  • entries
    58
  • comments
    571
  • views
    263,402
New and Re-plated Cylinder Prep
Today I want to share some pointers on preparing new or re-plated cylinders that will help ensure your engines run stronger and last longer. Plus, I've got an update on the two-stroke book I've been working on that I'd like to share. Let's get started!
A Universal Concern
First, both new and re-plated cylinders must be cleaned prior to assembling. Normally the cylinders will arrive looking clean, but looks can be deceiving. I have no doubt that the factories and re-plating services clean the cylinders as part of their processes, but I highly recommend cleaning the bores a final time prior to use. Shown below is a new Yamaha cylinder that I extracted quite a bit of honing grit out of.
Dirty cylinder
If left in place, the honing grit will ensure that the piston rings will wear out faster than they need to, so be sure to take the time to properly clean new cylinders prior to assembly.
What’s the best way to clean the cylinder bore?
Start by using warm soapy water and a brush to clean the cylinder. Take your time and be thorough.
Cleaning sequence
After the majority of the honing grit has been removed switch to automatic transmission fluid and a lint free rag for one final cleaning.
As a test to check cleanliness, rub a cotton swab against the cylinder bore. If the swab picks up any debris and changes color, your cleaning duties are not over. The swab should be able to be rubbed against the bore and remain perfectly clean.
Two-Stroke Port Dressing
For two-stroke owners, the second item I want to bring to your attention is port dressing. Port dressing is a term used to describe the process of deburring/breaking the edge at the intersection of the cylinder plating and the ports in the cylinder. During the plating process, plating usually builds up excessively at the edge of the port and must be removed after honing. Proper removal is critical to ensure acceptable piston ring life.
port dressing
Manufacturers and plating services will break the edge in different ways and to different magnitudes, which ends up being a whole other topic. The important thing is to ensure that any new or re-plated cylinder you use shows visible signs that the port edges have been dressed. A dressed port edge will be easy to spot because it will feature a different surface finish than the cross-hatch created from honing. This is easily visible in the image shown above. Many port dressing operations are done manually so some irregularity in the geometry will usually be present. If there is no visible edge break on the port edges, I would be highly suspicious and contact the service that plated the cylinder or sold the cylinder and confirm with them if a step was missed. Typically a chamfer or radius in the .020 - .040” (0.5 - 1mm) range is used.
Two-Stroke Power Valves
Lastly, it is possible that some of the power valve components, such as blades or drums, will not fit correctly on cylinders that have been replated. This is because the plating can occasionally build up in the slots or bores where the power valve parts reside. Prior to final assembly, be sure to check the function of the power valve blade and/or drums to ensure they move freely in their respective locations within the cylinder.
If plating has built up in a power valve slot or bore, it will need to be carefully removed. To do this, appropriately sized burs for die grinders or Dremel tools can be used. If one is not careful, irreversible damage to the slot or bore can result. When performing this work proceed cautiously or leave it to a seasoned professional. Burs for the job can be difficult to track down in stores, but are readily available online from places like McMaster-Carr. When purchasing burs, be sure to pick up a few variants, such as rounded and square edged, designed for removing hard materials.
The Two-Stroke Book
From February to March we photographed the entire book. From April onward we have been formatting and proofreading. Needless to say, we are in the final stretch! If you want to stay updated on the moment the Two-Stroke Dirt Bike Engine Building Handbook is ready for pre-order, sign up at the link below. We can't wait to get this book out the door and into your garage.
Sign Up for Updates on the Two-Stroke Book
Thanks for reading and have a great rest of your week!
-Paul
  • Like 5
1 Comment
Recommended Comments
I've always ran mine through the sink with hot soapy water.  Worked well for snowmo and moto over the years.
  • Like 2
Share this comment
Join the conversation
You are posting as a guest. If you have an account, sign in now to post with your account.
Guest
Add a comment...
  Only 75 emoji are allowed.
Loading...
