Spark but no fire.
I've got the engine re-assembled after putting in a new piston and cylinder. I set the timing as per the manual. Turned it by hand first to make sure it's ok.
When I crank the engine to start it, it spins, but won't fire. I pulled the plug (many times now) and checked that there IS indeed spark. But it won't run. What's odd is that it won't run on starting fluid either. I thought maybe it was flooded, so I let it air out overnight, and still nothing. There's not even a pop of puff from it trying to start. I figure that with starting fluid, even if the timing was off, there would be a pop or something.
Could it be that there's just not *enough* spark? I assume I have the engine together correctly, because the only way to get the timing off would be to have the cam 180 degrees out, and by then they'd hit the piston. No?
Edited by yellowdatsun
You need to triple check your cam timing. One tooth off will yield a no-fire situation.
Make sure you are looking directly across the top of the engine from the side when checking the timing marks on the cam sprocket and holder. Also verify that you've lined up properly on TDC before you check the cam timing.
Edited by JimDettman
I triple checked everything before I tightened the cam sprocket bolts. But I pulled the cam cover off just to be sure, and here's what I've me it looks spot on.
Kinda hard to see the arrow on the head, but you can see the side of it through the sprocket hole, which is darn near exactly where the line on the sprocket is. If it was a tooth off it would be way further out than that.
Don't rely on the mark from the right side case.
On the left side ignition cover, remove the plug using a 6mm Allen.
Line up the second timing mark ( the TDC mark) with the cut in the threads.
That is the most accurate way to do it.
Pffft, so looking into the flywheel hole, when everything else is at TDC, there are no marks all. How could the transmission side crank bolt be so far off?
I'll adjust things and we'll see what happens.
True what doc said . there is a T and a F mark on the flywheel. sometimes its hard to see them with the oil on it. Also cam lobes should be facing the rear and slightly up @ TDC
Edited by StonedInNy
Ok, so here's the flywheel side, now lined up:
But when you line up this side, you can't even see the crank bolt dimple on the other side. What the heck? I could see if they were a little off, but that would be WAY off.
FWIW, I've seen comments about which mark to use on the crank bolt, because apparently there's supposed to be two. Mine doesn't have two, only the one pictured in the previous post. I've spun the engine around a few times in search of the second, but it doesn't exist.
It's like there's a half-tooth discrepancy when aligning the flywheel and the cam sprocket. One tooth on the cam in one direction and it's too far advanced, and one tooth in the other direction and it's too far retarded. Which way should I error? If I have the flywheel lined up on the left mark, where should the cam be? Above the arrow, or below?
I assume the left flywheel mark is TDC, and the right is fire. Correct?
--EDIT: OK, so turns out right mark is TDC. Found that in the Clymer manual that everybody hates. The factory manual sucks with it's timing information. Let me try this again and see if things will line up now.
We have ignition! Works wonders when you have the right information. With the flywheel set on the mark to the right, and the cam set correctly, it fired instantly. Still have no idea what the deal is with the right side crank markings though, but they're obviously wrong.
  • Similar Content
    • By cmckay4
      Anyone having or had problems with the starter not turning over easily on the 450X???
      I have read about this problem on CRF's ONLY and not seen anyone come up with a fix.
      Problem being is that you think there is a problem with the battery, when infact the battery is OK. When you have a good fully charged battery in the bike and press the e-start, it turns over very slowly.
      I have checked the electrical circuit and it seems OK. I am wondering if it might be the starter itself - any suggestions?????
    • By Dust_Devil
      I'll start, if you see the "Fox Sticker" out in the Dez you know you crossed paths with ol' DD.....
    • By JohnnyAirtime
      Guys and Gals...
      Post your links to any of your pictures in this thread....
      (proper placement of pictures is in the "picture" threads)
      Post your links to any of your ride reports in this thread....
      (proper placement of your ride reports is relative to the area you live/ride)
      NO TECHNICAL issues, questions or comments in this thread.
      (it'll be deleted to keep this thread clean and with only the above listed).
      Please follow this format;
      Ride Report: Gorman, Tuesday 4-17
      (by Skoot22)
      Pictures from Ride: Baja 4.14.07
      (by Johnnyairtime)
    • By dakynz
      Guys, because of a member ban the jetting database has been removed. Let's start a new one to get this great information created into a sticky for everyone's benefit. Please stick to the information below.
      Temperature Range:
      Smog (AIS):
      Airbox Modified Top:
      Airbox Modified Sides:
      Backfire Screen:
      Air Filter:
      Pilot Jet:
      Main Jet:
      Needle Clip Position:
      Fuel Screw Type:
      Fuel Screw Setting:
      AP Modified:
      Leak Jet:
      AP Cover:
      Exhaust Type:
      Exhaust Modified:
      Pink Wire Modified:
    • By 2can
      I've studied the Jetting sticky's but still have a number of questions:
      I bought my '06 a couple of years ago and had a smog block-off kit installed and the pilot jet was upsized to a 48 and the air box opened up top only. The bike has appeared to run a little lean at times and got hot on a couple of occasions in elevation and on one other occasion. I'm looking at upping the main jet to either a 165 or 170 to help with the possible lean condition. The bike currently has a 142 main jet in it which I believe is the stock size. It looks like the most widely used Needle Jets are the JD Red, but it doesn't look like they are sold separately, is this correct?
      I was going to also get a 45 pilot to have options for further tuning. My assumption is that every bike is a little different and that where you ride is going to have a lot to do with jetting. We ride mostly, mojave desert, baja, and southern Utah with elevations from sea level to 9,000 feet but the higher elevations are generally for a short period as we generally continue through the peaks and head back down.
      I'm looking to convert from a stock exhaust to possibly an FMF Q4. I want something a little throatier but not overly loud and will provide a balanced flow of intake/exhaust.
      So can I get the JD Red Needle Jet by itself or can I get by using the stock and move the clip and be just as happy. I'm just looking to enhance overall performance of the engine and maintain reliability.
