  • entries
    56
  • comments
    57
  • views
    145,614
Video Tip: Motocross Jumping Techniques
Gary Semics
This video was taken at a training session that was held at Club MX Training Facility in Chesterfield S. Carolina. For this video lesson, I use slow motion, freeze frames and repeat frames while narrating the video, pointing out various riding techniques, conditions and even some mistakes, all relating to motocross jumping skills. Give it a watch and see if it confirms what you already know, gives you a different perspective or demonstrates techniques that you really need to work on.
Thanks for watching!
Gary Semics
Professional Motocross Trainer and Technique DVD production.
If you're serious about improving your motocross skills, checkout my website for additional tips and training resources.  Also, be sure to follow my Blog on ThumperTalk! In the upper-right of your screen, click the "Follow this blog" button.
3 Comments
Recommended Comments
Hi I'm 120llbs an 5'7. I have experience with riding a crf150rb 4 stroke, but I'm looking for more power. Would a ktm 150sx 2 stroke be good for me? Or would be to big for me?
Share this comment
in my opinion it would be good. im about the same as you and i ride a rmz250. it all depends on how much more power you want
Share this comment
Yes, I think the 150 KTM would be very good for you. Following is the differences between 2 and 4 strokes.
Ever since sometime in the early 80s two strokes have put to good use the development of a power valve in the exhaust port.  This power valve has smoothed out the hit of the two stroke’s power band a great deal.  But in order to get a lot of horsepower out of that two stoke engine they still have a certain amount of hit to the power band.  This is the biggest difference between the two and four stroke.  The four stroke is just smooth tractor like power right off idle all the way upstairs.  This is why the four strokes depend less on the clutch and more on throttle control.  You don’t have to help it into the power with the clutch nearly as much as with the two strokes.
The other difference is with engine braking.  When you’re going down a straight away and you shut off the throttle on a two stroke the back pressure from the engine will slow you down a little, but on the four stroke this engine braking is much stronger.  This will make the Exit Dex of a corner (where you go from braking to accelerating) easier.  You don’t have to be quite as precise with the brakes.  This engine braking effect will affect you on jumps too  because if you roll the throttle off on the take off of a jump it will throw the front end down much more on a four stroke.  This won’t be as noticeable if you’re in a higher gear.
Since you don’t have to be as precise with the clutch and throttle and the brakes on a 4 stroke they are easier to ride.
At this point in time that’s the main differences between the 2 and 4 strokers.  The actually riding techniques are the same.  The way I see it it’s all good.
All the details for the clutch, throttle and shifting techniques are shown in this DVD, see a free preview here.
Share this comment
