What do Clutch Baskets and Dampers Really do?
Spider Tech
Think of a clutch basket as the back-bone of your entire clutch system. Precision CNC machining combined with innovative world-class engineering allows Rekluse clutch baskets to safeguard your vital internal components, keeping you on the track or trail a lot longer. Read on as we dive into the function and construction of clutch baskets and dampers and learn more about how Rekluse billet baskets can protect your clutch system and engine.
Like we mentioned, the clutch basket is the back-bone of your bike's entire clutch system, but clutch modulation is not its only responsibility. In fact, an arguably even larger responsibility the clutch basket carries on its shoulders is being one of the main transfer points of load experienced back and forth between the rear wheel and the engine's rotating assembly. Not every bike utilizes a dampened clutch basket - dampened here meaning there are rubber cushions between the clutch basket and the primary gear. Small but mighty, these dampers are tasked with dampening any load transferred from the rear wheel and through the drive system, protecting the engine's internal components from potentially damaging, jolting forces.
To put this in perspective, think of hitting a metal object with a standard metal hammer vs. hitting that same object with a rubber mallet. The rubber mallet absorbs much more of the energy whereas the hammer transfers it to your hand and arm. Obstacles like whoops, square edges, braking bumps and even landing off a jump under acceleration are common riding situations that force load on the drive system through the rear wheel. These repetitive occurrences over time, as well as excess clutch heat, can break down the rubber dampers, putting internal engine components at greater risk of damage.
This risk can be mitigated through normal clutch maintenance and equipping your system with new dampers, but the problem is that stock clutch baskets in dampened designs are not serviceable, meaning the primary gears are riveted onto the basket and removing the gear to replace dampers renders the basket unusable.
On the right is an OEM basket still assembled with the primary gear. On the left is the same OEM basket with the rivets and gear removed. Even though there is now access to the dampers, having to drill out the rivets has rendered the basket unsafe to reuse.
Rekluse billet clutch baskets for dampened systems are designed with allen screws that can be easily installed and removed, making rubber damper replacement not only possible, but fairly simple with common garage tools. Replacement dampers for Rekluse baskets are designed to provide at least three times the life over OEM and are made available to help riders keep to service intervals, but those service intervals can vary by make, model, and even year. Be sure to do a little research on what's recommended for your machine, and feel free to chat with the tech experts at Rekluse as well.
Rekluse clutch baskets are serviceable, meaning just the dampers can be replaced through normal maintenance without having to
replace the entire basket.
So, we've discussed damper wear, but what about other common basket issues? Many will say basket notching is a highly common issue with basket wear that typically constitutes replacing the basket all together once it gets bad enough. However, basket notching can actually be attributed to worn our dampers as well. Once dampers are worn to the point where they lose their ability to sufficiently absorb force, undue forces make their way through the clutch system and the rest of the engine, part of which means the impact of clutch fiber fingers on basket tangs will be greater. To help combat this type of wear in between damper replacements, Rekluse has developed basket sleeves - replaceable, thin alloy sleeves that slide between basket tangs, protecting the basket itself and theoretically allowing the basket to last for the life of the motorcycle, especially when paired with Rekluse TorqDrive clutch products.
Rekluse basket benefits don't end there:
  • Made 100% in-house in the USA in our Idaho manufacturing facility
  • Billet aluminum hard anodized construction
  • Enhanced clutch modulation
  • Extreme durability resists notching and extends clutch life
  • Exclusive replaceable cushions protect your transmission even under the most extreme conditions
  • Tightly controlled tolerances ensure smooth operation, less drag and reduced clutch noise
Rekluse Clutch Baskets are machined from one piece of solid aluminum, giving them better precision and greater durability than OEM cast baskets.  #MadeInTheUSA
Because in-house research, testing, and development can only go so far (and we take it as far as possible), we lean on our partners in professional racing to provide further data and feedback that we translate back into our shelf parts. Just some of these teams are:
Want to learn more or order now? Visit Rekluse.com and use the "Select your ride" feature to find the right basket for your motorcycle.
  • Helpful 1
User Feedback
Recommended Comments
The video and discussion on riveted clutch baskets is very brand centric.  Is KTM/Husky avoided in the discussion because their clutch baskets, other than being cast, have a better dampening design? Is there any benefit to have a Rekluse billet clutch basket in a KTM other than the aforementioned benefits of billet (stronger, better balanced?). (note, just looked, don't see billet clutch baskets for KTM/Husky).
