  • entries
    56
  • comments
    517
  • views
    259,372
Workshop Basics For At Home Engine Building
Paul Olesen
I like to compare building an engine to performing open heart surgery. The precision and organization that goes into open heart surgery is exactly the mindset you need as you begin to rebuild your engine. Just like an operating room, I require my workspace to be as clean as possible. In the industry, companies have dedicated rooms just for engine building. These rooms are equipped with dust management systems, precise temperature control, and spotless work surfaces. I don’t expect the home mechanic to have this intense of a setup, but you should aim to have the cleanest work area possible.
One of the first things you will need to do is make sure the area you are working in is free of dirt. Use a vacuum to suck up dirt from work surfaces and the floor. Occasionally you’ll drop a part on the floor and the last thing you want is for it to wind up covered in dirt. This should go without saying, but don’t try building an engine where metal is being ground or cut.
The temperature of your build area is also important. Parts are designed, manufactured, and inspected at 68°F (20°C). This means that in order for you to correctly measure a part during your build it should be at the standard temperature of 68°F. As long as you are close to 68°F you’ll be fine, however building an engine in a cold unheated garage in the dead of winter may not yield accurate results. Conversely, measuring parts in a sweatbox of a garage without airconditioning will not work that well either.
index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=222138
Let’s move on to other aspects of the workshop that are important. Until recently, my workbench was old and the work surface wasn't the smoothest or cleanest. It is difficult to get all the dirt out of plywood so I like to line my plywood tops with paper or cardboard then replace as often as necessary throughout the build to ensure cleanliness is kept up. This practice ensures I’m not working on a dirty surface and exposing parts to unnecessary dirt which could cause scratches or damage. If you have the luxury of working on a laminate counter top or other hard smooth surface more power to you. Just remember to wipe the surface clean as you go to keep dirt to a minimum.
index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=222137
index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=222135
Lighting is one area that can be overlooked for many home mechanics. Make things easy on your eyes and be sure you have a good source of lighting where you are working. This way you’ll easily be able to see the wear in used parts, accurately read measuring equipment, and correctly assemble new parts. I prefer good overhead lighting when available, but when unavailable good portable lighting can be just as effective. Portable lights affixed to stands that can be raised above shoulder level work well.
Tool storage and how you choose to handle your tools throughout the build comes down to personal preference. My tools are stored in a two level rolling toolbox. I can easily roll my toolbox from the motorcycle lift to my workbench once the engine has been removed. Instead of putting tools away after I’ve used them for a given task I like to leave them out. By keeping them neatly organized I don’t have to go digging for them later down the road. The tools I frequently use are then set either on my workbench or on a rolling cart so I can quickly grab them throughout the build.
index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=222139
Allocating space to set parts aside as they are disassembled is important. Laying out and keeping a completely disassembled engine organized requires some room. A 3’ x 4’ area dedicated to storing disassembled engine parts will usually work. Alternatively a rolling cart with multiple levels is a handy option as it allows better organization and you can wheel parts around with ease. Make sure you are storing parts on nice smooth soft surfaces. Laying out parts on something like a grated metal shelf or work top wouldn’t be a good idea as the parts could be damaged when they contact the surface. This is especially true of gasket surfaces on covers which mar pretty easily. Another must is to never stack parts on top of one another. Make sure the area you have chosen to lay out parts is dirt and dust free throughout the build.
Do you have any workshop tips you'd like to suggest? Leave a comment below and share your tricks with the TT community!
Moto Mind - Empowering Riders from Garage to Trail
http://www.DIYMotofix.com
10 Comments
Recommended Comments
I have a roll of lint free paper towels on a roller mounted on the wall above my bench,  easy to tear one off for cleaning of parts/hands without accidentally grabbing that rag that's covered in grease or antiseize etc.
  • Like 3
Share this comment
Great addition to my post! Lint free is the way to go.
Share this comment
I have three folding work tables that I can fold the legs and store them vertical against the wall when not in use and they are very handy.
This is in addition to my permanent work benches and engine build table.
By using temporary worktables they don't get covered with "stuff", they take up almost no space when not in use, and I can set one or more up where I want it, when I want it.
I have a small 36"x30", a medium 60"x32", and a large 96"x32".
Folding picnic table legs and framework offer plenty of support for medium duty.
Simple1/2" plywood tops that are painted hammered silver currently but I am repainting the tops gloss white like my bike build tables and engine build table since it looks cleaner and is easier to see small parts on.
Especially those pesky little nuts that drop and roll...
Share this comment
Nice set up you have going on. The folding tables are a nice idea.
Share this comment
Another great write up Paul.
Couldn't agree more on the operations room.
One other thing I like to do is to organize every part of the component I am disassembling and take a quick snapshot for future reference before I put it away. This way I can easily recreate the photo and proceed with the assembly in the reverse order.
Not much of an example on engine building but this was my CRF's carb last night.
Share this comment
I keep a large dry erase board in my shop when rebuilding.  I keep reminders and a checklist of to do items.  When the board is clear, the engine 'should' be done.  The back side doubles as a peg board and tool holder.  I'll post a picture soon.
Share this comment
Very nice, it looks like you have no problem keeping track of your parts! Great tip on taking photos.
Share this comment
Good idea, similar to you, I use a notebook to keep track of all the important stuff.
Share this comment
I use egg cartons to place bolts into as I take items off and draw a little map noting which egg slot has bolts for which parts.  Usefull if I will not get back to it right away.
Old rubber maid lids (that seem to accumulate) are good parts trays that can easily be moved, cleaned and are not hard surfaces.
Large rubbermaid tubs are good parts washing bins with a good degreasing soap, rinse and put in the lid until you can dry with the air compressor. Grout scrubbing brushes have bristles that do not come out too fast and are offered in a number of sizes.
This helps manage all the big items that come off and clean before you start your open heart surgery.
Thanks Paul. I have not cracked my CRF450R's top end open yet but your top end rebuild video is getting reviewed and I look forward to my first surgery. All these supplimental posts help.
Tom F.
Share this comment
Tom F.
Hey Tom, I wrote this one with you in mind! Thanks for sharing your tips and let me know if you have any questions on the video.
Share this comment
