• entries
    7
  • comments
    51
  • views
    2,235
Video Riding Tip: Stand Up Cornering Techniques
Often times, stand up cornering is the best body positioning. In this training video I walk you through the correct techniques for stand up cornering and why they are important. Give it a watch and see how you're doing.
Thanks for watching!
Brian Garrahan
Garrahan Off-Road Training
5 people like this
12 Comments
Brian,  first thing I've got to say is I don't know how you do it man, you've always got that perfect helmet hair look.... Amazing man, really impressive.
Second thing is a question, I'm never really comfortable riding on the balls of my feet. Any tips on getting comfortable riding that way, just do it? I can see how it allows you to squeeze the bike better and so I guess that's why it's important?
See you at Hollister or Metcalfe soon.
3 people like this
Share this comment
Riding on the balls of your feet and standing helps lower your centre of gravity , instead of most of your weight being toward the front of your seat sitting down,  it puts it through the balls of your feet and into the pegs and with the combination of your chest over the front should give you good front end traction and help you corner faster , but it takes a lot of practice because your natural tendacies are to sit down toward the front of the bike and weight the outside peg
2 people like this
Share this comment
I can’t give you tips about the hair, that’s just my natural flow.
Yes practice, practice, also keep the toes tight at the same time this will help you grip the bike.Standing will also gives you better balance as you can control the bike with the pegs which have a lower center of gravity. It also makes have better reaction time. You don’t see the short stop for the Giants sitting down.
3 people like this
Share this comment
Keep the toes tight? What do you mean?
1 person likes this
Share this comment
I definitely agree that standing is better most of the time but I don’t see how it lowers center of gravity. I think center of gravity is determined by where you are on the bike not where you are contacting the bike. If you are leaning forward, center of g is moved forward. It doesn’t matter if you are touching the bars with your chest or not. Regardless, I know it does help
Share this comment
Simple the pegs are the lowest part of the bike. If you control with the pegs you are controlling the bike at its lowest point of G. If you are trying to control the bike with the bars, you have to transfer all the weight that is above the pegs. So you have to shift more weight, use more strength, using more energy. Last but not least your legs are one of the biggest muscles. So using your kegs instead of arms will give you more stanima and strength.
5 people like this
Share this comment
You're correct that where it is relative to forward/aft is determined by your body position, but there's CG fore/aft and also CG up/down to consider. If your weight is supported by the pegs, that's lower than it being supported by the seat. That's how your CG is lower standing than sitting. Furthermore, how much weight you've got on the pegs vs the handlebars through your arms will affect it as well, as Graham articulated.
1 person likes this
Share this comment
I love it, these are all great points. I’m working on a new series next week. Anything in particular you guys want to learn?
3 people like this
Share this comment
I've got the balls of my feet down but I am still uncomfortable with the forward lean over the bars at speed. Thus I shift rearward and make the front end way too light. Then I'm having to sit suddenly to drive into a corner. I loose a lot of time that way, too many old habits.............. MORE PRACTICE NEEDED ON MY PART!
Share this comment
Body positioning and braking on steep downhills. Especially those with obstacles in the path (rocks, trees, etc). I have many weak spots in my technique, that being the largest of them.
Great seeing a local NorCal Pro and D36 guy giving some great input. Keep it up!
2 people like this
Share this comment
Got it, we will have some exciting videos coming out monthly thanks for following.
1 person likes this
Share this comment
