Top 3 Signs Your Dirt Bike Needs a New Clutch
Kevin from Wiseco
The clutch system is the most important connection between your hand and the rear wheel, as far as controlling the machine. When working properly, most riders don’t give their clutch a second thought. However, the importance of the clutch quickly snaps into focus when there’s a problem with the system.
A clutch is an engineering marvel. Imagine you are on the starting line waiting for the gate to drop. You start your bike and pull in the clutch. What follows is a chain reaction of events. A series of moving parts transfer that load down to the clutch, where the pressure plate is pushed away from the clutch pack, basket and inner hub. At that point, there is a disconnection between the transmission and crankshaft.
Clutch functionality involves a series of moving parts that are crucial to engine operation. Periodic maintenance, inspection, and replacement will keep your machine running as it should. Shown here is an exploded view from Yamaha of a YZ250 clutch.
With the clutch disengaged, you click the shifter into gear. The gate drops, and you quickly release the clutch lever. The clutch springs force the pressure plate to squeeze the friction and drive plates together, causing the clutch basket and inner hub to synchronize. At that point, the energy generated inside the combustion chamber is carried through the transmission and to the countershaft sprocket, which then transfers the load to the rear wheel. Without an operating clutch, you would be sitting on the starting line as the pack raced away.
Suffice it to say that your clutch is a vital piece of the overall puzzle. And, like most parts on your bike, it won’t last forever. Fortunately, there are three general indicators that your clutch is not working properly. You don’t need to be deft or dexterous to determine whether your drive system is giving up the ghost. The only necessities are a handful of tools, basic mechanical knowledge, and a good sense of smell. In this article, we delve into the symptoms, causes and solutions for the most common clutch problems so you can get back to riding.
Sign #1: Slipping Away
Symptoms:
A slipping clutch is quickly recognizable when you’re twisting the throttle with reckless abandon while the machine is in gear, yet the rear wheel isn’t rotating in unison with the engine’s rpm. If you’re wound out in third gear and only accelerating at a snail’s pace, then something is wrong. You may also be able to notice a vague feel at the clutch lever. Either of these symptoms suggest that the internal clutch components need to be inspected for wear.
Causes:
When a clutch is performing optimally, the drive plates and friction plates are pushed together during clutch engagement (i.e. when the clutch lever is let out). The connection causes the rotation of the clutch basket and the inner hub to synchronize and work as one unit. However, as the plates begin to wear out, the clutch plates will slip against each other instead of grabbing. This prevents the transfer of energy from the engine to the transmission. Unfortunately, clutch slipping is inevitable, even if you aren’t a clutch abuser. Clutch plates wear out over time as a result of rubbing when the clutch is engaged.
When experiencing clutch slipping, the likely culprit is worn clutch plates. It's time to disassemble and inspect your steel and fiber plates for wear.
It is also possible that the clutch springs have lost their tension. When this happens, the springs aren’t strong enough to effectively pull the pressure plate against the clutch pack. Just as with clutch plates, clutch springs do not last forever.
Worn clutch springs can also contribute to a slipping clutch. Read on for an explanation on inspecting your clutch springs.
Solutions:
When you experience clutch slippage, you’ll need to inspect the drive and steel clutch plates, as well as the clutch springs. To quote Dave Sulecki, Wiseco Powersports Engineer, “It’s very easy to access the clutch on all the new bikes. You can literally lay the bike over on its side, pop off the clutch cover, and start inspecting the components.”
Using a vernier caliper or micrometer, measure the thickness of the steel (or aluminum) drive plates, and the fiber plates. Consult your owner’s manual to find the recommended specs. Be sure to also check the free length of the clutch springs. It’s a good idea to replace the drive and fiber plates, as well as the clutch springs.
1122131958_Photo5.jpg.e997233cb09c17b95bcc93d1bd16ad3e.jpg 394986739_Photo6.jpg.a4c72cf67ab72256f31cb0440b737df1.jpg
The most accurate way to know if your steels and fibers are worn is to measure them and compare the thickness to the recommended spec range in your owner's manual.
Similarly, clutch spring free length can be measured to determine if they are outside of spec and need to be replaced.
Replacement clutch components—both in individual components and clutch pack kits—are readily available through aftermarket companies like Wiseco. Replacing your fiber and drive plates at the same time is common practice, and when springs are required as well, all these components are available in kits with fibers, plates, and springs in one box. Each kit is built to OEM specifications and far less expensive, and Wiseco clutch springs feature a stiffer rating for a more positive clutch engagement.
