• entries
  • comments
  • views
How to Determine If You have True Sciatica or Just A Pain In The Butt
Coach Robb
Determine the Difference Between True Sciatica or Piriformis Syndrome
If you suffer from radiating pain through your hip and down your leg, you need to determine if you have true sciatica or if you have tight muscles in your gluts (butt muscles) and hip muscles (specifically the muscles that rotate the upper leg outward). Watch this video to determine if you need to see a doctor or work on your flexibility:
Periformis Syndrome Stretch
When you are in the proper attack position as described by Gary, you are engaging the muscles of your butt, hips and lower back (along with a bunch of other muscles). Like any other muscle, the more you use the muscles, the tighter they naturally become.
You can alleviate tight muscles by warming the tissue up, applying
exercises and then
. Click on each hyperlink for a bundle of videos to help you reduce the tension within the various muscles. To stretch the Piriformis muscle - the one that is causing your radiating pain down your leg, please watch this video:
Note: please stretch after you have warmed up the tissue, NOT prior.
and watch this video and learn why.
If you have any questions or would like anything clarified, please don't hesitate to post a comment below or start a new thread here on Thumper Talk! Thanks for watching and reading.
-Coach Robb
If you'd like to follow my blog, click the "follow this blog" button in the upper right.
There are no comments to display.
