Wiseco's Garage Buddy: Complete Engine Rebuild Kits for Dirt Bikes!
Kevin from Wiseco
Wiseco's new Garage Buddy engine rebuild kits offer everything you need for a bottom and top end rebuild. From the crank to the piston kit, and even an hour meter to track maintenance, everything is included in one box. Here we take a look at the components included, and the technology behind them.
Garage Buddy Kit
So, the time has come for an engine rebuild. Hopefully it’s being done as a practice of proper maintenance, but for many it will be because of an engine failure. Whether the bottom end, top end, or both went out, the first step is to disassemble and inspect. After determining any damage done to engine cases or the cylinder, and arranging for those to be repaired/replaced, you’re faced with choosing what internal engine components to buy, where to get them, and how much the costs are going to add up.
A full engine rebuild is a serious job and requires a lot of parts to be replaced, especially in four-strokes. You have to think of bottom end bearings and seals, a crankshaft assembly, piston, rings, clips, wristpin, and the plethora of gaskets required for reassembly. If you’re doing this rebuild yourself, or having your local shop do the labor, chances are you don’t have a factory team budget to spend on parts. However, you know you want high-quality and durable parts, because you don’t want to find yourself doing this again anytime soon.
Four Stroke Engine
Rebuilding a dirt bike engine is an involved job, requiring many parts to be replaced. Missing one seal or gasket can put the whole rebuild on hold.
You could source all the different parts you need from different vendors to find the best combination of quality and affordability. But, it can get frustrating when 6 different packages are coming from 6 different vendors at different times, and each one relies on the next for you to complete your rebuild.
Wiseco is one of the manufacturers that has been offering top end kits (including piston, rings, clips, gaskets, and seals) all in one box, under one part number for many years. Complete bottom end rebuild kits are also available from Wiseco, with all necessary parts under one part number. So, it seemed like a no brainer to combine the top and bottom end kits, and throw in a couple extra goodies to make your complete engine rebuild in your garage as hassle free as possible.
Four-Stroke Piston Kit Bottom End Kit
Top-end piston kits and bottom-end kits come together to create Wiseco Garage Buddy rebuild kits.
Wiseco Garage Buddy kits are exactly as the name implies, the buddy you want to have in your garage that has everything ready to go for your engine rebuild. Garage Buddy engine rebuild kits come with all parts needed to rebuild the bottom and top end, plus an hour meter—with a Garage Buddy specific decal—to track critical maintenance intervals and identify your rebuild as a Garage Buddy rebuild. The kits include:
  • Crankshaft assembly
  • OEM quality main bearings
  • All engine gaskets, seals, and O-rings
  • Wiseco standard series forged piston kit (piston, ring(s), pin, clips)
  • Small end bearing (for two-strokes)
  • Cam chain (for four-strokes)
  • Hour meter with mounting bracket and hour meter decal
Garage Buddy Kit Open Garage Buddy Kit Unboxing Garage Buddy Kit Hour Meter
Open up a Garage Buddy kit, and you'll find all the components you need to rebuild your bottom and top end.
2-stroke and 4-stroke
Whether your machine of choice is a 2-stroke or a 4-stroke, Wiseco can help you with your rebuild. 2-stroke Wiseco Garage Buddy kits include everything listed above, featuring a Wiseco forged Pro-Lite piston kit. You don’t even have to worry about sourcing a small-end bearing, that’s included too. 2-stroke fans often brag about the ability to rebuild their bikes so much cheaper than their 4-stroke counterparts, and they’ll have even more ammo for bragging now with these kits starting in the $400 range.
Garage Buddy Two-Stroke
A Wiseco 2-stroke Garage Buddy kit includes all the parts you'll need for piston and crankshaft replacement, plus an hour meter to track your next maintenance intervals.
However, don’t abandon your 4-stroke yet. Many riders cringe—and rightfully so—at the thought of rebuilding their 4-stroke because of the costs associated, but Wiseco 4-stroke Garage Buddy kits starting in the $600s takes a lot of sting off your rebuild project. They even include a new timing chain.
