GET IN ON THIS! Read more... ×
Single-Ring vs. Two-Ring 2-Stroke Pistons: Which One is Better?
Kevin from Wiseco
Single and dual compression ring two-stroke pistons have been in service for decades, and since their inception, many have wondered if there are advantages to one or the other. If you have been involved with dirt bikes, jet skis, or snowmobiles long enough, you’ve probably noticed different manufacturers have chosen to use one or two compression ring piston designs for their engines. Furthermore, you may have noticed some aftermarket piston companies offer single ring pistons that replace dual ring pistons and vice versa. So, as a consumer, what do these design differences mean, and which one should you choose?
Wiseco has been manufacturing two-stroke pistons since 1941. In fact, the company started with two-stroke racing pistons being built in Clyde Wiseman’s garage. There’s no replacement for experience, so we want to take this opportunity to shed some light on the advantages and disadvantages of single and dual compression ring two-stroke pistons designs.
Compression Ring Function
We’ll start with a quick review of what a compression ring is designed to do. First and foremost, the compression ring provides a seal that allows the piston to compress the air/fuel mixture as the piston travels upward, then during the combustion event itself, it seals the rapidly expanding hot gases that form during the combustion event. The effectiveness of the compression ring seal, in part, has a significant effect on the power and efficiency of the engine. Should the compression ring lose its ability to seal, the amount of trapped air/fuel mass that will be retained during the compression stroke will be significantly reduced, resulting in less power. Similarly, during the combustion event, a compromised ring seal will allow more gases to leak past the ring, often referred to as blow-by, resulting in reduced power.
The compression ring, or rings, seals compression so the piston can compress the air/fuel mixture. This plays a critical role in performance, as an improper seal will cause a very poor running condition or not allow the engine to run at all.
Heat Transfer
The piston rings play a vital role in transferring heat from the combustion process to the engine's liquid or air cooling systems. During combustion, the piston crown absorbs a portion of the extreme temperatures it is exposed to. If left unregulated, the piston would become so hot that it would melt. Thankfully, the piston rings transfer heat from the piston by connecting the piston to cooler parts of the engine such as the cylinder liner. From the liner, the heat finds its way to the water jacket or to the cooling fins on an air-cooled engine. Engine designers optimize the size, shape, position, and the number of rings to influence how the piston and rings transfer heat.
In addition to sealing compression, the piston rings play an important role in transferring heat from the piston crown and through the cylinder wall to be dissipated by the cooling system. Otherwise, the piston material would not survive the extreme heat.
Conformability
The piston ring’s conformability refers to how well it adheres to the shape of the cylinder bore. The conformability of the ring will have a direct effect on how well it seals the mixture and combustion gases as well as transferring heat to the cylinder liner. Factors that influence a ring’s conformability are shape and thickness. In particular, thicker rings will be less conformable than thinner rings because ring thickness has a significant influence on ring stiffness.
Thicker rings are generally less conformable, and therefore may not seal compression as effectively. However, too thin of a ring will not transfer heat well enough. It's important to develop a balanced ring that performs both tasks effectively.
Wiseco’s Research & Development Manager comments, “Racing applications tend to favor single rings for a lower friction penalty. Also, thinner single rings have better conformability to the cylinder and are less susceptible to flutter at high RPM. Even when specified with lower tension, thinner rings can still have good unit pressure which promotes sealing without a high friction penalty.”
Single Versus Two-Ring Applications
While many have speculated that certain types of two-stroke powered vehicles—whether it be ATVs, dirt bikes, jet skis, or snowmobiles—need one or two ring pistons, it isn’t so much the specific vehicle application that drives the selection, but more the intended use for the vehicle. The big differentiator is whether the vehicle’s intended use is for racing or not. Two-stroke engines designed and developed for racing typically utilize single ring pistons. When designers optimize an engine for racing and select a single compression ring design, several advantages and disadvantages arise when compared to a two-compression ring design. Let’s take a look at the pros and cons of each.
A single-ring design is common among Wiseco pistons that are designed for racing and high-performance engines, such as the Racer Elite piston.
Single Ring Pros:
●       Lowest friction design translating to increased power
●       Lowest weight design contributing to fast revving
Single Ring Cons:
●       Potentially less longevity due to heat dispersion
Two-rings designs are popular among riders that prefer added performance durability at the expense of a little performance. However, some big-bore two-stroke applications benefit more overall from a two-ring design.
