Safety Wiring Basics
NoFiddyPilot
If you're worried about critical nuts on your bike loosening up or brake lines being torn loose, you can always wire tie them as cheap insurance.
Materials need:
- 1/16th" (.5mm) drill bit
- Drill motor
- Stainless steel safety wire
- Pliers (specialty wire tie pliers are sweet)
Mark the nut you plan to drill with sharp punch to keep the drill bit from walking on you. Depending upon the material, you may need to carefully drill towards the threads initially to start the hole, but reorient the bit to be on target for the exit hole. Make sure to leave at least 2mm of material left to avoid the hole breaking through. If you're unsure on your abilities, put an old nut in a bench vice and practice before you drill on your scoot.
Areas of your bike to consider for safety wire:
- rear axle nut (tied off to adjuster bolt)
- front axle nut (tied off to axle pinch bolts)
- rear hanger bolt of your exhaust system (tied off to another subframe bolt)
- steering stem nut (tied off to triple clamp)
- brake calper bolts (tied off to each other)
- brake lines (tied off to banjo bolt body)
- Oil drain plug
When you tie any of these off, think about the direction the fastener turns when it backs out. Obviously the fastener needs to pull on the wire when this happens, not allowing it to back out.
If you have additions to this article, pm me and I'll add them. I'd like to hear about what else people wire tie.
Addition from TT Member Mythic:
grips - use instead of, or in addition to glue - works quite nicely in sloppy conditions instead of glue - be sure to turn the ends of the twist into the grip & you're golden.
spokes - old school race tech here - stiffens wheel assy slightly & keeps any broken spokes from flopping around & causeing havoc
just a few thoughts there.
Once you have the tools & start using them it really becomes addictive - I do all the key bolts on my XR (ie oil filter/oil pump cover, clutch cover & ign/magneto cover - all tied off one to another aircraft style) as well as anything that consistantly backs out & I don't want loc-tite anywhere near for fear of stripping (ie rear fender/sub-frame/brace interface)
User Feedback
Recommended Comments
There are no comments to display.
Join the conversation
Guest
Add a comment...
  Only 75 emoji are allowed.
Loading...
  • Similar Content
    • By NoFiddyPilot
      ProTaper's revolutionary Self-Engaged Launch Assist (SELA) solves a problem faced by all motocross racers, no matter their skill level: setting a start device alone is awkward at best and impossible at worst. With its patent-pending self-engaged twist dial, SELA can be easily set without any assistance, giving riders the freedom to practice starts and line up for races by themselves.
      During a start, SELA makes it possible to temporarily compress the motorcycle's front suspension, reducing its tendency to wheelie under acceleration. This optimizes rear wheel traction, allowing the rider to be more aggressive with the throttle and launch down the start straight with greater control.
      Its unique, modular design allows SELA to be installed on most full-size, late-model motocross bikes. A dual-hinged receiver ring makes for quick and convenient installation without removing the front wheel or fork.
      For detailed installation instructions and mounting templates specific to your motorcycle, enter its make, model, and year in the drop-down menus above. Then, see the Instructions & Templates tab below to download your files.
      The following video provides an installation walkthrough. Please note that this video is meant to serve as a visual aid to the written instructions. It is not a replacement for them.
    • By Ud_Luz
      Prevents loss of coolant due to overheating on most water-cooled motorcycles, snowmobiles, and ATV's Designed for hot weather and/or high-altitude riding conditions Compact, versatile, high density polyethylene bottle with built in mounting holes provide multiple mounting options Bottle cap is constructed from chemical-resistant rubber for durability and easy installation/removal Includes 275cc (9.3 oz.) Capacity bottle, hose, clamps, mounting ties and instructions
    • By jaybellnv
      Moto Bling Kit for your KTM includes rear wheel chain adjusters, oil fill cap, front and rear brake reservoir cap, air tube caps, rim lock caps, and steering stem nut.
    • By Madsmokey12
      The STEALTH ULTRA HD Soundbar Series represents the world’s first universal high performance plug and play sound system for side by side’s, golf carts and just about any mobile application. The Patented design is built with a full extruded aluminum housing which looks similar to our Rogue 4 led light bars. All STEALTH models feature a full range speaker array plus additional titanium dome tweeters for dynamic output and performance. Now with an ALL-NEW RF Wireless Remote for full control from steering wheel cradle. IP67 Rated.