No matter what you’re rebuilding, you’ll be able to track key maintenance intervals for your fresh engine with the Wiseco hour meter and log book that’s included in the Garage Buddy kits. All Garage Buddy kits include a specific hour meter decal as well, which is important for the limited warranty to identify the rebuild as a Garage Buddy rebuild.
Garage Buddy Four-Stroke
A Wiseco 4-stroke Garage Buddy kit includes all the parts you'll need for piston and crankshaft replacement, including a cam chain and an hour meter.
Ease of ordering
Wiseco Garage Buddy kits come with the listed parts boxed up in one box, and listed under one part number, which makes it nice to not have to worry about if you might’ve missed something when ordering. Simply find the single part number for your model, order, and you’re on your way to brand new performance.
Quality Performance, backed by a Limited Warranty
Ordering convenience doesn’t make a difference if the parts do not provide quality and reliability. Wiseco crankshafts are designed completely by in-house engineers, who determine all assembled dimensions, clearances, materials, and specifications. These specifications have been determined from R&D tests such as hand inspection, dyno, and failure analysis.
Once Wiseco cranks have been manufactured to exact specifications they are batch inspected, and critical tolerances and dimensions are measured. Major inspections and tests include crank run-out and trueness, because they must operate within a strict tolerance to last long and perform well.
Wiseco Crank Assembly and Main Bearings
Wiseco crankshafts and bearings are manufactured and tested according to strict tolerances and clearances, including run-out and trueness. Crankshaft designs are also tested for 4 hours at WOT.
Bearings are another critical point of inspection. Wiseco has worked to build relationships with top-tier bearing suppliers to provide a long lasting, low-friction product. Debris in a bearing can lead to very fast wear, and Wiseco makes it a point to inspect batches of bearings for cleanliness and proper operation.
As part of the design and engineering process, prototype crankshafts are hand inspected and dyno-tested at wide open throttle for 4 consecutive hours. This is a benchmark test, and new crankshaft designs must pass it before to be deemed worthy for manufacturing.
Wiseco Dyno
Watch our crank R&D and inspection process.
A Warranty on Engine Internals?
Yes! Wiseco is committed to providing performance and reliability in all their products. This is why Garage Buddy kits come with a limited warranty. Rebuild your engine with a Garage Buddy kit, and your new Wiseco components are covered against manufacturer defects for 90 days from the date of purchase, or 10 hours logged on the hour meter, whichever comes first. Check out all the warranty details on the detail sheet in your new Garage Buddy kit.
Garage Buddy Limited Warranty
Open up your Garage Buddy kit and you'll find a detail sheet on the warranty on your new components.
Forged Pistons
The top end kits included in Garage Buddy kits feature a Wiseco forged piston, which are designed, forged, and machined completely in-house in the U.S.A. Four-stroke Garage Buddy kits come with a Wiseco standard forged piston, which offers stock compression and more reliability and longevity, thanks to the benefits of the forging process.
Two-stroke Garage Buddy kits include a Wiseco Pro-Lite forged piston, which is the two-stroke piston that has been providing two-stroke riders quality and reliability for decades. Some applications, two and four-stroke, even feature ArmorGlide skirt coating, reducing friction and wear for the life of the piston.
Forged aluminum has an undeniable advantage in strength over cast pistons, thanks to the high tensile strength qualities of aluminum with aligned grain flow.
Read more about our forging process here, and get all the details on our coatings here.
Wiseco 2-Stroke Forged Piston Kit Wiseco 4-Stroke Piston Kit
All Wiseco pistons are forged in-house from aluminum. Some pistons may also come with ArmorGlide skirt coating, and some 2-stroke pistons may already have exhaust bridge lubrication holes pre-drilled.
All pistons are machined on state-of-the-art CNC machine equipment, then hand finished and inspected for quality. The forged pistons come complete with wrist pin, clips, and high-performance ring(s).
