2007 fuel screw- how many turns can I have
I was running a bit lean so I backed the screw out a turn from the factory 2 turns, helped a lot but its still a tad lean on colder days. How many turns does that thing have before I gotta worry about it falling out?
If you go more than 2.5-3 turns you need to rejet. 45 or 48 pilot NCVR needle 168-170 main works pretty dang good. Might fall out at 5 turns but would need to try it, not too many though.
What altitude are you at?
Ride from sea level to 6000 ft. Might runn a little leaner in Colorado, but the needle would be a great upgrade if it is not already in.
Alex
