When do you change your chain?
grayracer513
Change it when it's 2% longer than it was new. Assuming a 5/8" pitch chain (#520, 528, 530, 50, etc.), the length of ten full links pin to pin should be 6.25", 20 links, 12.5". Two percent over each of these would be 6.375" (6 3/8") and 12.75" (12 3/4"). The chain must be drawn taught when measuring, which is easily accomplished by placing a piece of wood or a tool handle between the chain and sprocket and rolling it under the chain to tighten it.
Another very accurate means of measuring the chain is to use a typical 6-7" vernier caliper on a 10 link section as shown in the attachment. Measure from one roller surface to the 11th one, and measure several sections. Compensating for the .400" roller diameter, the new length of the chain measured this way is 5.85", and 2% over is 6.0".
Once the chain is that much longer than spec, it starts chewing on the teeth of the sprockets. New sprockets can be installed without replacing the chain so long as it is 1% or less longer than new without any kind of problem.
User Feedback
Recommended Comments
Not only does a worn out chain eat up sprockets it eats up horsepower as well, up to 10%.
Adjust your chain normally and then fully compress the suspension and check the chain free play, if it is tighter than it was with the suspension unloaded then you need to make chain adjustments with the suspenssion loaded, your chain will last longer.
Share this comment
2% is unusually large. I am finding 0.6% and 0.8% to be more common. What is the source of this number please?
Share this comment
You countershaft sprocket is the one which ruins your chain,because of a lot of dirt and the little radius,the power impact on the chain.
If you keep an eye on your CS sprocket and replace that early,you can safe your chain and rear sprocket.I wish ALL dirt bikes(not only the trials bikes) had from the factory a automatic chain tensioner.I have them mounted on all of my dirt bikes for many years and have very little chain waer . PIC one on my Zunny right behind the swingarm ,and pic 2 on my OSSA 1971 just a HD rubberband and a roller and it made it all trough the ISDT without tightening the chaine.
Share this comment
When the rear sprocket starts to fishhook the teeth.
I have a 2011 SUZ DR650SE, 50k mostly street miles.  My original chain/sprockets lasted just short of 25k miles, but then again, I cleaned it with kerosene and lubed it with chain wax every 600 miles as instructed by the service manual. It saw very little dirt during it's life, and when it did, it was mostly sand, but I cleaned/lubed it right after riding/before riding it again. I also changed the countershaft sprocket whenever it started to look even a little worn, which was often.  So, I think the key to chain/sprocket life is very frequent maintenance and avoiding harsh environments when possible.
I probably could have ridden the original chain/sprockets further, but once the rear sprocket teeth started to fishhook, I figured I had gotten my money's worth and changed it all out... both sprockets, and chain.
Share this comment
  • Similar Content
    • By ThumperTalk
      Will work with all OEM and aftermarket chain blocks
    • By LuizSNeto
      Model: Yamaha - PN # RCG-YZ2
      Features:
      The inventor and only worldwide patent holder latest design with slimmer body and higher ground clearance .
      All new patented solid body design features our exclusive “RMS” (Return Memory System) to absorb heavy impacts.
      This plastic formula is virtually impact resistant and returns to center after a big hit.
      Accepts up to 3 over on rear sprocket and has the best side sprocket protection to prevent DNF's.
      Lightweight multipurpose design works for MX or any off road riding or racing.
      Used exclusively by Yamaha Offroad Race Team for the past 17 racing seasons!
      The only guide with 100% UV in a TMD Red or TMD Blue specific color. Black is also available.
      1-Year EZ breakage only warranty (in USA only). You break it we replace it. See instructions for details.
             Fitment:
      YZ 125/250 2-Stroke (08-18)
      YZ 250 X Off Road (16-18)
      YZF 250/450 MX (07-18)
      YZFX 250/450 (15-18)
      WRF 250 (07-18)
      WRF 450 (07-18)
    • By LuizSNeto
      Product Code: 1500-520-50
      The longest lasting most durable off-road sprocket you can buy–developed over 5 years. The unique flat face design keeps weight to a minimum and means that its as narrow as a regular chainwheel! Self-cleaning mud grooves between every tooth on both sides help prevent dirt build up, one less thing for you to do!
      Inner ring is high strength ultralight 7075 T6 aluminum
      Outer ring is electroless nickel coated steel
      Outer is expanded at 200°C and then fit to inner,
      creating a permanent bond for the life of the sprocket
      Precision CNC machined to extremely tight tolerances
      Flat socket head screw add additional strength to the chainwheel during side impacts
    • By LuizSNeto
      Part Number : 289--520-15GP
      Renthal front chain-wheels are simply the finest front chain-wheel on the market today. Our Front chain-wheels feature a specially developed nickel-chrome-molybdenum steel which is case hardened and core refined to give the ultimate combination of strength and hardness. Grooved chain-wheels have cut outs at the bottom of the tooth to allow the escape of mud that would otherwise be trapped between the chain-wheel and the chain. Allowing the easy escape of the mud prevents tension being placed on the chain and the resulting accelerated wear.
    • By LuizSNeto
      Part Number: 023107
      Features
      - Premium Gold Series motocross chains
      - Lightweight, ultra high-strength chromoly construction
      - Replacement master links available
      520XRC
      - Designed for up to 125cc to 750cc applications
      - Proprietary XRC ring seal technology is proven to withstand extreme temperatures and conditions
      - 7,700 lb. tensile strength
