Rekluse. He kept swearing by it. Yeah, I got that it helps "him" but I'm already faster and more skilled so I thought, hmm, it's good for him I don't need it.
After the install,  I hit a technical rocky uphill where a guy was stuck and blocking the trail. I just chilled and knew this was going to be the thumbs up or down on the autoclutch. As soon as I had room, I let it do it's thing on this offcamber rocky narrow uphill. I literally smiled, it really allowed me to focus ahead while the bars were jolting and deflecting off of rocks.
There are times when riding on ice or very slippery surfaces that I prefer to use the clutch to gain a smoother electric like feel. Any chugging will cause the rear wheel to break loose so I'm in favor of keeping the clutch lever on. Some toss it.
BTW, on one ice ride, I went down hard and the bike slid and ended up tearing my hydraulic clutch line. As mentioned, I prefer to use a clutch in those conditions, but since the hydraulic line tore, it was disabled. My autoclutch was still able to get me home. Absolutely no way that could have happend on ice without it.
This week I'm returning to the 5 mile uphill on volcanic rock. I'm anticipating a much easier time. My biggest concern will be punctures from the anticipated higher speeds.
I dig my Radius CX
  • Like 2
  • Helpful 1
Share this comment
What are the differences between cable and hydraulic actuation in regards to the function of the auto clutch? I take it that the slave cylinder of the hydro system needs a modification allowing it to be adjustable? Is there an application that allows the use of aftermarket hydraulic clutch actuation systems (e.g. a Magura Hymec)?
Also during the Thunder Valley 250 race yesterday, Weege mentioned Star Yamaha making undisclosed changes to Ferrandis' bike that sacrificed some comfort throughout the race for an advantage in the critical few seconds getting out of the gate to the first turn. In which DF14 showed marginal improvement, in the first moto at least. Any speculation if those changes perhaps involved switching back to(or from) a manual clutch? (if he indeed was using the auto previously)
thanks OP for the well explained summary (or just long-winded advertisement?), btw
@Spider Tech
Share this comment
@Spider Tech
Great questions! Really the main difference between hydraulic and cable bike auto-clutch products is how the adjustment is made and maintained. Ultimately the goal is to create a working gap to allow the EXP room to disengage the clutch when the rear wheel is stopped. To make it easy for customers all of our current hydraulic kits come with an adjustable billet slave cylinder that allows external and quick adjustment.  (KTM/HQV/ New Kawi models/ etc) The cable clutch systems are adjusted internally with a pressure plate adjuster (Core EXP) Hub adjuster (RadiusCX) which gives an OEM feel at the lever with normal free-play. RadiusX is adjusted with the cable, by tightening the cable to create a gap. This takes up all the slack when the bike is off or at idle but allows normal free-play when riding. RadiusCX can also be adjusted with the cable if so desired. The function of the auto clutch is the same between cable and hydraulic with the correct gap adjustment.
With the premier cable auto clutch systems (RadiusCX and Core EXP) you can use a hydraulic conversion kit like Magura as the adjustment will still be made internally. One note on hydraulic conversion kits is that they may be limited in lift capabilities so they can cause more drag due to less disengagement or lift of the pressure plate. This mostly comes into play for MX style starts or extreme off-road technical (almost trials) type riding.
I chatted with the technical manager for Star this am on this topic. He said they didn't change anything internally in regards to the clutch at TV so it may of been cable or lever/perch related. Teams always seem to run through different clutch options. Star has a few different Core Manual TorqDrive options and then the RadiusCX as well which are all used depending on the conditions. Last season the team was all on RadiusCX other than Justin Cooper who ran Core Manual TorqDrive. This season the team continues to use RadiusCX for training but most riders are primarily racing Core Manual TorqDrive other than Masterpool who is on RadiusCX. Star really takes full advantage of the Rekluse product line. On another note Justin Barcia has been racing RadiusCX along with teammate fill in rider Broc Tickle this season. They made the switch to allow Justin to ride the Yamaha in taller gears where the chassis seems happier and helps him maintain higher speeds around the track. JB51 started using RadiusCX 1/2 way through the MX season last year after catching wind of the success Star was having with that product.
  • Like 3
  • Helpful 1
Share this comment
Had one installed on my wife’s ttr125.....it sounds funny...under load even going up the truck ramps it chatters n slips....when hot it runs different it creeps a lot n that chattering sound gets worse....I think it’s the middle of the field core 3.0.....we brought it back....looked over everything even changed out the old clutch pack....ran great for two hours....now still does same thing....dealer test rode it n swears it’s good....at new he showed me that when you reved the bike the clutch moves a little...he said this is how you know it’s in proper adjustment??? Anyhow that gone lol....my wife doesn’t notice the chatter....so I’ll let her ride n see what happens
Share this comment
Join the conversation
Guest
Add a comment...
  Only 75 emoji are allowed.
Loading...
  • Similar Content
    • By Kyy2601
      Hi guys I got a rmz 250 2008 and it’s started jump into false neutral  and unfortunately it happened while I was in mid air in 4th gear on the weekend I’m all cut and bruised but I want sort this problem out soon as , ready for the weekend
      I no people say ‘it could be this’ ‘ it could be that’
      it’s a common problem.. is there anyone who has actually sorted this problem and what did it...? so I can go from there please instead of just trying guess some stuff, most of the time people break the engines in half and everything looks normal with this problem ...
      Thankyou all comments will be appreciated
    • By lugnut93
      I am looking to sell my Rekluse EXP 3.0 clutch pack, red springs, throwout spacer, and adjustable slave cylinder off of my 2005 KTM 250 EXC. The previous owner said it was recently installed before I bought the bike but I don't know exactly how many hours are on it. I took it off before putting an hour on the bike myself. It worked flawlessly but I don't like the auto clutches. Asking $375 Paypal G&S TYD CONUS. I pasted a link to the Rekluse webiste for now but I will try to get some pictures up here soon.
      https://rekluse.com/product/exp-3-0-clutch/
    • By Marcus Ysaguirre
      I got a 99 Kx250 that im working on for a friend. I changed out the clutch plates, tightened the pressure plate to the correct torque. Figured that would fix the power issue it was having. It still seems to have the same issue of not having the correct amount of power. I give it gas and it takes forever to reach higher RPMS and the thing just does not pull at all. Im familiar with 4 strokes but this 2 stroke is killing me. Any suggestions on what the issue could be?? The bike also rolls in first gear with the clutch out, and the only way we can start it is by push starting it in 2nd gear, which is odd cause yesterday we were able to Kickstart it and adjust the air/fuel mixture and idle. Any ideas what the issue could be?
    • By Brody Batten
      I recently purchased a new clutch plate set and changed out my stock clutch plates for Hinson fiber plates, steel plates, and springs. I didn’t really let them soak in tranny oil too much but when I tried to start the clutch was not working. I let it idle for about 5-6 minutes to let the oil get in and warm up, but the clutch still wouldn’t work. I even adjusted the cable and wherever I put the cable it didn’t help. I’m thinking I may have got the clutch spring bolts too tight but am not sure. Does anyone have any idea that could help me.