Share this comment
Tye good question. The product discussed in the video is really geared towards traditional aluminum baskets which are found in all Yamaha, Honda, Kawasaki, and Suzuki models. Older 1998-2011 (none RFS) KTM models would of also used this type of traditional basket. They can also be found in Gas Gas and Sherco. Modern KTM/HQV OEM clutch baskets for most models 2012 and newer are STEEL and have no dampers from the factory. Wear in these OEM steel baskets is rare and these basket designs really fall into a category of their own. The KTM/HQV 250F/350F competition models have no dampening at all however other 450/500 and 250/300 2T models have dampening that is within the inner hub (DDS) and not in the basket. Rekluse does offer replacement hub dampers for these types of DDS KTM models (P/N: RMS-0213080).
Edited by Spider Tech
  • Helpful 2
Share this comment
This seems like a good place for my question; I have a 2004 yz250 basket that has play where the primary gear is riveted to the oem basket. I would like to replace the cushions and re-Rivet the same basket on. Where do I purchase the rivets?
Share this comment
Join the conversation
Guest
Add a comment...
  Only 75 emoji are allowed.
Loading...
  • Similar Content
    • By Nolan Leal
      I saw somewhere online that said drag from a worn clutch basket could be fixed by filing down the notching on the edge of the tangs but would cause other problems does anyone know what these other problems would be? I don’t plan on ever doing this as clutch baskets aren’t really that expensive I’m just curious about what it would do.
    • By prebroken
      Firstly, hola! First post, new rider, go easy please.
      Second, I have reviewed the service manuals, online diagrams from various sources as well as online parts catalogs for each of these bikes.
      I recently picked up a 2003 yz450f of unknown hours. It’s in fair shape but does not run or ride well. I’ll likely make a separate topic post regarding the running issues. The concern I’m trying to address here is the clutch. It shows ever issue possible. Dragging, no achievable free-play, neutral is impossible to find and it simply does not shift well. So, obviously I tore it apart. Now, this is my first full size bike. I’ve rebuilt my Chinese four stroke four wheeler and my 2018 Apollo 125cc. I’m also a certified master technician with a bit of time under my belt in automotive work.
      After I took the clutch apart I noticed several things that were odd to me. Granted, I have no background in bikes. The fiber discs, while obviously worn to an extend all measured at or above the factory spec of ~3mm. The steels, while slightly discolored, showed no warpage on a flat steel surface using a .1mm feeler. The major difference came when I looked in the bottom of the basket to find that it starts with a steel plate. Now, in my diagram this is not what it shows. And beneath this steel plate there are two bevel springs. Also not in my manual. After some research I find that my top pressure plate is for a yz426 judging by the casting mark. After reviewing the diagram for a yz426 clutch I find that it contains these two bevel springs where the yz450 does not.
      Long story short: Is it a common mod to fit a 2001 yz426 clutch kit to a 2003 yz450f or did the previous owner make a mistake?
      Thanks!
    • By Thomas Hopkins
      I own a rn 125 and before I had to service the clutch it worked perfectly fine, then once I took it apart it’s not disengaging. The basket is in good condition as well as the plates but I notice there is play  in the clutch cover pinion shaft help? Once I Put it out together the clutch lever would pull in easy but not return
    • By Alexander Ortiz Maldonado
      My DRz400S does VERY hard load “clicks” when I go from neutral to any other gear. I have tried adjusting cable, changing oils, checking the basket, changing clutch plates for new ones, adjusting the chain tension, verifying the cam chain timing and I still have the issue. Whenever I change from one gear to another, speacially downshifting, the bike makes a very loud sound of metal smashing. Otherwise the bike runs perfect. I do not know if it is the transmission or what else, I hope not. I putted the bike on the stance, and tried changing gear there to see if the sound was coming from the chain, but the sound comes from the transmission close to where the front sprocket is located. I am honestly desperate since I don’t find a solution anywhere! Could someone please help me. i do have a video of what the bike does, but I cant upload it here.
      Also while in the stance, I noticed that when I let go of the clutch while in a gear, the tire starts spinning, but when I pull the clutch back in the tire slows but keeps spinning for a long time. If I put it on neutral it stops much faster. Again, I have played with the clutch cable on the upper side and on the bottom side as well, so its definitely not the cable or free play. Not the oil, and not a defective/ old clutch plates(they are new). I also tried using the bike to “let the clutch” adjust a little, but nope, nothing good came out.
    • By Hunter Wiskow 37
      Just bled the clutch line because it was wanting to grab a little bit in gear but it’s still having the same issue just not as bad but it’s still really noticeable. Anyone with the same issue and have a solution? I have a 2019 tc 125.