Lastly, all gaskets and seals are made by OEM quality manufactures. Sealing components are not something to ever go cheap on, because no matter how high-quality your moving components are, if your engine is not sealing properly, it’s coming back apart.
Need some tips on breaking in your fresh engine? Check this out.
Wiseco Top End Gasket Kit Wiseco Bottom End Gasket and Seal Kit
Gaskets and seals provided in Wiseco Garage Buddy kits are OEM quality, ensuring your freshly rebuilt engine is properly sealed.
  • Like 7
User Feedback
Recommended Comments
Looks like wiseco is trying to compete against the wrench rabbit kits.  This could be a good thing, but I heard that they’re cranks went to garbage once they started having them built in China.  Anyone have any further truth to that tid bit of info?  If that is the case I’d rather not go with cheap quality material even if it’s so call warrantied because they’re not going to pay when I have to do the work over again when there parts fail.
Ive heard the saying somewhere, “The bitterness of poor quality remains long after the sweetness of low price is forgotten”
  • Haha 1
Share this comment
We did have some different quality issues going through stages as we developed and progressed our cranks, that's no secret. We have addressed each issue we've run into, including changing parts sources and establishing a new, specific QC process for our cranks. We're continuing to develop our cranks to this day, and more updates will be added to our cranks in the future as well. Here's our R&D and QC process currently: http://blog.wiseco.com/inside-rd-and-quality-control-of-crankshaft-assemblies
  • Like 4
Share this comment
When will you have a kit for the '15 500exc?
Share this comment
We haven't seen as a high of a demand for bottom end rebuilds on those models, but I can check in with the Product Manager to see what the timeline looks like.
Share this comment
Update: The crankshaft is on the list of to-dos, but it would most likely be next year sometime before we see a Garage Buddy kit for it.
Share this comment
06-07 kx250 would be nice to have a crank ....oem or rebuild so it would be a nice time saver to have a kit .
Share this comment
KX250 is on the list as well!
Share this comment
On 8/18/2018 at 5:23 PM, rompsterdog said:
2nd that on the Honda XL600R. Would be cool beans.
Thank you for noting interested in this model, I'll make sure the interest is known internally!
Share this comment
I assume these kits are rotating assemblies only correct? No valve train components for 4 strokes?
Share this comment
Nice to see competition with the wrench rabbit, but this kit (2 stroke) does not supply transmission bearings. Good, 90% of the time transmission bearings in a 2 stroke don’t go bad.  I’ve never come across one of the “so called” bad cranks on any of the strokes I have fully rebuilt.
Good for you to offer a conditional limited warranty.
The YZDOC does the same on all rebuilds and restorations, when paid in full.
Share this comment
The only valve train components included in the 4-stroke kits are cam chains, but there are no valves/springs, etc. However, keep your eye on us, because you may see something you're looking for coming soon. 😉
Edited by Kevin from Wiseco
Typo
Share this comment
Thank you! We were on the same page with the transmission bearings, we figured most people would not need them, so it would be better to keep the price point more affordable for people and not include them. We're glad to hear you've good experiences with the cranks, we've been working hard for that!
Share this comment
  • Similar Content
    • By Koray
      I replaced the transmission on an '05 kx85, and ive put the cases back together and everything spins freely, it shifts through all the gears, but once you put that tensioner thing that presses on the shift drum (dont know what the part's called) you cant shift into 3rd, itll get stuck halfway between second and 3rd, but once you take off that tensioner thing you can spin the drum and shift through all the gears just fine, whats going on?
    • By drewkuze
      I recently bought a 2012 kx250f. The guy I bought it from said he never adjusted the valves, but the previous owner bought a new engine in 2014. The bike is burning oil (I haven’t had a chance to do an oil change yet so idk how much) but it burns on startup, and when the bike is revved high quickly. It isn’t hard to start, every time I’ve started it it only takes 1 kick. I’ve heard it could be the valve guides, seats, or the piston rings. Any suggestions on what it most likely is?
