High Compression Piston
I am new to the forum and this is my first post. I have a 2012 KX250F and will be doing some motor work in the near future. My goal is to increase the low end grunt without sacraficing reliability. Furthermore, i am an intermediate level rider and dont want to go "overboard" and create an un-rideable beast. I have previously installed a PC Ti-5 exhaust system. My plan is to do some head work and to remove the air cleaner screen. I am considering a high compression piston but wanted to get some feedback about expected increases in power. The stock compression ratio is 13.5:1 and a typical high compression piston (Pro Circuit, for example) will increase this by one point. Also, if i do go ahead and install the high compression piston, is it recommended to replace/upgrade other internal components such as wrist pin, springs, valve seats, etc. Thank you
Typically if you go with an aftermarket high compression piston it will come with the appropriate rings, pin, and retainers. Cosworth makes a good high compression piston for the Kawi's. You dont need to upgrade the valve springs when doing a high compression piston but you will need to run at minimum a mix 50/50 of race gas depending on what compression you go up to. You would be better off getting a performance cam over a high compression piston though dollar for dollar wise.
some say fitting a high comp piston can lead to putting excess pressure on the big end (and i tend to believe them), i would check into this before you went ahead and fitted one.
13.5:1 is about as high as I would go on pump gas. Any more and i'd be mixing race gas with pump, and then its like whats the point of mixing good race gas with the ethanol junk and end up just running race fuel. Put a set of stage 1 cams in it for low end and get it re mapped for the power to be tailored to your liking. For somebody not going overboard suprised you spent the extra 500 dollars for the TI over stainless exhaust....
  • Similar Content
    • By DirtBikeHead
      2015 Kawasaki KX250f - 20 hours
      As close to new as I'd imagine you'd get! I bought the bike brand new, I'm older and have taken extremely good care of this bike. Very little use and is COMPLETELY stock - everything is original.
      Comes with the title, original book and map couplers for the fuel injection.
      $4700 - cash
    • By CodyR
      Just thought maybe everyone could post up there youtube channels an we could all help eachother out by subscribing to one another.
      Heres mine ill sub back asap.
    • By bangmyhead
      Time for a top end on my bike, just wondering if there are any alternative Valve springs i can use. I have PC cams and $400 for just the springs and retainers is alil costly at the moment.
      This has been fun in other sections of TT, so I'll start the thread here and see if we can keep it going.
      Let us know what kind of mods, fixes, changes, etc.., you performed today, or just general fun you had with, your KX250F.
      I'll start with.. I installed a correct for my weight Race Tech shock spring, along with a Pivot Works shock spring thrust bearing. Also cleaned out all the nasty yellow plastic/wax crap that passes for grease in the lower shock bearing, and re-lubed it with Bel Ray waterproof.
    • By MotocrossMaverick
      Hey guys i have just gotten off my Honda crf150r and i am looking for a new bike. I have been to the dealership and have already checked out the Kx250f and the Crf250r. I am looking more at the Rm-z250 then any other bike right now. I need help finding what bike would be best for me. I have never been on a 250 but i am starting racing about a month after getting the bike. I was also offered $5800 for the Kx250f and i know it killed 2012 i am just not sure about a Kawasaki. Honestly i am not sure bout any please help!!
