Mickeydee how's about a report
well its in but it still needs fine tuning but HOLY CRAP i left the line and then dumped it at WOT and all i got was wheel spin ? and i had to stay over the bars as i went through the gears :applause: .i have pics and i will post them here either tonight or tomorrow
btw-if you have ever riden a yzf 400 its damn close to that now :ride:
img] ok, here are my pics.first thing i did was to do a BK mod and jet it properly.the carb is a 39mm fcrmx carb with hot start and no tps.once i got all the E parts i started with the swap.put on the new air boot and then started the install the carb<img src=[/img] the cable mount got in the way of the frame so i had to remove it and then put it on once the carb twisted over to the other side of the frame then once that was done the throttle wheel hit the frameimg] so instead of cutting the wheel i tilted the carb a bit.then i ran into another problem<img src=[/img] the hot start button hit the E petcock.so i got out the dremalimg] i also had to relocate the top engine mount<img src=[/img] i had to do this so the throttle cables had a straight route to the cable mountimg] when i put the engine mount to the other side i used 2 washers instead of the stock spacer so the rubber mount would bolt up.i have more pics but i don
  • 1 year later...
