Securing friction tiedown straps for the anal retentive
Bryan II
As the article title says, I'm a bit anal about how I tie down my bikes. But, I'm old, cranky and don't care if my riding buddies don't like it, so I'm good.
1. Cinch down the straps like you normally would.
2. Tie a simple knot below the friction buckle with the loose strap and slide it up against the buckle. The knot doesn't need to be tight. Its purpose is so that in order for the friction buckle to loosen, it has to suck the knot through it (not happenin').
3. Take the excess, loose strap and feed it through the eyelet on the top s-hook and route it downward.
4. Finally, tie a slip knot, securing the loose strap to the tight portion of the strap below the friction buckle by pulling the slip knot loop downward until tight.
I've been securing bikes like this for many moons and I've never had a since issue. Of course, this assumes that the strap webbing is in good shape to begin with. And no, this doesn't mean you can now drive like Mario Andretti when hauling your bikes. Leave the haulin' A for the track or trail. 👍
Do you have a different tie down method that has served you well? Share it up in the comments below. Are you friction or ratchet strap guy and why?
Edited by Bryan II
  • Helpful 1
User Feedback
Recommended Comments
i do the slip knot and release  the buckle to suck up the knot and thats all .. if you use the first knot and for get to untie it or the buckel slips a bit you`re stuck with a knot in the line thats hard to remove..
Share this comment
I use the bungee loops to hold excess straps. wal mart sells them they are the ones with it wood knobs and a loop of small bungee cord much simpler than threading and tying
Share this comment
I drive a ZR2 S-10 Blazer with enclosed trailer and front wheel locking chocks .  I use ratchet straps in front and these pull tight or friction straps on the rear just to keep them from swinging around. I'll have to try this , last fall i had my sons 03 cr125 buck loose and ruin my way too expensive graphics on my 01 cr250 , Thanks for the info. guys and here's a bit more. If you need more than 2 strokes you're just playing with it . 😉
Share this comment
Join the conversation
Guest
Add a comment...
  Only 75 emoji are allowed.
Loading...
  • Similar Content
    • By dieseldork
      As the title says, I'm looking for something better to help contain my bike in the bed of my truck.
      I like these two things:
      http://www.riskracing.com/pages/Lock_Page.html
      http://www.cinchitdown.com/catalog
      and have considered things like these:
      http://www.ccrsport.com/page.html?id=10
      http://www.usrack.com/cradle_motorcycle_carrier.php
      The top two are pretty expensive.... but if they work great, they're probably worth it. I can't help but wonder about just using some plain 'ol load binders like these to clamp the bike by the pegs to some d-rings I install in the bed floor.
      http://www.truckntow.com/showcategory.aspx?categoryid=146918&affiliateid=10060&gclid=CMWqtKrO5p8CFRVc2godvHPDHg
      Just a random thought on the last one.
      Thoughts and comments?
      Thanks
    • By Motomotives
      Need some feedback on this one. I'm interested in finding out how most of us transport our bikes. Doing some research on the most common method and can't seem find a reliable survey.
      Let me know who prefers van, truck, open trailer, closed trailer, toy hauler, or receiver hitch rack.
      Look forward to the results and will post percentages.
      Thanks guys.
    • By oceantrav
      Got a brand new bike, and started getting concerned about it getting stolen. Whats the best steps to take to prevent this?
      I know insurance is an option, but I hate paying for insurance. My bike is kept in a garage, and I usually have two bikes, so I was thinking a thick chain locking them together would probaly spoil an attempt to steal them. Does that sound like a decent plan? I wouldnt think that bike theifs would plan on the bikes being chained together, therefor they wouldnt have bolt cutters, but they could always come back.......
      When I travel to ride and stay at a hotel I keep it in my locked motovan that has no stickers, etc. It also has no windows in the back, so I feel kinda safe with it since no one would know whats in there.
    • By cadman_ks
      I've been thinking about getting some of these for use when I'm trailering my bike, or especially when I it loaded in the back of my truck:
      But, the reason that I'm hesitant, is because KTM redesigned the fender in 2014 so that mud doesn't pile up on it.  That's a good thing, but it doesn't look like one of these things will work now, since the underside of the fender is more or less flat across the bottom.
      One thing that I guess would make it work would be to alter it to something like this:
      Has anyone used one of these, or something simliar on a 2014, and do they work, or do they need to be modified???
      CADman_KS
