  • entries
    75
  • comments
    207
  • views
    151,597
Beat the heat! Rider's guide on proper hydration for max performance
Coach Robb
This article is in addition to the last three articles where we broke down fats, protein and carbohydrates as it related to health, wellness and ultimately performance. Proper hydration is one of the “easiest” nutritional components to implement, yields huge performance gains but is still one of the most misunderstood and neglected component of a nutritional program.
The Importance of Hydration
Here are some statistics to shed some light on the incredible importance of being properly hydrated:
The average human body consists of 96 pints of water (64 pints inside the cells & 32 pints in the blood, lymphatic & digestive juices)
  • Brain: 75% water
  • Bone: 20-30% water
  • Body Fat: 10% water
  • Digestive Juices: 86%
  • Blood 85%
  • Muscle: 70%
And in my opinion, the most staggering statistic is relevant to muscle strength; a muscle that is dehydrated by only 3% can lose up to 10% of its strength and 8% loss of speed! The potential for optimum levels of performance literally dries up!
Core Body Temperature
When your body is running low on proper water levels within any system of your body: lymphatic, digestive, circulatory, etc. your athletic performance is negatively affected. The most detrimental is the ability to avoidoverheating.
Exercise (or more specifically any form of movement) creates heat within the muscles; the higher the intensity the hotter your body becomes. When this happens, your body’s metabolic systems move into over drive to maintain 98.6 degrees (your core body temperature while you are at rest). As your core body temperature increases, your body moves this increased internal heat to the skin via your blood. The performance issue is associated with your bloods responsibility to deliver oxygen, nutrition to your working muscles and the transfer of metabolic waste of your working muscles. Outside of 98-100 degrees and your body will automatically sacrifice muscle contraction for regulation of core body temperature. Think about it this way, a reduction in muscle function, even immobility isn’t life threatening; however, if your core body temperature rises more than 9 degrees Fahrenheit, normal biochemistry ceases and you can die.
Simple Steps to Properly Hydrate
Daily Tips:
> Strive to consume half of your body weight in ounces of cold filtered water (For example: 150 pound athlete divided by 2 = 75 ounces per day).
> Keep a post it note of how many water bottles you consume throughout the day or put a black marker hash mark on your disposable water bottle to indicate how many times you have re-filled it.
> Drink cold fluids: this has been documented to absorb quicker and helps pull down your core temperature.
> Avoid carbonated water and sodas; they slow down the absorption of water.
> Consume complex carbohydrates - fruits & vegetables at every meal and snack:
- In addition to vitamins and minerals, fruits and vegetables are high in water and electrolytes
- To store sugar in your liver & muscles for energy, your body stores 2.7 grams of water – this is
During exercise:
> Refrain from waiting until you become thirsty – you are already dehydrated [Note: the sensation of thirst, regulated by hypothalamus in your brain, occurs due to the lower concentration of water in the blood.].
> Consume a sports drink that has a 5-7% carbohydrate ratio for optimum absorption.
> Consume 8-10 ounces every 15 minutes throughout exercise.
> Sip your fluids versus gulping to avoid the ingestion of air.
> Know your sweat rate: your goal is to lose no more than 2% (dehydrated) and no less than 1% (overhydrated). If you haven’t received a copy of our MotoE Sweat Rate Calculator, please email me and I will send one over to you.
> Test your hydration volumes, intake frequency and carbohydrate concentration in training and under the same conditions (temperature & humidity) as your race.
Post exercise:
> Consume a carbohydrate and protein liquid drink within the first 20 minutes of finishing.
> Avoid juices, especially citrus juice, this will only add to your stomach acidity which will increase your chance of cramping and feeling nauseated.
> Continue to sip on your sports drink to help replenish depleted electrolytes and sugar storages.
Until next time, Train Smart-Not Hard!
Coach Robb
http://www.completeracingsolutions.com/
  • Like 2
5 Comments
Recommended Comments
Thanks, Coach!
Last weekend it was crazy hot and humid, and I was sitting in an air conditioned car and eating watermelon between practice sessions. I felt wonderul! Fresh and strong all day.
I tried the same thing when it was less hot and it did't work. I just felt stuffed, I felt like I ate too much. I must have got myself overhydrated, like you said.
Would you consider a watermelon a perfect MX superfood, in reasonable quantities? Sugars, electrolytes, water, and it does not percolate immediately into the bladder either. It certainly is healthier than Gatorade.
Share this comment
The importance of acclimitzation cannot be overemphasized.Your body takes time to adapt to warmer weather. If you are going to race/ride in the heat, you should also practice in it.
Share this comment
Thanks, Coach!
I think that watermelon along with any fruit is a great ride/race day snack.  They are loaded with water, electrolytes, vitamins, minerals - everything that you need for health, wellness and performance.  Keep up the great snacking and enjoy your seat time!
Share this comment
NYTrainer - you are absolutely correct!  It kills me when I see riders training with sweat shirts on, this is ONLY going to cause a heat stroke - not heat acclimatization.  Keep up the good work and we will see you at the track.
Share this comment
