  • entries
    56
  • comments
    517
  • views
    259,381
Maintenance Readiness
I hope you all have been out riding and enjoying spring. I got back into the hare scramble racing scene over the weekend after a three year hiatus and had a blast. Today, I just want to share a quick tip and start a discussion on preparatory things that help shorten the time it takes to do complex maintenance tasks, such as rebuilding an engine.
Quick Tip
Prior to turning a wrench carefully look over the service manual scanning through all the applicable procedures and subsystems. If I’m working on an unfamiliar model, I find it is helpful to jot down a rough outline of the disassembly sequence. This saves me time in the long run as I don’t have to rely as heavily on the service manual or continually flip through various sections. Another option is to use post-it notes to bookmark each relevant section in the manual. Mark the post-it notes with numbers or headings so you know where to turn to next. Earmarking or bookmarking the torque tables is also a huge time saver no matter the task.
Be sure to scan through the manual as well to identify any specialty tools that are required that you may not have.
Discussion Points
  • What other preparatory things can be done to help speed up the major maintenance process?
  • Is there a method to your madness or do you dive right in?
Thanks for reading!
Paul
https://www.diymotofix.com/
  • Like 3
3 Comments
Recommended Comments
yes and it certainly helps to have all the proper tools laid out on cart or near by so you dont have to keep running over to your box and pawing through everything looking for the right tool
Share this comment
bag everything as you strip and take phone pics for sticky issues you mite find difficulty with, for later reference once assembling
Share this comment
