06 450 Small Back Fire While Kicking Over
Lately when I go to start the bike, (for the first time in the day), I am getting a backfire after those few initial kicks. After my second or third kick it will start an run great, like a raped ape. After it is hot it always starts on the first kick with no back fire. I am running at about 5500ft with the 48 pilot and 62main combo, the bike is perfect otherwise and has about 60hrs on it. Any thoughts?
I have the same problem, and when I rev I get a back fire and flame, every time! Now I seem to have loss of power out of the corners, like I'm in a higher gear then I should be but I'm not! It's not clean power at all! Have not changed the jetting yet, it is from factory but always seem to run fine. Any suggestions? Also appears to be using oil, I may have 65 to 75 hours on it. Piston and rings??? Already? Who knows, any suggestions? I'm no pro so I don't think I abuse the crap out of it and I drop the oil every four to six hours. I heard the clutches are weak in them due to lack of oil, could this be the issue as well?