Two Ring Pros:
  • Improved heat transfer due to the addition of the second ring
  • Engine performance durability due to 2nd ring’s ability to seal if first ring’s seal becomes compromised
Two Ring Cons:
  • Increased friction and weight
  • More susceptible to ring flutter at high RPM
“Since a good portion of the piston heat is transferred from the piston to the ring and then to the cooler cylinder wall, one advantage of a 2-ring system is that the second ring would provide a second heat transfer path,” adds Dave Fussner on the topic of two-ring designs.
The last point worth mentioning is that racing piston ring applications are optimized for excellent ring control at high RPM. A condition called “flutter” occurs when a ring becomes unseated from the piston’s ring groove. Flutter occurs around top dead center as the piston transitions from upward motion to downward motion, in part, because the inertia of the ring, which is a function of the ring’s mass, overcomes the gas pressure, pushing the ring against the bottom of the ring groove. When this happens, the ring’s sealing ability is compromised, and engine performance degrades both in terms of performance and durability. Engine designers combat flutter by optimizing the ring's weight so that the ring’s inertia forces cannot induce flutter within the intended RPM range. This is why in many single ring applications the rings are relatively thin.
Single-ring designs are less susceptible to flutter because there is less ring mass changing direction as the piston begins its return from TDC.
These are the general and major factors that drive single ring and two-ring designs in two-stroke pistons. The intended use of the vehicle usually drives ring selection, not the vehicle type itself. If you are considering a switch from a single ring to a two ring piston, ultimately, how you intend to use your machine should dictate whether the decision  is sensible or not.
  • Like 9
  • Helpful 1
User Feedback
Recommended Comments
Piston rings seal is very much aided by compression and combustion pressures...
The inherent spring tension style of lateral force that a ring exerts on a cylinder wall doesn't stand a chance of sealing combustion pressures on it's own... The ring MUST use combustion pressure to create an effective seal against both the bottom of the ring land AND to force the ring out against the cylinder wall..
The ring and ring channel have to work in unison to allow for gas pressure to get behind the ring to force it out against the cylinder wall... This is what allows the use of lower and lower tension rings... Low tension rings will have less parasitic drag when they don't need to seal tightly, and then have a tight seal when using gas pressure to enhance the downward and outward forces...
If a secondary ring is the one doing serious pressure retention of any kind, the performance is compromised and the piston's useful hours are on serious decline...
Appreciable pressure captured BELOW the top ring will unseat the top ring from the bottom of the ring groove... Which will then allow for hot gasses to ensconce the top ring... Heat transfer is lost and carbon build up on the bottom of the ring land will make blow bye even worse... And then you have weight and friction of 2 rings, yet only the seal (maybe) of the second ring...
In my experience, if the second ring is the one doing the sealing, you basically don't have a performance engine anymore...
Single ring for me please...
  • Helpful 1
Share this comment
The proceeding view point is loosely based on vague recall and seat of the pants experience; no math or science to back it up.
I prefer the 2 ring piston, if for no other reason, the longevity between top ends.  My 06 CR250R (single ring) would make about 25-30 hours, where as both of my 13 & 14 250SX's would make about 80 hours before needed top end.  Some of this may be due to technology improvements, or simply 2 rings will mask wear for a bit more time.
As far as the extra ring drag causing HP loss, I have no numbers to dispute such, but I'm guessing the numbers are negligible, or at least at the amateur lever.  Maybe the extra ring seals just a bit better against blow-by, and therefore having a cleaner base for the next incoming air-fuel charge.
I raced dirt cars for years before venturing into the world of Mx, and we used and had excellent results with Total Seal rings.  I contacted Total Seal about making a total seal ring for a 2-stroke.  They said they would look into it if I would send them the cylinder and piston, but I never followed through.
I reckon I'm done babbling/meandering, thanks for listening.
Share this comment
In the 50,s it was not seldom that a 2 stroke piston had 3 rings.
That was at a time when cast iron cylinders and lousy Piston and ring material needed big over bores.To stabelise the piston against the walls , 3 rings were better then less.
Today,with Nicasil plating , phantastik oil,s we can manage with one single ring for a very long time.
