Repair a broken clutch cable
FlashGordon
Broke the clutch cable at the upper lever while on an extended ride far away from home. A friend had a great idea I'd like to pass on. We pulled out the cable from the sleeve, and inserted it backwards so the lead coupling could be used in the upper lever. The sheared end of the cable was now at the bottom by the lower lever attached to the clutch disengage shaft. We used a small bolt and nut with 3 washers and pinched the cable between the washers, with the bolt going through the part of the lower lever where the swedged cable normally attaches. 1 or the 3 washers was slid between the upper and lower tabs of the lower lever, so it would not smash the tab when tightened.
Worked great for the 3 days I was there.
User Feedback
Recommended Comments
There are no comments to display.
  • Similar Content
    • By Bryan Bosch
      FLO MOTORSPORTS 3.0 Foot PEGS
      Rounded Edges Loctite on Cleats Extra Wide platform. KTM Footpeg Size is 57mm Wide and 86mm long. Stainless steel Flat teeth Removable Teeth (Cleats) with 5mm Hex Self Cleaning Mud Grooves. Foot pegs are possibly the most over looked parts on a bike but one of the most important parts. No matter how much power your bike makes, it means nothing if there is no control of the bike . You probably haven't given much consideration to you're footpegs before, but pretty much all professional AMA  supercross , motorcross  and off-road riders ride go with aftermarket footpegs for a wider platform, more grip and overall control of the bike .
      Our Pro series Flo Motorsports Foot pegs will offer all of the above . The foot pegs you are about to purchase are the same pegs used by Factory Supercross teams like Traders Racing (Yamaha) , BPR Home Depot ( Yamaha)  and JMC Husquvarna.   Our pegs are constructed from highly durable 7075 T6 alloy making them much more durable then some standard cheap 6061 T6 that many competitors use on the market.
    • By ThumperTalk
      Each footpeg is cast from 17-4 stainless steel, given a solution-annealing treatment, and age-hardened for superior strength
      Width (57mm) and length (90mm); slightly convex platform for better boot positioning and grip when leaning forward or back
      Dual-plane teeth provide traction without the stuck feeling
      Available with 1/2 rear offset to allow more space
      Use your OEM springs, unless otherwise noted in application chart
      Made in the U.S.A.
    • By ThumperTalk
      Built-in ergonomics; adjustable grip, height and setup
      Electromagnetic-polished patented system
      Allow both standard and lowboy setup with reversible collar insert with each peg; collars may also be purchased separately to take footpegs from one make to another for an exact fit
      Superwide (58mm) for comfort and traction control
      8mm Fast Kamber Mounting System (FKMS) allows camber angle adjustment for more control to keep a rider on the bike
      Available in three versions: F3, F5 and F6
      F3 footpegs feature SS setscrew teeth; easily adjustable and replaceable
      F5 footpegs feature SS press-pin teeth that are semi-replaceable (can be replaced up to three times); no adjustment necessary; just bolt up and ride
      F6 footpegs have the same great features as the F3 and F5 but have an improved cleat design to provide sure grip footing in any terrain
      Each system comes with reversible collars, springs, an 8mm FKMS system and teeth (F3 footpegs come with two different height setscrews, and F5 footpegs come with press-pin teeth installed)
    • By ThumperTalk
    • By ThumperTalk
      Pro-series foot pegs are made of stainless steel
      More traction than stock. 50mm X 75mm
      Hard coated to prevent drooping
