alberta canada winter jetting
been playing around trying to find the right winter jetting. i know its impossible to tell me exactly what i need but would like to know if iam on the right track.
my summer setup
Summer jetting 60 degrees f
165 main
45 pilot
needle on 3rd
1.5 turns out idle screw
not sure on pilot air screw
winter
main jet gone tried 168 and will not run
pilot jet still have 45 in (local shop has orderd two sets and compeltly wrong hopefully will be right 3rd try) will be getting a 48 and 50
needle moved down to 2nd from bottom
idle screw same
pilot air same
temp is around 30 degrees f
bike fires up with choke on and will run on choke for a 1min then stalls (running lean?) turn choke off wile running will not idle and can only keep running by giving throttle. have not been able to ride it too see if main jet is lean
hope a bigger pilot will help but just keep second guessing all of this.
An old saying here in Finland for the 2 strokes, is around 10 bigger main jet and 5 bigger pilot jet.
I got a 2007 rm 250 that ive had some jetting issues with, or its a bit lean from 1/3 to 3/4 throttle. Doesnt matter what i do its always the same, but idle and WOT is good.
It has new crank seals and some other stuff, but it will soon need a total rebuild.
Well anyways Jetting.
Air screw around 1 turn out.
I belive i had the NECH needle in it. 4th clip from top "Richer side"
Havent touched the power jet. I guess i would need to look at that and try if TPS and the power jet works.
Summer jets 175/50
Winter jets 185/55
Never fouled a plug on it.
Edited by Dadda
ok so i ve been playing and still not right be getting there
changed main to 162
pilot to 50
2nd from top on needle
everything else the same
runs but is way way too rich lots of smoke and sputters at any point in throttle
so went back down
main 160
pilot 48
same as above
runs rich from closed to 1/4 throttle than runs great above that
will moving the clip down help fix this moving down the pilot again i end up where i started and bike will not idle?