This little air cooled 125 SCREAMER runs on NICASIL-Single RING and 100-1 (Opti2) at least one full season ( before it may need a new ring.)
Share this comment
On 12/7/2018 at 2:23 PM, Antoine Mion said:
Interesting post.
What if I want my 2 rings piston become a single ring one? I guess I would have to keep the top ring.
Yes, you would have to keep the top ring. But it's always recommended to only run them as they were designed. It would only be recommended to buy a single-ring piston specifically if that's what you're looking for.
Share this comment
OK, thanks ! Of course, it would only be in case I cannot find a single ring one. For example, I have a 125 TSR Suzuki, for this one, you only find 2 rings pistons. I want to try some scavenging changes and the 2nd ring gets into my way.
Share this comment
  • Similar Content
    • By Kevin from Wiseco
      With a little bit of work on your part, Wiseco Garage Buddy Steel Valve Kits can help your dirt toys deliver years of service. Read on for full details on these reliable and affordable valve replacement kits.
      One of the basic truths of the imperfect world we live in is that the people who design machines are not the same people who have to maintain those machines. This often leads to situations where something that seemed like the way to go on the CAD screen turns out to be more difficult or more expensive to fix in the real world than it otherwise would be. Exotic materials and painstaking processes that are economical to implement when you’re mass-producing something turn out to be expensive to service in the field.
      Today's 4-strokes are engineered to be high-tech, but the parts come with a big price tag.
      In this single-serving, throw-it-away-when-it-breaks world, there are some noble souls who take a stand and say that we should be able to service and maintain things ourselves instead of discarding them, bringing new life to machines that need a bit of a refresh. Such is the case with Wiseco’s Garage Buddy Steel Valve Kits for a variety of popular dirt bike and ATV applications.
      Wiseco Garage Buddy Steel Valve Kits were engineered to be a more reliable and affordable option for riders who need to replace valves in their modern four-stroke machines. Read on for complete details!
      When faced with the price tag on factory replacement parts for bikes that came with trick valvetrain components, many owners cringe at the price of refurbishing a tired engine. However, with the right components at the right price, turning your dirt bike’s mid-life crisis around and letting it catch its second wind can be easy.
      Win on Sunday, Sell on Monday
      With the incredibly impressive machines under race tents worldwide, nobody wants to buy a new bike that has a whiff of “outdated” technology surrounding it, so a lot of the high-end features that really only make a difference to the top one percent of professional racers become must-haves for weekend warriors who just want to trail ride with their kids. When those parts wear out, the exotic bragging rights come with a cost, though.
      “Titanium is a great valve material due to the strength-to-weight ratio, and also the material’s ability to deal with the high temperature of combustion,” Wiseco Product Manager Dave Sulecki explains. “The light weight is important for engine acceleration; imagine how a heavy component takes more energy to move, and you can see where titanium is ideal when the camshaft needs to accelerate the valve quickly with less energy, and you can see that a lightweight component would be critical for a high-end racing engine.”
      Titanium is popular for valves for its light weight properties, but they are expensive to manufacture and can wear out faster than steel.
      While those race-spec valves come standard because they’re a positive selling point on the dealership floor, they’re mostly there for bragging rights instead of making a difference you’ll feel when twisting the throttle yourself, and it’s cheaper for the manufacturer to make everything to one specification than it is to have separate designs. “This light weight and performance comes at a greater cost,” Sulecki adds. “The material is more expensive, and costs more to machine or form into a valve. Additionally, the titanium requires a special coating to deal with the heat and wear, which also adds cost. This expense is needed for the highest performing engines, like the type you find in nearly all levels of racing from motocross up to Formula 1.”
      Sticker Shock
      Even expensive, exotic materials wear out, though, and when it’s time to freshen up the valvetrain of your bike, you might be surprised to see just how much it will cost to replace like-for-like with factory components. Per Sulecki, “Steel valves are a great low cost alternative to titanium, and offer longevity, reliability, and improved wear over titanium. Some customers are not always racing their vehicles, and just want longer service intervals and the peace of mind that comes with this material.”
