KDX200 Flywheel on a KX250!
Hey all,
I just bought a KX250 a couple weeks ago and wanted to put lights on it and a heavy fly wheel weight. Having a few KDXs around, I thought I would see if the flywheel would fit on the KX, and it did! The stator plate would not line up with any of the mounting holes, so I just CNCed a new one. The KDX flywheel is keyed 180 degrees from the KX flywheel, but this works out as the wiring exits the case 180 degrees apart as well. I used the KDX coil and CDI box as well. I rode it and it is an awesome little tractor now. I couldn't notice any difference between the KX and KDX ignition timing. I used some aluminum standoffs to get the coils elevated off the stator plate.
http://i594.photobuc...0120_133255.jpg
http://i594.photobuc...0120_134611.jpg
http://i594.photobuc...0120_161234.jpg
http://i594.photobuc...0120_161346.jpg
The big lighting coil is custom would and puts out 7 amps@12V at a slightly high idle. Link is here:
http://www.kdxrider....pic.php?p=97128
Edited by TurboStew
  • Like 3
Very interesting! Should be something about any KX250 owner could pull off. BTW, what year KX250 did you do this to? BTW, just a little side thought, since you made your own stator plate anyways, you might have been able to make it where it could hold two lighting coils.
I picked up a kdx250 lighting stator and it bolted right up. As did the flywheel. I plan to use my stock kx black box and kdx stator. Not sure if I will get it to work but I'm hopeful.
1997 KX250
2 lighting coils might mess with the ignition, I see that Kawa mounted the lighting coil as advanced as possible from the ignition coil. I assume they were avoiding strange magnetic dynamics.
Edited by TurboStew
Well, the SR KDX's had three coils. One ignition and two lighting.
This is a pic from KDXrider member KDXsq's stator from his SR. I believe as long as you keep the ignition coil in the same position as stock, and everything clears, you would be good.
Edited by SS109
Thanks SS109, because of you I now have to go make another stator plate........! ;)
Hey, now, don't go blaming me! :D I was just pointing out possibilities. BTW, if you get it to work with two lighting coils I bet you could sell a few stator plates if you made them fit the KDX200. I know I would be down for at least one! :thumbsup:
Edited by SS109
Any progress on this? and if you got this to work where do I send money?
I was with out internet that week and missed this, great job turbo. If I didn't have my elines I would be calling you too.
Ed
I haven't made a dual plate yet and probably won't for a while, I'll let yall know when I do.
Now, if yall get a possi together and throw $$$ at me, it might bubble to the top of the list.