    • By Christo6060
      I just bought a 1983 KX80E and found an new old stock piston for $30 but can’t find rings. I know Wiseco make rings for it that cost around $45, so I was wondering if I could pair the aftermarket rings with the oem piston. (Same size).
    • By Callum Hunter
      I'm quite new to the moto scene and I've got a '09 CRF250R in need of what I believe is a top end rebuild. I've never gotten a rebuild before so I'm unfamiliar with the process and the steps to take in getting this done in a safe and efficient manner. I was wondering if anyone knew of any reputable shops in or near Vancouver, Canada (where I live) that could look at my bike and help me out with my situation. About 6 months ago I got an inspection on the bike and the shop told me that my cam bearings had "spun in their journals", requiring the installation of a new cam along with the rebuild. I haven't had anything done to the bike since the inspection so the motor is still in this state. She's running but I'm afraid that the motor is a ticking time bomb and would like a shop to take a look at it, let me know what needs to be replaced and get the rebuild done without me worrying about getting taken advantage of. I'm currently out of the country in school but have plans to get this done once I'm back. Any tips, recommendations, or help would be greatly appreciated!
    • By Lone Danger
      Ok so I'm looking for opinions from those who have been on yz125s and 150 exc/xcw's and maybe the ktm 200's exc/xcw's. You gotta be out there.
      Here's the deal...I'm 5'7" 165lbs. A couple years back I was looking for a small bike for my wife to learn on and for me to play around with and race. Could only afford one bike. I got a '09 ktm 105 sx. Once I got it sprung for my weight it was great. I have been top five consistently in my local harescrambles B class, believe it or not. Ya, you were not the only ones shocked. And did pretty good in the local mx races as well, junior class up here in Canada. Lack of power was sometimes an issue but I learned to deal with it and just scream, scream, scream!
      However my wife is a complete beginner and she is scared of it. I have since moved her to a 4 stroke.
      Just got a mint '01 yz15 mid summer. Like less than 200 hrs! I have absolutely loved it on the mx track. Suspension is perfect and I love the extra power. I had planned to set it up for woods/mx with a suspension revalve. However, did a harescramble race a month ago that was really technical. Granted I have not done anything to the suspension minus clickers, had too much psi in the tires (13 front and 15 rear) (yes I know that's wonkey, I only had time to get a heavy duty tube in the front and had a stock tube in back. Less psi in the back would have been instant pinch flat because its so rocky) and it was running rich. I had to scream the thing to keep it running and even changed a plug mid race. Well I'm sure you can guess but it was the worst experience I have ever had on a motorcycle. The more open sections I passed a lot of people but the tech sections required way more effort than I liked and the suspension beat the hell out of me!!! Like my knees, wrists, and shoulders were just done. (I was out there for three hours).
      So keep in mind that I just came off a 105sx with suspension mods (set up for woods/mx). I have no problem slipping clutch and shifting precisely, yatta yatta. (I don't think the 105 would have done well here either due to even less power, however...) I've been second guessing fixing this 125 up for woods ever since I rode a friends '09 ktm 250xcw. I rode it on a local mx track. The power was just so effortless and I was absolutely floored by how the suspension worked. I never thought that I could hit the woops that hard and clear every jump on the track on an xcw and feel THAT good! It felt a lot heavier though, and I think the price tag on these things are going to be a stretch.
      So here's my question. I want the lightness of a 125, but want to be able to race both woods and mx. How does a 150 exc/xcw ENGINE compare to an mx 125 engine? I love the 125 engine, but more low end would be usefull in tech areas. But if there is not a huge difference, I will probably just revalve the yz for woods and go tubless, etc. The 150exc's are so expensive and I hardly ever even see one for sale unless its brand new. I don't want the weight of a 200/250/300. I barely touch the ground on a 125....so it has to at least be light. Is it worth waiting for a 150 engine? Thanks guys.
