Yz125 kickstarter problems
So I have a 2000 yz125 and my kickstarter rotates forward and hits my pipe...so much that its causing a dent. I heard it might be an o-ring...Can someone please tell me how to fix this with a diagram or something? Thanks, diego
Maybe move it back a few notches?
Yeah man already tried that and It stayed for maybe 2 rides and then rotated forward again causing a dent in my pipe
Had the same problem on my 98 yz125, The kick start spring is bad. I replaced mine and it was fine after.
I had the same problem on my 2000 125. The stop tab on the kickstart shaft was cracked at the shaft. This caused the kick start to move around and hit the pipe. Pull the clutch cover and take a look.