Replacement clutch components from Wiseco are available in individual packs of steels, fibers, and springs, as well as in clutch pack kits that include all three.
Find Wiseco clutch components for your bike or ATV here.
Sign #2: Creeping & Bad Smell
Symptoms:
The machine is emitting a foul burning smell that could strip paint off a wall. The stench might be so pungent that it’s evident after pulling into the pits. Generally, though, the smell is noticeable after removing the clutch cover. You may also notice your bike creeping forward with the clutch pulled in and the transmission in gear, no matter how much you adjust the clutch cable.
Causes:
Do the sniff test. Pull the clutch cover off. If you smell burnt clutch material, chances are your clutch will need new components. The burnt smell is the result of the clutch heating up.
“The parts that burn first are generally the friction plates. It’s a real obvious odor. You’ll know it when you smell it. Visually, you’ll see the heat marks in the drive plates. The friction plates can also become black in color. The best thing to do is check the plates dimensionally against the specifications in your owner’s manual. Make sure you’re within tolerance on width and flatness,” states Sulecki.
136596952_Photo11.jpg.4623335f3434020d4536f4586bef962f.jpg 426991578_Photo10.jpg.ea3136d01cf0be7b6740c5d57729d5eb.jpg
Burnt friction plates will typically become black in color and burnt drive plates commonly show dark colored wear marks.
Solutions:
For starters, you’re going to need to replace the oil. Be sure to pay close attention to the recommended service intervals in your owner’s manual. Doing so can extend the life of your clutch.
Sulecki adds, “Fresh oil will help keep things lubricated and running cool. Oil does break down from heat and friction over time. In a lot of engines, the clutch shares oil with the transmission and valve train. Oil gets a lot of opportunity to break down quickly. Keep the oil fresh.”
However, the damage of a cooked clutch cannot be undone. Clutch plates can warp over time from the heat. Warped plates cause the clutch to disengage unevenly and create all sorts of headaches. You will need to invest in new friction and drive plates, at least. However, heat could also damage the clutch springs, effecting spring tension. Be sure to inspect all your clutch components.
If you find your clutch components have been subjected to excessive heat, it's always a good idea to at least replace the drive plates, fibers, and springs (when applicable).
Sign #3: Feeling A Drag
Symptoms:
The clutch lever feels lumpy during clutch engagement/disengagement. Sometimes the lever can feel jerky. These are telltale signs that the clutch basket and/or inner hub is damaged and needs inspection.
Causes:
If your machine has the OEM/stock clutch basket, it was likely made using a diecast aluminum material. While fairly lightweight, durability is not stellar.
“When you cast aluminum, you take molten aluminum and pour it into a mold. Once it has solidified, it gets processed from there into a finished part. When the material is molded it is generally not very dense. You get a lot of voids, porosity, inclusions, and imperfections in the material. The constituents inside the material aren’t bonded tightly against each other,” states Sulecki.
740508726_Photo14.png.1892fa34d4e4ad8ae035a4f82d0728eb.png 1139321852_Photo15.png.800adc84c3a176027699d3ba18292200.png
The most common wear on cast clutch baskets is notching on the edge of the tangs where the clutch plates engage. The inner hub can be inspected for similar wear. If you see notching like this, it's time for a replacement.
Solutions:
There are a variety of aftermarket clutch basket options that use different manufacturing processes. Billet is a common alternative to casting, but even that has downfalls.
Sulecki explains, “With billet, you’ll start with a cast piece of aluminum. It will generally get compressed a little bit in a forge press or some sort of pressure casting. That’s to condense the material a little tighter. Then the part is machined from the solid piece of metal. It has slightly better properties than a cast part, but not as much as a forged part.”
Forging is a very intricate and involved process. It begins with a cast and drawn bar of aluminum material, which is then smashed until all of the molecules are bonded to each other. This makes the material much denser and creates what engineers refer to as feature aligned grain flow. Basically all of the grains in the material are forced to flow up through the features–particularly the tangs on the clutch basket and stanchions on the inner hub–for greater strength. All of the material properties improve–from tensile to fatigue to ultimate strength. Ductility is also improved, meaning the material can bend before it breaks.
Cast and billet constructed clutch baskets are susceptible to wear. This is why Wiseco forges their clutch baskets in house before machining them, achieving greater tensile strength and wear resistance.