      "Steel valves are a great low cost alternative to titanium, and offer longevity, reliability, and improved wear over titanium." - Dave Sulecki, Wiseco Powersports Product Manager
      That’s where Wiseco’s Garage Buddy Steel Valve Kits enter the picture. They’re designed to be an affordable way to refresh your high-tech dirt bike’s valvetrain. Although they may not be made from titanium, that doesn’t mean they aren’t precision-engineered. “Because steel valves are a small percentage heavier than titanium valves, heavier-rate valve springs are required to control the valve and protect the engine from valve float (the condition where the heavier valve will stay open under high RPM engine speeds),” Sulecki explains. “These springs are included with the Garage Buddy Steel Valve Kits.”
      Garage Buddy Steel Valve Kits are available separately for both intake and exhaust valves. They come complete with the valves, springs, and even a free packet of cam lube to make sure every box is checked during your reassembly.
      Converting to steel valves requires using valve springs designed for the specific weight of the valve. Springs are included with Garage Buddy Steel Valve Kits.
      Wiseco’s extensive experience with powersports valvetrain components provides confidence that their conversion kits are engineered to restore showroom-floor performance, and they utilize stock retainers, seals, shims, and other components for affordability and drop-in compatibility. The springs are crafted from premium chrome vanadium steel, and the nitrided steel valves can actually outlast an OEM titanium valve by a factor of three or more.
      Wiseco's nitrided steel valves are designed to utilize stock retainers, keepers, and seals. The steel conversion valve springs are manufactured from chrome vanadium steel.
      Time For A Change
      So, how do you know when it’s time to replace the stock components, short of a dropped valve or broken spring? Per Sulecki, “Valves and valve springs wear over time, like any highly-stressed engine component. When you are checking the valve clearance, or making shim adjustments, this is always a good indicator how quickly the valves are wearing or receding into the seat.” Keeping an eye on these telltales during your regular maintenance will allow you to judge when your factory valves and springs are reaching the end of their service life.
      Entire engine in need of a refresh? Garage Buddy also offers Complete Engine Rebuild Kits, check them out here.
      “When you are inspecting your top end for general overall health, such as the piston and ring condition, this is the best time to take a closer look at the valves and valve springs,” he continues. “Valves and springs need to be removed from the cylinder head for full inspection. Once these are removed, you can look closely at the condition of the valve face where it seals to the valve seat, and also the condition of the valve head overall and the stem condition. Any cupping or damage to the valve face means it is time to replace the valve, and any similar wear to the valve seat means replacement or re-cutting will be needed.”
      Inspecting your valves for wear while doing a top end is a good idea. Closely inspect the sealing surface of the valve for cupping, and inspect the rest of the valve for wear or damage. It's a good idea to also check the groove at the top of the stem for signs of wear to avoid breakage.
      Over time, springs become less elastic and may no longer be able to control valve motion at high speeds, but it’s not the sort of wear that is immediately obvious to the naked eye. Sulecki suggests, “Valve springs should be inspected for free length, and also overall condition, looking for any wear marks or defects that can lead to spring failure.” Any nicks or cracks are a sure sign of impending doom, and your cue to replace the entire set.
      Valve spring free length can be measured and compared to the recommended spec to get an idea of wear on the spring.
      Doing the Job Right
      Depending on your level of mechanical aptitude and how well-equipped your garage is, valve replacement might be a job you want to subcontract to a professional. “For most all valve replacements, it is a good idea to work with a qualified builder if you are not sure about the condition of any of these components,” Sulecki suggests. “The work can be done in your own workshop, but there are some special tools required to remove the valves from the head, and having an experienced eye on these items is always the best approach if you are not sure what to look for. An OEM service manual is always the best place to start, they will provide information about any special tools, and guidelines of what to look for regarding valves, valve seats, and even valve guides, and their condition.”
      When replacing your valves, be sure to use proper tools and follow all procedures and specifications outlined in your owner's manual. If you're unsure about performing your own valve maintenance, we recommend taking your machine to a trustworthy and certified shop.
      Whether tackling the job yourself or letting a pro handle your top-end maintenance, you’ll save time and money by seeing to all the wear-prone components at the same time. Sulecki adds, “When replacing valves, it is a good idea to inspect the top end for any concerning issues or conditions. Inspect the valve seals, valve keepers and seats, shim buckets, the condition of the cylinder head (flatness and sealing condition), and cam chain condition.” Needless to say, the time to service or replace these components is while everything is apart in the first place, and by using quality components like Wiseco’s Garage Buddy Steel Valve Kits, you’ll protect your investment for many off-road seasons to come.