Sulecki adds, “The denser material is very resistant to impact and fatigue, which are two critical components of a clutch basket. Impact is caused by the clutch plates as they drive against the tangs on the clutch basket. Clutch plates will actually start to create indentations on a stock cast part, and dimples on a billet basket. In turn, the plates can’t slide smoothly across the width of the tab as you pull in the clutch lever to disengage the clutch. A forged clutch basket’s resistance to impact means that it will not develop notches in the tangs.” Suffice it to say that forging is the superior material for clutch basket durability and lasting performance.
Check out all the technical details on Wiseco clutch baskets here.
The forged material creates much greater resistance to impact from the clutch plates during operation, providing a seemingly lifetime solution to tang notching.
To cap it off, Wiseco hard coat anodizes and coats their forged clutch baskets with Teflon. Hard coat anodizing aids in wear and abrasion resistance, as well as improves lubricity and corrosion resistance. Teflon coating is the last process. It helps fulfill the wear resistance and lubricity that Wiseco requires for their clutch baskets.
Hard coat anodizing and teflon coating finish off Wiseco clutch baskets for ultimate wear resistance and smooth operation.
Find a Wiseco clutch basket for your machine here.
Lifetime Guarantee
It’s interesting to note that Wiseco has been manufacturing forged clutch baskets, pressure plates and inner hubs for years, but this all-too-important detail has flown under the radar. “Our forged clutch basket is the best product we make that nobody knows about,” says Sulecki. The performance-driven powersports magnate is so resolute in the durability of their forged clutch baskets that they offer a lifetime guarantee against notching and breakage. What does that mean? You’ll buy it once and never have to worry about it again.
Related Reading: How to Replace the Clutch Basket in your Motorcycle
  • Like 4
  • Helpful 2
User Feedback
Recommended Comments
There are no comments to display.
Join the conversation
Guest
Add a comment...
  Only 75 emoji are allowed.
Loading...
  • Similar Content
    • By Blqke
      Hello there, today I just finished putting my bike together for the second time now after it keeps seizing up I originally pulled it apart because the shift drum cracked and transmission was damaged the bike ran fine before I pulled it down it never missed a beat. I went to put it back together after I rebuild the transmission and put new crank barings in when I went to start it, it just wanted to seize up I thought this might have been the Piston because it seemed a bit old at 168 hours so I got a new one put it all back together same issues it idels fine but when you go to accelerate at wants to seize up, then it gets hard to kick. no it's not the timming like 10 million people have said it's some weird bottom end issue could be the crank or rod even tho they were perfectly fine before it was pulled down. when it seizes up you just put it in gear and pull it back and it's fine again so confused on wtf is happening please help.
      cheers blake
    • By go2cnavy
      Rekluse Core EXP (RMS-7713). Fits 2002-2008 CRF 450R. $450. (MSRP $900) like new.
      Free shipping to continental US.
      Only a few hours on the clutch. Comes with everything you need. I bought the Honda with hopes of making it a good single trails bike, but really missed having a 6th gear. Sold it after a few weeks of owning it.
      I pulled the clutch before selling and forgot that I had it. It’s been bagged and sealed in a light ATF bath for a few years.
    • By SamkalmaWR
      Hey guys,
      When I'm stopped with the clutch fully in(I've wound the cable in and out and in again but it still does it) it trys to go forewards with just enough torque to be annoying( I can only just stop it with my feet) when the tires off the ground I can't stop it with my hands with the clutch in.
      Any ideas?
    • By Chuck Sandes
      My bike started to have a speratic slipping or maybe it's a miss fire. It only happens in fifth gear. At first I thought it was a miss fire, however the more I ride it it seems more like a clutch or trans issue. What happens is, I have it in 5th gear and try to accelerate at all it feals like I am dumping the clutch over and over again. Only at an allot faster pase that I would actually be posible. I took the cover off and inspected the clutch and everything is within spec. Which makes me think ita a trans issue. However I'd think if 5th gear had a missing tooth, the rest would get stripped off shortly after. Thanks for any help in advance
    • By Drz Florencybell
      Im rebuilding my 2000 drz's lower. It didnt have many miles on it aka 1500, but my crankshaft bearing is out and i need to replace it amd dont have the tools to change just the bearing. I was curious what brand yall would recommend the hotrods ive heard good and bad mixes. Please if you've replaced a crankshaft or know a reliable brand let me know. Thank you for your time. A.C. DrzFlorencybell