      Wiseco Garage Buddy Steel Valve Kits are available separately for both intake and exhaust valves.
    • By Evan Dodd
      I was looking at putting a Prox Piston in my kx 250 for my next rebuild. Have other things to get don't really want to buy a wiseco. How durable would it be in my bike, how long would it Last. I ride Michigan trails. Usually pretty tight averaging 30 mph. Also, ride Hatfield McCoy. Dont usually get on it hard besides the occasional drag race with friends. Would this Piston last a summer in my bike I will rebuild every summer anyway. Probably put 50-60 hours on it a summer maybe closer to 40.
    • By Bryan Bosch
      I know that I've seen complaints about the quality of some Wiseco cranks over the years. I received this press release yesterday and wondered if this might change things?
      Honestly, I can't say I have any knowledge of Falicon products. Does anyone here? http://www.faliconcranks.com/
    • By Crhenn23
      So,
      I purchased a clean 2012 kx250f with 49.6 hours on it. Bike starts first kick and runs and idles great. It revs out and shifts through all the gears and has plenty of power. This weekend I took it down to the frame and went through the whole bike for a rebuild for peace of mind. I decided to check the valve clearance before I threw it back together, and got some weird measurements.
      The exhaust clearance was at .28mm on both lobes. Is there any reason that someone would set the exhaust clearance "loose" and be .06mm above the spec in the manual?
      My intake clearance is in spec, one at .11mm, the other at .15mm. I am bringing the .11mm up to match the .15mm at the upper end of the spec.
      I also plan to bring the the exhaust back down into spec, but want to make sure i'm not gonna mess something up if this was done intentionally. I know the gap tightens as the valves stretch over time, so I don't see why the gap would be above the specification.
      This is my first Kawi KX250F, so the valve train sounded loud in my opinion. I owned a Kawi ZX6R. This also had a loud valve train, but that was typical for this bike. It had a self adjusting cam chain tensioner, so the valves would get a little loud before it self adjusted.
      Let me know what you guys think before I throw the bike back together.
      Thanks!
    • By ExtremePolyAthlete
      I just bought a 1998 Kawasaki kx80, and I'm gonna need some help getting it running, so any help that anyone could provide would be great. The bike had a little bit of fuel in it, but it mostly looked like oil, so i'm guessing that the gas evaporated. It was looking very blue inside there. I put in some mixed fuel but not a lot, i'm not actually sure if it was the right mix. I tried kick starting it and it has some compression, but it wouldn't start at all. I tried push starting it and kicking it into second, and it got a lot closer to starting, but still would not fire up. Then I realized that the clutch was not engaging. When I pull the lever, I can see the cable moving, so I think it is something inside the bike. Also, when I pull the lever, I know its supposed to have some tension as you pull it in farther, but the tension does not change at all, like its not doing anything. I know I probably need to get inside the clutch side of it, but what is wrong with it, and what do I need to do? I'm going to clean the carburetor because that is probably one of the main problems, and I will also try cleaning the air filter. I know that it also has a blown head gasket, which is pretty easy to fix, and I can do that by myself. I also checked the spark plug, and it was super oily, and I cleaned it quickly, and made sure it was getting spark. It was sparking, so I put it back, and tried push starting some more times, and it got a little closer, but it still isn't starting. The bike is also super oily/greasy all over, and I have no idea why, is there a specific reason for this, or just because it has been sitting? One other thing that is wrong with it is that the rear brake works, but is super stiff, and when I push it down, it doesn't want to come back up so I have to pull it back up. The return spring does look a little rusty, and everything around the rear brake system does look a little rusty. I'm going to take it apart and lubricate it and see if that helps at all.
      What I know I need to do: Clean carburetor, clean air filter, replace head gasket, drain all the fuel in the tank and put the correct mixture in, check the oil and all the fluids,
      What I need answers to: Why isn't the clutch engaging, and what do I need to do to fix it. Should I get a new spark plug just in case, and why is it so oily in there? What else do you guys think could be wrong with it, and what do I need to do to it?
      Thanks for the help, I really appreciate it.
